5480 connectés
  [BD7 BD7-II BE7] vmod trouve yaisse...
n°662671
Posté le 25-11-2002 à 16:48:56  answer
apres plus d'un moi de recherche sur different forum pour un vmod sur mon ex be7 maintenant que je l'ai plus j'ai trouve le vmod en question [:sisicaivrai] .
http://membres.lycos.fr/djangolefous69/105-0554_IMG.jpg
http://membres.lycos.fr/djangolefous69/105-0555_IMG.jpg
http://membres.lycos.fr/djangolefous69/105-0561_IMG.jpg
http://membres.lycos.fr/djangolefous69/105-0562_IMG.jpg
http://membres.lycos.fr/djangolefous69/Regulator_location.jpg
http://membres.lycos.fr/djangolefous69/vmod-chip2.jpg
explication en anglais pour l'instant
If you have a look at the pics there are 2 resistors (R1, R2) added to pin 19 of the W83301R regulator.
(R1+R2)/R2 should give new voltage. If R1 = 100 ohms and R2 = 10 ohms then it gives a 10% increase and 1.1 x 2.5V = 2.75V and 1.1 x 2.7V = 2.97V!
Details were added to the pic above.
Like DDTUNG mentioned before this mod includes cutting pin 19 of the W83301R regulator!
Most sure way to do the mod is connecting resistors directly to the W83301R chip's leg no 19. Desolder leg from the mobo (heat with solderingiron and pry it up with needle or something).
Look where the trace is going and solder 10 ohms resistor from original trace to the chip's leg. 100 ohms pot goes from chip's leg to ground.
The credits for this mod go to Jarmo Pirinen who did a great job helping me to figure out how this mod is to be done! Thanx again, Jarmo!
Be aware that like any other modification to hardware you'll loose waranty if doing this mod!
Furthermore i'm not responsible for any damage this mod might cause to your hardware!
I didn't have time to mod my BD7-II Raid yet, but i'm pretty sure it'll work - but it's still untested!
This post is for any of you who can't wait till i modded my board to validate this mod is working properly.
Good luck!
R1-pot(ohms)........bios settings.............. vmem reel
100.....................2.6V........................2.86V
100.....................2.7V........................2.97V
80......................2.5V........................2.81V
80......................2.7V........................3.04V
70......................2.5V........................2.85V
70......................2.6V........................2.97V
50......................2.5V........................3.0V
50......................2.6V........................3.12V
50......................2.7V........................3.24V
source: Xtreme Systems Forums
http://www.xtremesystems.org/forums/
Message édité par Profil supprimé le 25-11-2002 à 23:14:17
Posté le 25-11-2002 à 16:48:56  profilanswer
n°662751
vcentvin51
Posté le 25-11-2002 à 18:34:58  profilanswer
depuis le temps que je le cherchais aussi (depuis ma premiere bd7 en fait et maintenant ma bd7II)  :love:
mais bon pas tres clair le shema :(
faut que je regarde ç de plus pres
n°662774
Posté le 25-11-2002 à 19:01:05  answer
je vais detailler un peu plus ca veut venir ;)
mais en tout cas ca va ravir les posseseur de be7 qui sont limite a 2.7v en vmem
 :love:
n°662778
vcentvin51
Posté le 25-11-2002 à 19:03:25  profilanswer
 :love:
j'ai trouvé le regulateur sur ma bd7II mais sur quel point faut souder la resistance?
j'ai un potar de 10Khom qui traine ça doit pouvoir faire l'affaire?
n°662946
vcentvin51
Posté le 25-11-2002 à 21:17:13  profilanswer
:bounce:
n°663034
neo_
Posté le 25-11-2002 à 21:49:15  profilanswer
 :non: , regarde le schéma, il y a un potar de 100 ohms et une résistance de 10 ohms.
"Je pense qu'avec des 'si' on mettrai une bouteille de butagaz dans le cul de tous les manchots" © LaMite
n°663102
nikopop
凸(`0´)凸
Posté le 25-11-2002 à 22:27:49  profilanswer
Elle n'a pas l'air facile!!! :ouch:
Votre Installation Home-Cinema ici : installations-home-cinema.eu
n°663122
Posté le 25-11-2002 à 22:38:53  answer
mais j'ai trouve quand meme :kaola:
sinon je vais faire un scheme plus simple avec la valeur des resistance etc etc
n°663138
nikopop
凸(`0´)凸
Posté le 25-11-2002 à 22:55:40  profilanswer
Faut pas trembler pour souder!!!!!  :ouch:
n°663144
Posté le 25-11-2002 à 23:01:11  answer
kler
Posté le 25-11-2002 à 23:01:11  profilanswer
n°663145
Posté le 25-11-2002 à 23:01:25  answer
maj des schema en francais en cours
n°663148
Ken
H.P. Lovecraft forever !!!
Posté le 25-11-2002 à 23:05:22  profilanswer
Mais c'est très intéressant dis moi Django ...  :heink:
[:pioupiou]
Croire en Dieu est néfaste à l'émancipation individuelle.   "N'est pas mort ce qui à jamais dort, et au long des siècles peut mourir même la mort" HPL
n°663149
Posté le 25-11-2002 à 23:06:10  answer
[:pioupiou]
aurevoir :heink:
n°663158
Posté le 25-11-2002 à 23:14:47  answer
maj effectuer
Message édité par Profil supprimé le 25-11-2002 à 23:14:53
n°663161
Posté le 25-11-2002 à 23:18:40  answer
pour ceux qui on peur de souder il y a ca
http://membres.lycos.fr/djangolefous69/SMDGrabber_onchip.jpg
n°663177
Ben100g
Posté le 25-11-2002 à 23:45:52  profilanswer
yaisse depuis le temps..... :jap:    bravo en tout cas
j'attends que quelqu'un la fasse pour vérifier et je me lance
http://www.lifl.fr/~courbot/docume [...] ns-fr.html :hello:
n°663186
Posté le 25-11-2002 à 23:58:48  answer
j'ai revendu la carte a cause de ca :cry:
n°663188
akhnotpier​rot
Internaute
Posté le 26-11-2002 à 00:10:43  profilanswer
a ben je sens que je v modder ma bd7 poor mon deuxieme pc :D
apres vous bien enttendu ;)
[HFR] AKHnoT [:akhnotpierrot] Membre de la team [HFR] BattleTeam
n°663288
Ben100g
Posté le 26-11-2002 à 10:13:36  profilanswer
je t'en prie à toi l'honneur....
après du BF1942 avec Vapo ce n'est rien du tout....allons un peu de courage
n°663859
Ken
Posté le 27-11-2002 à 00:01:40  profilanswer
 [:sirjeannot]  :heink:
n°663860
Posté le 27-11-2002 à 00:02:12  answer
:fuck:
n°664360
vcentvin51
Posté le 27-11-2002 à 18:07:36  profilanswer
:fuck:
 :bounce:
n°664361
Posté le 27-11-2002 à 18:08:34  answer
qui a teste alors???
n°664374
vcentvin51
Posté le 27-11-2002 à 18:17:44  profilanswer
moi je le ferais bien mais je vois pas trop ou faut souder le potar et la resistance :??:
j'suis le seul à pas bien voir ou quoi?
car les soudures me paraissent faisable si je savais ou les faire exactement
n°665074
Ken
Posté le 28-11-2002 à 12:32:00  profilanswer
n°671672
Posté le 06-12-2002 à 16:53:33  answer
:bounce:
n°674826
Posté le 10-12-2002 à 11:32:17  answer
c'est le meme vmod que pour la nf7-s  :)
n°695019
@poppof
Posté le 08-01-2003 à 21:17:53  profilanswer
y a qq'un qui a teste cette mod :??:
elle a pas l'air tres simple! :(
n°695025
LaPointe
Roule toujours
Posté le 08-01-2003 à 21:28:57  profilanswer
le vmod tant cherché :lol:
mais bon vu que j'ai une P4PE avec 2.9v :whistle:
LaPointe
n°695475
@poppof
Posté le 09-01-2003 à 15:38:03  profilanswer
:bounce:
n°695478
[DMA] JF
Posté le 09-01-2003 à 15:40:47  profilanswer
Hey c'est cool ca je vais pouvoir avoir plus que 2.65v maintenant  :lol: je testerai sur ma vieille BD7 des qu'elle sera réparée  :sweat:
n°695497
Ben100g
Posté le 09-01-2003 à 16:28:50  profilanswer
elle a quoi...? la mienne se porte comme un charme.. :) ca fait env. 11 mois que je tourne avec :pt1cable:   ca me rappelle ma be6-II...
tu nous donneras un retour sur le mod vu que personne ne l'a testé sur BD7 je crois...
n°695504
[DMA] JF
Posté le 09-01-2003 à 16:47:17  profilanswer
J'ai un régulateur qui est parti en fumée avec une barette de ram  :lol:
Bref faut que je le remplace et ca devrait retourner  :D
n°695508
okelen
Posté le 09-01-2003 à 16:57:00  profilanswer
[DMA] JF a écrit :
 ... en fumée avec une barette ...
Ouuuuh lalaaaa, mais c'est pas bô du tout ça ! Tes parents sont au courant ?
n°695509
LaPointe
Roule toujours
Posté le 09-01-2003 à 16:57:46  profilanswer
 [:xp1700]
tu devrais travailler à la télé/radio :lol:
LaPointe
n°695511
[DMA] JF
Posté le 09-01-2003 à 16:58:06  profilanswer
Oui oui  :whistle:  :lol:
n°893807
Nicodonald
Posté le 11-10-2003 à 19:26:31  profilanswer
quelqu'un a essayé alors ?
n°894394
Nicodonald
Posté le 12-10-2003 à 18:54:01  profilanswer
:bounce:
BE7 et o/c : du grand n'importe quoi!NF7-S/8RDA+ m^m Vddr que la BE7.....
*Topic officiel mobos Epox récentes, Vmod A7N8X, NF7 et 8RDA+*j'trouve pas de T ni de Y
[Tunning] ou je peux trouvé du plexi coloré ??recherche vanne bidirectionnel!!!!!!!! et trouve pas pour du 8/10
question de vmod (+ de 2.25v ?)Chipset i845 PE ? Asus P4 Pe ou Abit Be7 raid ?
Chipset i845 PE ? Asus P4 Pe ou Abit Be7 raid ?Je trouve pas de neon BLEU !
Plus de sujets relatifs à : [BD7 BD7-II BE7] vmod trouve yaisse...
