6900 connectés
 Page :   1  2  3  4  5  ..  133  134  135  136  137  138
CUSTOM : concours du plus beau Foobar2000
n°1787091
Posté le 19-05-2012 à 23:21:56  answer
 j ai eu cette erreur a l instal
Scripting Engine Initialization Failed (WSH Path v1.0.0 by Br3tt aka Falstaff >> http://br3tt.deviantart.com, CODE: 0x80020101)
Check the console for more information (Always caused by unexcepted script error).
donc je sais pas si j ai merdé quelque pars ou .... ?
j ai un aw crashed qui est apparus juste en dessous du menu en haut de foobar
je te copie colle  la console
Watching: D:\Musique
WSH Panel Mod (WSH Path v1.0.0 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): Parsing file "F:\Users\m\AppData\Roaming\foobar2000\themes\fooRazor\scripts\WSHcommon.js"
Error: WSH Panel Mod (WSH Path v1.0.0 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): Erreur d'exécution Microsoft JScript:
Un composant ActiveX ne peut pas créer un objet.
File: <main>
Ln: 31, Col: 1
<source text only available at compile time>
WSH Panel Mod ({58210623-69D2-4049-B082-3B18E18FB453}): initialized in 4 ms
WSH Panel Mod ({881B89BF-0D7A-49B2-BA4D-259DDC85F74E}): initialized in 3 ms
WSH Panel Mod ({881B89BF-0D7A-49B2-BA4D-259DDC85F74E}): initialized in 2 ms
WSH Panel Mod ({4B58EBA9-3E91-4910-B2AD-91D8A4D38DBB}): initialized in 3 ms
WSH Panel Mod ({58210623-69D2-4049-B082-3B18E18FB453}): initialized in 2 ms
WSH Panel Mod ({881B89BF-0D7A-49B2-BA4D-259DDC85F74E}): initialized in 1 ms
WSH Panel Mod ({58210623-69D2-4049-B082-3B18E18FB453}): initialized in 1 ms
WSH Panel Mod ({4B58EBA9-3E91-4910-B2AD-91D8A4D38DBB}): initialized in 2 ms
WSH Panel Mod (Simple Cover Art Panel v2.0 by Br3tt): Parsing file "F:\Users\m\AppData\Roaming\foobar2000\themes\fooRazor\scripts\WSHcommon.js"
WSH Panel Mod (Simple Cover Art Panel v2.0 by Br3tt): initialized in 22 ms
WSH Panel Mod (CoverFlow View v1.4.1 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): Parsing file "F:\Users\m\AppData\Roaming\foobar2000\themes\fooRazor\scripts\WSHcommon.js"
WSH Panel Mod (CoverFlow View v1.4.1 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): initialized in 86 ms
WSH Panel Mod (WSH Playlist Viewer v2.0.7 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): Parsing file "F:\Users\m\AppData\Roaming\foobar2000\themes\fooRazor\scripts\WSHcommon.js"
WSH Panel Mod (WSH Playlist Viewer v2.0.7 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): initialized in 38 ms
WSH Panel Mod (WSH Controls v1.0.0 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): Parsing file "F:\Users\m\AppData\Roaming\foobar2000\themes\fooRazor\scripts\WSHcommon.js"
WSH Panel Mod (WSH Controls v1.0.0 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): initialized in 20 ms
Startup time : 0:00.669533
Message édité par Profil supprimé le 19-05-2012 à 23:25:12
Posté le 19-05-2012 à 23:21:56  profilanswer
n°1787093
Br3tt
Posté le 19-05-2012 à 23:29:15  profilanswer
Comme d'hab avec wsh panel mod, faut desactiver l'option "safe mode" dans les preferences de foobar, j'ai omis de le preciser, desolé
Br3tt (http://br3tt.deviantart.com)
n°1787096
Posté le 19-05-2012 à 23:32:43  answer
impec je te remercie
n°1787099
Br3tt
Posté le 19-05-2012 à 23:40:48  profilanswer
à priori petit bug sur le panneau de cover, j'ai ré-uploadé une 1.0.1 qui corrige peut être ce souci...
n°1787105
bullrott2
Posté le 20-05-2012 à 00:02:23  profilanswer
Fonctionne nickel (j'avais la même erreur résolue par la désactivation du "safe mode"
Par contre me semblais qu'il y avais un coverflow nan?
n°1787110
Br3tt
Posté le 20-05-2012 à 00:31:44  profilanswer
les 3 boutons en bas à gauche : L C R, c'est pas pour faire joli seulement ;)
n°1787121
bullrott2
Posté le 20-05-2012 à 02:13:46  profilanswer
merci :d
n°1787166
Grumms
Aimé de tous
Posté le 20-05-2012 à 14:21:17  profilanswer
J'ai découvert le fabuleux plugin ControlServer. Du coup, je peux piloter foobar depuis mon téléphone, ce qui est plutôt pratique dans certaines circonstances : ça m'évite d'allumer la télé lorsque j'ai lancé foobar sur mon PC de salon par exemple.
n°1787185
McNulty
Posté le 20-05-2012 à 16:53:30  profilanswer
Br3tt a écrit :
fooRazor dispo dès à présent pour les curieux :p
http://fav.me/d50gx6v
Br3tt
sympa ce thème, c'est possible d'ajouter le bitrate ? (en dehors d'ajouter la barre de statut qui fait un peu tache)
Message édité par McNulty le 20-05-2012 à 16:54:09
n°1787192
Br3tt
Posté le 20-05-2012 à 17:36:10  profilanswer
@McNulty
le bitrate est l'une des colonnes optionnelles de mon playlist viewer, donc la réponse est oui.
n°1787195
McNulty
Posté le 20-05-2012 à 17:52:01  profilanswer
ah oui je n'avais vu la barre de réglage pour la playlist, merci.
une dernière petite chose, toujours au niveau de la playlist c'est possible d'avoir une couleur qui ressorte mieux que le gris clair pour l'artiste/album/année ? une police un peu plus grande aussi (pour l'artiste/album) ?
Message édité par McNulty le 20-05-2012 à 18:00:53
n°1787204
Jinroh
Posté le 20-05-2012 à 18:30:47  profilanswer
Perso j'adore la présentation atuelle, très propre, clair épurée.
Je n'ai pas encore testé cette toute dernière version mais j'utilise déjà celle du premier essai Defaut UI.
Très très agréable à utiliser.
Galerie photos
n°1787215
Br3tt
Posté le 20-05-2012 à 18:44:03  profilanswer
File>Preferences>Display>Default User Interface> Colors & Fonts
là, tu choisis tes couleurs perso et tes polices. Après tu dois modifier le script si tu veux personnaliser encore plus comment s'affiche les groupes, ... etc
n°1787216
Br3tt
Posté le 20-05-2012 à 18:44:15  profilanswer
n°1791306
Jinroh
Posté le 09-06-2012 à 14:22:30  profilanswer
[HorsSujet]
Alors, il y a quelqu'un à cette rencontre DeviantArt ?
[/HorsSujet]
Galerie photos
n°1796000
Jinroh
Posté le 07-07-2012 à 12:15:20  profilanswer
Petite question toute bête, mais je ne trouve plus...
Comment fais-t-on pour retirer la barre de Menu (File, Edit, View etc..) ainsi que celle d'info de lecture tout en bas (Playing|format|bitrate, etc.) ?
Merci pour le rappel.
Galerie photos
n°1796069
Br3tt
Posté le 07-07-2012 à 20:40:58  profilanswer
CUI ou DUI ?
CUI dans les Preferences>Display, onglets Main pour la toolbar, onglet suivant pour la status bar
DUI, tu peux pas, sauf en installant un composant tiers foo UI Hacks qui ajoute des options et notament la désactivation de ces deux barres pour DUI
n°1796079
Jinroh
Posté le 07-07-2012 à 23:17:42  profilanswer
C'est dans DUI (je suis avec ta fooRazor :love: ). Je passerai donc par ce foo_ui_Hacks.
Merci.
EDIT : C'est fait, Merci.
Message édité par Jinroh le 08-07-2012 à 19:41:12
Galerie photos
n°1796331
Jinroh
Posté le 09-07-2012 à 22:44:33  profilanswer
Encore une petite question, mais c'est peut-être moins de la custo...
Dans foobar j'ai défini 1 playlist par répertoire avec des classements particuliers.
Est-ce qu'il est possible de définir une playlist depuis le contenu d'un répertoire et que celle-ci se mette à jour en fonction du contenu ?
Je déplace un nouveau répertoire, il est pris en compte. Je supprime un répertoire, il disparait de la playlist...
Possible, or not ?
Galerie photos
n°1796342
Br3tt
Posté le 09-07-2012 à 23:28:28  profilanswer
bien sur, ça s'appelle une autoplaylist :)
menu Library>Search, permet d'en créer à partir d'une requête (clique le bouton "?" pour l'aide sur la syntaxe)
exemple, tu veux une autoplaylist qui soit le reflet du dossier C:\MP3\dossier01\, et bien tu saisies la requête suivante:
%path% HAS C:\MP3:\dossier01\
ceci est plus juste:
"$directory_path(%path%)" IS C:\MP3\dossier01\
à tester ;)
Message édité par Br3tt le 10-07-2012 à 08:10:55
n°1796345
Jinroh
Posté le 09-07-2012 à 23:43:39  profilanswer
Cooooooool.
Si simple.
Merci beaucoup. Je viens de tout refaire :)
Galerie photos
n°1796347
Posté le 09-07-2012 à 23:47:49  answer
Failed to load DLL: foo_plorg.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000.
j ai ce genre d erreur après un formatage ?
n°1796361
Br3tt
Posté le 10-07-2012 à 08:10:25  profilanswer
installe Visual C++ 2010 redistribuable package comme l'indique ce composant dans ses recommandations : http://wiki.hydrogenaudio.org/inde [...] o_plorg%29
n°1796541
Posté le 11-07-2012 à 10:35:41  answer
merci br3tt
n°1796600
fourer
Tartiflette Connection
Posté le 11-07-2012 à 15:44:15  profilanswer
Br3tt, t'es vraiment bon !
Merci de mettre ton boulot à notre disposition !
Je viens d'installer ton dernier fooRazor ! Excellent !
Aussi vite que possible, mais aussi lentement que nécessaire -- You and I have to change history -- Est-ce de ma faute à moi si j'aime le café et l'odeur du tabac ?
n°1796635
Br3tt
Posté le 11-07-2012 à 18:28:47  profilanswer
@fourer
Shuss :jap:
n°1797391
Jinroh
Posté le 15-07-2012 à 21:41:22  profilanswer
Je suis toujours avec fooRazor, très agréable et avec une petite chose bien pratique : la possibilité de fin de lecture à la fin du titre courant.
Je ne sais pas trop d'où ça vient : standard ou de ton dév, mais serait-il possible d'avoir dans le même genre, une option pour termine la lecture en fin de disque (selon les groupements définis dans la playlist ;) ) ?
Galerie photos
n°1797462
Br3tt
Posté le 16-07-2012 à 13:13:54  profilanswer
c'est natif (menu Playback>Stop after current). pour ce qui est à la fin d'un groupe, je sais pas, peut-être exisite-t-il un plugin pour ça, essaie Google ;), sinon par script c'est surement possible mais je suis off sur tout dev foobar ces derniers temps, donc mieux vaut pas attendre après moi sur ce coup là ^^
a+
n°1797495
Jinroh
Posté le 16-07-2012 à 14:46:06  profilanswer
Ok, je vais jeter un oeil pour voir si cela existe.
Sinon, on verra quand tu reprendras, ce n'est pas du tout pressé.
Merci pour l'info.
Galerie photos
n°1798080
nii2
Posté le 19-07-2012 à 11:27:56  profilanswer
Bonjour à tous,
je suis un nouveau venu sur foobar (il était temps!)...
j'ai testé quelques skins de Br3tt, et franchement 1 seul mot : respect pour ce taf énorme que tu nous proposes.
J'essaie parallèlement de faire mon propre skin sur columns ui. J'utilise elplaylist, mais j'ai un petit souci avec mes albums taggés "various artists". En effet, dans la playlist il ne m'affiche pas l'album artist dans le titre (group header), mais le nom du 1er artiste de la piste 01. De plus dans ce cas d'albums "various artists", j'aimerais également que pour le noms des pistes j'ai : nom de l'artiste - nom du titre".
Voilà, j'espère avoir été assez explicite...! Je pense qu'il doit falloir changer quelque chose dans le code de la playlist, mais j'ai cherché un peu...et pour moi c'est compliqué.
Quelqu'un pourrait m'éclairer?
Merci d'avance.
Message édité par nii2 le 20-07-2012 à 09:55:20
n°1798454
Br3tt
Posté le 21-07-2012 à 13:45:05  profilanswer
AVIRER SVP
Message édité par Br3tt le 21-07-2012 à 13:45:57
n°1798455
Br3tt
Posté le 21-07-2012 à 13:45:30  profilanswer
éclaire nous aussi, tu dis faire une config, mais le script utilisé dan ELPlaylist est celui par défaut ou bien t'a essayé d'en faire un perso ?
sinon: pour un album en VA, tu renseignes le TAG %album artist% avec une valeur (en général on met "Various Artists" ou "VA" ... etc) et le TAG %artist% contient bien le nom de l'artiste de chaque piste de l'album
donc dans ton Header Group, il faut afficher %album artist% et pas %artist%
pour les pistes, tu affiches "%artist% - %title%" et le tour est joué (à adapter selon le code titleformat utilisé dans ton script ELPlaylist bien sur)
pour le faire que si c'est un VA album, tu ajoute une condition qui teste si tu est sur un VA album, comment? et bien si %album artist% est différent de %album% alors c'est du VA :)
exemple:
$ifequal(%album artist%,%artist%,
 %title%
 %artist% - %title%
comme ça t'affiche pas l'artist si c'est un album mono artiste ;)
n°1798543
panzemeyer
The torture never stops
Posté le 22-07-2012 à 11:59:26  profilanswer
J'ai besoin de votre aide pour mettre au point un ordre de classement d'une playlist de mes titres favoris : j'ai imaginé un classement par points qui tient compte, pour chaque titre, de son rating s'il est supérieur à 0, du nombre de fois jouées et de sa durée (mon objectif étant de rééquilibrer le classement par note en faveur des titres très longs, qui ont général un plus petit %play_counter%).
J'ai donc imaginé ça :
$num($mul($mul(%play_counter%,100),$div(%length_seconds%,30),$ifgreater(%rating%,0,$mul(%rating%,3),1)),10)
Mon problème est que ce classement avantage beaucoup trop les titres longs (7 min ou plus). J'ai essayé de jouer sur les chiffres multiplicateurs  pour chaque tag, mais bizarrement l'ordre des titres reste à peu près le même.
Une idée pour affiner ce classement ? :)
Message édité par panzemeyer le 22-07-2012 à 12:01:06
Pour la préservation de l'environnement, n'imprimez ce post qu'en cas de nécessité | Fais du bien à un vilain, il te chiera dans la main.
n°1798555
Grumms
Aimé de tous
Posté le 22-07-2012 à 14:11:36  profilanswer
nii2 a écrit :
Bonjour à tous,
Merci d'avance.
J'avais résolu la chose en mettant 'VA' dans le nom du dossier.
n°1798583
Br3tt
Posté le 22-07-2012 à 20:32:12  profilanswer
Hmm
n°1798626
nii2
Posté le 23-07-2012 à 12:27:32  profilanswer
exemple:
 %title%
 %artist% - %title%
Merci Br3tt pour ta réponse! Effectivement je n'avais pas précisé que le script que j'utilise dans ELPlaylist est celui par défaut.
J'ai donc bien changé dans le group header %artist% par %album artist%.
Par contre,pour les pistes je vois ce que tu veux dire, mais je n'arrive pas à le réaliser. Je rajoute la condition dans Track list et Per second, mais ça ne marche pas...
Message édité par nii2 le 23-07-2012 à 12:28:28
n°1798642
Br3tt
Posté le 23-07-2012 à 15:01:52  profilanswer
publie ton script ici, on verra si on peut t'aider ;)
Message édité par Br3tt le 23-07-2012 à 15:02:01
n°1798702
nii2
Posté le 24-07-2012 à 09:41:32  profilanswer
Ok alors voilà ce que ça donne :
- pour le track list :
$puts(art.size,$mul(%ART.ROW%,%el_row_height%))
$puts(text.left,$add(10,$mul(%ART.MARGIN%,2),$get(art.size)))
$puts(text.color,%TEXT.COLOUR%)
$puts(track.text,%tracknumber%  %title%)
$puts(len.width,$add(4,$gettextwidth(%length%)))
$puts(text.right,$add(%el_width%,-$get(len.width)))
$puts(effect,$ifequal(%ON.SHADOW%,1,glow:0:48-48-48:3 offset:1:2,))
///////Track Info///////
$setcoordinate(1)  //x,y,r,b mode
$if($not(%el_isplaying%),
     $drawtextex($get(track.text),
                 $get(text.left),0,$get(text.right),%el_height%,$get(text.color),vcenter end_ellipsis)
     $drawtext(%length%,0,0,$sub(%el_width%,4),%el_height%,$get(text.color),vcenter right),)
$setcoordinate(0)
///////Album Art///////
$enabledraw(1)
$puts(art.top,$add($select(%ON.ART.IN.GROUP%,%el_row_height%),%ART.MARGIN%))
$puts(art.left,%ART.MARGIN%)
$setworldtransform($add(2,-%ON.ART.IN.GROUP%))
$imageabs($get(art.left),$get(art.top),$get(art.size),$get(art.size),%el_group_first_path%,artreader,,,$get(effect))
- pour le Per second :
$puts(track.text, %tracknumber%   %title%)
$puts(text.right,$add(%el_width%,-$el_scale(12,$get(len.width),5)))
            $get(text.left),0,$get(text.right),%el_height%,%PLAY.TEXT.COLOUR%,vcenter end_ellipsis)
$setcoordinate(0)
$drawtext(%playback_time%,0,0,$sub(%el_width%,4),%el_height%,%PLAY.TEXT.COLOUR%,vcenter right)
Voilà, encore merci.  :)
n°1817751
Gr3cKo
Posté le 14-11-2012 à 15:49:12  profilanswer
 %title%
 %artist% - %title%
Ou plus simple :
[%track artist% - ]%title%
Le probleme avec ta solution comme la miene, c'est si un artiste fait une compil multi artiste où il y a une de ses tracks dedans, ça te mettra le nom de l'artiste pour les autres tracks mais pas celle là.
Du coup ce que je fais pour que ça soit homogene sur tout l'album (cad avec l artiste pour chaque track) c'est :
$if($meta_test(album artist),%artist% - )%title%
(enfin un truc un peu mieux pour les artistes multiples mais c'est hs là)
n°1836340
pepito451
Pepito Le Magnifique
Posté le 18-01-2013 à 01:20:13  profilanswer
Bonsoir,
ca fait vraiment une paye !
pas mal d'ennuis de sante...
toujours avec xchange sur 7( à mon avis le plus abouti techniquement et esthétiquement),mais là j'ai un windows 8 sur une nouvelle machine
et j'ai donc installer le dernier opus : foorazor que je decouvre doucement
j'aurais 2 petites requetes...si possible
où trouver foo UI Hacks ? pour cacher les barres haut et bas ! j'ai cherché partout ou alors la possibilité de les ...colorier  :jap:
et enfin remplacer le panneau haut gauche qui affiche la pochette par l'équivalent de foo uie albumart qui cycle des images de l'artiste
merci bien
ps: toujours fidéle comme tu vois :love:
n°1836943
Br3tt
Posté le 20-01-2013 à 12:54:49  profilanswer
@pepito451
bon retour et bon rétablissement alors.
Pour foo_ui_hacks, voici le lien que google trouve assez simplement: https://sites.google.com/site/fooba [...] 2012-12-24
Pour remplacer un panneau par un autre (albumart), là c'est du basique de DefaultUi, tu passes en layout Editing mode (menu View> Layout) et le clique droit sur les panneau est ton ami...
p/i je bosse actuellement sur un portage de Itunes 11, laissé un peu en jachère en décembre et janvier mais que je vais tacher de finir rapidement j'espère... petit screenshot:
http://fc01.deviantart.net/fs70/i/2012/344/2/3/e11even_____an_itunes11_like_foobar2000_config_by_br3tt-d5ffnvl.png
a+
[Topic Unique] Foobar2000 le successeur de WinampConcours vidéo en ligne
[concours de video de vacances] repaire.netcd audios "custom"
radeon vivo : tv-out pas beau...Arggghhh ! Sony pas beau !
Lequel de ces deux sites trouvez vous le plus beau !!Besoin d'aide pour un concours - Questions sur Creative Labs
Ou trouver des Rio volt sp250? les tout nouveaux tout beau en noir ?!qualité à c... de mes SVCD...comment faire du beau ?
Plus de sujets relatifs à : CUSTOM : concours du plus beau Foobar2000
