6704 connectés
  Linux et OS Alternatifs
  Installation
  Secteur de boot effacé
n°1194607
Taz
bisounours-codeur
Posté le 23-01-2010 à 22:14:06  profilanswer
Bonjour les gens,
j'ai bien moulé en installant debian tout en jouant à WoW, résultat j'ai effacé pour MBR. Du coup plus de table de partition.
La je suis entrain de tester gpart mais ça à l'air long.
Etant donné que j'ai le log de debian, comment je pourrais recréer mes partitions proprement ?
parted_server: Closing infifo and outfifo
parted_server: main_loop: iteration 4
parted_server: Opening infifo
Device: yes
Model: ATA ST9320325AS
Path: /dev/sda
Sector size: 512
Sectors: 625142448
Sectors/track: 63
Heads: 255
Cylinders: 38913
Partition table: yes
Type: msdos
Partitions: # id length type fs path name
(0,0,0) (0,0,62) -1 0-32255 32256 primary label /dev/sda-1
(0,1,0) (0,32,31) -1 32256-1048575 1016320 primary free /dev/sda-1
(0,32,32) (1912,26,33) 1 1048576-15727591423 15726542848 primary fat32 /dev/sda1
(1912,26,34) (11639,254,62) 2 15727591424-95742259199 80014667776 primary ntfs /dev/sda2
(11640,0,0) (38912,254,62) 3 95742259200-320070320639 224328061440 primary extended /dev/sda3
(11640,0,0) (11640,0,0) -1 95742259200-95742259711 512 logical label /dev/sda-1
(11640,0,1) (11640,2,9) -1 95742259712-95742328831 69120 logical label /dev/sda-1
(11640,2,10) (30762,82,39) 5 95742328832-253028728831 157286400000 logical ntfs /dev/sda5
(30762,82,40) (30762,254,62) -1 253028728832-253034288639 5559808 logical free /dev/sda-1
(30763,0,0) (30763,0,62) -1 253034288640-253034320895 32256 logical label /dev/sda-1
(30763,1,0) (38574,254,62) 6 253034320896-317290175999 64255855104 logical ext4 /dev/sda6
(38575,0,0) (38575,0,62) -1 317290176000-317290208255 32256 logical label /dev/sda-1
(38575,1,0) (38912,254,62) 7 317290208256-320070320639 2780112384 logical linux-swap /dev/sda7
(38913,0,0) (38913,80,62) -1 320070320640-320072933375 2612736 primary label /dev/sda-1
Dump finished.
n°1194608
Mjules
Parle dans le vide
Posté le 23-01-2010 à 22:20:34  profilanswer
testdisk ne permet pas ça ?
http://www.cgsecurity.org/wiki/TestDisk_FR
Message édité par Mjules le 23-01-2010 à 22:20:56
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°1194611
Taz
bisounours-codeur
Posté le 23-01-2010 à 22:24:33  profilanswer
Je suis entrain de faire tourner gpart là (gpart pas gparted).
Après je tente testdisk.
J'ai posté sur la list du debian-installer pour voir.
En fait juste besoin d'un outil pour recréer à l'identique au bloc prêt ma table vu que j'ai les offsets.
n°1194615
black_lord
Truth speaks from peacefulness
Posté le 23-01-2010 à 22:39:03  profilanswer
testdisk fait ça, je confirme
uptime is for lousy system administrators what Viagra is for impotent people - mes unixeries - github me
n°1194616
Taz
bisounours-codeur
Posté le 23-01-2010 à 22:56:33  profilanswer
Je suis sous systemrescuecd là.Ouah testdisk à l'air vachement plus rapide, il me trouve tout, sauf que les positions divergent légèrement. Ca à l'air pas mal du tout.
Du coup je suis sauvé !
n°1194621
Taz
bisounours-codeur
Posté le 23-01-2010 à 23:21:07  profilanswer
Ouais mais en fait non, je ne suis pas sorti, testdisk m'a recréé une table invalide, certaines partitions ont des bornes fausses.
n°1194624
l0g4n
Expert en tout :o
Posté le 23-01-2010 à 23:37:06  profilanswer
Ya une options pour les définirs à la main me semble...Et tente la deeper search, plus longue, mais plus average...
Fort et motivé. Sauf parfois.
n°1194625
Taz
bisounours-codeur
Posté le 23-01-2010 à 23:54:57  profilanswer
Faudrait surtout que j'arrive à créer des partitions en précisant bien le cylindre, tête, secteur.
n°1194628
Taz
bisounours-codeur
Posté le 24-01-2010 à 01:05:25  profilanswer
Le gros bordel c'est quand il détecte les étendues comme des primaires. Bonjour le bordel.
  Installation
Une question urgente sur le Master Boot RecordDual Boot Xp - Open Suse
Multiboot GAG "secteur de démarrage infecté"Problème de multi boot (grub cassé)
Karmic Koala et le boot sur mon ToshibaUbuntu 9.10 / RAID : mdadm refuse de monter au boot
installation automatisé via un boot pxe d'ubuntuproblème de boot sur cd
supréssion de la partition moblin sur netbooks et plus de boot!Boot floppy / kernel sur cd
Plus de sujets relatifs à : Secteur de boot effacé
