9011 connectés
  Linux et OS Alternatifs
  Installation
  [Debian Etch/2.6.18] Problème de make menuconfig
n°928866
redvivi
Posté le 30-06-2007 à 15:16:55  profilanswer
Bonjour à tous !
        J'essaye de compiler mon noyau et voici l'erreur que j'obtiens sur un make menuconfig:
Code :
  1. make menuconfig
  2.   HOSTCC  scripts/basic/fixdep
  3.   HOSTCC  scripts/basic/docproc
  4.   HOSTCC  scripts/kconfig/conf.o
  5.   HOSTCC  scripts/kconfig/kxgettext.o
  6.   HOSTCC  scripts/kconfig/mconf.o
  7.   HOSTCC  scripts/kconfig/zconf.tab.o
  8.   HOSTLD  scripts/kconfig/mconf
  9.   HOSTCC  scripts/kconfig/lxdialog/checklist.o
  10. In file included from scripts/kconfig/lxdialog/checklist.c:24:
  11. scripts/kconfig/lxdialog/dialog.h:31:20: error: curses.h: Aucun fichier ou répertoire de ce type
  12. In file included from scripts/kconfig/lxdialog/checklist.c:24:
  13. scripts/kconfig/lxdialog/dialog.h:128: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âuse_colorsâ
  14. scripts/kconfig/lxdialog/dialog.h:129: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âuse_shadowâ
  15. scripts/kconfig/lxdialog/dialog.h:131: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âattributesâ
  16. scripts/kconfig/lxdialog/dialog.h:143: error: expected â)â before â*â token
  17. scripts/kconfig/lxdialog/dialog.h:146: error: expected â)â before â*â token
  18. scripts/kconfig/lxdialog/dialog.h:147: error: expected â)â before â*â token
  19. scripts/kconfig/lxdialog/dialog.h:148: error: expected â)â before â*â token
  20. scripts/kconfig/lxdialog/dialog.h:149: error: expected â)â before â*â token
  21. scripts/kconfig/lxdialog/dialog.h:151: error: expected â)â before â*â token
  22. scripts/kconfig/lxdialog/checklist.c:31: error: expected â)â before â*â token
  23. scripts/kconfig/lxdialog/checklist.c:59: error: expected â)â before â*â token
  24. scripts/kconfig/lxdialog/checklist.c:95: error: expected â)â before â*â token
  25. scripts/kconfig/lxdialog/checklist.c: In function âdialog_checklistâ:
  26. scripts/kconfig/lxdialog/checklist.c:117: error: âWINDOWâ undeclared (first use in this function)
  27. scripts/kconfig/lxdialog/checklist.c:117: error: (Each undeclared identifier is reported only once
  28. scripts/kconfig/lxdialog/checklist.c:117: error: for each function it appears in.)
  29. scripts/kconfig/lxdialog/checklist.c:117: error: âdialogâ undeclared (first use in this function)
  30. scripts/kconfig/lxdialog/checklist.c:117: error: âlistâ undeclared (first use in this function)
  31. scripts/kconfig/lxdialog/checklist.c:117: warning: left-hand operand of comma expression has no effect
  32. scripts/kconfig/lxdialog/checklist.c:121: warning: implicit declaration of function âendwinâ
  33. scripts/kconfig/lxdialog/checklist.c:122: warning: implicit declaration of function âfprintfâ
  34. scripts/kconfig/lxdialog/checklist.c:122: warning: incompatible implicit declaration of built-in function âfprintfâ
  35. scripts/kconfig/lxdialog/checklist.c:122: error: âstderrâ undeclared (first use in this function)
  36. scripts/kconfig/lxdialog/checklist.c:140: error: âCOLSâ undeclared (first use in this function)
  37. scripts/kconfig/lxdialog/checklist.c:141: error: âLINESâ undeclared (first use in this function)
  38. scripts/kconfig/lxdialog/checklist.c:143: warning: implicit declaration of function âdraw_shadowâ
  39. scripts/kconfig/lxdialog/checklist.c:143: error: âstdscrâ undeclared (first use in this function)
  40. scripts/kconfig/lxdialog/checklist.c:145: warning: implicit declaration of function ânewwinâ
  41. scripts/kconfig/lxdialog/checklist.c:146: warning: implicit declaration of function âkeypadâ
  42. scripts/kconfig/lxdialog/checklist.c:146: error: âTRUEâ undeclared (first use in this function)
  43. scripts/kconfig/lxdialog/checklist.c:148: warning: implicit declaration of function âdraw_boxâ
  44. scripts/kconfig/lxdialog/checklist.c:148: error: âattributesâ undeclared (first use in this function)
  45. scripts/kconfig/lxdialog/checklist.c:149: warning: implicit declaration of function âwattrsetâ
  46. scripts/kconfig/lxdialog/checklist.c:150: warning: implicit declaration of function âmvwaddchâ
  47. scripts/kconfig/lxdialog/checklist.c:152: warning: implicit declaration of function âwaddchâ
  48. scripts/kconfig/lxdialog/checklist.c:156: warning: implicit declaration of function âprint_titleâ
  49. scripts/kconfig/lxdialog/checklist.c:159: warning: implicit declaration of function âprint_autowrapâ
  50. scripts/kconfig/lxdialog/checklist.c:166: warning: implicit declaration of function âsubwinâ
  51. scripts/kconfig/lxdialog/checklist.c:191: warning: implicit declaration of function âprint_itemâ
  52. scripts/kconfig/lxdialog/checklist.c:197: warning: implicit declaration of function âprint_arrowsâ
  53. scripts/kconfig/lxdialog/checklist.c:200: warning: implicit declaration of function âprint_buttonsâ
  54. scripts/kconfig/lxdialog/checklist.c:202: warning: implicit declaration of function âwnoutrefreshâ
  55. scripts/kconfig/lxdialog/checklist.c:204: warning: implicit declaration of function âdoupdateâ
  56. scripts/kconfig/lxdialog/checklist.c:207: warning: implicit declaration of function âwgetchâ
  57. scripts/kconfig/lxdialog/checklist.c:214: error: âKEY_UPâ undeclared (first use in this function)
  58. scripts/kconfig/lxdialog/checklist.c:214: error: âKEY_DOWNâ undeclared (first use in this function)
  59. scripts/kconfig/lxdialog/checklist.c:224: error: âFALSEâ undeclared (first use in this function)
  60. scripts/kconfig/lxdialog/checklist.c:225: warning: implicit declaration of function âscrollokâ
  61. scripts/kconfig/lxdialog/checklist.c:226: warning: implicit declaration of function âwscrlâ
  62. scripts/kconfig/lxdialog/checklist.c:235: warning: implicit declaration of function âwrefreshâ
  63. scripts/kconfig/lxdialog/checklist.c:285: warning: incompatible implicit declaration of built-in function âfprintfâ
  64. scripts/kconfig/lxdialog/checklist.c:286: warning: implicit declaration of function âdelwinâ
  65. scripts/kconfig/lxdialog/checklist.c:290: error: âKEY_LEFTâ undeclared (first use in this function)
  66. scripts/kconfig/lxdialog/checklist.c:291: error: âKEY_RIGHTâ undeclared (first use in this function)
  67. make[2]: *** [scripts/kconfig/lxdialog/checklist.o] Erreur 1
  68. make[1]: *** [menuconfig] Erreur 2
  69. make: *** [menuconfig] Erreur 2
Je ne vois pas ce qui cloche ! on dirait qu'il me manque un package ? D'ou vient d'erreur !?
Merci d'avance !
RedVivi[cpp]
Message édité par redvivi le 30-06-2007 à 15:19:02
n°928870
e_esprit
Posté le 30-06-2007 à 15:44:00  profilanswer
il te faut le paquet de developpement de ncurses : libncurses5-dev
n°928872
redvivi
Posté le 30-06-2007 à 16:02:51  profilanswer
Merci ! ça marche !
n°928875
redvivi
Posté le 30-06-2007 à 16:32:24  profilanswer
Après la création du paquet deb kernel-image avec fakeroot et son installation, fautil modifier grub ?
n°928876
e_esprit
Posté le 30-06-2007 à 16:33:38  profilanswer
Normalement il le fait à l'installation du paquet comme un grand.
Tu peux toujours verifier en jetant un oeil à /boot/grub/menu.lst que ton nouveau noyau est bien configuré dans grub.
n°928878
redvivi
Posté le 30-06-2007 à 16:48:06  profilanswer
Ok, et pour la sauvegarde du noyau en cours ?
n°928882
redvivi
Posté le 30-06-2007 à 17:22:18  profilanswer
J'ai dis une betise !? ça ne se sauvegarde pas un noyau !?
n°928884
e_esprit
Posté le 30-06-2007 à 17:41:27  profilanswer
C'est à dire ?
Si tu installes un nouveau noyau, l'ancien n'est pas supprimé pour autant.
Tant que tu ne desinstalles pas explicitement un noyau, il reste dispo et inclus dans le menu de grub.
n°928895
M300A
Posté le 30-06-2007 à 19:56:28  profilanswer
Si grub le fait pas > update-grub
n°928896
redvivi
Posté le 30-06-2007 à 20:00:01  profilanswer
Ok ça fonctionne! Merci à tous !
  Installation
Problème étrange avec Packet FilterAlias sous debian
Problème avec Apache 2, DirectoryIndex et accessibilité des pagesProblème d'installation Ubuntu
[debian etch] Pb d'écriture sur une clé USBRecherche fichier status pour dpkg
[Debian] Problème avec NTPDATE (no servers can be used)nvidia-legacy dans /etc/make.conf
Plus de sujets relatifs à : [Debian Etch/2.6.18] Problème de make menuconfig
