4269 connectés
  F1 2012 - probleme NVIDIA GeForce GTX 550 Ti
n°8485987
antonio vi​las
Posté le 22-10-2012 à 21:24:07  profilanswer
Bonjour a tous jai en probleme avec le jeux F1 2012 ,ca lag a mort comme des frezzes ,  33 FPS avec tout bas e quelques parties desactivé, avec d autres jeux marche tres bien excelent meme je vous laisse ici mes indices merci de me aidé.
System Information
Time of this report: 10/22/2012, 12:05:16
       Machine name: AMG-PC
   Operating System: Windows Vista 32 bits
           Language: French (Regional Setting: French)
System Manufacturer: Packard Bell BV
       System Model: MCP73VT-PM
               BIOS: Default System BIOS
          Processor: Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz (4 CPUs), ~2.4GHz
             Memory: 4096MB RAM
Available OS Memory: 3328MB RAM
          Page File: 1487MB used, 5165MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce GTX 550 Ti
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 550 Ti
           DAC type: Integrated RAMDAC
         Device Key: Enum\PCI\VEN_10DE&DEV_1244&SUBSYS_83C21043&REV_A1
     Display Memory: 2385 MB
   Dedicated Memory: 977 MB
      Shared Memory: 1407 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: SONY TV
         Monitor Id: SNYA401
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: HDMI
        Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
Driver File Version: 9.18.0013.0697 (English)
     Driver Version: 9.18.13.697
        DDI Version: 10.1
       Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
   Driver Date/Size: 10/3/2012 00:20:00, 15309160 bytes
        WHQL Logo'd: Yes
F1 2O12
Configuration requise
Minimum :
 Système d'exploitation : Windows Vista ou Windows 7
 Processeur : Intel Core 2 Duo @ 2.4Ghz ou AMD Athlon X2 5400+
 Mémoire vive : 2 Go de RAM
 Affichage : AMD HD2600 ou NVIDIA Geforce 8600
 DirectX® : 11
 Disque dur : 15 Go d'espace disque disponible
 Son : Carte son compatible Direct X
 Autres prérequis : Connexion internet haut débit
 Supplémentaire : Cartes graphiques supportées : AMD Radeon HD2600 ou supérieure, HD3650 ou supérieure, HD4550 ou supérieure, séries HD5000, HD6000 et HD7000. nVidia GeForce 8600 ou supérieure, 9500 ou supérieure, GTX220 ou supérieure, séries GTX400, GTX500 et GTX600. Intel HD Graphics 3000 ou supérieure, AMD Fusion A8 ou supérieure
Recommandée :
 Processeur : Intel Core i7/AMD Bulldozer
 Mémoire vive : 4 Go de RAM
 Affichage : AMD série HD6000 ou NVIDIA Geforce série GTX500 comportant au moins 1 Go de mémoire vidéo
 DirectX® : 11
 Supplémentaire : Cartes graphiques supportées : AMD Radeon HD2600 ou supérieure, HD3650 ou supérieure, HD4550 ou supérieure, séries HD5000, HD6000 et HD7000. nVidia GeForce 8600 ou supérieure, 9500 ou supérieure, GTX220 ou supérieure, séries GTX400, GTX500 et GTX600. Intel HD Graphics 3000 ou supérieure, AMD Fusion A8 ou supérieure.
Message édité par antonio vilas le 22-10-2012 à 21:55:45
[ASUS] GTX 560 à vendreproblème g13 et soudgraph veris premier (résolu)
Problème montage pc, Disque Dur non reconnu.Problème de connectivité lecteur Blu Ray avec TV
multiple probleme acer 7735zgprobleme raid 0
Probleme extractionbesoin d'aide s'il vous plait, problème disque dur externe WD
[Résolu] Problème matériel? Qu est ce qui est mort?Sony Vaio VGN-C1Z/B - NVIDIA Geforce Go 7400
Plus de sujets relatifs à : F1 2012 - probleme NVIDIA GeForce GTX 550 Ti
