11350 connectés
 Page :   1  2  3
Page Suivante
quel version de linux installer ?
n°1188227
thana54
made in concept
Posté le 27-12-2009 à 13:25:46  profilanswer
enlève le "1." :o
n°1188230
loan__
Posté le 27-12-2009 à 13:32:32  profilanswer
g tape ça smartctl -x /dev /sda        il a fallu que j'installe le programme smartctl
ensuite j'ai rerentre la coomande mais il m a demande de remplacé x par h
j'ai obtenu ça comme résultat
=======> UNRECOGNIZED OPTION: x   <=== ,option x non reconnu
Use smartctl -h to get a usage summary
vostro1400@vostro1400-laptop:~$ smartctl -h /dev/sda
smartctl version 5.38 [x86_64-unknown-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
Usage: smartctl [options] device
============================================ SHOW INFORMATION OPTIONS =====
  -h, --help, --usage
         Display this help and exit
  -V, --version, --copyright, --license
         Print license, copyright, and version information and exit
  -i, --info
         Show identity information for device
  -a, --all
         Show all SMART information for device
================================== SMARTCTL RUN-TIME BEHAVIOR OPTIONS =====
  -q TYPE, --quietmode=TYPE                                           (ATA)
         Set smartctl quiet mode to one of: errorsonly, silent, noserial
  -d TYPE, --device=TYPE
         Specify device type to one of: ata, scsi, marvell, sat, 3ware,N
  -T TYPE, --tolerance=TYPE                                           (ATA)
         Tolerance: normal, conservative, permissive, verypermissive
  -b TYPE, --badsum=TYPE                                              (ATA)
         Set action on bad checksum to one of: warn, exit, ignore
  -r TYPE, --report=TYPE
         Report transactions (see man page)
  -n MODE, --nocheck=MODE                                             (ATA)
         No check if: never, sleep, standby, idle (see man page)
============================== DEVICE FEATURE ENABLE/DISABLE COMMANDS =====
  -s VALUE, --smart=VALUE
        Enable/disable SMART on device (on/off)
  -o VALUE, --offlineauto=VALUE                                       (ATA)
        Enable/disable automatic offline testing on device (on/off)
  -S VALUE, --saveauto=VALUE                                          (ATA)
        Enable/disable Attribute autosave on device (on/off)
======================================= READ AND DISPLAY DATA OPTIONS =====
  -H, --health
        Show device SMART health status
  -c, --capabilities                                                  (ATA)
        Show device SMART capabilities
  -A, --attributes
        Show device SMART vendor-specific Attributes and values
  -l TYPE, --log=TYPE
        Show device log. TYPE: error, selftest, selective, directory,
                               background, scttemp[sts,hist]
  -v N,OPTION , --vendorattribute=N,OPTION                            (ATA)
        Set display OPTION for vendor Attribute N (see man page)
  -F TYPE, --firmwarebug=TYPE                                         (ATA)
        Use firmware bug workaround: none, samsung, samsung2,
                                     samsung3, swapid
  -P TYPE, --presets=TYPE                                             (ATA)
        Drive-specific presets: use, ignore, show, showall
============================================ DEVICE SELF-TEST OPTIONS =====
  -t TEST, --test=TEST
        Run test. TEST: offline short long conveyance select,M-N
                        pending,N afterselect,[on|off] scttempint,N[,p]
  -C, --captive
        Do test in captive mode (along with -t)
  -X, --abort
        Abort any non-captive test on device
=================================================== SMARTCTL EXAMPLES =====
  smartctl --all /dev/hda                    (Prints all SMART information)
  smartctl --smart=on --offlineauto=on --saveauto=on /dev/hda
                                              (Enables SMART on first disk)
  smartctl --test=long /dev/hda          (Executes extended disk self-test)
  smartctl --attributes --log=selftest --quietmode=errorsonly /dev/hda
                                      (Prints Self-Test & Attribute errors)
  smartctl --all --device=3ware,2 /dev/sda
  smartctl --all --device=3ware,2 /dev/twe0
  smartctl --all --device=3ware,2 /dev/twa0
          (Prints all SMART info for 3rd ATA disk on 3ware RAID controller)
  smartctl --all --device=hpt,1/1/3 /dev/sda
          (Prints all SMART info for the SATA disk attached to the 3rd PMPort
           of the 1st channel on the 1st HighPoint RAID controller)
Message édité par loan__ le 27-12-2009 à 13:36:14
n°1188241
thana54
made in concept
Posté le 27-12-2009 à 14:48:30  profilanswer
Essaye ca alors (pour avoir le max d'info sur ton disque et son état)
Code :
  1. sudo smartctl -a /dev/sda
n°1188243
loan__
Posté le 27-12-2009 à 14:59:19  profilanswer
Code :
voila le rapport mais moi je n'y comprend rien....  :sweat:
vostro1400@vostro1400-laptop:~$ sudo smartctl -a /dev/sda
[sudo] password for vostro1400:
=== START OF INFORMATION SECTION ===
Device Model:     SAMSUNG HM160HI
Serial Number:    S14QJD0Q205209
Firmware Version: HH100-11
User Capacity:    160 041 885 696 bytes
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   7
ATA Standard is:  ATA/ATAPI-7 T13 1532D revision 0
Local Time is:    Sun Dec 27 14:57:07 2009 CET
==> WARNING: May need -F samsung or -F samsung2 enabled; see manual for details.
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
     was never started.
     Auto Offline Data Collection: Disabled.
Self-test execution status:      (  32) The self-test routine was interrupted
     by the host with a hard or soft reset.
Total time to complete Offline
data collection:    (  62) seconds.
capabilities:     (0x5b) SMART execute Offline immediate.
     Auto Offline data collection on/off support.
     Suspend Offline collection upon new
     command.
     Offline surface scan supported.
     Self-test supported.
     No Conveyance Self-test supported.
     Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
     power-saving mode.
     Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
     General Purpose Logging supported.
Short self-test routine
recommended polling time:   (   2) minutes.
Extended self-test routine
recommended polling time:   (  62) minutes.
SCT capabilities:         (0x003f) SCT Status supported.
     SCT Feature Control supported.
     SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   100   100   051    Pre-fail  Always       -       5
  3 Spin_Up_Time            0x0007   252   252   025    Pre-fail  Always       -       2062
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       5199
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       2
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       986
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1239
191 G-Sense_Error_Rate      0x0032   024   024   000    Old_age   Always       -       771378
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       42
194 Temperature_Celsius     0x0022   127   106   000    Old_age   Always       -       37 (Lifetime Min/Max 9/44)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       58473
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       1423  <=== c'est ici que ça doit ce passé j ' en suis à 1424
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       5220
199 UDMA_CRC_Error_Count    0x0036   252   252   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x000a   252   252   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Aborted by host               150%       976         -
# 2  Extended offline    Completed without error       00%       973         -
# 3  Short offline       Completed without error       00%       951         -
# 4  Short offline       Completed without error       00%       569         -
# 5  Short offline       Completed without error       00%       568         -
# 6  Short offline       Completed without error       00%         2         -
# 7  Short offline       Completed without error       00%         0         -
# 8  Short offline       Completed without error       00%         0         -
SMART Selective Self-Test Log Data Structure Revision Number (0) should be 1
SMART Selective self-test log data structure revision number 0
Warning: ATA Specification requires selective self-test log data structure revision number = 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Interrupted [00% left] (0-65535)
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Message édité par loan__ le 27-12-2009 à 16:15:44
n°1188456
loan__
Posté le 28-12-2009 à 21:18:24  profilanswer
... 1431 ... mon disque ne serait il pas en train de rendre l'âme :(
n°1188466
thana54
made in concept
Posté le 28-12-2009 à 21:45:25  profilanswer
Tente de voir ce qui se passe en livecd (pour avoir ton disque démontable), puis lis ceci: http://ubuntuauquotidien.wordpress [...] us-ubuntu/
(c'est l'interface graphique utilisant smartctl, entre autres)
Message édité par thana54 le 28-12-2009 à 21:45:49
n°1188474
loan__
Posté le 28-12-2009 à 22:08:35  profilanswer
ok merci je vais essayer par contre j ai aussi un probleme avec firefox dans cette page par exemple il ne m'affiche pas tout : http://support.euro.dell.com/suppo [...] 7=362048#1
... en effet je devrais avoir trois icone avec les differentes versions de windows à savoir XP , Vista et Seven afin de pouvoir cliquet dessus mais ici je n'ai rien d'afficher dessus.
Aurais je oublier de parametrer quelque chose ... j'ai installer le plugin flash en choisissant la version adobe gnome ... ais je bien fait ?
 Page :   1  2  3
Page Suivante
Shell Linux > MySql ne renvoie aucune informationpas de virus ni spyware sous linux: intox?
debian : locales-all ne veux plus s'installercommande pour scanner dd avec linux live cd
Live cd Linux qui boote très rapidement ?installer une police d'écriture
etude nas/htpc/virtual serveur sous linuxQuel version de linux installer?
quel version installer de linux sur P166 - 32Mo - dd 2 go ????Comment installer linux (version Mips) sur une SGI indigo 2 ?
Plus de sujets relatifs à : quel version de linux installer ?
