3694 connectés
  Water & Xtreme Cooling
  [Worklog] Watercoolled Lian-Li PC-V350B - New photos pages 6
 Page :   1  2  3  4  5  6
Page Précédente
n°1865616
Ames974
Posté le 25-03-2009 à 21:53:26  profilanswer
Le toupic de ma bouate :D
Bon, le first poste fera part du projet uniquement à partir de cette config la :o :
Donc petit récap de la config :
Maximus II Gene
Q9550
2x 2Go OCZ Flex XLC
Gainward GTX295 (qui remplace ma 285, et pas WC)
Le matos WC :
MCP655
ModKit + Top Blitspower
EK Multioptions 100ml
Watercool HeatKiller 3.0
Embouts & cie et tubbing TFC
Sur le projet initial, les tof sont sur les première page j'crois :o
MAJ 21/09/09
http://nsm02.casimages.com/img/2009/09/21//090921121823613844492289.jpg
http://nsm02.casimages.com/img/2009/09/21//090921121823613844492290.jpg
http://nsm02.casimages.com/img/2009/09/21//090921121821613844492279.jpg
http://nsm02.casimages.com/img/2009/09/21//090921075238613844497586.jpg
http://nsm02.casimages.com/img/2009/09/21//090921075239613844497587.jpg
http://nsm02.casimages.com/img/2009/09/21//090921075239613844497588.jpg
MAJ 25/09/09
http://nsm02.casimages.com/img/2009/09/25//090925124405613844517844.jpg
http://nsm02.casimages.com/img/2009/09/25//090925124405613844517846.jpg
http://nsm02.casimages.com/img/2009/09/25//090925124405613844517847.jpg
http://nsm02.casimages.com/img/2009/09/25//090925124405613844517848.jpg
http://nsm02.casimages.com/img/2009/09/25//090925124406613844517849.jpg
http://nsm02.casimages.com/img/2009/09/25//090925124406613844517850.jpg
MAJ 24/11/09
http://nsm02.casimages.com/img/2009/11/24//091124053509613844928592.jpg
http://nsm02.casimages.com/img/2009/11/24//091124054048613844928623.jpg
http://nsm02.casimages.com/img/2009/11/24//091124053509613844928594.jpg
http://nsm02.casimages.com/img/2009/11/24//091124053510613844928596.jpg
MAJ 29/04/10
http://lh5.ggpht.com/_txNEw1YnjZA/S9SgLIG8SUI/AAAAAAAAAPk/Kn1xSVfntus/01.jpg
http://lh6.ggpht.com/_txNEw1YnjZA/S9SgNYgEPcI/AAAAAAAAAPo/nxzzyz6bWcQ/02.jpg
http://lh4.ggpht.com/_txNEw1YnjZA/S9SgQlDxgkI/AAAAAAAAAPs/jQWGYC7afz0/03.jpg
http://lh5.ggpht.com/_txNEw1YnjZA/S9SgVuZOGxI/AAAAAAAAAPw/NB93SmGneBE/04.jpg
http://lh4.ggpht.com/_txNEw1YnjZA/S9SgYI4z1PI/AAAAAAAAAP0/zLOqQGprTWA/05.jpg
http://lh3.ggpht.com/_txNEw1YnjZA/S9SgahWkK4I/AAAAAAAAAP4/NScQ4epfU_4/06.jpg
MAJ 30/06/10
http://lh3.ggpht.com/_txNEw1YnjZA/TCuisrXd98I/AAAAAAAAAZE/02LFqyS-OVE/DSC_0032.jpg
http://lh5.ggpht.com/_txNEw1YnjZA/TCuiu2nG8nI/AAAAAAAAAZI/8u68_Wi05kQ/DSC_0033.jpg
http://lh4.ggpht.com/_txNEw1YnjZA/TCuiw18VooI/AAAAAAAAAZM/VLY9ntfz7jI/DSC_0052.JPG
http://lh4.ggpht.com/_txNEw1YnjZA/TCui0vE-KfI/AAAAAAAAAZU/uEOvE1F-rfg/DSC_0062.JPG
http://lh4.ggpht.com/_txNEw1YnjZA/TCui5sEyJEI/AAAAAAAAAZc/cVipIldv0so/DSC_0081.JPG
http://lh4.ggpht.com/_txNEw1YnjZA/TCui3njW-LI/AAAAAAAAAZY/zMuWtVOlXEg/DSC_0075.JPG
http://lh6.ggpht.com/_txNEw1YnjZA/TCui7isUJ6I/AAAAAAAAAZg/L-d6ewafdSQ/DSC_0088.JPG
http://lh3.ggpht.com/_txNEw1YnjZA/TCui9pOFf2I/AAAAAAAAAZk/0qZejsMxhWc/DSC_0091.JPG
http://lh5.ggpht.com/_txNEw1YnjZA/TCui_8rit2I/AAAAAAAAAZo/7vRnxQVpbyE/DSC_0094.JPG
Message édité par Ames974 le 04-07-2010 à 16:14:16
n°1865668
zombiie
Posté le 25-03-2009 à 23:47:01  profilanswer
[:cerveau drapal]
edit : le v350b qui est sur MDPC c'est des toyo en 8/10 :)
Message édité par zombiie le 25-03-2009 à 23:47:59
n°1865671
Ames974
Posté le 25-03-2009 à 23:51:30  profilanswer
Tu vois ça donne l'impression d'être du 10/13 tellement c'est tout confiné. Du 10/13 ça passerai tu penses ? En plus tu m'a dis de passer le chips sous eau, alors en 10/13 je pense que ça va être galère...
Si je suis contraint à passer en 8/10, su penses que ça va casser le débit ?
n°1865677
Cubensia
Men Sana In Corpore Sano
Posté le 25-03-2009 à 23:59:01  profilanswer
La rampage II gene si je ne me gourre pas à la fix S775 et S1334
http://www.puissance-pc.net/images/stories/_cm-cpu-ram/x58/asus_rampage_2_gene_02.jpg
Gagné ;)
Message édité par Cubensia le 25-03-2009 à 23:59:56
Mon Feedback - Mes Ventes - Simplexity 650D
n°1865679
Ames974
Posté le 26-03-2009 à 00:04:42  profilanswer
Ah, c'est à dire que j'ai pas besoin du fix prévu pour installer l'Apogee prévu en 775 sur la CM ! Je savais pas ça, et j'avais pas fais attention !
Message édité par Ames974 le 26-03-2009 à 00:05:01
n°1865687
zombiie
Posté le 26-03-2009 à 00:19:20  profilanswer
tu pourra garder ton block cpu, et pour le 10/13 ca passe :)
 si tu manque de courbe y a des embouts a 45° et du coolsleeve ;)
n°1865689
Ames974
Posté le 26-03-2009 à 00:23:24  profilanswer
Finalement j'aurai le rad240 à prendre, toyo et coude.
Par contre, je cherche toujours comment et où mettre la pompe :/
J'ai oublié de précisé que le rad sera éventuellement un GTS Lite 240. Si vous connaissez mieux et aussi épais je suis ouvert a toutes suggestions :jap:
Message édité par Ames974 le 26-03-2009 à 00:25:19
n°1865692
zombiie
Posté le 26-03-2009 à 00:25:14  profilanswer
dans les baies ?
n°1865693
Ames974
Posté le 26-03-2009 à 00:26:08  profilanswer
La pompe ? Y a de la place ?
Baies 3.5" ? Et le HDD ?
Désolé, mais je me situe pas trop :sweat:
n°1865718
zombiie
Posté le 26-03-2009 à 07:33:38  profilanswer
non dans les 5"
ou le dd dans  les 5" et la pompa a la place des durs
comme celui plus haut
Message édité par zombiie le 26-03-2009 à 07:34:28
n°1865753
Ames974
Posté le 26-03-2009 à 10:56:33  profilanswer
Dans les 5,25, j'avais prévu un graveur+rheobus Zalman ZM-MFC1 Plus.
A la limite, le graveur je peux le zapé, l'utiliser uniquement pour installer Windows...
Si je comprend bien, je devrai dans tous les cas sacrifié quelque chose...
Niveau réservoir, j'ai pour l'instant un XSPC en un baie 5,25. Ce qui pose encore problème :/
Y a moyen de prendre un autre réservoir pour l'intégrer dans le boitier quelque part (ce qui risque d'être dur :/)
Message édité par Ames974 le 26-03-2009 à 10:57:57
n°1865756
SolidShark
PSN: SolidShark
Posté le 26-03-2009 à 11:11:06  profilanswer
Up d'encouragement, vivement qu'on voit ce cube tourner ^^
[ACH] [VDS] [ECH] matos informatique et Consoles, Jeux Video à/pour SolidShark
n°1865758
Ames974
Posté le 26-03-2009 à 11:21:16  profilanswer
n°1865770
Cubensia
Posté le 26-03-2009 à 11:45:13  profilanswer
Tu me donne envie toua c'est pas bien :D
n°1865775
Ames974
Posté le 26-03-2009 à 11:48:35  profilanswer
Revends tout et lance toi :o
C'est ce que j'ai fais :o
Tout balancé : CM, Q9550 et Ram.
Je devrais passé commande sous peu, la semaine prochaine les premiers matos seront là :D
Normalement : Boitier, CM et rheobus.
Après viendra dans la foulé CPU et Ram que j'irai chercher à LDLC Lyon :)
Message édité par Ames974 le 26-03-2009 à 11:50:12
n°1865784
Cubensia
Posté le 26-03-2009 à 12:03:32  profilanswer
Pour ma part çà serait plus sur MFII Gene suis un peu réticent sur les I7 mais bon si elle sort au même prix que la REII Gene .. là je me poserais la question
n°1865787
Ames974
Posté le 26-03-2009 à 12:08:23  profilanswer
ça devrai être moins cher je pense
Là, pour comparaison, la DFI JR x58 est 10€ moins cher sur LDLC que la R2G sur mat.net et Grosbill
Si on prend la DFI P45 qui est à 129€, je pense que la M2G devrai tourner au allentour de 150€ je pense.
n°1866010
Ames974
Posté le 26-03-2009 à 21:20:42  profilanswer
Petit up...
Je suis en trin de réfléchir pour prendre un SSD en 2,5". Déjà, je vais pas investir dans un SSD de fou furieux, j'en ai absolument pas les moyens. Je me dis que ça va être facile à caser, que je pourrais virer la cage à DD pour y mettre la pompe. Enfin, la virer je sais pas vraiment, ou du moins l'installer dedans quoi. Tout dépendra de comment l'agencement des toyo vont être.
Alors, pour le SSD, je pense à OCZ Solid Serie en 30Go, histoire d'installer le Système des les applis. Après viendront mes HDD en externe, j'en que des 2,5", je compte liquider mon 250Go pour me prendre un autre 2,5"...
Mais je connais pas trop les perfs des SSD. Il me semble avoir lu, qu'en lecture c'est du bon, qu'en écriture pas toujours... 90€ les 30Go, ça fait mal, mais au moins c'est facile à caser, et en plus total silence.
Vous en pensez quoi ?
EDIT : moisi on m'a dit sur le toupic des SSD OCZ :/
Message édité par Ames974 le 26-03-2009 à 21:37:48
n°1866081
caillebott​e
Mes raboteurs de parquet sûrs
Posté le 27-03-2009 à 01:48:37  profilanswer
Salut sur la photo c'est du 8/10, prends du 10/13. C'est ce que j'ai dans mon V350 MOD :o
n°1866088
Ames974
Posté le 27-03-2009 à 02:59:25  profilanswer
Dis moi, dans le V350 les deux ventilo en avant sont assez rapproché pour mettre un rad 240 ?
Car, je viens de le remarquer, dans le V351, les deux ventilos sont trop espacé :/
Bah sinon, balance des tof et explique un peu comment ta caser tout le p'tit monde :o
Message édité par Ames974 le 27-03-2009 à 03:00:19
n°1866089
caillebott​e
Posté le 27-03-2009 à 03:16:53  profilanswer
J'ai du faire un peu de bricolage, mais c'est faisable a 100%. Si je retrouve les photos je te MP.  [:clooney17]
n°1866092
caillebott​e
Posté le 27-03-2009 à 03:42:05  profilanswer
Bon j'ai retrouvé les tofs...  [:clooney18]
C'est pas compliqué, dis toi juste que ton boitier va perdre sa garantie et que si tu te loupes, tu devra en racheter un autre et recommencer si tu as la force en toi.  [:clooney20]
Let's go...
Déjà a l'époque seul un rad 240 était compatible avec ce montage, le DOC 240 de chez docmicro.
Tu dois couper cette pièce ainsi car le fait que les ventilos seront moins éloignés donc tu elimines la partie centrale, ainsi l'air passera sans problème...
http://i132.photobucket.com/albums/q25/k-one76/P1010099.jpg
Puis il y a la pièce dévissable où tu fixes les ventilos...
Tu la découpe aussi comme sur la photo. Tu dois dire que je suis fou, hein...  [:clooney11]
http://i132.photobucket.com/albums/q25/k-one76/P1010386.jpg
Oui un peu, mais c'est la solution pour ne pas a devoir refaire une pièce en alu spécialement pour le rad.
Donc tu découpes, une fois que c'est fait. Ces deux pièces viendront a chaque extremité du rad, entre le ventilo et le rad.
C'est pas facile a comprendre comme ça alors schéma de la mort...  [:clooney36]
http://i132.photobucket.com/albums/q25/k-one76/trucdefou.jpg
Voilà...
Si t'es pas un manchot, tu peux espérer te retrouver avec un mod comme celui ci...
http://i132.photobucket.com/albums/q25/k-one76/P1010552.jpg
Questions ?  [:clooney10]
n°1866129
Ames974
Posté le 27-03-2009 à 10:39:45  profilanswer
Merci pour ces precisions :)
J'avais vu ton mod sur toupic v350, mais t'avais plus poster les tofs final après :D
Je me doutait bien de ça, que les ventilos ne soit pas espacé avec la bonne distance pour mettre un 240 :/
Alors, la découpe ne me fait pas peur du tout, j'ai déjà pratiquer, mais gros prob je suis en appart [:ezm]
En plus, j'ai pas de dremel avec moi, et je vais pas investir dans un dremel maintenant, je part en déplacement, mon but était de partir avec une config toute montée, me restant que la mis en eau un fois sur palce. De plus, limité au max le poids, faut pas exploser le budget de la boite :whistle:
Le v351 était vraiment top, il fait 3,6Kg. Pas vu moins lourd parmi les autres boitier Lian-Li ou autres. En plus, il est petit, et même si la place manque cruellement pour du WC, il est tout de même bien pensé, car c'est le seul avec un autre boitier Silverstonne (à ma connaissance) intégrant 2x120 disposé de cette manière, et même un des rare à disposé 2 ventilos de 120mm.
Bref, je voulais me retrouver avec un boitier pou je pourrait d'origine installer un 240 ou 2 rad 120. C'est un peu mort à ce que je vois. J'ai trouver des boitier avec 2 emplacement 120 (y en a pas des masse dans ce gabarit) mais soit il sont trop lourd, soit la disposition du matos à l'intérieur me plait pas, soit le look me plait pas.
Il y en avait un qui me paraissait pas mal, le Silverstone Sugo SG03B, l'autre intégrant 2x120
Il dispose en façade de deux emplacement 120mm modulable, et après avoir regarder plusieurs photos, y a possibilité de mettre un 240. Mais j'aime pas comment est placé l'alim, car c'est un boitier format tour et non cube. Dans un cube, la question se pose pas. Ensuite, une seule baies 5,25". Sinon, poids (3,5Kg) et dimensions à ma convenance, juste plus haut de 10cm, largeur et profondeur plus petites. Mais je vais pas m'aventurer avec ce boitier, pas vu de projet sur cette base, et je crois que l'espace dispos est plus restreint pour y faire un WC.
Les autres boitier, sont un peu plus lourd, et ça démarre à 5Kg environs. En dans ce poids, il y a quelques un (format tour/cube). M'enfin, si je dois prendre un boitier très léger, ça sera V351. Sans faire de modifs (pour le moment) je me demande s'il est possible de fixer qu'un seul ventilo au rails et l'autre ventilo fixer uniquement au rad. J'ai peur que le rad fasse flancher le tout, car il faut emboiter le ventilo avec un système de joint (prévu à l'origine comme système anti anti-vibrations). Après, plus tard, j'effecturai ou non la modif.
Après, pour un boitier de 5kg, je sais pas (le v350 faisant lui 5kg déjà).
Message édité par Ames974 le 28-09-2009 à 08:42:55
n°1866360
caillebott​e
Posté le 27-03-2009 à 17:33:06  profilanswer
Ah aussi j'oubliais, si tu mets un RAD 240, tu ne pourras plus insérer de CG de plus de 23 CM, donc pour NVIDIA c'est mort.  [:clooney19]
Sinon tu n'es pas obligé d'acheter un DREMEL, une scie a métaux et une lime c'est déjà pas mal. J'habitais en appartement depuis la construction du mod, je faisais tout dans la cuisine. Le tout c'est de réfléchir énormement pour ne pas avoir a faire des decoupes pour rien et te faire perdre du temps. Je me souviens encore quand j'ai voulu refaire la pièce pour y fixer le RAD et les ventilos, j'ai été a LEROI MARLIN, je me suis fais chier a reproduire la même pièce  [:clooney14] . Le résultat n'était pas top, et puis j'ai eu l'idée de découper la pièce d'origine, c'était la solution...  [:clooney8]
Donc t'inquètes c'est faisable...  [:clooney7]
n°1866362
caillebott​e
Posté le 27-03-2009 à 17:39:50  profilanswer
J'ai vu que tu comptes WCooler CPU etGPU, normalement tu n'aura pas besoin de coudes, à l'époque j'avais le CPU, NB et GPU en WC et aucun coude...  [:clooney3]
Faut que tu sois en harmonie avec les toyos, faut jouer avec voir les formes qu'il peut prendre, mais tout dépend de l'emplacement de ta pompe.  [:clooney21]
n°1866370
Ames974
Posté le 27-03-2009 à 17:44:42  profilanswer
Ah j'ai pas penser à la scie à métaux :D
Bon, déja le soucis c'est que moi je compte prendre le v351, et la plaque n'est pas pareil. De deux, j'ai peur qui fasse que je dérive la plaque...
Oui je sais, y a le v350, mais 5Kg, pas négligeable pour moi...
Concernant la CG, c'est HD4870, je sais pas combien elle fait, faut que je mesure pour voir... Car sinon, c'est mort...
PS : t'aime bien Clooney toua :D
EDIT : Si je part sur la base R2G, y aura normalement CPU/CG/NB. Oui, car je suis en trin de réfléchir si le passage en i7 est vraiment judicieux en ce moment, et d'autant plus que le mec qui devait prendre mon Q9550 a annulé. Donc, en cours de grosse réflexion intensive.
EDIT 2 : faut bien percer la/les plaques ? La scie seulle suffirai pas.
Message édité par Ames974 le 27-03-2009 à 17:48:33
n°1866377
caillebott​e
Posté le 27-03-2009 à 17:53:30  profilanswer
Si tu as des photos de l'interieur ce serait pas mal...
Je crois que c'est 23-24 CM, comme la HD4850, je disais ça car les cartes de chez NVIDIA sont énormes
Message édité par caillebotte le 27-03-2009 à 17:54:04
n°1866386
caillebott​e
Posté le 27-03-2009 à 18:03:52  profilanswer
Pour le reste, je ne sais pas ce que c'est que le R2G, a moins que j'ai oublié... Mais si tu achètes tes bloc tu sera condamné a rester dans cette voie, alors réflxion mon ami. Par exemple je veux aussi partir sur du i7, ça devrait etre simple vu que mon MOD est déja fait mais il y a les blocs a racheter, et e ne compte même pas le prix du matos (CM, RAM, CPU)... [:clooney11]  Le truc c'est que j'ai trop de passions et un loyer + factures a payer... [:clooney30]
Oui j'aime les Clooney.  [:clooney21]
n°1866390
Ames974
Posté le 27-03-2009 à 18:09:47  profilanswer
http://hfr-rehost.net/lian-li.com/v2/tw/product/upload/image/V351/v351-11.jpg
http://hfr-rehost.net/lian-li.com/v2/tw/product/upload/image/V351/v351-18.jpg
http://hfr-rehost.net/lian-li.com/v2/tw/product/upload/image/V351/v351-24.jpg
R2G : Asus Rampage II Gene, la carte µATX i7. J'ai déjà tous les block, je tourne sur ma config actuelle en WC. Le block NB que j'ai sur ma M2F est compatible aussi sur la R2G.
Moi si je passe en i7, je balance CPU/CM/RAM. Faudra investir en plus certes, mais ça soulage un peu.
Message édité par Ames974 le 30-03-2009 à 21:40:09
n°1866397
caillebott​e
Posté le 27-03-2009 à 18:35:05  profilanswer
AH ouais je comprends mieux ce que tu voulais dire en voyant les phots, en fait ils ont viré la pièce. Faut que je refléchisse.  [:clooney3]
n°1866453
noobzed
Where is Brian ? DTC !
Posté le 27-03-2009 à 20:35:52  profilanswer
et cay tout ?
FEEDBACK HFR
n°1866456
Ames974
Posté le 27-03-2009 à 20:37:18  profilanswer
n°1866462
noobzed
Posté le 27-03-2009 à 20:50:13  profilanswer
t'as besoin de gaine tressée et thermo de premier choix ?
j'ai un kit murder-mod quasi complet en rab à vendre ;)
FEEDBACK HFR
n°1866463
Ames974
Posté le 27-03-2009 à 20:54:50  profilanswer
ah bien :D
je suis très intéressé effectivement [:goret]
il est vraiment au complet de chez complet ?
EDIT : quasi complet :D
manque quoi ?
Message édité par Ames974 le 27-03-2009 à 20:55:07
n°1866482
noobzed
Posté le 27-03-2009 à 21:55:42  profilanswer
non pas complet, en gros je vais utiliser un peu de gaine pour un ou deux sata, j'ai pris un peu de gaine pour faire mon pci express et puis c a peu pres tout, donc il va en rester 90% je pense, par exemple je sias pas de quelle maniere tu compte gainer, mais si c'est fil par fil pour l'alim par ex, bah le rouleau de gaine de petite diametre fil par fil est complet a 100% ;=)
FEEDBACK HFR
n°1866486
Ames974
Posté le 27-03-2009 à 22:21:56  profilanswer
je vais gainer fil par fil mes 2 pcie. Pour l'alim je sais pas encore, j'ai une partie de l'alim qui est gainé (tout les fil dans une même gaine), je sais pas si je refais tout ou si je gaine fil par fil juste la partie visible. Je compte gainé tout les fil boitier, et 2 sata.
Message édité par Ames974 le 27-03-2009 à 22:22:12
n°1866487
noobzed
Posté le 27-03-2009 à 22:25:35  profilanswer
alors mon kit a 90% complet te suffiras amplement,
par contre j'ai payé 50€ in pour l'avoir, donc ca sera
vraisemblablement danc les 40 - 45 in, apres a toi de
voir si tu px te permettre un budget important pour la gaine,
ceci dit fait une recherche sur le net, tu veras que la gaine
du kit murdermod est la meilleure sur le marché ;) voili voilou
FEEDBACK HFR
n°1866494
caillebott​e
Posté le 27-03-2009 à 22:34:45  profilanswer
Je ne vois pas du tout comment bricoler ce 351, enfin mais ça deviendrait trop compliqué là sauf si tu mets un RAD 120 ce qui n'est pas envisageable....  [:clooney23]
En gors il faudrait que tu arrives a refaire la pèce du V 350 mais adaptable sur le V 351, truc de fou quoi. Si tu n'as pas de DREMEL c'est mort.
Prends un 350 !  [:clooney36]  Je sais bien que ce sera plus lourd mais pour du WC ce sera plus simple.
n°1866496
Ames974
Posté le 27-03-2009 à 22:45:38  profilanswer
bah je comptait en commandé le kit murdermod, et je connais la réputation des produit ;)
Par contre, si tu peux me le garder, le moi prochain c'est sur et certains que je prend, déjà que ce mois je suis carrément hors budget avec les dépenses que m'occasionne mon futur déplacement...
je réfléchi encore, j'attends que tout soit bouclé avec la DRH pour savoir se que je peux faire pour emporter des affaire. De toute façon, mon directeur d'agence est ok pour faire rembourser le poids sup, ou si y a autre solution il est ok (il nous a jamais rien refusé ce bon bonhomme). Après, la DRH&cie c'est autre chose... Je pense pas qu'il refuse, mais je sais pas à hauteur de combien de poids sup je serai remboursé. Et pour les bagage spéciaux, j'me souvient comment j'avais fais une fois pour faire voyager un ecran :D
Donc, je sais bien que le v351 ça va être plus galère, si j'ai assez de poids sup, il se peut que j'envisage même de prendre un boitier un peu plus grand pour avoir encore plus de facilité pour intégrer.
Message édité par Ames974 le 27-03-2009 à 22:46:23
n°1867414
SolidShark
PSN: SolidShark
Posté le 30-03-2009 à 21:36:01  profilanswer
Ames974 a écrit :
http://hfr-rehost.net/http://lian- [...] 351-11.jpg
http://hfr-rehost.net/http://lian- [...] 351-18.jpg
http://hfr-rehost.net/http://lian- [...] 351-24.jpg
Edit ton message et ajouter devant chaque photo ça (je te l'ai fait sur les 3 dans ton message):
Ca donne ça (ça chargera l'image plus rapidement ^^):
Message édité par SolidShark le 30-03-2009 à 21:37:20
 Page :   1  2  3  4  5  6
Page Précédente
Vanessa Tree : dissipateur home made maj: photos et testsMon nouveau PC
[MOD] Apple Powermac G5 <Terminé !>Question montage WC dans un Lian-Li V1000Z
New watercooling : problème température CPUIntegration dans un mini PC, grosse config et tofs inside MAJ n°2
PC @stock neuf - Petite Optimisationchanger le ventilo pour PC portable
[Mod CM] PC-DL & FSB800 ?
Plus de sujets relatifs à : [Worklog] Watercoolled Lian-Li PC-V350B - New photos pages 6
