4312 connectés
  Linux et OS Alternatifs
  Installation
  message d'erreur de x
n°266698
zit
Posté le 23-05-2003 à 10:43:46  profilanswer
Bonjour a tous,
Voila ce matin quand j'ai redermarrer ma machine voila ce que m'affiche le server x :
(**) S3: Monitor ID: "Generic Monitor"
(--) S3: Mode "640x350" needs vert refresh rate of 85.08 Hz. Deleted.
(--) S3: Mode "640x400" needs vert refresh rate of 85.08 Hz. Deleted.
(--) S3: Mode "720x400" needs vert refresh rate of 85.04 Hz. Deleted.
(--) S3: Mode "640x480" needs vert refresh rate of 72.81 Hz. Deleted.
(--) S3: Mode "640x480" needs vert refresh rate of 75.00 Hz. Deleted.
(--) S3: Mode "640x480" needs vert refresh rate of 85.01 Hz. Deleted.
(--) S3: Mode "800x600" needs vert refresh rate of 72.19 Hz. Deleted.
(--) S3: Mode "800x600" needs vert refresh rate of 75.00 Hz. Deleted.
(--) S3: Mode "800x600" needs hsync freq of 53.72 kHz. Deleted.
(--) S3: Mode "1024x768" needs vert refresh rate of 86.96 Hz. Deleted.
(--) S3: Mode "1024x768" needs hsync freq of 56.48 kHz. Deleted.
(--) S3: Mode "1024x768" needs hsync freq of 60.06 kHz. Deleted.
(--) S3: Mode "1024x768" needs hsync freq of 68.68 kHz. Deleted.
(--) S3: Mode "1152x864" needs hsync freq of 67.50 kHz. Deleted.
(--) S3: Mode "1280x960" needs hsync freq of 60.00 kHz. Deleted.
(--) S3: Mode "1280x960" needs hsync freq of 85.94 kHz. Deleted.
(--) S3: Mode "1280x1024" needs hsync freq of 63.98 kHz. Deleted.
(--) S3: Mode "1280x1024" needs hsync freq of 79.98 kHz. Deleted.
(--) S3: Mode "1280x1024" needs hsync freq of 91.15 kHz. Deleted.
(--) S3: Mode "1600x1200" needs hsync freq of 75.00 kHz. Deleted.
(--) S3: Mode "1600x1200" needs hsync freq of 81.25 kHz. Deleted.
(--) S3: Mode "1600x1200" needs hsync freq of 87.50 kHz. Deleted.
(--) S3: Mode "1600x1200" needs hsync freq of 93.75 kHz. Deleted.
(--) S3: Mode "1600x1200" needs hsync freq of 106.25 kHz. Deleted.
(--) S3: Mode "1792x1344" needs hsync freq of 83.66 kHz. Deleted.
(--) S3: Mode "1792x1344" needs hsync freq of 106.27 kHz. Deleted.
(--) S3: Mode "1856x1392" needs hsync freq of 86.35 kHz. Deleted.
(--) S3: Mode "1856x1392" needs hsync freq of 112.50 kHz. Deleted.
(--) S3: Mode "1920x1440" needs hsync freq of 90.00 kHz. Deleted.
(--) S3: Mode "1920x1440" needs hsync freq of 112.50 kHz. Deleted.
Warning: The directory "/usr/lib/X11/fonts/CID" does not exist.
         Entry deleted from font path.
Warning: The directory "/usr/lib/X11/fonts/Speedo" does not exist.
Warning: The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi"
(--) S3: PCI: unknown (please report), ID 0x8c10 rev 12, Linear FB @ 0xf0000000
(--) S3: Unknown S3 chipset: chip_id = 0x8c10 rev. 12
 *** None of the configured devices were detected.***
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages
XIO:  fatal IO error 104 (Connection reset by peer) on X server ":0.0"
      after 0 requests (0 known processed) with 0 events remaining.
Est ce quelqu'un a deja eu ce probleme, car je sais pas du tous a koi sa correspond?
Merci d'avance
n°266704
Mjules
Parle dans le vide
Posté le 23-05-2003 à 10:53:43  profilanswer
Pour une raison X ou Y ( :lol: ), la conf d'écran est mauvaise, il faut donc la refaire.
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°266729
zit
Posté le 23-05-2003 à 11:34:28  profilanswer
je refaisla config de xfree? on la fait ou la config?
n°266746
Mjules
Parle dans le vide
Posté le 23-05-2003 à 12:03:53  profilanswer
si Mandrake, XFdrake
si Debian, apt-get reconfigure xfree-serveur
si autre : xfconfig
n°285342
zit
Posté le 30-06-2003 à 11:15:32  profilanswer
j'ai reussi a le reparer avec dpkg-reconfigure mais maintenant quand je basucle l'affichage en crt (ecran ordinateur) de mon portable j'ai pas le pointeur de la souris mais sur le portable oui.
Une idée???
Merci d'avance
  Installation
message d'erreur au démarrage de gnomemessage d'erreur au démarrage de gnome
C'est quoi cette erreur dans mon /var/log/messageMessage d'erreur dans la fenêtre Mozilla
message d'erreur inconnu au bataillonPb de boot, Message d'erreur L, svp un petit coup de main
message erreur dual boot win2000 /linux (redhat v7.3)Probleme NFS! message d'erreur inside
Pouvez m'expliquer ce message d'erreur ?[Erreur] Message qui m'empeche de booter
Plus de sujets relatifs à : message d'erreur de x
