4731 connectés
  [Résolu] Gros probleme chut de FPS
n°10440620
daychi
Posté le 07-10-2018 à 07:28:05  profilanswer
Bonjour a tous, j'ai actuellement monté mon PC il y a un mois:
-Acer Predator XB241Hbmipr G-Sync
-Corsair TX550M, 550W
-KFA2 GeForce GTX 1080 EXOC SNIPER White, 8 Go
-AMD Ryzen 7 2700X (3.7 GHz)
-Samsung Série 970 EVO, 250 Go, M.2 (Type 2280)
-MSI B450 GAMING PLUS
-DDR4 Corsair Vengeance LPX, Noir, 2 x 8 Go, 3000 MHz, CAS 15
-Be Quiet ! Pure Rock
J'ai de gros drop de FPS periodiquement je passe de 144(bloqué) a 120 (toute les 1 secondes), quand je branche mon deuxieme ecran c'est encore pire je passe de 144 a 30-60 cela depend
voici quelque graphique:
http://image.noelshack.com/minis/2018/40/7/1538890570-2018-10-06-17h46-cpuusage-cpu-usage.png
http://image.noelshack.com/minis/2018/40/7/1538890570-2018-10-06-17h46-frequency-cpu-0.png
http://image.noelshack.com/minis/2018/40/7/1538890570-2018-10-06-17h46-frequency-gpu-0-mem.png
http://image.noelshack.com/minis/2018/40/7/1538890570-2018-10-06-17h46-frequency-bus.png
http://image.noelshack.com/minis/2018/40/7/1538890570-2018-10-06-17h46-fps-fps.png
http://image.noelshack.com/minis/2018/40/7/1538890573-2018-10-06-17h46-frequency-gpu-0.png
http://image.noelshack.com/minis/2018/40/7/1538890602-2018-10-06-17h46-frequency-gpu-0.png
http://image.noelshack.com/minis/2018/40/7/1538890602-2018-10-06-17h46-memory-usage-memory-used.png
http://image.noelshack.com/minis/2018/40/7/1538890602-2018-10-06-17h46-temperature-cputin.png
http://image.noelshack.com/minis/2018/40/7/1538890602-2018-10-06-17h46-temperature-gpu.png
http://image.noelshack.com/minis/2018/40/7/1538890602-2018-10-06-17h46-voltage-3vcc.png
http://image.noelshack.com/minis/2018/40/7/1538890618-2018-10-06-17h46-voltage-avcc.png
http://image.noelshack.com/minis/2018/40/7/1538890618-2018-10-06-17h46-voltage-cpu-vcore.png
http://image.noelshack.com/minis/2018/40/7/1538890618-2018-10-06-17h46-voltage-cpu-vdd.png
http://image.noelshack.com/minis/2018/40/7/1538890618-2018-10-06-17h46-voltage-gpu-2.png
http://image.noelshack.com/minis/2018/40/7/1538890618-2018-10-06-17h46-voltage-soc-vdd.png
http://image.noelshack.com/minis/2018/40/7/1538890635-2018-10-06-17h46-voltage-vid.png
http://image.noelshack.com/minis/2018/40/7/1538890635-2018-10-06-17h46-voltage-vin1.png
http://image.noelshack.com/minis/2018/40/7/1538890635-2018-10-06-17h46-voltage-vin4.png
http://image.noelshack.com/minis/2018/40/7/1538890635-2018-10-06-17h46-voltage-vin5.png
http://image.noelshack.com/minis/2018/40/7/1538890635-2018-10-06-17h46-voltage-vin6.png
Merci de bien vouloir analyser et me donner les raisons de ce dysfonctionnement et la solutions a appliqué sil vous plait.
en attente de votre aide, cordialement.
Message édité par daychi le 10-10-2018 à 10:25:09
n°10440658
zonka
x58 forever!
Posté le 07-10-2018 à 10:05:56  profilanswer
http://image.noelshack.com/fichiers/2018/40/7/1538890602-2018-10-06-17h46-temperature-cputin.png
Ca chauffe là-dedans.....
=> quel est ton ventirad? Celui fourni par AMD si c'est le cas n'est probablement pas suffisant.
n°10440740
daychi
Posté le 07-10-2018 à 12:37:18  profilanswer
Bonjour, merci pour ta réponse.
j'ai ce ventirad : Be Quiet ! Pure Rock.
que me conseille tu?
n°10440760
zonka
x58 forever!
Posté le 07-10-2018 à 13:41:39  profilanswer
Normalement c'est un bon rad : peut-être vérifier le montage et/ou l'application de la pâte thermique.
Je suis peu familier des Ryzen : le 2700X c'est 3.7 Ghz, 4.35 ghz en turbo.
Si on se fie à OCCT, tu es à 4.2 Ghz lors du test (?)
Le 2700X c'est 105W ; ton ventirad est donné pour 150W donc ça devrait être OK.
=> voir si ton boitier est correctement ventilé.
=> touche le rad : s'il est brûlant lors d'un test où le CPU monte à 90°C comme ton graph le montre, c'est "logique" ; s'il est à peine tiède, ça peut être le signe d'un mauvais contact avec le CPU et donc mauvaise dissipation.
Tu peux nous faire un OCCT CPU pour voir ce qui se passe CPU "seul en charge"? Il est possible que la machine chauffe globalement quand tout est à fond si l'alim, la carte graphique et le CPU chauffe dans un boitier mal ventilé etc.
Message édité par zonka le 07-10-2018 à 13:42:12
n°10440788
daychi
Posté le 07-10-2018 à 14:43:30  profilanswer
OCCT CPU : https://goopics.net/a/Y1Dbn4UW
Je ne sais pas pourquoi mon processeur est a 4.2 ghz alors que je n'ai pas overclock (enfin je ne l'ai pas fait exprès alors).
Merci pour ton aide !
Message édité par daychi le 07-10-2018 à 14:43:42
n°10440791
zonka
x58 forever!
Posté le 07-10-2018 à 14:49:14  profilanswer
Bon, c'est pareil : 90°C : c'est trop.
Donne nous quelques détails:
- boitier : bien ventilé?
- rad : brulant ou a peine tiède au toucher en charge?
perso:
1) aller dans le BIOS au démarrage du PC, vérifier s'il y a une option d'overclock automatique activée (les noms varient : "OC Genie"? etc) ; la fréquence du CPU est affichée dans le BIOS etc. fais nous des photos du BIOS eventuellement.
2) s'il n'y a pas d'OC auto : démontage/nettoyage-réapplication de pâte thermique/remontage
n°10440796
daychi
Posté le 07-10-2018 à 14:57:10  profilanswer
Le boitier est vraiment tiède voir froid, j'ai qu'un seul ventilateur a l'arrière.
Je n'ai pas d'appareil photo mon téléphone étant cassé.
Au montage j'ai enlever un peu de pâte thermique en passant mon doigt déçu sans faire exprès, ça peut être du a cela ou pas?
coté BIOS j'ai remis tout par Default, la fréquence est 3.7ghz affiché.
Je pense aller acheter la pâte thermique et nettoyer+remonter et je vous tiens au courant, merci beaucoup pour avoir prit le temps de m'aider !
Message édité par daychi le 07-10-2018 à 14:58:22
n°10440799
zonka
x58 forever!
Posté le 07-10-2018 à 15:00:10  profilanswer
Y'a pas de souci :)
=> fais un test OCCT CPU avec ton BIOS remis à zero pour voir : frequence/chauffe
=> je ne parle pas du boitier/tour mais du RADIATEUR du Dark Rock :p
n°10440830
daychi
Posté le 07-10-2018 à 15:57:14  profilanswer
Oui je parle bien du radiateur du dark rock, il est tiède.
OCCT CPU aprés remise a zero du bios :
https://goopics.net/a/7pdUK2L8
n°10440833
zonka
x58 forever!
Posté le 07-10-2018 à 16:05:42  profilanswer
Merci.
La fréquence affichée est la même (normal ou erreur de lecture OCCT, ou overclock appliqué "par derrière"...), ainsi que la température à 90°C
Pour la pâte thermique, pas cher et sympa tu as de la Noctua NT-H1 ou Artic MX2/MX4.
On a tous notre façon de faire avec des polémiques parfois, je te livre ma méthode (éprouvée sur des dizaines de machines depuis >15 ans mais bon hein)
=> retirer la pâte thermique avec un petit morceau de sopalin et du dissolvant à ongles sans acétone
=> appliquer une LIGNE de pâte thermique sur un bord du CPU
=> utiliser une vieille carte bleue ou equivalent pour ETALER la pâte de manière homogène sur toute la surface. (remettre de la pâte sur le bord et étirer à nouveau s'il n'y en a pas assez)
=> ne pas hésiter à "écrémer" si l'épaisseur est trop importante.
Le but est d'avoir une surface homogène, mais PAS TROP EPAISSE (sinon ça isole thermiquement)
Certains te conseilleront de mettre "une noix de pâte au centre" et de poser le rad, la nature fera le reste = perso je trouve ça toujours hallucinant mais bon :D
Message édité par zonka le 07-10-2018 à 16:06:19
n°10440835
daychi
Posté le 07-10-2018 à 16:08:58  profilanswer
j'ai commandé la Noctua NT-H1, je vais effectuer ton protocole pas a pas et aprés avoir remonté le tout, je referai quelques test, et je reviendrai vers toi si tu est toujours là.
merci beaucoup pour ton aide et le temps que tu m'a accordé !
n°10440838
zonka
x58 forever!
Posté le 07-10-2018 à 16:10:46  profilanswer
Pas de souci.
Ca DEVRAIT être la cause du problème = pas normal d'avoir 90°C avec ce processeur.
Si au final, ça ne change rien, bon, je t'aurai fait faire des manips pour rien, et on retournera coté BIOS pour être CERTAINS que la carte-mère n'applique pas un léger overclock automatique et/ou une tension de malade au processeur dans le même temps.
Tiens nous au courant.
n°10442890
daychi
Posté le 10-10-2018 à 10:24:14  profilanswer
http://image.noelshack.com/minis/2018/41/3/1539159792-sans-titre.png
J'ai trouvé le problème, et j'ai remis de la pâte thermique, tout est revenu a la normal, ca bug plus.
en auto la core boost fais un overclock je ne sais pas pourquoi, du coup je l'ai desactiver!
merci pour ton aide!! a bientot
n°10442896
zonka
x58 forever!
Posté le 10-10-2018 à 10:33:06  profilanswer
Voilà... Un OC auto de merde au passage dans le BIOS ;)
Message édité par zonka le 10-10-2018 à 10:33:48
n°10442899
chermositt​o
Posté le 10-10-2018 à 10:37:15  profilanswer
je débarque : sur la dernière copie d'écran, le cpu volt est à 1,385.
Y'a pas moyen d'optimiser cela ?
n°10442930
daychi
Posté le 10-10-2018 à 11:20:21  profilanswer
La capture d’écran n'est pas de moi, je l'ai repris de google image juste pour montré d'ou viens le problème.
Je n'ai pas touché au voltage personnellement j'ai laissé en automatique. Que me conseilles-tu?
Problème CPU EZ debug led allumée[Résolu] Problème FPS 1080TI
Montage PC - Problème pas de signal écranProblème avec pilote Intel contrôleur IDE ATA/ATAPI après installlatio
Problème ports SATA - SSDProbleme corsair h150i pro pas reconnu par windows ,icue...
probleme triple écrans avec bordure
Plus de sujets relatifs à : [Résolu] Gros probleme chut de FPS
