7249 connectés
  Traitement Audio
  Du "nouveau" chez A-MAX bis... -> 396 & 398
n°497797
RAff
Posté le 16-08-2003 à 11:35:45  profilanswer
lecteurs CD MP3 qui ont l'air intéressant,
d'abord le DAV 396:
http://www.amaxde.com/amax/images/dav396_gross.jpg
18mm Ultra-slim player
MP3, CD-DA disc playback.
ISO9660 Joliet,CD-R,CD-RW disc playback
Line remote control
ID3 V2 &V1 tag display selectable(Album / Artist / Title / Playing Time)
Support Multi-session CD-R/RW disc playback.
Searching by directory / file selectable.
MP3/CD-DA with 480/160seconds Anti-shock function.
6 EQ Mode : Classic / Pop / Jazz / Rock / Normal/User Setting EQ
Song Programming: up to 32 songs.
Play Mode : Repeat DIR / Random Repeat DIR / Introduce / Repeat One / Repeat All / Random Repeat All / Random
Digital Volume Control : 32 Steps
Built-in recharge circuit
Sony Ultra Slim Mechanism
Specifications
KIND OF PLAYING FILES
 MP3, CD-DA
DIGITAL VOLUMN CONTROL
 32 steps
EQUALIZER
 Normal, Classical, Pop, Jazz, Rock, User
AUDIO FREQUENCY RANGE
 20Hz ~ 20 kHz
MAXIMUM OUTPUT
 > 25mW (16 Ohms)
SIGNAL TO NOISE RATIO
 > 85 dB
TOTAL HARMONIC DISTORTION
 < 0.1%
AUDIO OUTPUT
 Earphone (Multiport Connector)
LINE-OUT
 Stereo
OPERATING TIME (approximate)
 11hours (11 hours(MP3/128kbps)
7 hours(CD-DA ESP)
8 hours(CD-DA without ESP)
le DAV 398:
http://www.amaxde.com/amax/images/dav398_gross.jpg
WMA , MP3, CD-DA disc playback.
Line remote control with LCD display & blue backlight
ID3 information display:
Digital FM Radio tuner Support Multi-session CD-R/RW disc playback.
WMA/MP3/CD-DA with 960/480/120 seconds Anti-shock function.
6 bands EQ Mode
5 preset EQ mode : Classic / Pop / Jazz / Rock / Normal
1 user setting EQ mode
Song Programming : up to 32 songs.
Song Tracking : Fast Forward / backward
FF / FW scanning in one track (CD Only)
Key Hold
Specifications
 WMA, MP3, CD-DA
 32 steps
FM Tuner
 88 MHz ~ 108 MHz
 20Hz ~ 20 kHz
MAXIMUM OUTPUT
 > 25mW (16 Ohms)
 > 90 dB
 < 0.1%
AUDIO OUTPUT
 Multiport Connector
LINE-OUT
 Stereo
OPERATING TIME
 12- hours (WMA/96kbps)
bref une bonne concurrence face au Chrome-X, le point fort de l'Iriver étant la mise a jour du firm.
si vous avez l'un de ces lecteurs, mettez vos remarques etc...
PS : encore un sujet "j'hésite entre celui la et l'autre" mais on a pas encore parlé des nouveaux a-max alors ... [:alucard]
Message édité par RAff le 16-08-2003 à 12:04:04
--<  MON FEED >--   "Technicien informatique de père en fils depuis 1923."
n°497804
julos44
Posté le 16-08-2003 à 11:53:07  profilanswer
sisi on en a parlé à leur sortie ... ya 3 mois, cherche un peu
n°497809
RAff
Posté le 16-08-2003 à 12:02:52  profilanswer
ouai, j'ai trouvé ton topic, mais au final on ne parle que des anciens modèles, j'éspère qu'il y aura du nouveau dans les commentaires cette fois çi.
up :bounce:
n°506939
Enidan
Posté le 07-09-2003 à 20:21:46  profilanswer
:bounce:
Qq avis ou tests ?
n°506978
RAff
Posté le 07-09-2003 à 21:20:12  profilanswer
si seulement Tang s'intéressait à A-MAX et mettait de côté I-River ...
n°506995
Tang
Plug'n'Troll
Posté le 07-09-2003 à 21:57:24  profilanswer
Raff comme le signale Julos on vait parlé d'au moins un de ces 2 modèles (le 396 en l'occurence).
Effectiveemnt il sont sympathiques et leur caratéristiques sont de bons niveau malheureusement ces modeles n'apportent rine de plus que les iRiver (peut etre un prix moindre remarque). Ils sontmeme un leger retard puisque là ou iRiver propose un mode programme sans limitation (+ fonction enqueue" ) et le support playlist *.m3u,  Amax  quant à lui ne permet qu'un simple mode de type programme avec seulement 32 plages programmables...
En somme le secteur CDmp3 ayant atteint la maturité, on ne peut plus attendre bcp de choses de neuf a part ebventuelment le support de nouveaux codecs.
Al'inverse Amax serait sans doute bien inspiré de profiter du vide laissé par iRiver dans lagamme MiniDiscman (8cm)... La il y a une niche où les utilisateurs serainet demandeurs de bons modeles Slim....
En tt cas merci de ton intervention Raff, et n'oublie pas que je ne suis pas le messie: je ne suis qu'un utilisateur lambda qui a testé le seul disclman mp3 que j'ai eu entre les mains...
Salut
• • • "La démocratie c'est bien mais il faudrait que les gens soient pas cons..." © Alpacou aux Nouilles • • •
n°507001
julos44
Posté le 07-09-2003 à 22:08:45  profilanswer
faux, il en a eu 2!
n°507009
Tang
Plug'n'Troll
Posté le 07-09-2003 à 22:23:39  profilanswer
Ouie faut que je me soigne: deja je parle de mapoire àla 3emepersonne comme un vulgaire Demon (et je pretends ne pas etre le messie, lol!)
Et puis en plus j'arrive plus àcompter jusqu'à 2...
Bon si j'ai pas parlé de 2 slimx c'ets tt simplement que je n'ai pas encore arreté mon jugement sur l'iMP-550: je vais devoir faire des vérifs avec divers CD etc...
Ca dervait etre fait d'ici peu et j'en profiterai pour mettre àjour le topic en questio (en plus de ma review du 350)
Voilou...
Tanguy
julos44 a écrit :
faux, il en a eu 2!
  Traitement Audio
Nouveau jukebox audio nomade : ogg vorbis de la partie !!!Nouveau format audio : HE-AAC ou l'assassinat planifié du mp3PRO
Nouveau Materiel detecté??Nouveau firmware iriver IMP : 2.30
Nikon coolpix 700 et capacité compactflash MAX ?Nouveau lecteur usb/mp3 A-Max PA26 128 Mo
Baladeur MP3 ... un nouveau venuNouveau codec VP6: une tuerie!!!!
Que pensez-vous du nouveau service MAC...
Plus de sujets relatifs à : Du "nouveau" chez A-MAX bis... -> 396 & 398
