9648 connectés
  Linux et OS Alternatifs
  Installation
  [gentoo] pb pour emerge frozen-bubble
n°580624
PII350
Posté le 27-10-2004 à 13:47:20  profilanswer
Salut tlm,
Je suis sous gentoo 2004.1 fraichement installée et voila, mon problème est que je n'arrive pas a installer frozen bubble.
J ai pourtant installé perl, sdl-perl, sdl-image et sdl-mixer comme ils disent sur leur site, mais voila pas moyen...  :sweat:
Voila ce qu'il me dit :
Code :
  1. bash-2.05b# emerge frozen-bubble
  2. Calculating dependencies ...done!
  3. >>> emerge (1 of 1) games-arcade/frozen-bubble-1.0.0-r3 to /
  4. >>> md5 src_uri ;-) frozen-bubble-1.0.0.tar.bz2
  5. >>> md5 src_uri ;-) frozen-bubble-client-0.0.3.tar.bz2
  6. >>> md5 src_uri ;-) frozen-bubble-server-0.0.3.tar.bz2
  7. QA Notice: USE Flag 'macos' not in IUSE for games-arcade/frozen-bubble-1.0.0-r3
  8. QA Notice: USE Flag 'macos' not in IUSE for games-arcade/frozen-bubble-1.0.0-r3
  9. >>> Unpacking source...
  10. >>> Unpacking frozen-bubble-1.0.0.tar.bz2 to /var/tmp/portage/frozen-bubble-1.0.0-r3/work
  11. >>> Unpacking frozen-bubble-client-0.0.3.tar.bz2 to /var/tmp/portage/frozen-bubble-1.0.0-r3/work
  12. >>> Unpacking frozen-bubble-server-0.0.3.tar.bz2 to /var/tmp/portage/frozen-bubble-1.0.0-r3/work
  13. * Applying fb-sdlperl-deb.patch ...        [ ok ]
  14. You should add the contents of `/usr/share/aclocal/libtool.m4' to `aclocal.m4'.
  15. automake: configure.in: installing `./install-sh'
  16. automake: configure.in: installing `./mkinstalldirs'
  17. automake: configure.in: installing `./missing'
  18. automake: Makefile.am: installing `./INSTALL'
  19. automake: Makefile.am: required file `./NEWS' not found
  20. automake: Makefile.am: installing `./COPYING'
  21. automake: Makefile.am: required file `./AUTHORS' not found
  22. automake: Makefile.am: required file `./ChangeLog' not found
  23. >>> Source unpacked.
  24. Can't load '/usr/lib/perl5/vendor_perl/5.8.4/i686-linux/auto/SDL_perl/SDL_perl.so' for module SDL_perl: libnvidia-tls.so.1: ne peut traiter les données TLS at /usr/lib/perl5/5.8.4/i686-linux/DynaLoader.pm line 230.
  25. at /usr/lib/perl5/vendor_perl/5.8.4/i686-linux/SDL.pm line 9
  26. Compilation failed in require at /usr/lib/perl5/vendor_perl/5.8.4/i686-linux/SDL.pm line 9.
  27. BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.8.4/i686-linux/SDL.pm line 9.
  28. Compilation failed in require at -e line 1.
  29. BEGIN failed--compilation aborted at -e line 1.
  30.     *** I need perl-SDL installed
  31. make: *** [dirs] Erreur 1
  32. !!! ERROR: games-arcade/frozen-bubble-1.0.0-r3 failed.
  33. !!! Function src_compile, Line 55, Exitcode 2
  34. !!! emake game failed
  35. !!! If you need support, post the topmost build error, NOT this status message.
Please help me, je tiendrai pas longtemps sans ce jeu... :pt1cable:
n°580743
Jar Jar
Intaigriste
Posté le 27-10-2004 à 16:02:14  profilanswer
Drivers nvidia kipuent.
n°580776
vanilla
datoune's revival
Posté le 27-10-2004 à 16:23:04  profilanswer
Tu as emerge sync && emerge -u world récemment ?
n°580810
PII350
Posté le 27-10-2004 à 16:52:32  profilanswer
oui j ai fais un mise a jour recemmenent, ce serai de la que viendrai le problème ? :sweat:
n°580834
vanilla
datoune's revival
Posté le 27-10-2004 à 17:06:17  profilanswer
Essaye
opengl-update xorg-x11
n°580950
PII350
Posté le 27-10-2004 à 19:41:22  profilanswer
vanilla a écrit :
Essaye
Merci ;)
Cette commande m a permi d'atteindre le bout de la compilation, mais maintenant c est au lancement que ca cloche  :cry:
Code :
  1. bash-2.05b$ frozen-bubble
  2. Can't load '/usr/lib/perl5/vendor_perl/5.8.4/i686-linux/auto/SDL_perl/SDL_perl.so' for module SDL_perl: libnvidia-tls.so.1: ne peut traiter les données TLS at /usr/lib/perl5/5.8.4/i686-linux/DynaLoader.pm line 230.
  3. at /usr/lib/perl5/vendor_perl/5.8.4/i686-linux/SDL.pm line 9
  4. Compilation failed in require at /usr/lib/perl5/vendor_perl/5.8.4/i686-linux/SDL.pm line 9.
  5. BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.8.4/i686-linux/SDL.pm line 9.
  6. Compilation failed in require at /usr/games/bin/frozen-bubble line 51.
  7. BEGIN failed--compilation aborted at /usr/games/bin/frozen-bubble line 51.
n°580974
j_c_p
Linux user
Posté le 27-10-2004 à 20:08:11  profilanswer
Solution ;) :
[19:43][jcp@phoenix]
[~] > su root
Password:##
bash-2.05b#
1/emerge File-Spec
2/opengl-update xorg-x11
3/emerge sdl-perl
4/opengl-update nvidia
http://forums.gentoo.org/viewtopic [...] rl+sdlperl
Message édité par j_c_p le 27-10-2004 à 20:09:47
  Installation
Probleme lors du premier lancement de la gentooGentoo et paquetages
Debian + install d'une gentooemerge au travers d'un proxy
Avenir de gentoo[wifi] netgear wg511 / prism54 / gentoo
question pr gentoo et environement X[gentoo] emerge ne fonctionne plus du tout
[GENTOO] bootstrap
Plus de sujets relatifs à : [gentoo] pb pour emerge frozen-bubble
