3464 connectés
 Page :   1  2  3  4  5  ..  11  12  13  ..  517  518  519  520  521  522
[Topic Unique] ASUS P4C800 / P4P800 (Intel i865/i875)
n°2820514
webzeb
Posté le 10-11-2003 à 13:12:20  profilanswer
Cavalier sur la mobo' : :??:
Pour le clavier, c'est du PS2 (logitech ultrax flat)
n°2820515
Juicy
Oui je suis un con.. et?
Posté le 10-11-2003 à 13:13:24  profilanswer
un jumper sur la carte mère vi par contre je ne sais pas où, à toi de chercher ds le manuel
n°2820519
webzeb
Posté le 10-11-2003 à 13:15:41  profilanswer
ok, merci, je vais chercher ça.:)
n°2820585
Schimz
Bouge pas, meurs, ressuscite !
Posté le 10-11-2003 à 13:58:58  profilanswer
ahhhhhhh  :wahoo:
voilà pê le pourquoi du comment des p4p/p4c qui refusent de POSTer :
http://www.techsupportforums.com/s [...] genumber=3
Hello everyone, this is my first time posting into this forum. I came across this topic from a Google search while trying to find out why my co-workers and myself have been having so many problems with the Asus P4C800 Deluxe model motherboard as we have had an excellent track record with Asus in the past. However, since we moved to this platform, we have had stacks of motherboards that will run for a while and then fail to post, refuse to install, and so on.
Now we are using 300W and 350W power supplies and stock P4 CPU fans. Not to mention that some of the mounting brackets for the CPU fans needed to be tightened as the were so loose they were falling off of the board. However, I think we have discovered that the source of our problems is not from the CPU heatsink being too tight, but rather a mistake on Asus' part during manufacturing.
I do not know what compelled my co-worker to do this, but he took one of the supposedly "dead" boards and removed the CPU heatsink mounting bracket to get a good look at the circuitry. There, located beneath the bracket on the underside of the board, he found the problem. There is a small glob of solder located beneath where the bracket sits that, when pressure from the bracket is applied, shorts the motherboard. Upon cleaning the glob from the contact and resoldering it, the board now runs perfectly fine with the 350W power supply we have testing.
This is not a one-time thing, either. Every motherboard we have looked at since has had this same glob that was not cleaned in manufacturing. There are 2 other contact points near it that have been cleaned, but this particular one seems to be the source of all the boards that refuse to post. We have even been in contact with representatives of Asus and they have informed us that the mounting bracket design has been changed to get around this.
I suggest that everyone having a problem take a look at the board for yourself and see if you have it as well. If you're not comfortable with a soldering iron, please do not try and fix it yourself, but still take a look. I also suggest that anyone visiting other forums for such information spread what we have learned and see how far this issue pans out. It could just be a bad batch that we received from our vendor, but it could also be present on all of the P4C800s.
Thank you all for your time and I will post again if we find out any other problems. Have a good day and good luck.
pour les anglophobes : ce serait le support de ventirad qui deteriorerait une soudure de la mobo lorsque l'on fixe le ventirad.
le "glob of solder" (point de soudure) relevé effectivement par une des personnes presente sur le thread :
http://koti.mbnet.fi/~nightops/eki/DSC00249.JPG
ça fait peur [:mlc]
et c'est un vice caché  ;)
Message édité par Schimz le 10-11-2003 à 14:00:59
n°2820590
dWarFy81
Super-Connard
Posté le 10-11-2003 à 14:02:56  profilanswer
Schimz a écrit :
ahhhhhhh  :wahoo:
ça fait peur [:mlc]
rien du tout.
toutes les miennes qui ont refusé de poster, c'était avec un rad fixé par les 4 trous, et rien de déterioré.
donc y'a peut être de ça, mais y'a aussi surement autre chose :D
p4 2.6c@3.6 - p4 1.8a@3.25 - tualeron 1.2@1.72 - p133@250
n°2820592
randoom
Posté le 10-11-2003 à 14:03:23  profilanswer
ventirad stock c mal :D
n°2820605
Schimz
Posté le 10-11-2003 à 14:13:03  profilanswer
dWarFy81 a écrit :
rien du tout.
oué mais toi, t'as des circonstances aggravantes :
p4 2.6c@3.6
chauffe Marcel  :D
[:cupra]
mais bon, si le reste de la carte est concue avec le même souci de qualité ...  [:psywalk]
n°2820800
phosphorus​68
Pseudo à n°
Posté le 10-11-2003 à 16:37:01  profilanswer
ça fait peur [:mlc]
On leur a pas appris à pas déborder quand on dessine?  :ouch:
n°2820865
Alfa147
Posté le 10-11-2003 à 17:31:33  profilanswer
Effectivement, je viens de demonter ma P4C800 deluxe d'avril 2003 et le support de ventirad a deterioreré une soudure, comme sur la photo, la soudure s'est écrasée et fait contact avec un tout petit point de soudure, dommage que je n'ai pas lu le poste avant, je viens de remonter il y'a une heure une P4C800-e Deluxe révision 2.00 que je viens de recevoir, j'espere que le pb est resolu sur ma nouvelle carte ....
n°2820889
MEI
|DarthPingoo(tm)|
Posté le 10-11-2003 à 17:52:30  profilanswer
Y'a quoi comme revision de P4C800-E Deluxe, c'est quoi leurs différences ?
n°2820909
Alfa147
Posté le 10-11-2003 à 18:12:11  profilanswer
dWarFy81,
Tu en as eut combien des cartes qui n'ont pas voulu booter ? quel modèle ? et maitenant tu as quel model ???
n°2820924
dWarFy81
Super-Connard
Posté le 10-11-2003 à 18:26:45  profilanswer
déjà répondu.
n°2820927
Alfa147
Posté le 10-11-2003 à 18:28:44  profilanswer
tu as repondu ou ?
n°2821073
blade67
Posté le 10-11-2003 à 20:04:36  profilanswer
Besoin d?aide pour choisir une alimentation :
NoiseBlocker  380w ou 430w 480w
Pour P4C800 E Dlx ? 3,2 Ghz - lecteur cd ? graveur ? 9800 PRO
Merci pour votre aide
n°2821075
Zeboss
Posté le 10-11-2003 à 20:06:58  profilanswer
YODA_57 a écrit :
J'avais mon 1.8A à 2.8 :sol: et là j'ai un 2.6C @3.2 :/
bizarre que dwarfy n'est pas encore repondu a ca
n°2821076
JACKPOTE
Posté le 10-11-2003 à 20:07:35  profilanswer
blade67 a écrit :
y a t'il des prises alim S-ATA ?
si oui prend une 480w, tu auras de quoi voir venir.
si non une 380w devrais suffir.
Message édité par JACKPOTE le 10-11-2003 à 20:09:21
[Topic Unique] Overclocking des INTEL P4C FSB800 [tableau inside]
n°2821095
Qixxx
Posté le 10-11-2003 à 20:17:24  profilanswer
Pas vu de changement avec le bios 1012 pour la P4P800 deluxe
n°2821098
dWarFy81
Super-Connard
Posté le 10-11-2003 à 20:19:23  profilanswer
tu veux dire mon 1.8@3.25 avec l'intel stock et 1.55v ?
ton 1.8 à la même fréquence avec l'intel stock et 1.55v ?
celui de nicodonald à 3.5 avec l'intel stock ?
(ah mince, j'ai répondu :whistle:)
EDIT: stables. bien évidemment. (en screen, on doit aller un brin plus haut)
EDIT bis: /me bastonne Zeboss
Message édité par dWarFy81 le 10-11-2003 à 20:20:13
n°2821120
spoon25
Posté le 10-11-2003 à 20:31:34  profilanswer
J'ai la solution (grâce à ASUS) au problème des disque reliés au Controller Promise en mode IDE non reconnus sous Windows:
j'ai fait un format de mon disque sur le quel il y avait Windows (2 disque en raid 0).
J'ai commencé l'installation de Win XP en appuyant sur F6 pour installer les driver du ICH5R (pour lui permettre de reconnaître mon Raid 0) et ensuite j'ai aussi mis les driver du Promise 378SATA (pas les drivers pour le raid), et là aussi il les a acceptés.
J'ai installé Windows sur mon Raid 0 mais je dois dire que mon disque relié au Controller Promise était reconnu.
Une fois terminé l'installation je me retrouve avec tous mes disque reconnus.
Résolu tous les problèmes!
Merci au service technique ASUS qui m'a répondu en moins de 24h.
n°2821154
Pentier
Posté le 10-11-2003 à 21:04:49  profilanswer
drapo. Je viens de recevoir une p4c800-e deluxe pour mon p4 3.0 :)
Je l'installerai d'ici 2 semaines. En attendant je vais lire la première page :jap:
n°2821221
Dimebag Da​rrell
The Trend Is Fuckin' Over
Posté le 10-11-2003 à 21:56:35  profilanswer
j'ai une question le serial ata n'est pas en native sur le chipset ????
n°2821243
Yoda_57
Marc, gagame, c'était mieux
Posté le 10-11-2003 à 22:06:47  profilanswer
Sur quelle mobo ?  :sarcastic:
Art ?|Pro ?|Sport ?| ACH/VDS matos photo divers
n°2821273
speedwizar​d
Posté le 10-11-2003 à 22:31:29  profilanswer
j ai 2 tites questions , sur la première page il est dit de desactiver le performance mode au dela de 200MHz , est-ce celui dans jumperfree config ou le perfomance acceleration mode dans chipset . que mettre pour les 2 ? sachant que pour performance mode c est soit Auto/Standard/Turbo et pour performance acceleration mode c est soit Auto/Activé
j ai cherché la fonction command per clock pour la disable mais j dois etre aveugle quelqu un peut m eclairer ?
merci d'avance :)
Message édité par speedwizard le 10-11-2003 à 22:32:51
n°2821340
danouche
Posté le 10-11-2003 à 23:12:48  profilanswer
Salut tt le monde
J'ai un pb sur mon PC (p4p800 DELUXE, avec un PIV C 2.4, XP pro) , ms jsé pas si ca vient de la carte mere ou d autre part:
Parfois, l'ordiateur reboote sans raison -apparente du moins-
Je ne sais pas si qq un a u ce meme pb, ms un ptit coup de main serait le bienvenue!
( niveau carte, g une carte graphique PWC radeon 9200SE et pour le son, c une muse5.1 de Hercules ...)
Merci tt le monde,
by
n°2821344
alvinio
Posté le 10-11-2003 à 23:15:59  profilanswer
pour info je viens de tester le bios 1013 sur P4C800-deluxe. pas de changements visibles (tenue overclock/fonctions) à par l'ajout d'une langue supp..
Message édité par alvinio le 11-11-2003 à 11:13:52
n°2821354
Yoda_57
Posté le 10-11-2003 à 23:23:34  profilanswer
danouche a écrit :
Salut tt le monde
Merci tt le monde,
by
Ben désactive déjà le reboot automatique, comme çà t'auras au moins quelques infos.
RAM peut-être ?
n°2821379
Dimebag Da​rrell
Posté le 10-11-2003 à 23:37:25  profilanswer
la p4p800
n°2821390
sakuraba
Posté le 10-11-2003 à 23:45:41  profilanswer
Emile Buisson a écrit :
1 gigo ça va être juste pour longhorn :D
vaut mieux 4*512
j ai testé longhorn et j ai installé mais ca plante sur 3 machines differentes et neuves ( gx 270 de chez Dell ) il va falloir bosser chez crosoft
n°2821405
blade67
Posté le 10-11-2003 à 23:57:25  profilanswer
Merci pour l'info jackpote,
Il n'y a pas de prises S-ATA, je vais prendre la 430w, elle à l'air pas mal(28A/3,3v/Valeur Mesurée 3,26v - 36A/5v/ValMes 4,93v - 20A/12v/ValMes 11,76v)
 :bounce:
n°2821416
T@nker-xXx
Overclocker retraité
Posté le 11-11-2003 à 00:05:27  profilanswer
en fait elle est pas si mauvaise en screen la p4c800 :D
http://membres.lycos.fr/thetankerx/p4%202.4c/sl6z33331a560/4132.jpg
Bosse.... bosse encore et toujours pour toute la nuit ..... pour toute la vie
n°2821431
sakuraba
Posté le 11-11-2003 à 00:17:02  profilanswer
j ai une radeon 9700 pro hercules PN 109-A04100 30 : elle marche sur une p4P800 Rev1,02 ? merci d avance
n°2821433
lolo92
Posté le 11-11-2003 à 00:17:46  profilanswer
T@nker-xXx
tu parles de la jeune fille derrière  [:solid shark]
Message édité par lolo92 le 11-11-2003 à 00:18:06
n°2821448
Yoda_57
Posté le 11-11-2003 à 00:26:31  profilanswer
Voir F.A.Q. :o
n°2821465
speedwizar​d
Posté le 11-11-2003 à 00:35:38  profilanswer
:ange: dsl pour le flood mais j ai vraiment besoin d aide sur ce coup la , j ai 2 ptites questions :
  • Sur la première page il est dit de desactiver le performance mode au dela de 200MHz , est-ce celui dans jumperfree config ou le perfomance acceleration mode dans chipset .
Que mettre pour les 2 ? sachant que pour performance mode c est soit Auto/Standard/Turbo et pour performance acceleration mode c est soit Auto/Activé .
  • J'ai cherché la fonction "command per clock" pour la disable mais j'dois etre aveugle quelqu un peut m eclairer ?
n°2821472
corneliani
Le Prestige du Noir&Blanc
Posté le 11-11-2003 à 00:38:08  profilanswer
Salut à tous j'ai la P4P800 Deluxe je viens de la flasher avec le bios 1012, pour le moment c'est sable mais les T° on augmenter de 10°C avant j'etais à 26°C en idle maintenant je suis à 37°C sans rien changer a part le bios
je suis seule à l'avoir remarque
n°2821484
sakuraba
Posté le 11-11-2003 à 00:45:31  profilanswer
YODA_57 a écrit :
Voir F.A.Q. :o
ok mais je comprends pas c est le dernier chiffre je suis à 30 donc c est <30 ou <=30 ?
n°2821524
T@nker-xXx
Posté le 11-11-2003 à 01:39:48  profilanswer
lolo92 a écrit :
T@nker-xXx
les 2 [:ddr555]
n°2821635
Yoda_57
Posté le 11-11-2003 à 08:42:02  profilanswer
Paragraphe 2.6.4 de la doc :
PN 30 or later
n°2821661
freduche
Posté le 11-11-2003 à 09:57:42  profilanswer
Chez moi, ça n'a rien changé.
n°2821713
Angelneo
Oh putain 15 ans déjà
Posté le 11-11-2003 à 10:48:17  profilanswer
drapal :)
Celui qui pose une question risque cinq minutes d'avoir l'air bête. Celui qui ne pose pas de question restera bête toute sa vie
n°2821725
paintball_​46
faites de l'aikido!
Posté le 11-11-2003 à 10:54:59  profilanswer
salut comment vous faites pour contacter asus technique??? car je voudrais bien savoir pourquoi la carte son  soundmax a des probleme???????
La nature a des perfections pour montrer qu'elle est l'image de Dieu et des défauts pour montrer qu'elle n'en est que l'image.
au utilisateur d'intel ( nouveau package)Mettre un DD de 40 Go sur une carte mère ancienne (Asus P5A)
ASUS Smartdoctor 2 : comment ça marche ?# Radeon 9200 (agp 8x) sur une Abit BH6 (Intel 440) ?
Paramètrage ASUS P4P800 Deluxe....quelle carte mère Intel avec Sata intégré??
asus reste chez nvidia (aussi)raid sur p4c800 deluxe
Config bios Asus A7N8X pour CG
Plus de sujets relatifs à : [Topic Unique] ASUS P4C800 / P4P800 (Intel i865/i875)
