4388 connectés
  Linux et OS Alternatifs
  Installation
  [ Problème de Make ] Piave...
n°392594
j-'-r
Sans horraires fixe
Posté le 19-01-2004 à 23:22:46  profilanswer
Making all in libsamplerate
make[5]: Entering directory `/home/jerome/tmp/piave-0.2.3/plugins/effects/samplerate/libsamplerate'
source='src_zoh.c' object='src_zoh.lo' libtool=yes \
depfile='.deps/src_zoh.Plo' tmpdepfile='.deps/src_zoh.TPlo' \
depmode=gcc3 /bin/sh ../../../../depcomp \
/bin/sh ../../../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../../../..   -I/usr/include/arts  -g -O2 -c -o src_zoh.lo `test -f 'src_zoh.c' || echo './'`src_zoh.c
rm -f .libs/src_zoh.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../../../.. -I/usr/include/arts -g -O2 -c src_zoh.c -MT src_zoh.lo -MD -MP -MF .deps/src_zoh.TPlo  -fPIC -DPIC -o .libs/src_zoh.lo
In file included from src_zoh.c:24:
float_cast.h:191:10: warning: #warning "Don't have the functions lrint() and lrintf()."
float_cast.h:192:10: warning: #warning "Replacing these functions with a standard C cast."
src_zoh.c: In function `zoh_process':
src_zoh.c:89: `ENABLE_DEBUG' undeclared (first use in this function)
src_zoh.c:89: (Each undeclared identifier is reported only once
src_zoh.c:89: for each function it appears in.)
make[5]: *** [src_zoh.lo] Erreur 1
make[5]: Leaving directory `/home/jerome/tmp/piave-0.2.3/plugins/effects/samplerate/libsamplerate'
make[4]: *** [all-recursive] Erreur 1
make[4]: Leaving directory `/home/jerome/tmp/piave-0.2.3/plugins/effects/samplerate'
make[3]: *** [all-recursive] Erreur 1
make[3]: Leaving directory `/home/jerome/tmp/piave-0.2.3/plugins/effects'
make[2]: *** [all-recursive] Erreur 1
make[2]: Leaving directory `/home/jerome/tmp/piave-0.2.3/plugins'
make[1]: *** [all-recursive] Erreur 1
make[1]: Leaving directory `/home/jerome/tmp/piave-0.2.3'
make: *** [all] Erreur 2
Ca y est je fais des makes mais ca loupe...
Que ce passe-t-il donc ?
J'ai déjà résolut toutes les dépendances à la main c'était chaud :D
HELP
Perdu ? Vous êtes ici : --> *
n°392654
ganjo
Posté le 20-01-2004 à 08:15:12  profilanswer
en fait il te dit que la macro ENABLE_DEBUG n'éxiste pas, un oubli des developpeurs certainement. Regarde sur ton configure (avec ./configure --help) si il n'y a pas une option pour activer le debug. Sinon dans le fichier src_zoh.c tu peux soit virer les lignes utilisant ENABLE_DEBUG (et la suite s'il sagit d'un if) ou rajouter en debut de fichier
#define ENABLE_DEBUG
et juste après tu peux mailler le mainteneur du paquet pour lui signaler le prob
  Installation
[Résolu] Probleme LILO + Compact Flash IDEProbleme avec Mac OS 10 & 9 + Freemidi sur G4
[MDK 9.2] Carte Son & Graphique - problemeDebian probleme de clavier
Problème de clavier sous XProblème avec les pdf généré par open office
Problème pour démonter mon disque USBprobleme modem speed touch et redhat
Problème de sons sous mdk 9.2[iptables] probleme ident 113 avec client
Plus de sujets relatifs à : [ Problème de Make ] Piave...
