5104 connectés
 Page :   1  2  3  4  5  ..  20  21  22  23  24  25
Le Topic Radeon 9X00 ! [topic RV250/R300]
n°1966265
evildeus
Posté le 15-11-2002 à 20:54:17  profilanswer
http://www.sapphiretech.com/vga/9100.asp
ATI RADEON 9100 Chipset
Empower Your Imagination
Turning the ordinary into the extraordinary, the ATLANTIS RADEON 9100?s rendering capabilities such as TRUFORM?, SMARTSHADER?, and SMOOTHVISION will reignite your passion for a truly immersive 3D experience.
Features:
Powered by ATI?s latest and most powerful RADEON? 9100 GPU
128MB DDR memory provides lightning-fast 3D graphics
Features TRUFORM? technology to make characters and objects more rounded and natural
HYPER Z? II technology conserves memory bandwidth for improved performance in demanding applications
SMOOTHVISION?, ATI?s most advanced anti-aliasing, eliminates distracting visual artifacts for smoother looking images
High resolution 32-bit 3D gaming up to 2048x1536
SMARTSHADER? technology takes advantage of the DirectX® 8.1 features to enable more complex and realistic lighting effects
Support for DirectX® 8.1 and OpenGL® 1.3 applications
CHARISMA ENGINE? II supports Transformation, Clipping and Lighting (T&L) at 68.7 million triangles/second peak processing capability
PIXEL TAPESTRY? II, 3D rendering engine, powers an incredible 2.4 gigatexels/second for high fill rates in 32-bit at high resolutions
Dual monitor support and DVD playback
Leading-edge HYDRAVISION? technology supports traditional CRT monitors, flat panel displays and TVs
VIDEO IMMERSION? II technology enables integration of industry-leading digital video features, including advanced de-interlacing algorithms for unprecedented video quality
Connect to digital flat panel to enjoy crisper images and true flat screen, significantly reduce eyestrain and save space on your desk
Use video-out to connect your PC to TV or VCR for recording
Model Number Product Description
  64MB DDR, 250/230, DVI-d, TVO
  128MB DDR, 250/230, DVI-d, TVO
n°1966274
Oxygen3
Tears from the moon
Posté le 15-11-2002 à 20:56:12  profilanswer
:whistle: R9000 AGP8x  :whistle:
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°1966312
mikestewar​t
Air Roll Spinnin'
Posté le 15-11-2002 à 21:17:05  profilanswer
:non: Regarde bien. :)
Sapphire annonce que la R9100 aura un multitexturing fillrate de 2.4 gigatexels/s, ce qui veut dire que R9100 aura 2 unités de textures par pipeline, comme la R8500. Mais les fréquences seront à la baisse : 250/230Mhz.
n°1966321
Ernestor
modo-coco :o
Posté le 15-11-2002 à 21:19:10  profilanswer
Je comprend plus rien la  :??:
La 9100 etait sensee etre une 9000 Pro plus rapide en frequences non ?
n°1966340
mikestewar​t
Air Roll Spinnin'
Posté le 15-11-2002 à 21:26:13  profilanswer
Oui, en tout cas elle sera annoncée dans 2 semaines on verra bien. La R9100 sera plus rapide que la R9500 ! [:yaisse2]
Message édité par mikestewart le 15-11-2002 à 21:26:24
n°1966342
Oxygen3
Tears from the moon
Posté le 15-11-2002 à 21:26:59  profilanswer
la version 64Mo :o
n°1966357
RadiATion
Posté le 15-11-2002 à 21:34:47  profilanswer
Compliqué tout ça les gars ;-)
Sinon, sur une Hercules R9700PRO on trouve le PN pour connaitre la révision où il y en a pas ?
n°1966360
Oxygen3
Tears from the moon
Posté le 15-11-2002 à 21:36:02  profilanswer
b'en euhhhh ...
n°1966375
mikestewar​t
Air Roll Spinnin'
Posté le 15-11-2002 à 21:41:20  profilanswer
Il y en a pas sur les Hercules. :/
n°1966407
Marc
Chasseur de joce & sly
Posté le 15-11-2002 à 21:51:01  profilanswer
Bon le plus récent que g c un Week 33
on va bien voir
Moi, j'aime pas les signatures
n°1966412
mikestewar​t
Air Roll Spinnin'
Posté le 15-11-2002 à 21:52:14  profilanswer
on va bien voir
T'es pile au milieu, ça craint. :/
n°1966414
Oxygen3
Tears from the moon
Posté le 15-11-2002 à 21:52:48  profilanswer
me demande si sandra peut pas le donner le step:
SiSoftware Sandra
Device Information
Device Type : VGA Display Adapter
Device ID : bus 1, device 0, function 0
Windows Device Name : RADEON 9700/9500 SERIES
OEM Device Name : ATI Technologies Radeon 9700 Series
OEM Hardware ID : FUN_0, VEN_1002, DEV_4E44, REV_00
Product Device Name : Giga-Byte Technology Radeon 9700 Series
Product Hardware ID : VEN_1458, DEV_4012
Revision / Stepping : A / 1 (0)
n°1966648
qqpanpan
Mourir pour des idées.....
Posté le 15-11-2002 à 22:52:44  profilanswer
HIS et Sapphire remportent la palme au niveau de la qualité d?affichage
 :heink:
http://www.tomshardware.fr/article [...] &NumPage=3
Message édité par qqpanpan le 15-11-2002 à 22:53:23
n°1966680
titi14518
Posté le 15-11-2002 à 23:00:51  profilanswer
mouarf ca depend de trop de trucs ca  [:spiegel]
le moniteur etc....c tres subjectif, ca doit vraiment se valoir je pense entre les 9700 :)
quoiqu il en soit Ati a toujours une meilleure qualité que Nvidia pour moi (ancien possesseur de GF4TI, et de 2 marques differentes) :love:
n°1966714
Marc
Posté le 15-11-2002 à 23:13:31  profilanswer
Etant donné que toutes les PCB sont plus ou moins issus de la même usine, ca prouve bien que c'est aléatoire.
n°1966742
bhj
Ni dieu ni maître!
Posté le 15-11-2002 à 23:25:42  profilanswer
barbarella a écrit a écrit :
les problèmes de démarrage a froid peuvent (je dis peuvent) provenir d'un prob d'alim insuffisante. Attention avoir une 400W ne signifie pas que tu seras a l'abris, toute les alim ne sont pas de la même trempe.
Regardes sur ton alim t'as normalement une etiquette. cherche les valeur d'amperage en 3,3 et 5v en dessous de 30A c'est délicat. enfin il me semble.
Merci mais j'ai un boîtier Enermax tout neuf de 300W et si je me souviens bien c'est au moins 30 A.
Et je précise bien que ce problème n'est arrivé qu'une fois en un mois alors peut-il y avoir un faux contact? Car ça c'est dangereux.
C'est tenter l'homme que de lui laisser le choix. Or Dieu, par sa préscience infinie savait bien ce qui en résulterait. De ce moment c'est donc à plaisir qu'il perd la créature que lui-même a formée. (Sade)
n°1966957
Arcapt
Tout ça c la faute d'Obiwan!
Posté le 16-11-2002 à 01:38:21  profilanswer
il s'est passé quelque chose de merveilleux. je ne pouvias plus jouer à Gens (ému megadrive) en plein ecran. j'ai mis un dual boot XP, pour tester si le SP1 l'avait amélioré depuis le temps.
Et là je vois que contrairement à mon 2000SP3, je peux le remettre en plein écran. fou de joie, mais sceptique, je retente sous 2000...ca marche. rien compris
Sinon petit bug sur ces nouveaux drivers sous winXP: l'utilitaire SMARTGART donne l'agp comme désactivé, alors qu'il est activé, ce qui m'est confirmé par WCPUID, et des résultats 3d tout à fait normaux. Aucun problème sous 2000 en revanche... (j'ai toujours dit que 2000>XP ;))
concernant la qualité 2D, du fait de mes problèmes j'ai pu comparer Gigabyte et powercolor. la powercolor donnait une image infimement plus floue que la gigabyte, c'était à peine perceptible, cela sur un 19' qui est maintenant un peu vieux (hyundai P990 d'il y a 2 ans et demi).
J'ai aussi une rev. A/1 d'après Sandra, alors que j'ai acheté ma carte il y a une semaine à peine.
Et pour finir, j'ai monté un 8cm sur la carte, avec des fils de nylon, le montage tient très bien, et j'ai pas mal gagné en overclocking (25Mhz sur le core en plus par rapport à avant)
Message édité par Arcapt le 16-11-2002 à 01:38:48
n°1966984
barbarella
Posté le 16-11-2002 à 02:16:34  profilanswer
je dois reconnaitre quand lisant l'artilce de TH je suis un peu refroidis pour l'achat d'une 9700. je ne compredns pas comment une carte de ce prix peu avoir de variation dans la qualité d'affichage apparement aussi visible.
un flou sur le primaire ... j'ai une de ces envis de repasser chez matrox.
y a quelqu'un qui a une sapphire ?
n°1966990
qqpanpan
Posté le 16-11-2002 à 02:25:27  profilanswer
j ai vu today un infographiste sur une pharelia avec 3 écran :ouch:
nvidia /ati même combat :/
la ffichage me parait + satisfaisant kan me^me sur l ati ... ke sur ma ti4
Message édité par qqpanpan le 16-11-2002 à 02:26:58
n°1967911
bgx
reviens brunette!
Posté le 16-11-2002 à 15:21:14  profilanswer
SiSoftware Sandra
Device Information
pour moi aussi sur ma hercules....
c'est fiable?
bgx
n°1968112
titi14518
Posté le 16-11-2002 à 16:15:43  profilanswer
Salut
j ai beau chercher dans les drivers je trouve pas l endroit (si il y en a un  :??: ) ou regler l image de la sortie TV sous Radeon 9700Pro.
si quelqu un sait ou ca se trouve...merci!  :jap:
n°1968117
qqpanpan
Posté le 16-11-2002 à 16:17:59  profilanswer
c'est fiable?
bgx
j ai la même sur ma hercule aussi :/
n°1968484
tonton son​ic
RTFM
Posté le 16-11-2002 à 18:42:35  profilanswer
 :pfff:
FO vraiment chercher la ptite bete alors.
Possesseur d'une hercules donc image soit disant brouillé en 1600*1200... Faut arreter la coke c super net chez moi
C plutot la marijuana qui brouille l'écran... :whistle:
Et?
n°1968580
barbarella
Posté le 16-11-2002 à 19:02:01  profilanswer
ToNToN SoNiC a écrit a écrit :
 :pfff:
t'as pas compris la question qui est en suspend, c'est la variation de qualité d'une carte a une autre l'aspect aléatoire (dans une même marque un même type). Ce qui fait que cela peut-être très bien chez quelqu'un et pas chez un autre pour raisons plus ou moins indéterminé.
Toute la question est là.
Message édité par barbarella le 16-11-2002 à 19:02:23
n°1969213
qqpanpan
Posté le 16-11-2002 à 23:04:20  profilanswer
clair concis
n°1969232
cybermatos
Posté le 16-11-2002 à 23:13:36  profilanswer
Tophy a écrit a écrit :
Plop,
J'ai le meme blem, apres avoir testé les dmeos, je lance un q3 je me connecte a un server, et j ai des freezes toutes les 15 secodnes d une durée de 2 3 secondes. Pilote DX9 + Drivers RC9.
KKun sait comment resoudre le blem ?
Reinstall windows ?
Patch pour retirer DX9
Remettre catalyst WHQL :) ?
pag 121 2 mecs ont le meme blem doit bien yavoir une soluce
j'ai compris le truc en faite....tous les jeux avec le moteur QUAKE 3 (MOHAA,RTCW...) ont tous des freezes,je viens de tester,donc c'est normal,ce sont les pilotes betas DX9 qui font çà!!!
Pour les autres qui ne savent pas,il suffit d'installer les pilotes certifiés DX8 ça resoud le probleme (meme s'il reste DX9 installé) !!!
Message édité par cybermatos le 16-11-2002 à 23:24:34
n°1969241
qqpanpan
Posté le 16-11-2002 à 23:18:44  profilanswer
tu vire les beta et réinstall de whql :??:
n°1969323
Tom slayer
Posté le 17-11-2002 à 00:04:02  profilanswer
A propos des jeux avec cette putain de carte graphique: j'ai toujours pas mal de pbs (freeze-bluescreen-reboot) avec de nombreux jeux (morrowind,nolf 2,ARX...). J'ai tout essayé: derniers pilotes pour tout mon matos, flash et config du bios..., et rien n'y fait c'est toujours aussi instable.Y a que les benchs qui marchent!!! Plein le cul. HELP ME!!
Merci d'avance pour vos réponses (et éviter svp les reponses du genre "c:format" ou "Ah bon moi sur mon PC c'est nickel, c'est ballot hein!" ) :fou:  :fou:  :fou:
n°1969526
shadowblad​e
Posté le 17-11-2002 à 02:19:12  profilanswer
 :pfff:
C'est pas simplement dans le cas d'un bi-ecran poussé que l'image se brouille?
Parce que c'est de ca dont parle l'article,je pense qu'une utilisation normale (1 moniteur) ne doit poser aucun probleme de qualité :)
n°1969534
bgx
reviens brunette!
Posté le 17-11-2002 à 02:32:18  profilanswer
heureusement que dx9 ne change en rien les perfs des jeux opengl! :)
sinon, ayant lu la faq des derniers drivers ATI, le pb du rafraichissement sous dx est reglé (mais c caché, il faut aller dans les prop avanc" de l'affichage, puis affichage, propriété du monieur, et la y'a un truc pour lui dire de synchroniser comme la frequence de l'ecran! (cequi est moins porc que les tweakers, et surtout ca change tout seul avec l'ecran, alors que c pas le cas sinon (et c chiant qd on swape tv/ecran)
bgx
n°1969535
qqpanpan
Posté le 17-11-2002 à 02:35:31  profilanswer
cai ou exactement ton option?
n°1969810
cybermatos
Posté le 17-11-2002 à 10:13:45  profilanswer
si si ,j'ai l'impression que MOHAA n'est pas aussi fluide qu'avant.... :(
n°1969820
igor
Posté le 17-11-2002 à 10:23:24  profilanswer
Sachant que DX9 correspond au D3D, y a qd meme peu de chance que cela est un impact sur l'OpenGL. C'est psychologique cette impression  ;) .
n°1970353
bgx
reviens brunette!
Posté le 17-11-2002 à 14:18:02  profilanswer
affichage, et la tu cliques sur moniteur.
et la tu as un petit menu pour directX (ca ne marche que sous 2k/XP°, mais de toute facon, les autre en ont pas besoin....
pour l'openGL, il faut attendre la 2.5.
bgx
n°1970363
cybermatos
Posté le 17-11-2002 à 14:24:46  profilanswer
Bon, puisque c'est le topic de reference,je repose ma question ici (j'ai au moins des chances qu'on me reponde,avec tous les milliardaires que nous sommes,et qui avons acheté cette carte :D ):
La Hercules RADEON 9700 PRO est elle compatible à 100% avec la ASUS P4PE sans broncher (cad sans les problemes de boot à froid que j'ai avec ma ABIT KR7A-RAID et sans plantages evidemment)??
J'attends vos experiences!! :)
MERCI!!
Message édité par cybermatos le 17-11-2002 à 14:26:49
n°1970429
mikestewar​t
Air Roll Spinnin'
Posté le 17-11-2002 à 14:48:20  profilanswer
CYBERMATOS > Il n'a pas d'incompatibilité entre la P4PE et la R9700Pro (c'est pas officiel bien sûr mais c'est ce que j'ai vu sur les forums). Apparemment il faut quand même faire attention lors de l'installation des drivers Intel sinôn 3DMark2001 plante et quelques autres jeux. (il vaut mieux installer le SP1 de WinXP et en premier les drivers Intel puis les drivers Radeon)
Message édité par mikestewart le 17-11-2002 à 14:48:35
n°1970571
cybermatos
Posté le 17-11-2002 à 15:29:36  profilanswer
Merci de ton conseil! ;)
Sinon j'ai trouvé un lien génial pour la compatibilité des RADEON 9700 avec les differentes cartes-meres (la base est MAJ regulierement):
http://www.rage3d.com/tech/?page=9700
n°1970887
mikestewar​t
Air Roll Spinnin'
Posté le 17-11-2002 à 17:17:38  profilanswer
Comparo R9500(non-pro)/R9700/R9700Pro avec Ti4200/Ti4600 chez Digit-Life !!! :sol:
http://www.digit-life.com/articles [...] -9700.html
Très intéressante et très compléte comme review pour ceux qui sont pas anglophobes. ;)
En ce qui concerne la R9500, ça confirme la review d'Inpact avec des perfs no-FSAA/no-Aniso en retrait par rapport à la Ti4200 mais avec FSAA/Aniso la Ti4200 est larguée ! Et pour la R9700 pas de surprise. :)
n°1971044
Tom slayer
Posté le 17-11-2002 à 18:17:13  profilanswer
qu'est-ce que tu entends par"drivers intel"? ça correspond à quoi exactement? (désolé mais moi être newbie)
n°1971138
Yoda_57
Marc, gagame, c'était mieux
Posté le 17-11-2002 à 18:39:22  profilanswer
Les drivers du chipset je pense.
Art ?|Pro ?|Sport ?| ACH/VDS matos photo divers
n°1971352
barbarella
Posté le 17-11-2002 à 19:33:30  profilanswer
information interessante sur sapphire (digit-life)
"The headquarters of Sapphire are in Hong Kong. This company is a branch establishment of PC Partner, it has two plants measuring 250 feet square in Donguan (China). The company has been cooperating with ATI for 10 years already and it has been producing graphics cards based on ATI's chips for 5 years. Sapphire is not just the largest official partner of ATI (its facilities are enough for monthly production of 1.8 M video cards), it also manufactures video cards for ATI which sell in North America and are marked as Build by ATI. Sapphire covers all market sectors starting from value solutions to mainstream-perfomance monsters. It uses both the ATI's reference design and its own."
je sens que je vais me laisser tenter par une sapphire, si je ne trouve rien de désagréable sur cette marque d'ici là :)
Spec de la T2P4 (version du PCI): pblm avec Radeon 9000 PCIca vaut quoi la ATI MOBILITY RADEON 7500 M7P ???
Preview de la All In Wonder Radeon 9700...pbr avec sortie video (RADEON VE)
radeon 9000 ?radeon 8500 275/275 on en trouve encore ??
Radeon 9500 [demande d'explications inside]je confirme les radeon 7500
GF 2Mx vs. Radeon 7000Radeon 9700 Pro + jeux direct 3d = Total Chaos...
Plus de sujets relatifs à : Le Topic Radeon 9X00 ! [topic RV250/R300]
