4040 connectés
  Linux et OS Alternatifs
  Installation
  gros pb lors du passage de hoary vers breezy, plus de wifi
n°736509
newportabl​e
Laboris gloria Ludi
Posté le 02-10-2005 à 08:48:43  profilanswer
Hier soir j'avais tellement rien à faire que j'ai déscidé de passer mon hoary en breezy, j'ai utilisé le source liste de easy ubuntu et ça donne ça
deb http://archive.ubuntu.com/ubuntu breezy main restricted
deb-src http://archive.ubuntu.com/ubuntu breezy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://archive.ubuntu.com/ubuntu breezy-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu breezy-updates main restricted
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team
deb http://archive.ubuntu.com/ubuntu breezy universe multiverse
deb-src http://archive.ubuntu.com/ubuntu breezy universe multiverse
## Security Updates
deb http://security.ubuntu.com/ubuntu breezy-security main restricted
deb-src http://security.ubuntu.com/ubuntu breezy-security main restricted
deb http://security.ubuntu.com/ubuntu breezy-security universe multiverse
deb-src http://security.ubuntu.com/ubuntu breezy-security universe multiverse
## Skype
deb http://download.skype.com/linux/repos/debian/ stable non-free
## Hoary Extras (because Breezy Extras are not curently available)
deb http://ubuntu-backports.mirrormax.net/ hoary-extras main universe multiverse restricted
## Officials Backports
## deb http://archive.ubuntu.com/ubuntu breezy-backports main universe multiverse restricted
## Backports
## deb http://ubuntu-backports.mirrormax.net/ breezy-backports main universe multiverse restricted
## deb http://ubuntu-backports.mirrormax.net/ breezy-backports-staging main universe multiverse restricted
## deb http://ubuntu-backports.mirrormax.net/ breezy-extras-staging main universe multiverse restricted
je fait un petit apt-get dist-upgrade et j'ai cette erreur
250 mis à jour, 34 nouvellement installés, 5 à enlever et 2 non mis à jour.
965 partiellement installés ou enlevés.
Il est nécessaire de prendre 0o/293Mo dans les archives.
Après dépaquetage, 241Mo d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer [O/n] ? o
Extracting templates from packages: 100%
Préconfiguration des paquets ...
(Lecture de la base de données... 140580 fichiers et répertoires déjà installés.)
Dépaquetage de language-pack-kde-fr-base (à partir de .../language-pack-kde-fr-base_20050930_all.deb) ...
dpkg : erreur de traitement de /var/cache/apt/archives/language-pack-kde-fr-base_20050930_all.deb (--unpack) :
 tentative de remplacement de « /usr/share/locale-langpack/fr/LC_MESSAGES/kaffeine.mo », qui appartient aussi au paquet language-pack-fr-base
dpkg-deb: sous-processus paste tué par le signal (Relais brisé (pipe))
Des erreurs ont été rencontrées pendant l'exécution :
E: Sub-process /usr/bin/dpkg returned an error code (1)
Quesque je dois faire????
Message édité par newportable le 02-10-2005 à 10:28:10
n°736517
newportabl​e
Laboris gloria Ludi
Posté le 02-10-2005 à 10:09:28  profilanswer
évolution dans mon problème...
J'ai choisi la technique bourrine et j'ai supprimé language-pack-kde-fr-base à la main et je l'ais réinstallé ensuite, aucun pb.
Par contre j'ai un autre pb très gravce ce coup si, j'ai plus de réseau :cry:. J'ai un carte wifi intel 2100b (celle de base) dans mon portable qui a été détecté à l'install de ma warty (ouai ça date). J'ai eu aucun pb lors du passage de warty en hoary mais maintenant avec la passage en breezy elle n'est plus détectée :sweat: Quand je vais dans système > administration > réseau ma carte wifi n'apparait plus, par contre si je vais dans système > administration > device manager elle apparait.
J'ai essay de rebooter sur mon 2.6.10 et là aucun pb j'ai bien internet et elle apparait dans réseau.
Là je suis vraiment paumé, un petit coup de main serait le bienvenu
n°736528
chaced
Posté le 02-10-2005 à 11:22:08  profilanswer
Ils ont surement viré le module qui gere ta carte, recompile le kernel a la mano.
n°736531
vlack
Posté le 02-10-2005 à 11:24:32  profilanswer
Ou charge le module du driver.
n°736532
chaced
Posté le 02-10-2005 à 11:27:17  profilanswer
lsmod pour voir les modules qui sont chargés
n°736548
newportabl​e
Laboris gloria Ludi
Posté le 02-10-2005 à 11:45:46  profilanswer
voilà la liste des modules du 2.6.10 qui marche
Module                  Size  Used by
rfcomm                 39420  0
l2cap                  26468  5 rfcomm
bluetooth              50532  4 rfcomm,l2cap
speedstep_centrino      7892  1
proc_intf               3908  0
freq_table              4004  1 speedstep_centrino
cpufreq_userspace       4348  1
cpufreq_ondemand        6140  0
cpufreq_powersave       1632  0
pcmcia                 22244  4
ipt_limit               2368  6
iptable_mangle          2720  0
ipt_LOG                 6880  8
ipt_MASQUERADE          3488  0
iptable_nat            26376  1 ipt_MASQUERADE
ipt_TOS                 2368  0
ipt_REJECT              6848  1
ip_conntrack_irc       71664  0
ip_conntrack_ftp       72528  0
ipt_state               1824  6
ip_conntrack           46420  5 ipt_MASQUERADE,iptable_nat,ip_conntrack_irc,ip_conntrack_ftp,ipt_state
iptable_filter          3584  1
ip_tables              18464  9 ipt_limit,iptable_mangle,ipt_LOG,ipt_MASQUERADE,iptable_nat,ipt_TOS,ipt_REJECT,ipt_state,iptable_filter
usblp                  12672  0
video                  15972  0
sony_acpi               5928  0
pcc_acpi               11008  0
ibm_acpi               17524  0
button                  6480  0
battery                 9988  0
container               4320  0
ac                      4676  0
ipv6                  257760  8
deflate                 3648  0
zlib_deflate           21336  1 deflate
twofish                36928  0
serpent                13376  0
aes_i586               38612  0
blowfish                7904  0
des                    11424  0
sha256                  8992  0
sha1                    8224  0
crypto_null             2080  0
xfrm_user              16164  0
ipcomp                  8200  0
esp4                    8288  0
ah4                     6656  0
af_key                 33328  0
ipw2100                84796  0
firmware_class          9984  1 ipw2100
ieee80211              23332  1 ipw2100
ieee80211_crypt         5640  1 ieee80211
e1000                  85620  0
yenta_socket           21344  0
pcmcia_core            57984  2 pcmcia,yenta_socket
snd_intel8x0m          18372  0
snd_intel8x0           32352  2
snd_ac97_codec         74144  2 snd_intel8x0m,snd_intel8x0
snd_pcm_oss            52132  0
snd_mixer_oss          19680  1 snd_pcm_oss
snd_pcm                94696  5 snd_intel8x0m,snd_intel8x0,snd_ac97_codec,snd_pcm_oss
snd_timer              25060  2 snd_pcm
snd                    55012  9 snd_intel8x0m,snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
soundcore              10016  1 snd
snd_page_alloc          9732  3 snd_intel8x0m,snd_intel8x0,snd_pcm
i2c_i801                8364  0
i2c_core               22320  1 i2c_i801
ehci_hcd               32708  0
uhci_hcd               32816  0
usbcore               119000  4 usblp,ehci_hcd,uhci_hcd
shpchp                 99172  0
pci_hotplug            33488  1 shpchp
intel_agp              22140  1
agpgart                33608  1 intel_agp
irtty_sir               8544  0
sir_dev                18828  1 irtty_sir
irda                  191936  2 irtty_sir,sir_dev
crc_ccitt               1920  1 irda
floppy                 58864  0
rtc                    12472  0
pcspkr                  3496  0
nls_utf8                1952  1
ntfs                  110512  1
dm_mod                 59420  1
capability              4648  0
commoncap               7712  1 capability
fglrx                 261064  0
nvram                   9096  1
parport_pc             37252  1
lp                     11144  0
parport                36744  2 parport_pc,lp
ide_cd                 41700  0
cdrom                  40220  1 ide_cd
joydev                  9664  0
evdev                   9344  1
mousedev               11288  1
tsdev                   7520  0
psmouse                21320  0
md                     47440  0
ext3                  137256  2
jbd                    60536  1 ext3
mbcache                 8356  1 ext3
ide_generic             1312  0
piix                   10340  1
ide_disk               20416  5
ide_core              129356  4 ide_cd,ide_generic,piix,ide_disk
unix                   28276  530
thermal                13320  0
processor              22452  2 speedstep_centrino,thermal
fan                     4388  0
fbcon                  37504  0
font                    8192  1 fbcon
bitblit                 5472  1 fbcon
vesafb                  6724  0
cfbcopyarea             3808  1 vesafb
cfbimgblt               2912  1 vesafb
cfbfillrect             3488  1 vesafb
et voilà la liste des modules incriminé (ceux de 2.6.12 qui ne marche pas)
Module                  Size  Used by
rfcomm                 38460  0
l2cap                  24740  5 rfcomm
bluetooth              48356  4 rfcomm,l2cap
speedstep_centrino      7636  1
cpufreq_userspace       4316  1
cpufreq_stats           5252  0
freq_table              4388  2 speedstep_centrino,cpufreq_stats
cpufreq_powersave       1696  0
cpufreq_ondemand        6044  0
cpufreq_conservative     6948  0
pcmcia                 26568  4
ipt_limit               2208  6
ipt_LOG                 6976  8
ipt_MASQUERADE          3296  0
iptable_nat            22900  1 ipt_MASQUERADE
ipt_TOS                 2336  0
ipt_REJECT              5376  1
ip_conntrack_irc       71696  0
ip_conntrack_ftp       72688  0
ipt_state               1792  6
ip_conntrack           43064  5 ipt_MASQUERADE,iptable_nat,ip_conntrack_irc,ip_conntrack_ftp,ipt_state
iptable_filter          2816  1
ip_tables              19456  9 ipt_limit,iptable_mangle,ipt_LOG,ipt_MASQUERADE,iptable_nat,ipt_TOS,ipt_REJECT,ipt_state,iptable_filter
usblp                  12640  0
video                  15748  0
tc1100_wmi              6692  0
sony_acpi               5324  0
pcc_acpi               11104  0
ibm_acpi               17684  0
hotkey                  9284  0
dev_acpi               11108  0
i2c_acpi_ec             5472  0
button                  6480  0
battery                 9348  0
container               4384  0
ac                      4708  0
ipv6                  251200  8
deflate                 4000  0
zlib_deflate           22584  1 deflate
twofish                37472  0
serpent                17184  0
aes_i586               38848  0
blowfish                7968  0
des                    11552  0
sha256                  9184  0
sha1                    2560  0
crypto_null             2176  0
xfrm_user              15844  0
ipcomp                  7784  0
esp4                    8096  0
ah4                     6368  0
af_key                 33136  0
ipw2100                87920  0
firmware_class          9952  1 ipw2100
ieee80211              29380  1 ipw2100
ieee80211_crypt         5604  2 ipw2100,ieee80211
yenta_socket           25292  2
rsrc_nonstatic         13376  1 yenta_socket
pcmcia_core            49348  3 pcmcia,yenta_socket,rsrc_nonstatic
snd_intel8x0m          18084  0
snd_intel8x0           33248  0
snd_ac97_codec         83932  2 snd_intel8x0m,snd_intel8x0
snd_pcm_oss            52704  0
snd_mixer_oss          19296  1 snd_pcm_oss
snd_pcm                88840  4 snd_intel8x0m,snd_intel8x0,snd_ac97_codec,snd_pcm_oss
snd_timer              24164  1 snd_pcm
snd                    54884  7 snd_intel8x0m,snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
soundcore               9600  1 snd
snd_page_alloc         10600  3 snd_intel8x0m,snd_intel8x0,snd_pcm
i2c_i801                8556  0
i2c_core               21200  2 i2c_acpi_ec,i2c_i801
tpm_atmel               5536  0
tpm_nsc                 6656  0
tpm                     9888  2 tpm_atmel,tpm_nsc
shpchp                 96996  0
pci_hotplug            27508  1 shpchp
intel_agp              23164  1
irtty_sir               8512  0
sir_dev                18444  1 irtty_sir
irda                  187612  2 irtty_sir,sir_dev
crc_ccitt               1984  1 irda
floppy                 59124  0
rtc                    12344  0
pcspkr                  3396  0
nls_utf8                2016  1
ntfs                  108144  1
dm_mod                 57692  1
joydev                  9984  0
tsdev                   7776  0
evdev                   9664  1
fglrx                 255524  0
agpgart                34792  2 intel_agp,fglrx
nvram                   8488  1
parport_pc             35236  1
lp                     12292  0
parport                35912  2 parport_pc,lp
mousedev               11616  1
psmouse                30116  0
md                     45584  0
ext3                  136264  2
jbd                    54776  1 ext3
mbcache                 9252  1 ext3
thermal                13000  0
processor              22812  2 speedstep_centrino,thermal
fan                     4484  0
e1000                 101940  0
ehci_hcd               34248  0
uhci_hcd               31184  0
usbcore               117884  4 usblp,ehci_hcd,uhci_hcd
ide_cd                 41572  0
cdrom                  39616  1 ide_cd
ide_disk               18464  5
ide_generic             1376  0
piix                   10372  1
ide_core              138772  4 ide_cd,ide_disk,ide_generic,piix
unix                   26896  528
vesafb                  7992  0
capability              4712  0
commoncap               6816  1 capability
vga16fb                12584  1
vgastate                9664  1 vga16fb
softcursor              2272  2 vesafb,vga16fb
cfbimgblt               2944  2 vesafb,vga16fb
cfbfillrect             3872  2 vesafb,vga16fb
cfbcopyarea             4608  2 vesafb,vga16fb
fbcon                  38496  72
tileblit                2368  1 fbcon
font                    8224  1 fbcon
bitblit                 5632  1 fbcon
n°736569
newportabl​e
Laboris gloria Ludi
Posté le 02-10-2005 à 12:22:21  profilanswer
pourtant le module ipw 2100 est chargé
ipw2100                87920  0
Message édité par newportable le 02-10-2005 à 12:22:38
n°736581
chaced
Posté le 02-10-2005 à 12:27:29  profilanswer
Vache, je suis impréssioné par le nombre de module chargé ! j'en ai 3 fois moins !
n°736594
newportabl​e
Laboris gloria Ludi
Posté le 02-10-2005 à 12:42:44  profilanswer
ouai mais ça m'aide pas :D
n°736611
chaced
Posté le 02-10-2005 à 13:18:25  profilanswer
Désolé  :pt1cable:
cedric@yup:~$ lsmod
Module                  Size  Used by
nvidia               3710984  12
thermal                13512  0
fan                     4676  0
button                  6544  0
processor              22580  1 thermal
amd64_agp              12680  1
ehci_hcd               49160  0
snd_emu10k1_synth       8064  0
snd_emux_synth         39552  1 snd_emu10k1_synth
snd_seq_virmidi         8384  1 snd_emux_synth
snd_seq_midi_emul       7488  1 snd_emux_synth
snd_seq_dummy           3716  0
snd_seq_oss            36992  0
snd_seq_midi            9248  0
snd_seq_midi_event      8448  3 snd_seq_virmidi,snd_seq_oss,snd_seq_midi
snd_seq                56272  9 snd_emux_synth,snd_seq_virmidi,snd_seq_midi_emul,snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_emu10k1           122116  3 snd_emu10k1_synth
snd_rawmidi            26720  3 snd_seq_virmidi,snd_seq_midi,snd_emu10k1
snd_seq_device          8844  8 snd_emu10k1_synth,snd_emux_synth,snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq,snd_emu10k1,snd_rawmidi
snd_ac97_codec         83448  1 snd_emu10k1
snd_pcm_oss            54944  1
snd_mixer_oss          20288  1 snd_pcm_oss
snd_pcm                97864  3 snd_emu10k1,snd_ac97_codec,snd_pcm_oss
snd_timer              26628  3 snd_seq,snd_emu10k1,snd_pcm
snd_page_alloc          9988  2 snd_emu10k1,snd_pcm
snd_util_mem            4608  2 snd_emux_synth,snd_emu10k1
snd_hwdep               9760  2 snd_emux_synth,snd_emu10k1
nls_iso8859_1           4032  3
ntfs                  185424  3
via_velocity           35424  0
crc_ccitt               2048  1 via_velocity
ide_cd                 43076  0
cdrom                  40736  1 ide_cd
n°737182
newportabl​e
Laboris gloria Ludi
Posté le 03-10-2005 à 20:32:17  profilanswer
up
n°737215
janno_59
Posté le 03-10-2005 à 22:31:04  profilanswer
Salut ,
si tu fais un
sudo rmmod ipw2100
sudo modprobe ipw2100
puis dmesg ipw2100 pour voir les erreurs
n°737313
newportabl​e
Laboris gloria Ludi
Posté le 04-10-2005 à 11:44:16  profilanswer
merci janno ça marche, génial :jap:
Sinon j'ai 1 autre pb avec ma connection internet via ethernet, je suis obligé de la reconfigurer à chaque redémarrage avec pppoeconf, si je fais un sudo pon dsl-provider ça me dit module chargé mais j'ai pas internet, je suis obligé de la reconfigurer :pfff:
une idée?
n°737317
newportabl​e
Laboris gloria Ludi
Posté le 04-10-2005 à 11:53:44  profilanswer
aussi tôt dit aussi tôt résolu, dsl ;)
  Installation
Mandriva 10.2 avec freebox en wifi -zd1211 de sourceforgeRediriger une commande vers un fichier et l'ecran
plantage connection wifi ==> reconnexion impossibleServeur SAN sous hoary
vieux linuxien reparti sous win et re-cour !! vers linux.. need adviceProblème carte wifi sous mandrake 10.2
[mandriva] installer et configurer le wifi d'un amilo 1425 ?MDK 10.1 : Clé wifi TRENDNET 424 UB - Musal
configurer connection wifi sous mandrivarouteur wifi sous linux ou autre
Plus de sujets relatifs à : gros pb lors du passage de hoary vers breezy, plus de wifi
