7767 connectés
  Linux et OS Alternatifs
  Débats
  Probleme deconnexion ADSL SpeedTouch
n°175554
666-667
Posté le 19-10-2002 à 00:04:02  profilanswer
Depuis quelques jours ma connexion ADSL plante et ne veut plus se relancer. Je suis obligé de rebooter pour que mon modem veuille bien se connecter...
Voici un extrait de mon /var/log/messages :
Oct 18 23:10:19 gandalf pppd[12820]: Modem hangup
Oct 18 23:10:19 gandalf pppd[12820]: Connection terminated.
Oct 18 23:10:19 gandalf pppd[12820]: Using interface ppp0
Oct 18 23:10:19 gandalf pppd[12820]: Connect: ppp0 <--> /dev/pts/0
Oct 18 23:10:20 gandalf pppoa3[13120]: PPPoA3 version 1_0 started by root (uid 0)
Oct 18 23:10:20 gandalf /etc/hotplug/net.agent: assuming ppp0 is already up
Oct 18 23:10:20 gandalf pppoa3[13120]: A previous instance seems to be running
Oct 18 23:10:20 gandalf pppoa3[13120]: A previous instance of pppoa3 seems to be running (modemID 1)
Oct 18 23:10:20 gandalf pppoa3[13120]: Use --clean/-c option to avoid this kind of problems
Oct 18 23:10:20 gandalf pppoa3[13120]: Exiting
Oct 18 23:10:20 gandalf pppd[12820]: Modem hangup
Oct 18 23:10:20 gandalf pppd[12820]: Connection terminated.
Oct 18 23:10:20 gandalf pppoa3[13126]: PPPoA3 version 1_0 started by root (uid 0)
Oct 18 23:10:20 gandalf pppd[12820]: Using interface ppp0
Oct 18 23:10:20 gandalf pppd[12820]: Connect: ppp0 <--> /dev/pts/0
Oct 18 23:10:20 gandalf pppoa3[13126]: A previous instance seems to be running
Oct 18 23:10:20 gandalf pppoa3[13126]: A previous instance of pppoa3 seems to be running (modemID 1)
Oct 18 23:10:20 gandalf pppoa3[13126]: Use --clean/-c option to avoid this kind of problems
Oct 18 23:10:20 gandalf pppoa3[13126]: Exiting
Oct 18 23:10:20 gandalf pppoa3[13134]: PPPoA3 version 1_0 started by root (uid 0)
Oct 18 23:10:20 gandalf /etc/hotplug/net.agent: NET unregister event not supported
Oct 18 23:10:20 gandalf pppoa3[13134]: A previous instance seems to be running
Oct 18 23:10:20 gandalf pppoa3[13134]: A previous instance of pppoa3 seems to be running (modemID 1)
Oct 18 23:10:20 gandalf pppoa3[13134]: Use --clean/-c option to avoid this kind of problems
Oct 18 23:10:20 gandalf pppoa3[13134]: Exiting
Oct 18 23:10:20 gandalf pppoa3[13147]: PPPoA3 version 1_0 started by root (uid 0)
Oct 18 23:10:20 gandalf pppoa3[13147]: A previous instance seems to be running
Oct 18 23:10:20 gandalf pppoa3[13147]: A previous instance of pppoa3 seems to be running (modemID 1)
Oct 18 23:10:20 gandalf pppoa3[13147]: Use --clean/-c option to avoid this kind of problems
Oct 18 23:10:20 gandalf pppoa3[13147]: Exiting
Oct 18 23:10:20 gandalf pppoa3[13178]: PPPoA3 version 1_0 started by root (uid 0)
Oct 18 23:10:20 gandalf pppoa3[13178]: A previous instance seems to be running
Oct 18 23:10:20 gandalf pppoa3[13178]: A previous instance of pppoa3 seems to be running (modemID 1)
Oct 18 23:10:20 gandalf pppoa3[13178]: Use --clean/-c option to avoid this kind of problems
Oct 18 23:10:20 gandalf pppoa3[13178]: Exiting
Oct 18 23:10:20 gandalf pppoa3[13188]: PPPoA3 version 1_0 started by root (uid 0)
Oct 18 23:10:20 gandalf last message repeated 2 times
Oct 18 23:10:20 gandalf pppoa3[13188]: A previous instance seems to be running
Oct 18 23:10:20 gandalf pppoa3[13188]: A previous instance of pppoa3 seems to be running (modemID 1)
Oct 18 23:10:20 gandalf pppoa3[13188]: Use --clean/-c option to avoid this kind of problems
Oct 18 23:10:20 gandalf pppoa3[13188]: Exiting
Oct 18 23:10:20 gandalf pppoa3[13218]: PPPoA3 version 1_0 started by root (uid 0)
Oct 18 23:10:20 gandalf pppoa3[13218]: A previous instance seems to be running
Oct 18 23:10:20 gandalf pppoa3[13218]: A previous instance of pppoa3 seems to be running (modemID 1)
Oct 18 23:10:20 gandalf pppoa3[13218]: Use --clean/-c option to avoid this kind of problems
Oct 18 23:10:20 gandalf pppoa3[13218]: Exiting
Oct 18 23:10:20 gandalf pppd[12820]: Exit.
Oct 18 23:10:21 gandalf /etc/hotplug/net.agent: assuming ppp0 is already up
Oct 18 23:10:21 gandalf /etc/hotplug/net.agent: NET unregister event not supported
Oct 18 23:10:21 gandalf last message repeated 2 times
Merci d'avance pour votre aide :hello:
n°175555
dofor
:F
Posté le 19-10-2002 à 00:04:46  profilanswer
euh... tu as fait une recherche sur le forum? :sweat:
n°175556
dofor
:F
Posté le 19-10-2002 à 00:05:48  profilanswer
n°175558
666-667
Posté le 19-10-2002 à 00:06:54  profilanswer
oui comme toujours avant de poster j'ai fait une petite recherche mais j'ai rien trouvé qui puisse repondre a mon pb ...
 :sweat:
n°175560
dofor
:F
Posté le 19-10-2002 à 00:13:14  profilanswer
arf :/
je pensais qu'au milieu de tous les topics liés au speedtouch tu trouverais ton bonheur :/
ben désolé je peux pas t'aider, j'ai choisi un modem ethernet pour pas être emmerdé justement :/
ou alors achete un routeur qui accepte les modems usb...
n°175561
Zzozo
Un peu, passionément, à la fol
Posté le 19-10-2002 à 00:17:00  profilanswer
Quelle est la version de ton noyau ?
n°175576
FlamM
comme tarte flambée bien sûr !
Posté le 19-10-2002 à 00:58:10  profilanswer
t'utilise quelle version de pilotes pour le modem ?
avant la version 1.1 les pppoa3 avait tendance à ne pas se terminer quand il y avait déconnection du coup il bloque l'accès au modem quand tu tentes de te reconnecter. 9a faisait aussi que l'option persist ne focntionnait pas.
essaie de faire un killall pppoa3 et killall pppd avant de tenter de te reconnecter.
* La vitesse de la lumière étant supérieure à celle du son, certaines personnes paraissent brillantes jusqu'à ce qu'elles ouvrent leur gueule. *
n°175619
Dacal
Posté le 19-10-2002 à 08:56:32  profilanswer
Tu utilises quel noyau ? Le problème peut venir de là :
- Si < à 2.4.18, il faut patcher le module "HDLC line discipline support".
- Si >= à 2.4.18, normalement, c'est bon...
RTFM... ;)
n°175628
aurelboiss
Posté le 19-10-2002 à 10:15:57  profilanswer
moi g eu le meme probleme alors g changer de modem pour prendre un home ethernet mais aparament c ma raie manta qui commencait a donner des signes de faiblesses. pourant ca faisait 7 mois que je l'avais et aucuns prob a signales mais ca arrive
n°175654
666-667
Posté le 19-10-2002 à 11:02:32  profilanswer
Mon noyau est un 2.4.18
n°175655
666-667
Posté le 19-10-2002 à 11:05:30  profilanswer
RTFM... ;)
Ok ok ben je vais tenter ca ... alors
Mais le point que je comprend pas c'est que ca fait 6 mois que ca tourne sans pb comme ca et paf d'un coup  :ouch: ca me met cette erreur!
n°175657
666-667
Posté le 19-10-2002 à 11:06:57  profilanswer
ouais mais si j'explique ca a wanadoo ils voudront jamais me m'echanger le modem ...
n°175660
leirn
A.D.I.D.A.S.
Posté le 19-10-2002 à 11:17:42  profilanswer
tu leur dit ke le modem marche pu, ca suffit po?
"Je brandirai une épée d'orichalque, je m'assouvirai sur des Templiers." | "Avec dans son sillage l'Ombre du Diable, Leirn appelait les morts pour une danse macabre et déchainaît les horreurs de la nuit..."
n°175665
666-667
Posté le 19-10-2002 à 11:22:14  profilanswer
heu je me rappelle plus qu'elle version j'ai installée mais quand je fais pppoa3 --version il connait pas  :(
Comment je peux connaitre la version du pilote pppoa3 ?
n°175674
FlamM
Posté le 19-10-2002 à 11:35:44  profilanswer
en fait quand je parle de version c'est pour l'intégralité des pilotes de Papillault, à titre indicatif je crois que la 1.1 est sortie début juin.
Sinon est-ce que ça focntionne si tu tues les ppoa3 et pppd qui trainent avant de rettenter une connexion
  Débats
[debian] Ya plus probleme ...probleme pour installer l'opengl Help Me please ! :'(
La plus petite distribution pour un firewall avec ADSL USB?Probleme de partition pour installer Linux
Problème InstallationProblème de reboot sur les portables avec Linux ?
Probleme d'installation Mandrake 9[probleme pas grave lors d'install d'audigy sous debian...]
[Linux] probleme simple.... mais ca urge!![MDK9] Problème d'icônes sur bureau et Konqueror après installation ?!
Plus de sujets relatifs à : Probleme deconnexion ADSL SpeedTouch
