1821 connectés
  Matériel
  [Topic Unique] Auzentech Xplosion Cinema 7.1
n°1419971
Spyn
Posté le 26-06-2008 à 22:49:23  profilanswer
http://www.erenumerique.fr/images/news/20080418/xplosion_cinema_1.jpg
Fiche site officiel : http://www.auzentech.com/site/prod [...] cinema.php
Features and Specifications
      C-Media CMI8770 PCI chipset (8CH audio single chip with DTS® Connect and Dolby® Digital Live Real-Time Content Encoder)
      8CH codec embedded PCI audio single chip
      Full-duplex 8CH 24bit/96kHz DAC / 2CH 16bit/48kHz ADC
      Integrated S/PDIF input/output supports 44.1kHz/48kHz/96kHz sample rate and 16/24bits resolution
      The world's first DTS¨ Connect logo program certificated PCI audio board, now with upgraded OPAMPS.
      DTS® Interactive : A real-time 5.1 encoder that takes any 2 or more channel and encodes it into DTS® bit stream. DTS® Interactive provides a single cable connection via S/PDIF digital audio output to a DTS® enabled surround sound system by encoding all audio into a DTS® compatible bit stream at 1.5Mbps
      DTS® Neo:PC : An up mixing matrix technology that turns any 2 channel audio into 7.1 surround sound. DTS® Neo:PC, based upon DTS® Neo:6 matrix surround technology, transforms any stereo content such as MP3, WMA or CD audio, into a 7.1-channel surround sound experience
      Dolby® Digital Live(DDL) Real-Time Content Encoder converts PC audio into a 5.1 channel Dolby® Digital bit stream
      Swappable dual DIP type OPAMP controlled preamp circuit (4pcs output control OPAMP IC with DIY socket, 2pcs MIC input control OPAMP IC with DIY socket)
      Upgraded Operational Amplifiers from National OPAMP LM4562 (Front L/R) and JRC 5532 (B.S & Cent/S.W)
      Max 2.8Vrms full swing analog output gain by unique preamp circuit / incredible powerful analog output, improve dynamic range / SNR
      Proper OPAMP control circuit (+8V, -8V dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level
      Package contents: Auzen X-Plosion 7.1 Audio Card / MPC to MPC(2pin-2pin) CD S/PDIF audio cable / TOSLINK fiber optic digital cable / installation CD / warranty card / owner's manual
    * Swappable OPAMPs: All Auzen soundcards support swappable OPAMP sockets for OPAMP upgrades.
test : http://www.generation-3d.com/Presentation,ar219-1.htm
prix : (entre 80 et 100 €) http://www.achetezfacile.com/auzen [...] 93841.html
Avis perso : Je passe d'une Audigy 1 à cette carte, j'ai une denon UDM31 ainsi qu'un petit caisson de basse yamaha de 70 watts, le son est plus clair, plus puissant, plus percutant, la différence n'est pas non plus phénomènale mais c'est clairement perceptible, pas encore testé dans les jeux mais devrais pas y avoir de soucis, les drivers sont simplicimes, léger et bien concu. Seul petit bémol pour les fous de jeux vidéo : elle n'est compatible que "EAX 2.0" si vous voulez une compatibilité EAX 5.0 il faut prendre la Prelude qui est 80 € plus cher.
Message édité par Spyn le 27-06-2008 à 00:42:15
n°1421718
Spyn
Posté le 02-07-2008 à 14:15:26  profilanswer
bide  :D
n°1458395
Damal77
Posté le 16-10-2008 à 13:03:05  profilanswer
:bounce:
J'ai reçu la mienne aujourd'hui.
Je l'installe ce week end et je matte direct un film.
  Matériel
Besoin de conseil pour achat ampli / Home cinemaJ'arrive pas à lire des DVD-R sur mon Home cinema SAMSUNG HTX20R
Home cinema 5.1 avec upscale DVD en 1080p (samsung HT-Z310)compo home cinema petit budget
Problème home cinema/TVBranchement optical de ma carte mere à mon home cinéma
Chaine DVD Home CinémaCherche ampli home cinema à moins de 400€
REGULER LA TENSION sur mon ensemble HOME CINEMA[VOS AVIS] Quel pack Home cinema 5.1 ? Infinity VS Jamo
Plus de sujets relatifs à : [Topic Unique] Auzentech Xplosion Cinema 7.1
