5816 connectés
  Linux et OS Alternatifs
  Installation
  pb avec postfix + mysql :/ [RESOLU !!!]
n°381074
Tomate
Posté le 28-12-2003 à 17:19:14  profilanswer
salut,
bon jai un postfix ki marche normalement
j ai voulu rajouter une base mysql pour pouvoir mettre des users non systeme :)
le pb : postfix n arrive pas a se connecter a mysql :/
voila les logs ke ca me sort kan j essaie d envoyer un mail et ke le support de mysql est actif ds la conf de postfix (car sinon ca marche) :
Dec 28 17:16:39 tomate postfix/smtpd[9269]: connect from unknown[192.168.0.254]
Dec 28 17:16:39 tomate postfix/smtpd[9269]: 59134217A7: client=unknown[192.168.0.254]
Dec 28 17:16:39 tomate postfix/trivial-rewrite[25962]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Dec 28 17:16:39 tomate postfix/trivial-rewrite[25962]: warning: connect to mysql server 127.0.0.1: Can't connect to MySQL server on '127.0.0.1' (111)
Dec 28 17:16:39 tomate postfix/trivial-rewrite[25962]: warning: connect to mysql server unix:/var/run/mysqld/mysqld.sock: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Dec 28 17:16:39 tomate postfix/trivial-rewrite[25962]: fatal: mysql:/etc/postfix/mysql_virtual_alias_maps.cf: table lookup problem
Dec 28 17:16:40 tomate postfix/smtpd[9269]: warning: premature end-of-input on private/rewrite socket while reading input attribute name
Dec 28 17:16:40 tomate postfix/smtpd[9269]: warning: resolve_clnt_query: bad read: Success
Dec 28 17:16:40 tomate postfix/master[17728]: warning: process /usr/lib/postfix/trivial-rewrite pid 25962 exit status 1
j ai cherché et recherché mais je comprends po :(
Message édité par Tomate le 03-01-2004 à 16:58:51
:: Light is Right ::
n°381085
void_ppc
Posté le 28-12-2003 à 17:49:59  profilanswer
ton serveur mysql écoute sur 127.0.0.1 ?
n°381087
Tomate
Posté le 28-12-2003 à 17:54:08  profilanswer
humm tres bonne kestion :D
mais ce ke je capte pas c est pk avec la socket ca marche po [:zytrahus5]
voila un bout de ma conf mysql :
[mysqld]
user            = mysql
pid-file        = /var/run/mysqld/mysqld.pid
socket          = /var/run/mysqld/mysqld.sock
port            = 3306
Message édité par Tomate le 28-12-2003 à 17:55:05
n°381100
void_ppc
Posté le 28-12-2003 à 18:21:15  profilanswer
mysql est bien lancé avec --socket ?
n°381101
void_ppc
Posté le 28-12-2003 à 18:21:54  profilanswer
essaye de te connecter à mysql sur la machine elle-même sur 127.0.0.1  (mysql -u lamer -h 127.0.0.1 -p )
n°381102
void_ppc
Posté le 28-12-2003 à 18:22:56  profilanswer
et t'as pas de chroot si ?
n°381309
Tomate
Posté le 29-12-2003 à 12:21:10  profilanswer
root@tomate:~$ mysql -p -h 127.0.0.1 -u postfix
Enter password:
ERROR 2003: Can't connect to MySQL server on '127.0.0.1' (111)
root@tomate:~$ mysql -u postfix -h localhost -p
Enter password:
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 202 to server version: 4.0.16-log
Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
mysql> exit
Bye
alors ca c est formidable [:zytrahus5]
en plus ca marche po non plus avec localhost pour postfix c est super ...
sinon, nan pas de chroot, et je le lance par : postfix start ;)
n°381588
Dark_Schne​ider
Close the World, Open the Net
Posté le 29-12-2003 à 18:16:12  profilanswer
pb de conf de mysql
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°381607
mikala
Souviens toi du 5 Novembre...
Posté le 29-12-2003 à 18:49:29  profilanswer
& quand je lui demandais sur irc si son mysql fonctionnait correctement il me disais que oui .. [:xx_xx]
Intermittent du GNU
n°381627
void_ppc
Posté le 29-12-2003 à 19:11:13  profilanswer
kick ban sodo
n°381632
Tomate
Posté le 29-12-2003 à 19:17:29  profilanswer
bah il marche tres bien mon mysql :o
d ailleurs j ai montre ke je peux me connecter avec localhost, mais postfix lui n y arrive po :o
n°381642
Dark_Schne​ider
Posté le 29-12-2003 à 19:22:51  profilanswer
mais tu n'y arrive pas avec 127.0.0.1 .... donc tu dois autoriser pour 127.0.0.1 si dans ton postfix il utilise 127.0.0.1 comme paramètre.
plus simple, tu allow pour tout, et ensuite tu restreins
n°381643
mikala
Posté le 29-12-2003 à 19:23:10  profilanswer
pourquoi cela ne marche pas en  127.0.0.1 ? [:meganne]
Intermittent du GNU
n°381646
mikala
Posté le 29-12-2003 à 19:24:16  profilanswer
[HS]
il fonctionne ton icq ? ou c'est mon jabber qui fait des siennes ? :]
[/HS]
Intermittent du GNU
n°381676
Dark_Schne​ider
Posté le 29-12-2003 à 19:53:26  profilanswer
marche pas et me souviens plus de mon pass
n°381695
Tomate
Posté le 29-12-2003 à 20:12:50  profilanswer
c est ce ke j ai fais :o
ds postfix pour hosts, j ai 127.0.0.1, localhost et unix:socket
mais ce con y arrive po kan meme :fou:
n°381710
mikala
Posté le 29-12-2003 à 20:41:48  profilanswer
& l'user postfix ? il est accessible en @localhost
eventuellement mets le pour n'importe quel acces des fois que .
fais mysql écoute sur ton ip local & tapes sur l'ip local avec postfix .
on verra bien
Message édité par mikala le 29-12-2003 à 20:42:33
Intermittent du GNU
n°381988
Tomate
Posté le 30-12-2003 à 10:38:13  profilanswer
on verra bien
comme vu si dessus :
Enter password:
mysql> exit
Bye
et apres tu te fou de moi car j oublie de lire une pitite partie de ton how to  :whistle:
n°382050
the_fireba​ll
We Are What We Shit
Posté le 30-12-2003 à 12:24:41  profilanswer
et à la place de localhost, si tu mets le hostname de ta machine, ça ne marche pas mieux ?
genre mysql -u postfix -h nomdupcdetomate -p
Two thousand years of misery, of torture in my name, hypocrisy made paramount, paranoia the law, my name is called religion, sadistic, sacred whore.
n°382119
mikala
Posté le 30-12-2003 à 14:27:36  profilanswer
de toute façon tu peux oublier postfix pour recevoir des mails vu qu'a partir du 6 janvier tele2 filtre le port 25 :]
télé2 c'est bon mangez en :sol:
Intermittent du GNU
n°382122
the_fireba​ll
We Are What We Shit
Posté le 30-12-2003 à 14:29:43  profilanswer
mikala, l'homme qui en connait un rayon sur les FAI en tout genre
n°382127
mikala
Posté le 30-12-2003 à 14:37:18  profilanswer
tsss
Intermittent du GNU
n°382134
void_ppc
Posté le 30-12-2003 à 14:46:07  profilanswer
source ? :o
n°382136
mikala
Posté le 30-12-2003 à 14:49:13  profilanswer
bla@osa j'ai posté l'info la :sol:
Intermittent du GNU
n°382531
Tomate
Posté le 31-12-2003 à 10:30:57  profilanswer
m en fou  :kaola:
n°383876
Tomate
Posté le 03-01-2004 à 16:59:54  profilanswer
bon aye ca marche :)
suis content car j ai trouve tout seul :D
j ai bien fait de reinstaller mysql, car il nous dit a la fin de l installe : "network is disabled" !!! :fou:  [:albator7k]
donc c est regle :)
n°384006
Popop56
56
Posté le 03-01-2004 à 21:02:33  profilanswer
cool, tu va pouvoir recevoir des mails durant 3jours :]
n°384009
Tomate
Posté le 03-01-2004 à 21:03:24  profilanswer
  Installation
autoriser un utilisateur à lire un fichier [Résolu]pop ident postfix
[MDK9.2] Plusieurs utilisateurs en mode graphique [Résolu]mon cygwin ne fonctionne plus [résolu]
Probleme avec acpi (resolu) demande conseil sur la ramSamba probleme avec les accents [résolu]
Impossible d'installer amule/xmule sous mdk 9.2 [résolu][Résolu avec nouveaux drivers] Plus de tty depuis les drivers nVidia
AAM sur hdd [résolu] - plus de led sur la tour : hdd s-ata [help][DEBIAN]PB après compilation 2.6.0 [Quasi-résolu]
Plus de sujets relatifs à : pb avec postfix + mysql :/ [RESOLU !!!]
