6027 connectés
  Linux et OS Alternatifs
  Logiciels
  [debian sid] Problème rage128pro et xfree 4.3
n°620990
XK
Posté le 16-01-2005 à 15:15:31  profilanswer
Je n'arrive pas à faire fonctionner correctement xfree avec une rage128pro et un écran LCD L1920P (19" 1280*1024).
Voici mon XF86Config-4
Section "Files"
 FontPath "unix/:7100"   # local font server
 # if the local font server has problems, we can fall back on these
 FontPath "/usr/lib/X11/fonts/misc"
 FontPath "/usr/lib/X11/fonts/cyrillic"
 FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/Type1"
 FontPath "/usr/lib/X11/fonts/CID"
 FontPath "/usr/lib/X11/fonts/Speedo"
 FontPath "/usr/lib/X11/fonts/100dpi"
 FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
 Load "GLcore"
 Load "bitmap"
 Load "dbe"
 Load "ddc"
 Load "dri"
 Load "extmod"
 Load "freetype"
 Load "glx"
 Load "int10"
 Load "record"
 Load "speedo"
 Load "type1"
 Load "vbe"
EndSection
Section "InputDevice"
 Identifier "Generic Keyboard"
 Driver  "keyboard"
 Option  "CoreKeyboard"
 Option  "XkbRules" "xfree86"
 Option  "XkbModel" "pc104"
 Option  "XkbLayout" "fr"
EndSection
 Identifier "Configured Mouse"
 Driver  "mouse"
 Option  "CorePointer"
 Option  "Device"  "/dev/input/mice"
 Option  "Protocol"  "ImPS/2"
 Option  "Emulate3Buttons" "true"
 Option  "ZAxisMapping"  "4 5"
EndSection
Section "Device"
 Identifier "ATI Rage128 Pro"
 Driver  "ati"
EndSection
Section "Monitor"
 Identifier "LG Flatron L1920P"
 HorizSync 30-83
 VertRefresh 56-75
 Option  "DPMS"
EndSection
Section "Screen"
 Identifier "Default Screen"
 Device  "ATI Rage128 Pro"
 Monitor  "LG Flatron L1920P"
 DefaultDepth 24
 SubSection "Display"
  Depth  16
  Modes  "1280x1024" "1024x768" "800x600" "640x480"
 EndSubSection
  Depth  24
 EndSubSection
EndSection
Section "ServerLayout"
 Identifier "Default Layout"
 Screen  "Default Screen"
 InputDevice "Generic Keyboard"
 InputDevice "Configured Mouse"
EndSection
Section "DRI"
 Mode 0666
EndSection
Xfce4 se lance en 1280*1024 mais je trouve le log de Xfree étrange, normal ou pas ? :
(EE) R128(0): No DFP detected
(II) R128(0): LG Flatron L1920P: Using hsync range of 30.00-83.00 kHz
(II) R128(0): LG Flatron L1920P: Using vrefresh range of 56.00-75.00 Hz
(II) R128(0): Clock range:  12.50 to 400.00 MHz
(II) R128(0): Not using default mode "640x350" (vrefresh out of range)
(II) R128(0): Not using default mode "320x175" (vrefresh out of range)
(II) R128(0): Not using default mode "640x400" (vrefresh out of range)
(II) R128(0): Not using default mode "320x200" (vrefresh out of range)
(II) R128(0): Not using default mode "720x400" (vrefresh out of range)
(II) R128(0): Not using default mode "360x200" (vrefresh out of range)
(II) R128(0): Not using default mode "640x480" (vrefresh out of range)
(II) R128(0): Not using default mode "320x240" (vrefresh out of range)
(II) R128(0): Not using default mode "800x600" (vrefresh out of range)
(II) R128(0): Not using default mode "400x300" (vrefresh out of range)
(II) R128(0): Not using default mode "1024x768" (vrefresh out of range)
(II) R128(0): Not using default mode "512x384" (vrefresh out of range)
(II) R128(0): Not using default mode "1280x960" (hsync out of range)
(II) R128(0): Not using default mode "640x480" (hsync out of range)
(II) R128(0): Not using default mode "1280x1024" (hsync out of range)
(II) R128(0): Not using default mode "640x512" (hsync out of range)
(WW) (1600x1200,LG Flatron L1920P) mode clock 162MHz exceeds DDC maximum 140MHz
(WW) (1600x1200,LG Flatron L1920P) mode clock 175.5MHz exceeds DDC maximum 140MHz
(II) R128(0): Not using default mode "1600x1200" (hsync out of range)
(II) R128(0): Not using default mode "800x600" (hsync out of range)
(WW) (1792x1344,LG Flatron L1920P) mode clock 204.8MHz exceeds DDC maximum 140MHz
(II) R128(0): Not using default mode "1792x1344" (hsync out of range)
(II) R128(0): Not using default mode "896x672" (hsync out of range)
(II) R128(0): Not using default mode "1856x1392" (hsync out of range)
(II) R128(0): Not using default mode "928x696" (hsync out of range)
(II) R128(0): Not using default mode "1920x1440" (hsync out of range)
(II) R128(0): Not using default mode "960x720" (hsync out of range)
(II) R128(0): Not using default mode "1152x768" (vrefresh out of range)
(II) R128(0): Not using default mode "576x384" (vrefresh out of range)
(WW) (1400x1050,LG Flatron L1920P) mode clock 155.8MHz exceeds DDC maximum 140MHz
(II) R128(0): Not using default mode "2048x1536" (hsync out of range)
(II) R128(0): Not using default mode "1024x768" (hsync out of range)
(II) R128(0): Not using default mode "1792x1344" (width too large for virtual size)
(II) R128(0): Not using default mode "1600x1200" (width too large for virtual size)
(II) R128(0): Not using default mode "1400x1050" (width too large for virtual size)
(--) R128(0): Virtual size is 1280x1024 (pitch 1280)
De plus l'AGP ne fonctionne pas alors que le module a bien été compillé et agpgart est bien chargé lorsque je lance X, dans le log j'ai :
(WW) R128(0): [agp] AGP not available
(WW) R128(0): [agp] AGP failed to initialize -- falling back to PCI mode.
(WW) R128(0): [agp] Make sure you have the agpgart kernel module loaded.
Je ne comprends pas tout ces problèmes, si vous pourriez m'éclairer ça m'aiderai bp :hello:
Message édité par XK le 16-01-2005 à 15:29:52
n°621236
bunyman
Posté le 16-01-2005 à 19:30:18  profilanswer
On dirait que Xfree essai de frequence et résolution qui ne sont pas dans ton XF86config-4, es-tu sur que c'est bien le bon fichier, et que tu n'a pas un autre fichier de conf qui traine ?  Essai de reconfiguré ton serveur X avec
dpkg-reconfigure xserver-xfree86
Sinon essai d'installer X.org. Des paquet on été fait par buntu.
Pour otn problèem d'agp que te donne un lsmod ? Ta compilé agpgart en dur ou en module ? quel est ton chipset ?
n°622027
XK
Posté le 17-01-2005 à 21:14:29  profilanswer
je ne sais pas pour quelle raison il teste toutes ces fréquences, elles ne sont pas spécifiées dans le fichier de config.
j'ai déjà fais "dpkg-reconfigure xserver-xfree86" plusieurs fois mais rien d'anormal...
j'avais compilé agpgart en dur dans le noyau avec le module du 440BX (chipset de la carte mère) mais ça ne fonctionnait pas. J'ai envuite compilé en module agpgart.
<M> /dev/agpgart (AGP Support)
  < >   ALI chipset support
  < >   ATI chipset support
  < >   AMD Irongate, 761, and 762 chipset support
  < >   AMD Opteron/Athlon64 on-CPU GART support
  <M>   Intel 440LX/BX/GX, I8xx and E7x05 chipset support
  < >   Intel i865 chipset support
  < >   NVIDIA nForce/nForce2 chipset support
  < >   SiS chipset support
  < >   Serverworks LE/HE chipset support
Je l'ai chargé avec modprobe, il apparait dans lsmod
# lsmod
Module                  Size  Used by
agpgart                34472  0
r128                  109092  0
mais
est tjr dans le log :heink:
de plus xfce ne se lance que en root et pas en utilisateur simple, pourquoi? :??:
n°622419
XK
Posté le 18-01-2005 à 15:39:52  profilanswer
up
n°622499
goldyfruit
Je me lève et je confirme !
Posté le 18-01-2005 à 18:18:46  profilanswer
Code :
  1. <*> /dev/agpgart (AGP Support)
  2.   < >   ALI chipset support
  3.   < >   ATI chipset support
  4.   < >   AMD Irongate, 761, and 762 chipset support
  5.   < >   AMD Opteron/Athlon64 on-CPU GART support
  6.   <*>   Intel 440LX/BX/GX, I8xx and E7x05 chipset support
  7.   < >   Intel i865 chipset support
  8.   < >   NVIDIA nForce/nForce2 chipset support
  9.   < >   SiS chipset support
  10.   < >   Serverworks LE/HE chipset support
Tu as essayé comme ca ?
Et pour xfce tu as ajouté ton user au groupe video ?
Message édité par goldyfruit le 18-01-2005 à 18:19:34
https://openvoiceos.org | https://github.com/orgs/smartgic/
n°622514
XK
Posté le 18-01-2005 à 18:58:05  profilanswer
effectivement ça fonctionne comme ça, j'avais la flème de tester mais finalement il n'y a que ça qui marche! merci :jap:
n°622518
goldyfruit
Posté le 18-01-2005 à 19:03:29  profilanswer
n°622567
XK
Posté le 18-01-2005 à 20:51:47  profilanswer
par contre la souris est très très lente et saccadée... tu as une idée?
n°622616
goldyfruit
Posté le 18-01-2005 à 22:02:47  profilanswer
Hum regarde dans ton XF86Config au niveau de la section souris tu as une valeur avec "false" remplace la par "true" je vois que ca :/
  Logiciels
Problème de droit sur une partition montéeprobleme de download de pdf en pieche jointe - webmail sous linux
Probleme reseau Gigabit[Debian] Kernel-headers du noyau 2.4.28
[Resolu]Problème INEDIT, drivers pour carte nVidia "No screens found"[qmail]probleme
Probléme de configuration Postfix + ldap + maildropproblmem d'installation débian LVM+GRUB
[Résolu] Etrange Problème avec xfce 4.2 RC3[Help] A l'attention de Monsieur Leneuf - Debian et armes à feu
Plus de sujets relatifs à : [debian sid] Problème rage128pro et xfree 4.3
