5790 connectés
  C++
  Comment recuperer les code des touches multimedia d'un clavier
n°268417
da_s_monk
Awwwww! Good Job!
Posté le 12-12-2002 à 19:12:29  profilanswer
Bonjour a tous
je voulais savoir comment on recupere les codes des touches des claviers multimedia (je sais pas si c tjrs de l'ascii c pour sa que je mes code)
merci d'avance
n°268714
gatorette
Posté le 12-12-2002 à 22:45:09  profilanswer
msdn a écrit :
Keyboard Keys for Browsing and Other Functions:
Microsoft Windows® provides support for keyboards with special keys for browser functions, media functions, application launching, and power management. The WM_APPCOMMAND supports the extra keyboard keys. In addition, the ShellProc function is modified to support the extra keyboard keys.
It is unlikely that a child window in a component application will be able to directly implement commands for these extra keyboard keys. So when one of these keys is pressed, DefWindowProc will send a WM_APPCOMMAND message to a window. DefWindowProc will also bubble the WM_APPCOMMAND message to its parent window. This is similar to the way context menus are invoked with the right mouse button, which is that DefWindowProc sends a WM_CONTEXTMENU message on a right button click, and bubbles it to its parent. Additionally, if DefWindowProc receives a WM_APPCOMMAND message for a top-level window, it will call a shell hook with code HSHELL_APPCOMMAND.
Windows also supports the Microsoft IntelliMouse® Explorer, which is a mouse with five buttons. The two extra buttons support forward and backward browser navigation. For more information, see XBUTTONs.
(pris de http://msdn.microsoft.com/library/ [...] input.asp)
each day I don't die is cheating
  C++
Recuperer le flux clavier.Cherche le code Acsii de la touche effacé
comment remplir le buffer clavier, mais sans toucher au clavier ?Recuperer un parametre a partir d'un jSP
[php] recuperer l adresse ip du visiteur et l afficherAlleger mon code (inside) siouplait...........
[HTML]Comment recuperer ts les elt selectionnées d'une boîte liste?Code qui permet de virer la barre d'ascenseur à droite inutile. OK
Code souce de XP , qui n'en veut !!!
Plus de sujets relatifs à : Comment recuperer les code des touches multimedia d'un clavier
