8250 connectés
 Page :   1  2  3  4  5  ..  161  162  163  ..  1033  1034  1035  1036  1037  1038
[Topic Unique] Nvidia Pascal GP104 : GTX 1080/1070 (16nm FinFET+)
n°9809193
- gab
Posté le 17-05-2016 à 18:45:40  profilanswer
Une explication tirée d'une conférence nvidia : What is NVIDIA Fast Sync? https://www.youtube.com/watch?v=WpUX8ZNkn2U
En gros, les avantages de la VSync off, mais sans tearing ?
Message édité par - gab le 17-05-2016 à 18:47:08
n°9809195
mum1989
Posté le 17-05-2016 à 18:48:06  profilanswer
- gab a écrit :
On a une description/explication détaillée du FastSync quelque part ?
Je spam F5 sur la page dédiée du test de tridam mais ça n'affiche rien [:abstro:1]
http://www.microsofttranslator.com [...] an_und_aus
un petit résumé :
Fast sync combined VSync on and off
With Pascal introduced the VSync technology is fast sync. Fast sync is aimed at players who use love to extremely high frame rates that are higher than those of the refresh rate of the monitor. Fast sync decouples the render the display pipeline for the first time. This has the consequence that the game asks for new frames and the GPU renders consistently new frames, as opposed to VSync but still held a synchronization of the two components.
Fast Sync for many FPS, G-sync for little FPS
Multiple images in the graphics card memory can be stored with fast sync. Has signed with the Refreshzyklus, the monitor issued the last completed frame.
The refresh rate is 60 Hz, the GPU can now spend 60 images per second.
Fast sync so that a combination of "V-sync off" before the display output and "V-Sync" is when the display output: there is no tearing on the monitor and the input latency is very low - almost as low as with off V-sync.VRR techniques such as G-Sync and FreeSync for games, whereas providing less FPS than the refresh rate of the monitor would allow, is fast sync to those titles that run faster. The two techniques complement one another.
Message édité par mum1989 le 17-05-2016 à 18:49:44
n°9809198
Neptunelig​ht
Posté le 17-05-2016 à 18:50:21  profilanswer
B1LouTouF a écrit :
le g sync va plus servir du coup ? j'espère que ça fait le même truc que le g sync leur fast sync , après je m'en fiche mon écran reste g sync quand même mais une fois qu'on y goutte , dur de s'en passer car le latence ressenti en souris avec la syncro verticale , c'est clairement enervant !
https://www.youtube.com/watch?v=xHrR4lnDOPg vers 7min10
n°9809199
Kak4$hi
Posté le 17-05-2016 à 18:50:51  profilanswer
D'après JV (bon OK source de m....), le FastSync est un complément du GSync
n°9809204
Zurkum
Posté le 17-05-2016 à 18:52:56  profilanswer
On se passera de leurs avis je pense :o
n°9809205
Yopfraize
Posté le 17-05-2016 à 18:53:31  profilanswer
https://www.youtube.com/watch?v=wlSeHCPd75s
Une vidéo sur l'overclock de la 1080 avec l'accelero Xtreme :jap:
C'est en allemand mais tant pis, les chiffres c'est universel :o
n°9809206
farika
Posté le 17-05-2016 à 18:53:41  profilanswer
Ca serait bien que HFR complète la partie sur fast sync en la mettant en corrélation avec Gsync.
Car si j'ai bien compris en fast sync, le gpu est en vsync off, c'est à dire qu'il produit plein de frames qui sont chargés en mémoires. Par contre le moniteur lui va fonctionner comme si c'était du vsync on et dès qu'un refresh est là, il mange une frame...
Donc pour moi, que ce soit inférieur à 144Hz ou supérieur, c'est la même chose que Gsync... ?
http://img1.lesnumeriques.com/article/1794/G-Sync.png
Message édité par farika le 17-05-2016 à 18:57:14
n°9809207
Lutinnoir
Seul parmi les autres
Posté le 17-05-2016 à 18:56:05  profilanswer
Ainsi que la partie Overclocking, qui se résume a 4 lignes.
Genre un bios mod sur la limite de conso. :D
Edit: Pas vu d'article traitant le "nouveau SLI"
Message édité par Lutinnoir le 17-05-2016 à 18:57:42
"If in doubt, flat out." @Colin McRae
n°9809208
- gab
Posté le 17-05-2016 à 18:57:21  profilanswer
Non mais ça va être complété, laissez-lui quelques heures :D
n°9809212
Kak4$hi
Posté le 17-05-2016 à 19:02:09  profilanswer
Ils sont pas con de laisser pourrir leur marché sur les écran G-Sync juste pour les joueurs.
Vu leur politique
n°9809215
flagada007
No Pain No Gain
Posté le 17-05-2016 à 19:05:07  profilanswer
d'ailleurs c'est quand qu'ils vont annoncer leur cartes AMD?
La plus belle victoire est de se vaincre soi-même (Chevalier de Méré 1687)
n°9809216
el_nono_ma​squay
#Balkany2027
Posté le 17-05-2016 à 19:05:36  profilanswer
Bon du coup j'garde ma 980 ti du coup ? :o
n°9809220
ravenloft
Meilleur jeu du 20ème siècle
Posté le 17-05-2016 à 19:06:55  profilanswer
Ravenloft
n°9809223
farika
Posté le 17-05-2016 à 19:07:28  profilanswer
Vu leur politique
Je crois avoir pigé, mais il faut que Damien confirme.
En Gsync (schéma : http://img1.lesnumeriques.com/article/1794/G-Sync.png)
On est dans une situation où le GPU serait plus lent que l'écran. Donc un jeu gourmand sur un écran 144Hz qui tournerait à 50-60Hz mettons.
Là dans le schéma, gsync va commander l'écran pour qu'il fasse un scan pile quand le draw est terminé.
Le tout pour éviter ceci : http://img1.lesnumeriques.com/arti [...] G-Sync.png , où un draw serait plus long que le scan et où il faut attendre le prochain refresh.
Le Fast Sync lui n'apporte ses bénéfices que si il y a plusieurs draw dans le délai de scan et donc où le GPU sortirait plus de 144 fps. En l'état actuel des choses Gsync est désactivé quand on est supérieur à 144Hz. Donc il n'y avait que le choix vsync on ou vsync off. Vsync off = tearing. Et Vsync on = input lag.
Donc le Fast sync charge en mémoire toutes les frames générées pendant le scan mais le framebuffer lui fonctionnera à 144Hz. Donc en fait l'écran, à chaque scan de 144Hz aura une frame à afficher. Proprement et sans imput lag. En gros avantage du vsync off + on.
Message édité par farika le 17-05-2016 à 19:08:09
n°9809224
ravenloft
Posté le 17-05-2016 à 19:07:32  profilanswer
Message édité par ravenloft le 17-05-2016 à 19:09:06
Ravenloft
n°9809226
el_nono_ma​squay
#Balkany2027
Posté le 17-05-2016 à 19:07:55  profilanswer
1080p :o
J'attendrais la 1180ti et un écran 4k abordable je pense :o
n°9809231
Kak4$hi
Posté le 17-05-2016 à 19:10:51  profilanswer
Merci pour les explications.
Bon moi me faut une 1080 à 650in pour pouvoir jouer en 1440p PROPAL
n°9809233
el_nono_ma​squay
#Balkany2027
Posté le 17-05-2016 à 19:12:56  profilanswer
Ouais, je trouve ça pas foufou. En même temps +20% c'est totalement dans la norme de ce qui se fait depuis plusieurs années maintenant je trouve.
Certains voyaient déjà le 60fps ultra en 4k... Génération suivante, voire encore suivante :o
Message édité par el_nono_masquay le 17-05-2016 à 19:13:06
n°9809240
jumbaii
Posté le 17-05-2016 à 19:17:24  profilanswer
el_nono_masquay a écrit :
1080p :o
Aucun intérêt de changer si tu joues en 1080, au pire tu fais un SLI  :o
GT : jumbaii7
n°9809242
liojac
SV 1000 Ma liberté de pencher
Posté le 17-05-2016 à 19:18:07  profilanswer
sauf qu'à ce moment là on sera déjà sur des écrans 5k ou 6k.
Ou de la VR qui tue mais qui bouffe.
Message édité par liojac le 17-05-2016 à 19:18:47
n°9809246
el_nono_ma​squay
#Balkany2027
Posté le 17-05-2016 à 19:19:33  profilanswer
Ouais et encore même le SLI j'sais pas si ce sera utile pour du 1080p en fait. J'ai pas l'impression que les jeux pour 2016-2017 la mettront à genoux.
Après faut voir si nVidia nous refait le coup des 780/780ti :o
n°9809252
globule
Posté le 17-05-2016 à 19:24:32  profilanswer
Non tu la revends vite 350 euros avant qu'elle ne vaille plus rien :lol:
n°9809253
silv3rm@n
Posté le 17-05-2016 à 19:24:51  profilanswer
Je trouve pas l'info sur le test de tridam ,le gpu boost est à 1733 officiellement ,le modèle que vous avez reçu de base fait 1733 ou plus comme bien souvent sur les 9xxx?
Celui qui sauve une  vie , sauve le monde entier .
n°9809259
mum1989
Posté le 17-05-2016 à 19:29:37  profilanswer
computerbase.de a testé dans un Fractal Design R5 la fréquence :
http://www.computerbase.de/2016-05 [...] _dauerlast
n°9809261
remiche35
One day the flames will fade
Posté le 17-05-2016 à 19:30:34  profilanswer
je me porte volontaire pour la prendre, mais c'est vraiment pour rendre service hein  :o
n°9809263
Kanysse12
Posté le 17-05-2016 à 19:35:06  profilanswer
enuma a écrit :
Ben voyons  :sleep:  La 1080 est à peu près au niveau d'un SLI de 980 (dans le meilleur des cas, parfois moins), en mono elle fait +20% mieux qu'une seule 980Ti, mais sinon ouais elle est proche d'un SLI de 980 Ti, ça me parait évident :D  Après c'est sûr que si "proche" pour le mec qui écrit ça c'est à +/- 40% de perfs, alors oui la 1080 est proche d'un SLI de 980 Ti :o
une custom water cooling avec 2*8 pin  pour l'alim tournant a 2.3-2.4ghz , vaudra un sli de Ti car pas de soucis de drivers toujours à 99% de charge ce qui est loin d'être le cas des SLI.
Si toutefois la température est bien géré comme les custom Ti actuel ( je ne dépasse pas les 63° a 1400Mhz avec les miennes).
n°9809264
B1LouTouF
PSN : Geo62280 / GT : Mr Geo
Posté le 17-05-2016 à 19:35:09  profilanswer
je vois pas en quoi elle vaudrait plus rien , elle rox toujours et faut les claquer les 800e pour la founder edition , tout ça pour gagner 10fps , ça laisse le temps de se retourner et attendre un bon custom de la mort qui s'oc a 2300 pour changer car la honnêtement , ça vaut pas trop le coup , ça donne envie de prendre de suite mais non , moi au final je garde ma ti , j'attends les bon custom et je la file a ma femme , une 1080 custom avec un bon oc dans la tronche , ça devrait fournir le petit manque de la ti sur les jeux les plus gourmand !
FeedBack
n°9809269
tistou77
Geek Inside!!
Posté le 17-05-2016 à 19:37:24  profilanswer
C'était ironique je pense :D
n°9809273
cobrasony
cobrasony
Posté le 17-05-2016 à 19:38:45  profilanswer
globule a écrit :
bah sinon vous achetez la 1080 et vous partez pas en vacances :D
marre des flots de touristes à Saint Raphael, j'en peux plus
lol , les vrais vacances pour moi se sera pas en france
n°9809274
SuperLobo
Vivement les vacances
Posté le 17-05-2016 à 19:38:47  profilanswer
Vivement un benchmark avec THE 2600K ! :sol:
n°9809276
guner36
Posté le 17-05-2016 à 19:39:20  profilanswer
On est largement au dessus des 10 FPS... mais plutôt de l'ordre de 30 % de perf en plus  par rapport à une 980 TI  sans parler de d'overclocking ou de VR  voir meme de SLI opptimisé sur cette generation  ... car sur ces niveaux ont est tres loing des 980TI ^^
D'ailleur personne a reussi à trouver des benchs  en SLI pour les 1080 ?
n°9809279
B1LouTouF
Posté le 17-05-2016 à 19:42:27  profilanswer
a lire les test on est la plupart du temps a 10 fps de plus qu'un 980ti custom donc un coup de 1500 sur la ti et on a peu près la même chose , après c'est sur la 1080 s'oc pas mal mais bon ayant une 980ti a 1500 qui bronche pas , autant attendre un gros custom qui envoie du lourd et qui pourra s'oc comme il le faut pour avoir un gros changement
edit : les ponts sli ne sont pas encore dispo je pense et si il n y a pas de test avec les anciens ponts , c'est qu'a mon avis y a des problèmes :D
Message édité par B1LouTouF le 17-05-2016 à 19:43:59
FeedBack
n°9809283
guner36
Posté le 17-05-2016 à 19:45:03  profilanswer
20 fps  tu veux dire ?? "  http://www.hardware.fr/articles/94 [...] ances.html "
apres ca depend de ton utilisation mais pour mon cas je suis en 4K  et VR donc la question ne se pose même plus..
" edit : les ponts sli ne sont pas encore dispo je pense et si il n y a pas de test avec les anciens ponts , c'est qu'a mon avis y a des problèmes :D  "
J'espere que les ponts seront dispo DAY ONE ^^
Message édité par guner36 le 17-05-2016 à 19:47:24
n°9809286
B1LouTouF
Posté le 17-05-2016 à 19:47:12  profilanswer
oui 10/20 selon le jeu , après je ne sais pas a combien est la fréquence de cette ti custom
edit : ha oui 4k , j'ai remarqué que le gain était plus grand , moi je suis en 1440p 165hz donc voila :p
Message édité par B1LouTouF le 17-05-2016 à 19:48:14
FeedBack
n°9809291
cyberfred
Posté le 17-05-2016 à 19:49:59  profilanswer
je ne sais pas à combien tourne la ti Custom de HFR (la Evga SC+)  , mais je suppose qu'ils ont du la laisser overclocké d'usine :jap:
(si on se réfère aux chiffres 3dmou , elle doit tourner dans les 1300 Mhz et quelques en boost )
Message édité par cyberfred le 17-05-2016 à 19:52:12
n°9809297
B1LouTouF
Posté le 17-05-2016 à 19:51:14  profilanswer
manque 200mhz quand même :D 2fps par tranche de 100 :lol:
FeedBack
n°9809298
alexreunio​n
Posté le 17-05-2016 à 19:51:17  profilanswer
Comme prévu je vais passer mon tour pour cette fois ci. Mais c'est intéressant de voir l'évolution des performances.
+20% de performance sur une 980Ti c'est pas mal, le prix pique un peu mais ça c'est un discours de pauvre donc on va éviter. Que ceux qui ont l'argent pour s'offrir ces CG se fassent plaisir, qui sommes nous pour juger? Et si cette 1080 ne se vend pas, Nvidia pourra toujours baisser les prix mais ne rêvons pas trop, je suis persuadé que la masse silencieuse des Geeks du monde entier a déjà préco tout le stock du lancement :D
Et pour finir vivement que DX12 soit supporté complètement. C'est rageant de voir une nouvelle génération de CG sortir et que les dernières API ne soient pas complètement gérées.
Mon feedback
n°9809299
Hatring
Posté le 17-05-2016 à 19:53:13  profilanswer
http://www.computerbase.de/2016-05 [...] -1920-1080
Comparatif hyper complet sur une dizaine de jeux en 1080p, 1440p et 2160p avec notamment : 980ti, Gigabyte 980ti Gaming, 1080, 1080 OC.
n°9809300
hifibuff
Posté le 17-05-2016 à 19:53:49  profilanswer
Y a-t-il un site qui a testé un SLI de 1080 avec ou sans le nouveau pont ?
"Every man dies, not every man really lives"
[HFR] Actu : Rise of the Tomb Raider offert par Nvidia[HFR] Actu : CES: Drive PX 2: Tegra et Pascal au pilotage
Comment reconnaitre le lecteur E:\ "Nvidia Geforce Experience"Nvidia comme pilote
Windows 10: Code 43 sur CG Nvidia 750mLunette 3D nvidia vision 2
nvidia shield proInstallation carte graphique NVIDIA NVS 510 sur PC tour HP Pavilion P6
[HFR] Actu : Pilotes Nvidia 361.43 WHQLNvidia GTX (960 ou 760 ou 660)?
Plus de sujets relatifs à : [Topic Unique] Nvidia Pascal GP104 : GTX 1080/1070 (16nm FinFET+)
