11039 connectés
 Page :   1  2  3  4  5  ..  30  31  32  ..  553  554  555  556  557  558
[Topic Unique] NVidia GK110 - 780, 780Ti, Titan, Titan Black & Titan Z
n°8619659
aliss
Rhyme the Rhyme Well
Posté le 12-02-2013 à 16:07:32  profilanswer
Qu'ils soient dispatchés sur 2 pcb's ou 4 ne change pas grand chose, ça reste 4 gpu's en sli quel que soit le terme marketeux inventé.  ;)
n°8619672
romanov45
Odi panem quid meliora.
Posté le 12-02-2013 à 16:16:24  profilanswer
c'est pas faux. :)
FEEDBACK
n°8619675
B1LouTouF
PSN : Geo62280 / GT : Mr Geo
Posté le 12-02-2013 à 16:19:21  profilanswer
AVatar66 a écrit :
900€*4=3600€.....seulement 6 fois mon loyer  :D
Je vais voir avec mon proprio si il veux bien me faire grâce d'une demi année de loyer :)
vas y 2/2 , vu la puissance la , 4 ça fait quand même énorme  :love:
FeedBack
n°8619676
Invite_Sur​prise
Racaille de Shanghaï
Posté le 12-02-2013 à 16:19:32  profilanswer
Special Report: Nvidia GeForce GTX official winning features of Titan - Donanimhaber
First let me say, contrary to the news in the last few days, not 512-bit GeForce GTX Titan will support 384-bit memory bus. GK110 28nm Kepler architecture, parallel processing unit owned 2688 graphics chip graphics card, Nvidia's official documents as the world's fastest single-GPU graphics card goes. So, contrary to some claims GeForce GTX Titan, dual-GPU GeForce GTX 690 is faster, but performance is very close to the values of the information.
GeForce GTX 690 is the same as in the high-tech arena, and thermal conductivity, high strength metal used in the used graphics card equipped with vapor chamber-based cooling is accompanied by 6GB of GDDR5 memory. The performance of texture fill 288 billion / sec (GeForce GTX 690 is 234) we learn that the graphics card 5.4 teraflops of computing power will at the same time.
PCIe 3.0 compliant graphics card with Nvidia's recommended minimum power supply for the 600 Watt.
Astronomical video card is expected to be launched with a retail price, GK110 graphics chip performance / watt performance benchmarks that will capture the single-GPU graphics card for a very long time as is expected to remain as
Message édité par Invite_Surprise le 12-02-2013 à 16:22:01
n°8619690
El Paladin​ Malefik
Posté le 12-02-2013 à 16:32:14  profilanswer
Ou sinon ils nous font une GTX 790 avec 2 puces de Titan sur un même PCB  :love:
n°8619698
silv3rm@n
Posté le 12-02-2013 à 16:40:05  profilanswer
AVatar66 a écrit :
HS-Troll ON:
IRL 2m10 avec ce qui va bien entre les jambes  :D
Qui n'en veux?
Hs-Troll OFF
plutot que des ecris,pourrait'on voir  :D ?  :sol:
Celui qui sauve une  vie , sauve le monde entier .
n°8619701
Invite_Sur​prise
Posté le 12-02-2013 à 16:40:44  profilanswer
La GeForce Zeus  [:bailey's]
Message édité par Invite_Surprise le 12-02-2013 à 16:41:16
n°8619703
romanov45
Posté le 12-02-2013 à 16:42:09  profilanswer
J'imagine la conso de malade... :(
FEEDBACK
n°8619708
Eyldebrand​t
Assisté par IA
Posté le 12-02-2013 à 16:45:00  profilanswer
 [:cerveau lent]
Topic ventes hardware
n°8619715
B1LouTouF
Posté le 12-02-2013 à 16:48:05  profilanswer
comme la 690 surement sauf que la puissance....  :love:
une 790 lightning  :love:   :love:   :love:
Message édité par B1LouTouF le 12-02-2013 à 16:49:08
FeedBack
n°8619745
romanov45
Posté le 12-02-2013 à 17:18:01  profilanswer
une GTX 789780 XXX XTI ultra lighning DirectCuX 256Go :D
FEEDBACK
n°8619803
NoradII
Il y a 17 ans naquit un PC
Posté le 12-02-2013 à 18:19:37  profilanswer
Peut-être pas non. un indice ?
De ce que j'ai vu le scaling, et la gestion IG surement !
Un Quad-SLI passe inaperçu dans 89% des cas (2x GTX295), là ou un 4-Way (4x GTX285) est plus proche des 50% et en arrive parfois à être considéré comme un 3-Way + PhysX (10% des cas).
valid.x86.fr/575505 /842925 /902578
n°8619832
aliss
Posté le 12-02-2013 à 18:48:04  profilanswer
Peut-être est-ce dû à la gestion des lignes PCI-E, voir aux drivers, néanmoins au delà de 3 gpu's le scaling reste globalement mauvais (que ça soit chez nVidia ou AMD). :/
n°8619845
hifibuff
Posté le 12-02-2013 à 18:56:50  profilanswer
le 4-way que ce soit avec deux cartes bi-GPUs ou quatre cartes (à fréquences GPU / shader / mémoire égales, cela va sans dire), la seule différence tient effectivement au switch PLX installés sur les cartes bi-GPUs qui est souvent un goulet d'étranglement des perfs par rapport à quatre cartes - pour peu qu'on ait de la CM et du proc' qui gère bien les multiples lignes PCIe.
Cela étant, le scaling en 4 vs 3 GPUs, n'est, aux dernières nouvelles, pas sensas c'est vrai...
Message édité par hifibuff le 12-02-2013 à 18:59:55
"Every man dies, not every man really lives"
n°8619851
calagan57
BF3 : calagan57
Posté le 12-02-2013 à 19:01:56  profilanswer
on s'en fou on veut des news du titan bordel!  :o  :fou:
Waterbox
n°8619916
NoradII
Posté le 12-02-2013 à 19:59:38  profilanswer
hifibuff a écrit :
le 4-way que ce soit avec deux cartes bi-GPUs ou quatre cartes ..
[:kurt haribo:2]
Le monsieur, il a pas compris
n°8619925
hifibuff
Posté le 12-02-2013 à 20:04:26  profilanswer
Genre, t'as pas compris Norad...
Mais tu as raison, 4-way-> 4 cartes; quad SLI -> 4 GPUs sur deux cartes. Le fond du discours consistant à dire qu'il n'y a aucune différence dans les faits, à part les switchs PLX sur les cartes bi-GPUs. C'est donc purement marketing mais, rendons à nV, ce qui appartient à nV : c'est eux qui créent les appellations, autant les utiliser de façon juste :jap:
Message édité par hifibuff le 12-02-2013 à 20:07:40
n°8620022
Activation
21:9 kill Surround Gaming
Posté le 12-02-2013 à 21:07:29  profilanswer
4-Way ça existe ça ? je croyais que le 4 eme était forcément utilisable uniquement par physx et donc "non considéré" dans la chaine sli
Message édité par Activation le 12-02-2013 à 21:08:10
n°8620045
Bob Wiskar​fe
Posté le 12-02-2013 à 21:16:34  profilanswer
4-way existe ;)
Le 3way +physx existe aussi, mais c'est pas forcément compatible 4way -> exemple:  EVGA 3way sli classified (E760), sur laquelle on peut mettre 3 680 en sli, et une autre carte (en simple épaisseur only) pour physx
Message édité par Bob Wiskarfe le 12-02-2013 à 21:26:05
I7 920 - EVGA Classified X58 3 way-SLI - GTX670 EVGA FTW - 3*4go DDR3-2000 - BenQ XL2420T - 3D 120Hz 1920x1080 - Win7 x64
n°8620065
hifibuff
Posté le 12-02-2013 à 21:25:49  profilanswer
Il me semble aussi me souvenir qu'à l'époque, des tests avaient été fait sur le micro-stuttering et que c'était moins présent sur des configurations de cartes impaires...Je ne sais pas si c'est encore d'actualité mais c'est une des raisons qui m'a poussé à ne jamais dépasser 3 cartes en SLI ;)
n°8620122
Invite_Sur​prise
Posté le 12-02-2013 à 22:00:58  profilanswer
The Titans will not be around for long guys. The yield is so very low. The numbers for the entire of Europe are not many units at all.
http://forums.overclockers.co.uk/s [...] tcount=547
n°8620145
kalidrimmm
Posté le 12-02-2013 à 22:13:38  profilanswer
va falloir être à l’affût :o ils vont peut être limité à 1 carte par personne :o
en attendant 680 de référence à 369e :o
http://www.grosbill.com/4-selectio [...] m_content=
Message édité par kalidrimmm le 12-02-2013 à 22:13:58
n°8620176
ravenloft
Meilleur jeu du 20ème siècle
Posté le 12-02-2013 à 22:29:36  profilanswer
Message édité par ravenloft le 12-02-2013 à 22:30:11
n°8620187
mum1989
Posté le 12-02-2013 à 22:35:32  profilanswer
Toujours plus cher qu'une 7970 de base.
Allez un effort
n°8620266
wnorton
Je suis néerlandophone
Posté le 12-02-2013 à 23:12:03  profilanswer
Personne d'assez fou pour tenter un quad sli de titan? :D
moi 4 ou rien :D
Je suis néerlandophone une fois
n°8620272
wnorton
Posté le 12-02-2013 à 23:14:23  profilanswer
j'en prend 2 alors :D
n°8620284
wnorton
Posté le 12-02-2013 à 23:17:49  profilanswer
Bon qui se zigouille en premier 1 carte par personne mais ils sont fou  :cry:
n°8620314
NoradII
Posté le 12-02-2013 à 23:31:48  profilanswer
http://www.nokytech.net/images/news/Evga/evga_x58_4_way_sli_03.jpg
Visuellement ça donne ça, mais dans les pilotes c'est plus 2x (2-Way SLI) [0;2/1;3]@+1/2 pour l'AFR NVIDIA.
Sinon ça scale de -1 à +12% par rapport à un Quad-SLI
Message édité par NoradII le 12-02-2013 à 23:33:05
n°8620321
XDunder
Posté le 12-02-2013 à 23:37:21  profilanswer
NoradII a écrit :
http://www.nokytech.net/images/new [...] sli_03.jpg
Bonjour le refroidissement en air cooled...
n°8620367
hifibuff
Posté le 12-02-2013 à 23:58:55  profilanswer
ravenloft a écrit :
C'est donc une carte collector pour dire:" messieurs on est capable de faire une très grosse carte standard de fin 2014-2015 et avec ça, on essaie d'occuper l'espace car la vraie remplaçante de la gtx680 n'arrivera pas avant 1 an".
Je le vois tellement gros que c'est déprimant.  :cry:
Je le sens venir également...Si c'est le cas et qu'on a des cartes au compte-goute, pire que les 690, je ne vois comment nous-autres, pôôôvres européens, nous pourrions avoir du stock.
Et effectivement, ils auraient l'excuse toute trouvée pour dire : "on sort plus rien d'autre avant 9-12 mois comme AMD"... :(
Message édité par hifibuff le 13-02-2013 à 00:11:00
n°8620379
Modigliani​-Miller
Posté le 13-02-2013 à 00:02:45  profilanswer
C'est moi ou vous vous plaignez que vos cartes à 400 € ne soient olus dépassées au bout de 12 mois ?
n°8620388
wnorton
Posté le 13-02-2013 à 00:10:15  profilanswer
6 mois vue à la vitesse que sa avance  :whistle:
n°8620389
hifibuff
Posté le 13-02-2013 à 00:11:46  profilanswer
Non, non, c'est pas toi  :o (et c'est 550 euros x2 pour moi :p)
n°8620390
XDunder
Posté le 13-02-2013 à 00:11:50  profilanswer
Effectivement je suis pas certain que ce soit un mal. Ca forcera peut être un peu les devs à bosser sur les optimisations et les pilotes pour tirer d'avantage du matériel.
( et perso je me sentirai moins sous pression pour rester "up to date" :o )
Message édité par XDunder le 13-02-2013 à 00:17:32
n°8620407
NoradII
Posté le 13-02-2013 à 00:25:59  profilanswer
détrompe toi, perso en GTX285 ça nous a fait un joli 94/96/97/93
n°8620408
hifibuff
Posté le 13-02-2013 à 00:27:14  profilanswer
Je ne dis pas que les devs devraient gâcher de la puissance sur nos CGs en misant systématiquement sur les nouveaux plus puissants pour faire leur boulot d'optimisation, mais ça a toujours été comme ça sur PC...
Ceux qui veulent de l'efficience et de l'optimisation avant tout, ils prennent une console :o
Si les deux géants s'accordent pour ne rien sortir avant la fin de l'année (9-12mois) hors Titan, ce serait autant que je me souvienne, un précédent et une mauvaise nouvelle pour le PC quoi qu'on en dise, surtout avec l'arrivée des nouvelles consoles.
Message édité par hifibuff le 13-02-2013 à 00:27:56
n°8620412
Yoyo_5
Posté le 13-02-2013 à 00:30:22  profilanswer
Vu ce qu'elles vont avoir sous le capot, t'inquiète pas, une vulgaire GTX660Ti sera toujours plus perf... ^^
¤ Paix et félicité ¤
n°8620436
kroks-
Posté le 13-02-2013 à 00:49:29  profilanswer
n°8620457
mum1989
Posté le 13-02-2013 à 01:06:33  profilanswer
Avec une disponibilité limitée ça ne poussera pas ni AMD ni NVIDIA à baisser le prix de leur vieille carte :/
(d'autant plus qu'elle sera à 800-900€ évidemment)
n°8620461
wnorton
Posté le 13-02-2013 à 01:10:12  profilanswer
Pas juste  :cry:
Edit: si pas sorti avant la fin du mois je me prend une GTX690  :o
Message édité par wnorton le 13-02-2013 à 01:12:12
n°8620465
mum1989
Posté le 13-02-2013 à 01:14:06  profilanswer
wnorton a écrit :
Pas juste  :cry:
O que je te plains, tu ne pourras pas remplacer tes vieilles 570 si peu performantes en quad SLi.
[:hido45] [:dieggg']
[HFR] Actu : GTC: Plus de détails sur le GK110[HFR] Actu : Nvidia lance les GT 610, 620 et 630
[HFR] Actu : GTC: Nvidia lève le voile sur le GK110[HFR] Actu : GTC: GTC 2012: la semaine du GPU computing
AMD A8 3870K APU + NVIDIA GEFORCE GT...[Topic Unique] ASUS - Les Cartes mères Z77
Mise à jour NVIDIA GT 330M sur SONY VPCL14S1E[HFR] Actu : Résultats Nvidia pour le premier trimestre
[HFR] Dossier : Nvidia GeForce GTX 670 en test
Plus de sujets relatifs à : [Topic Unique] NVidia GK110 - 780, 780Ti, Titan, Titan Black & Titan Z
