1284 connectés
 Page :   1  2  3  4  5  ..  975  976  977  978  979  980
OCCT : Mise à jour du site pour halloween et déménagement :)
n°2596085
Tetedeienc​h
Head Of God
Posté le 06-05-2024 à 12:00:30  profilanswer
absolumentpasbultom a écrit :
Je sais pas si ca avait été remonté
Mais avec la beta 13, a chaque fois que je veux utiliser la fonction "Save report" j'ai OCCT qui plante
Avec un bon "ne répond pas" dans la barre de titre et après quelque instant
https://rehost.diberie.com/Picture/Get/f/273598
Je vais fixer, merci :)
L'ingénieur chipset nortiaux : Une iFricandelle svp ! "Spa du pâté, hin!" ©®Janfynette | "La plus grosse collec vivante de bans abusifs sur pattes" | OCCT v12 OUT !
n°2596140
Tetedeienc​h
Head Of God
Posté le 09-05-2024 à 10:49:16  profilanswer
:hot: OCCT 13.0.0 OUT ! :hot:
Changelog :
  • Main : Revamped the communication between the test for reactivity and robustness. It also paves the way for the upcoming Linux edition
  • Main : Introducing the "Combined" test allowing you to launch several tests in parallel - some make a lot of sense, some don't ( Running CPU and Memory at the same time is a BAD idea as they will compete for resources - using CPU + RAM is advised )
  • Main : Greatly improved OCCT's startup time, especially on older setups
  • Main : OCCT will now do its best to work around some silly antivirus locking temp files or purging them before use.
  • Ui : Updated the underlying technology of the UI ( Major update if there's any ) which led us to reimplement a lot of stuff - paving the way for the future. CPU Usage of the UI is lower than ever
  • Ui : Updated brand identity and looks for the UI, to reflect our new brand identity. OCCT has never been looking so amazing !
  • Ui : You can now chose between Direct3D and OpenGL as a renderer option. Direct3D is the default, but suffers from flickers with Nvidia cards due to a bug in either Nvidia drivers or Windows that hasn't been fixed for more than a year now. It's the same bug as Chrome. You can switch to OpenGL to avoid those, but the UI will use more RAM sadly.
  • Monitoring : Updated Monitoring Engine
  • Monitoring : Added VRAM usage support to the top monitoring bar
  • Monitoring : Fixed : You can now disable the "Physical memory used" sensor in the table
  • Settings : Coolermaster collaboration ended sadly - the option for the coolermaster skin has been removed and won't be present in v13 anymore. Maybe it will come back in the future !
  • Cpu : Split the CPU test to CPU and CPU+RAM ( CPU Small (v12) => CPU (v13), CPU Medium and Large (v12) => CPU + RAM (v13)). This is to better outline which component the test is actually testing
  • MemoryBenchmark : Introduced a new mode for the Latency & Bandwidth benchmark, testing a lot of different data set points, going up to 1GB. You'll now have full curves for identifying breakpoints !
  • Report : Major update to the HTML report : graphics, technology, memory used
  • Report : The HTML report graph tooltip will now properly report values exactly at the hovered point ( previous hovers were off by a few points )
  • Report : Fixed a memory leak that could occur in the HTNL report when comparing
Enjoy !
https://www.ocbase.com
n°2596141
Tetedeienc​h
Head Of God
Posté le 09-05-2024 à 10:53:54  profilanswer
OK les gars. On y est. 9 mois de taff bordel. 9 MOIS DE TAFF EN PROD.
Nouvelle identité
On a refondu l'identité d'OCCT, le logo, le site, bref, tout. Putain que c'est beau. On est si loin des débuts !
allez voir https://www.ocbase.com . J'en reviens pas moi même.
OCCT v13 stable
Une sacrée release avec ;
  • le test combined, permettant dfe lancer n'importe quel test OCCT en parallèle. 3D adaptive + Vram + memory ? No problem !
  • le nouveau test latence/memoire, super précis, vous fournissant un graphe exact des performance de votre mémoire
En surprise, on a refondu l'apparence d'OCCT :) C'est risqué à mort, mais on voulait jouer :)
ON VA AU COMPUTEX BORDEL
Oui, vous avez bien lu : OCCT au computex ! On va dévoiler OCCT Enterprise + là bas, une solution pour les fabricants de prebuilts, assembleurs, et tout et tout.
OCCT à Taipei, qui l'aurait cru bon sang !
On aura notre propre stand au même étage que AMD et Nvidia et co :D Bon, OK, on est plus petit, mais OSEF, bon sang, ON Y EST !
Putain, ce rêve de geek devenu réalité les gars :) Que de chemin parcouru !
n°2596142
dje33
57 BUTS !!!
Posté le 09-05-2024 à 11:01:15  profilanswer
Félicitations. Je me souviens des premières versions  [:adodonicoco]
J'espère que tu auras le temps de faire du tourisme à Taipei. La ville est sympa, il y a de très bon resto.
n°2596144
skyzo-appl​e
Posté le 09-05-2024 à 11:11:09  profilanswer
Woa félicitation pour le computex, bien stylé  :love:
Sympa le nouveau logo/site  :)
n°2596145
arkrom
note, ca passait c'etait beau
Posté le 09-05-2024 à 11:21:59  profilanswer
Félicitations
Sacré boulot et sacrées progrès, toujours plus beau,  toujours plus chaud,  toujours plus exigeant  :sol:  OCCT mérite son stand
n°2596146
Tetedeienc​h
Head Of God
Posté le 09-05-2024 à 11:35:46  profilanswer
Merci les gars :)
On lache rien, et surtout, on se perd pas en chemin. Community first ! :) :)
n°2596148
Xixou2
Posté le 09-05-2024 à 12:39:32  profilanswer
Nouvelle identité
OCCT v13 stable
FANTASTIQUE!!!!!!!!!!!!!
J'aime le rouge plus pétant.
Le GUI est super responsive now.
Message édité par Xixou2 le 09-05-2024 à 12:47:11
n°2596150
Xixou2
Posté le 09-05-2024 à 12:41:12  profilanswer
Ha, quand je click sur le dash board ( https://www.ocbase.com/account/dashboard ) en haut à droite avec chrome  j'ai ce message:
Application error: a client-side exception has occurred (see the browser console for more information).
Message édité par Xixou2 le 09-05-2024 à 12:42:19
n°2596151
Tetedeienc​h
Head Of God
Posté le 09-05-2024 à 12:54:52  profilanswer
Essaie de te délogguer/relogguer ?
n°2596155
G-LOC
Mais je vais bien, hein.
Posté le 09-05-2024 à 13:45:18  profilanswer
Nouvelle identité
OCCT v13 stable
Clairement, le nouveau style visuel fait très pro  [:moonblood2:3]
Et j'allais oublier, le COMPUTEX :ouch: :sol:
Message édité par G-LOC le 09-05-2024 à 13:46:44
>> ACHATS/VENTES >> FEEDBACK
n°2596156
burn2
ça rox du poney
Posté le 09-05-2024 à 13:48:30  profilanswer
Nouvelle identité
OCCT v13 stable
Effectivement c'est beau!!!
Bravo pour tout le taf et sympa pour le computex!!!   :wahoo:
n°2596157
Xixou2
Posté le 09-05-2024 à 13:52:54  profilanswer
oui ça fonctionne.
A propos, tu indiques login by email or patreon.
En fait je choisis by email mais je rentre mon pseudo et pas mon email ^^
Message édité par Xixou2 le 09-05-2024 à 13:53:26
n°2596158
Tetedeienc​h
Head Of God
Posté le 09-05-2024 à 16:43:18  profilanswer
:jap: :jap: :jap:
Xixou2 a écrit :
oui ça fonctionne.
C'est vrai :D Mais la page de login est chiante à souhait à modifier, donc ben... :ange:
n°2596181
astrojojo
Editeur compulsif
Posté le 10-05-2024 à 12:04:49  profilanswer
GG pour tout ce taf, GG pour cette V13, et GG pour le computex  :love:  !!!
n°2596182
Tetedeienc​h
Head Of God
Posté le 10-05-2024 à 14:16:43  profilanswer
:love:
n°2596205
absolument​pasbultom
It's Not A Loop, It's A Spiral
Posté le 11-05-2024 à 08:57:38  profilanswer
Tout frais payé j'espère le voyage :o
Mais joli taff :jap:
Les HDD c'est dans les NAS :fou:
n°2596240
DayWalker ​II
Posté le 13-05-2024 à 08:18:50  profilanswer
Félicitations pour le computex : c'est un peu une officialisation bien méritée pour cet outil formidable !
Franchement, ce couteau suisse du test de stabilité est largement inégalé : c'est donc chouette d'atteindre une visibilité et une reconnaissance qui en est digne.
n°2596257
Xixou2
Posté le 13-05-2024 à 20:44:33  profilanswer
Manque plus que le bench disques.
n°2596554
muzah
Bal Musette @ HFR depuis 1997
Posté le 30-05-2024 à 17:35:19  profilanswer
https://www.youtube.com/watch?v=kfqPVFSSQLQ Spa encore Ballmer mais un peu de sueur sous les bras et c'est bon :o
n°2596555
w00t w00t
RUSH B, Cyka Blyat !
Posté le 30-05-2024 à 17:44:22  profilanswer
Quel bel accent Mr iench  :whistle:  :sol:
INTEL Core i7 14700K @ 5,70Ghz - CORSAIR Vengeance RGB PRO @ 2035Mhz CL16 - EVGA RTX 3080 Ti FTW3 ULTRA @ 2055Mhz
n°2596556
Posté le 30-05-2024 à 17:48:43  profilanswer
Le nouveau Yves Guillemot [:ojap]
n°2596557
Xixou2
Posté le 30-05-2024 à 17:49:09  profilanswer
La belle musique relax ^^
Couleurs des lunettes comme OCCT ^^
Le iench patron, c'est fait ^^
Même pas peur:
https://zupimages.net/up/24/22/r2os.png
Message édité par Xixou2 le 30-05-2024 à 17:53:30
n°2596559
jonas
c'est mon identité
Posté le 31-05-2024 à 09:20:09  profilanswer
putain l'accent du iench [:ddr555]
et voilà
n°2596562
Xixou2
Posté le 31-05-2024 à 12:07:04  profilanswer
ça fait son charme ^^
n°2596633
Tetedeienc​h
Head Of God
Posté le 04-06-2024 à 15:36:11  profilanswer
n°2596634
Tetedeienc​h
Head Of God
Posté le 04-06-2024 à 15:52:52  profilanswer
J'ai qu'une chose a dire : NOM DE ZEUS
https://www.ocbase.com/misc/computex2.jpg
https://www.ocbase.com/misc/computex1.jpg
On a une tonne de monde sur le stand, je me fais arrêter en permanence par des fans, c'est assez dingue.
Je croise des grosses légendes : derbauer, skatterbencher, Martin de HwInfo, Steve de GN ... C'est dingue ! Crevant, mais dingue.
Putain les gars quelle aventure !
n°2596636
matthiman
de Gilead
Posté le 04-06-2024 à 16:21:07  profilanswer
profites à fond !  [:al_bundy]
Ventes - Feedback
n°2596637
lagaffe67
Posté le 04-06-2024 à 17:17:11  profilanswer
gg tetedeiench :o
Topic Vente Hardware
n°2596638
bitubo
GT Turbo Addict
Posté le 04-06-2024 à 17:58:51  profilanswer
GG
le stand est stylé aussi :sol:
:d
Watercooling CPU+GPU, i9 9900KF @4.9Ghz, 32Go Ddr4 3200Mhz Dual, RTX 4070Ti
n°2596640
astrojojo
Editeur compulsif
Posté le 04-06-2024 à 19:53:01  profilanswer
Félicitations, tu mérites tout ça :jap:
Profites-en bien !
n°2596641
MacIntoc
tu lis une phrase formidable.
Posté le 04-06-2024 à 20:13:56  profilanswer
Je sais pas qui a designé le stand mais il est magnifique :o
Je pense donc tu suis. Crois moi, je suis zététicien.
n°2596642
Moonly
Ready? Let's dance!
Posté le 04-06-2024 à 20:52:54  profilanswer
Le stand est super class, et on est tellement fier de toi, de ton travail, du parcours !
Merci de partager ça avec nous ici et de nous offrir le meilleur outil de stress informatique. ;)
Je m'exprime très rarement parce que je fais partie de la masse silencieuse, mais dans cette masse, tu as des gens comme moi qui suivent et apprécient beaucoup, sans forcément l'exprimer fort et/ou souvent.
Bref, bravo et bonne continuation. :)
| Créateur de feu PC-Updates.fr | Ardent défenseur des formats 21:9 & 16:10 | Ma chaîne YouTube : gameplay de jeux vidéo exclusivement PC |
n°2596643
quentincc
It's all ogre now
Posté le 04-06-2024 à 21:09:29  profilanswer
n°2596644
burn2
ça rox du poney
Posté le 04-06-2024 à 21:17:22  profilanswer
+1 clairement!
Félicitation, respect pour le travail abattu pour en arriver là.
Et Bravo pour le stand qui oui clairement est super!  :jap:
n°2596645
lagaffe67
Posté le 04-06-2024 à 21:22:42  profilanswer
quentincc a écrit :
t'as même pas caché un redface quelque part ? :o
+1 :o
n°2596650
phardfr
Posté le 05-06-2024 à 12:35:14  profilanswer
lagaffe67 a écrit :
gg tetedeiench :o
+1 et en +, c'est un voisin le iench... :)
Note à moi-même: renouveler mon support à occt... :o
ASUS TUF X670-E Gaming Wifi - Ryzen 5 7600X - 32 Go CORSAIR Vengeance 6000 C30 - XFX Merc 319 6800 XT - Win11/Linux
n°2596651
Tetedeienc​h
Head Of God
Posté le 05-06-2024 à 16:58:01  profilanswer
OCCT sur le stand Gskill toute la journée pour le World record d'overclocking
https://i.ibb.co/HV2sqvm/PXL-20240605-044203925-MP.jpg
https://i.ibb.co/crCt1Fd/PXL-20240605-035235163-MP.jpg
n°2596652
Xixou2
Posté le 05-06-2024 à 17:04:54  profilanswer
De toute beauté ton stand! Gg
n°2596667
Tetedeienc​h
Head Of God
Posté le 08-06-2024 à 08:22:29  profilanswer
Salon fini, je suis sur les rotules. Par contre putain j'imaginais même pas ça dans mes rêves les plus fous.
Le nombre incroyable de monde, pro, particuliers, journalistes, qui m'ont remercié pour OCCT car l'outil leur est utile est hallucinant. On est bien connus maintenant, y a pas de problème.
Y a eu tellement de choses, tellement de contacts, et tout le monde est sympa.
Je me rendais pas compte que OCCT est un passe pour rentrer un peu partout au final.
Je sais pas trop comment décrire ça sans paraître prétentieux en fait. J'étais un gusse lambda qui s'est retrouvé avec un traitement de petite star parfois. Hallucinant.
J'ai tellement fait d'anglais que j'ai du mal a retrouver mon français bordel.
Message édité par Tetedeiench le 08-06-2024 à 08:23:45
n°2596668
SynE
Posté le 08-06-2024 à 08:26:16  profilanswer
Avoue que ça a plu à ton gros ego de iench :o
Félicitation, depuis le temps que tu t'investis la dessus, tu mérites d'être reconnu, tu fais un produit super et suivi. :)
Pkoi mon PC devient tres lent des que le disque dur travailleMoi j'appelle ça du travaille d'orfèvrerie ...
Plus de sujets relatifs à : OCCT : Mise à jour du site pour halloween et déménagement :)
