6207 connectés
  Ma carte graphique ne chauffe pas meme en jeu !
n°10374611
gotendu621​00
Posté le 26-05-2018 à 14:45:46  profilanswer
Bonjour je m'appelle John et je suis ici pour vous faire parvenir mon problème par rapport à ma carte graphique qui ne dépasse pas 50°c même en jeu c'est qui est très embêtant pour jouer car les Fps sont très bas voici ma config :
System Information
      Time of this report: 5/25/2018, 17:11:20
             Machine name: JOHN
               Machine Id: {4D1BAD20-6198-47B0-81F0-5327294E184B}
         Operating System: Windows 10 Entreprise 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
                 Language: French (Regional Setting: French)
      System Manufacturer: MSI
             System Model: MS-7693
                     BIOS: V22.3 (type: UEFI)
                Processor: AMD FX(tm)-6300 Six-Core Processor              (6 CPUs), ~3.5GHz
                   Memory: 8192MB RAM
      Available OS Memory: 8140MB RAM
                Page File: 9340MB used, 1744MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.17134.0001 64bit Unicode
Display Devices
           Card name: AMD Radeon HD 7900 Series
        Manufacturer: Advanced Micro Devices, Inc.
           Chip type: AMD Radeon Graphics Processor (0x679A)
            DAC type: Internal DAC(400MHz)
         Device Type: Full Device (POST)
          Device Key: Enum\PCI\VEN_1002&DEV_679A&SUBSYS_E249174B&REV_00
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 7122 MB
    Dedicated Memory: 3052 MB
       Shared Memory: 4070 MB
        Current Mode: 1920 x 1080 (32 bit) (59Hz)
         HDR Support: Not Supported
    Display Topology: Internal
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.641125,0.337414), Green(0.313977,0.623547), Blue(0.151867,0.070813), White Point(0.313977,0.329602)
   Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
        Monitor Name: HP 22xi IPS LED Backlit Monitor
       Monitor Model: HP 22xi
          Monitor Id: HWP302E
         Native Mode: 1920 x 1080(p) (60.000Hz)
         Output Type: DVI
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
      Advanced Color: Not Supported
         Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\c0323831.inf_amd64_1212be4b9fe2386c\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0323831.inf_amd64_1212be4b9fe2386c\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0323831.inf_amd64_1212be4b9fe2386c\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0323831.inf_amd64_1212be4b9fe2386c\amdxc64.dll
 Driver File Version: 23.20.15017.3010 (English)
      Driver Version: 23.20.15017.3010
         DDI Version: 12
      Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
        Driver Model: WDDM 2.3
 Graphics Preemption: DMA
  Compute Preemption: DMA
            Miracast: Not Supported
 Hybrid Graphics GPU: Not Supported
      Power P-states: Not Supported
      Virtualization: Not Supported
          Block List: No Blocks
  Catalog Attributes: Universal:False Declarative:False
   Driver Attributes: Final Retail
    Driver Date/Size: 31/01/2018 02:00:00, 1987280 bytes
         WHQL Logo'd: Yes
     WHQL Date Stamp: Unknown
   Device Identifier: {D7B71EE2-24DA-11CF-397F-E0F8BBC2DA35}
           Vendor ID: 0x1002
           Device ID: 0x679A
           SubSys ID: 0xE249174B
         Revision ID: 0x0000
  Driver Strong Name: oem15.inf:cb0ae41469197015:ati2mtag_R575DS:23.20.15017.3010:pci\ven_1002&dev_679a
      Rank Of Driver: 00D12001
         Video Accel: Unknown
         DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeVC1_VLD  DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
      Deinterlace Caps: n/a
        D3D9 Overlay: Not Supported
             DXVA-HD: Not Supported
        DDraw Status: Enabled
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 1
            MPO Caps: Not Supported
         MPO Stretch: Not Supported
     MPO Media Hints: Not Supported
         MPO Formats: Not Supported
    PanelFitter Caps: Not Supported
 PanelFitter Stretch: Not Supported
Merci d'avance  ;)
n°10374661
mrdoug
Posté le 26-05-2018 à 16:12:14  profilanswer
Sur quel jeu ?
Il faut dire que ton CPU est un très mauvais CPU pour le jeu du coup ça ne m’étonne pas.
n°10374693
gotendu621​00
Posté le 26-05-2018 à 17:24:05  profilanswer
mrdoug a écrit :
Sur quel jeu ?
Sur tout les jeux c'est a dire les fps sont bas et il n'y as pas un jeu ou je tourne bien.
n°10374697
Cutter
Posté le 26-05-2018 à 17:33:50  profilanswer
Comme le remarque mrdoug ton processeur limite probablement les performances.
last.fm
n°10374776
Xenon19
Ubuntu for Human.
Posté le 26-05-2018 à 20:00:03  profilanswer
Oui le FX 6300 était l'un des pires processeurs pour les jeux à l’époque ...
Asus Mini Transformer - Intel Atom X5 X8350 1.44 GHz, 1.92 GHz Turbo - Intel HD 400 - 4 GB memory - 128 GB eMMC - Windows 10.
n°10374835
gotendu621​00
Posté le 26-05-2018 à 22:09:21  profilanswer
C'est vraiment embêtant mais merci pour les réponses
n°10374869
gotendu621​00
Posté le 26-05-2018 à 23:37:18  profilanswer
Vous pensez que si je change le processeur avec un processeur plus puissant comme AMD FX-8370E Black Edition car elle adaptable as ma carte-mère, cela va-t-il régler mon problème ?
n°10374876
oufouf84
Posté le 26-05-2018 à 23:53:41  profilanswer
un combo fx8+hd7900 c'est déjà mieux, après il faut voir si ta cm peux encaisser un fx8 au niveau de sont étage d'alim.
puis prend le d'occase ;) sa couteras pas grand choses comme update.
n°10374889
gotendu621​00
Posté le 27-05-2018 à 01:45:02  profilanswer
D'accord merci beaucoup, sinon pas d'autres suggestion pour mon problème ?
n°10374891
gotendu621​00
Posté le 27-05-2018 à 01:51:39  profilanswer
Sachant que ma carte-mère est une MSI 970 gaming, mais ce problème vient régulièrement mais il y eut des jours où tout se passer bien et ma carte graphique marchent normalement c'est-à-dire utiliser toutes ses performances.
n°10374905
FUX_huhu
Imprompted
Posté le 27-05-2018 à 07:12:27  profilanswer
Voir si tu n'aurais pas le même problème => https://forum.hardware.fr/hfr/Hardw [...] 3394_1.htm
Ou un problème logiciel, windows ou un malware qui te boufferait les perfs? La température du CPU est inférieure à 71°? (pousière sur le rad, pate thermique d'origine et vieillissante)
Le FX 6300 n'est pas fameux mais ça permet de jouer encore un peu de façon modeste, quelques exemples de tes jeux?
Si la CM est ok tu peux aussi l'OC raisonnablement.
n°10374924
max022
Posté le 27-05-2018 à 09:17:59  profilanswer
C'est surement que ton cpu est bloqué à un coeff 7 au lieu de 20.5 (tu as un cpu à 1.4 GHz au lieu de 4.1 Ghz).
Bon il faudrait déja installer afterburner pour vérifier la température de ton cpu dans les jeux.
Ensuite désactiver cpu smart protection dans le bios et surement changer 2 paramètres dans cpu feature (personne qui avait le même soucis sur la même CM)
: j'ai désactivé core c6 state et activé c1e support.
n°10374928
artouillas​sse
9 lettres...pas mieux :o
Posté le 27-05-2018 à 09:31:27  profilanswer
En dehors de ton problème, il me semble que ta version de windows n'est pas accessible au grand public, ou alors tu t'es fait refiler un PC avec une copie pirate, ou version d'évaluation de 90 jours.
Un coup d'oeil à ce topic : https://forum.hardware.fr/hfr/Windo [...] 7513_1.htm
n°10374973
gotendu621​00
Posté le 27-05-2018 à 11:28:27  profilanswer
Je vous remercie beaucoup j'ai trouver le problèmes en désactivant quelques trucs dans le bios.
Plantages driver carte graphique pendant navigation webChoix carte graphique sans alimentation externe
Demande d'aide carte graphique[Conseil] CM MSI Z270 GP - Fréquence Carte Ram
Compatibilité ram pour carte mère Asus M4A87TDMa carte graphique chauffe-t-elle trop ?
[HELP] Ma carte graphique chauffe trop !Ma carte graphique chauffe, plante : est-elle vraiment morte ?
Plus de sujets relatifs à : Ma carte graphique ne chauffe pas meme en jeu !
