Bojour, voila ma petite config:
CPU Info
CPU 1/1
Intel(R) Pentium(R) 4 CPU 3.00GHz
Manufacturer Intel
Family Intel(R) Pentium(R) 4 CPU 3.00GHz
Architecture 32-bit
Internal Clock 3.0 GHz
Internal Clock Maximum 3.0 GHz
External Clock 200.0 MHz
Socket Designation CPU 1
Type Central
HyperThreadingTechnology Available - 2 Logical Processors
Capabilities MMX, CMov, RDTSC, SSE, SSE2, PAE
Version Intel(R) Pentium(R) 4 CPU 3.00GHz
Caches
Level 1 8 KB
Level 2 512 KB
Level 3 0 B
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.2180
Primary Device RADEON X850 Series
Display Device 1/1
RADEON X850 Series Driver 6.14.10.6583
Description RADEON X850 Series
Manufacturer ATI Technologies Inc.
Total Local Video Memory 256 MB
Total Local Texture Memory 256 MB
Total AGP Memory 64 MB
Driver File ati2dvag.dll
Driver Version 6.14.10.6583
Driver Details 8.191-051028a1-027345C-ATI
Driver Date 10-28-2005
Driver WHQL Certified true
Max Texture Width 2048 px
Max Texture Height 2048 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 2.0
Pixel Shader Version 2.0
Max Vertex Blend Matrices 37
Max Texture Coordinates 8
VGA Memory Clock 540.0 MHz
VGA Core Clock 519.8 MHz
PCI
Name RADEON X850 Series
Vendor ID 0x1002
Device ID 0x4b49
SubSystem ID 0x009e1043
Revision ID 0x0000
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [UYVY]
FourCC [YUY2]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
DirectShow
Version 9.0c
Registered DirectShow Filters
.RAM file Parser
AC3 Parser Filter
AC3 Source Filter
AC3Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
Avi Source
Avi Splitter
CDXA Reader
Color Space Converter
CoreAAC Audio Decoder
CoreFLAC Audio Decoder
CoreFLAC Audio Source
CoreVorbis Audio Decoder
Creative MP3 Source Filter
CyberLink Audio Decoder
CyberLink AudioCD Filter
CyberLink DVD Navigator
CyberLink Video/SP Decoder
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
DirectVobSub (auto-loading version)
DivX Decoder Filter
DivX MPEG-4 DVD Video Decompressor
Dtrameur dcalage BDA
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
Indeo Audio Software
Indeo Video 4.5 Decompression Filter
Indeo Video 5.2 Decompression Filter
InterVideo Audio Decoder
InterVideo Audio Processor Fx
InterVideo Video Decoder
Internal LMRT Renderer
Internal Script Command Renderer
Intervideo H.264 Decoder
Line 21 Decoder
Line 21 Decoder 2
Lyric Parser
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
MainConcept (AdobeEncore) MPEG Audio Decoder
MainConcept (AdobeEncore) MPEG Splitter
MainConcept (AdobeEncore) MPEG Video Decoder
Matroska Source
Matroska Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Morgan Stream Switcher
Multi-file Parser
NSC file Parser
NVF Filter
Nero DVD Decoder
Nero Digital Audio Decoder
Nero Digital Parser
Nero ES Video Reader
Nero Video Decoder
Ogg Multiplexer
Ogg Splitter
Overlay Mixer2
QT Decompressor
QuickTime Movie Parser
RealAudio Decoder
RealMedia Source
RealMedia Splitter
RealVideo Decoder
SAMI (CC) Parser
SubtitleSource (Preview)
SubtitleSource (S_ASS)
SubtitleSource (S_SSA)
SubtitleSource (S_TEXT/ASCII)
SubtitleSource (S_TEXT/UTF8)
True Audio Decoder
True Audio Encoder
True Audio Splitter
TrueMotion 2.0 Decompressor
URL StreamRenderer
VBI Surface Allocator
VGA 16 Color Ditherer
Video Port Manager
Video Renderer
Vorbis Decoder
WM ASF Reader
WM ASF Writer
WMS Filter
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Pad VU Data Grabber
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
XviD MPEG-4 Video Decoder
DirectSound
Version 5.3.2600.2180
Speaker Configuration Quadraphonic
Primary Device SB Live! Audio [DF80]
Sound Device 1/1
Creative EMU10K1 Audio Processor (WDM) Driver 5.12.2.290
Description SB Live! Audio [DF80]
Manufacturer Creative Technology, Ltd.
Driver File ctaud2k.sys
Driver Version 5.12.2.290
Driver Date 6-16-2003
Max Supported 3D Hardware Sounds 32
HD Audio Support false
EAX Support Supported
PCI
Name Creative EMU10K1 Audio Processor (WDM)
Vendor ID 0x1102
Device ID 0x0002
SubSystem ID 0x80671102
Revision ID 0x000a
Capabilities
Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
Memory Info
Total Physical Memory 1022 MB
Free Physical Memory 560 MB
Total Pagefile Memory 2.40 GB
Free Pagefile Memory 1.94 GB
Memory Array 1/1
Max Module Capacity 0 B
Supported Error DC Parity
Supported Speeds
Supported Types
Supported Voltages
Memory Slot 1/4
Installed Enabled Size 512 MB
Form Factor DIMM
Frequency 0.0 Hz
Slot DIMM0
Manufacturer <unknown>
Type Details
Enabled Size 512 MB
Total Bit Width 64 b
Data Bit Width 0 b
Memory Slot 2/4
Form Factor DIMM
Frequency 0.0 Hz
Slot DIMM2
Type Details
Enabled Size 512 MB
Data Bit Width 0 b
Memory Slot 3/4
Installed Enabled Size 0 B
Frequency 0.0 Hz
Type Details
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Memory Slot 4/4
Frequency 0.0 Hz
Type Details
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Motherboard Info
Supported Slot Types ISA, PCI, AGP
Manufacturer ASUSTeK Computer Inc.
Model P4C800
Version Rev 1.xx
BIOS Vendor American Megatrends Inc.
BIOS Version A M I - 11000321
BIOS Release Date 21/11/03
BIOS Properties Plug and Play, Flash, AGP
AGP
Revision 3.0
Rate 4x, 8x (8x enabled)
Available Rate 0x0000000c
Selected Rate 0x00000008
Aperture Size 64 MB
Sideband Addressing supported (enabled)
Fast Write supported (enabled)
Card Slots
Slot 1/6 (AGP)
Order 0
Designation AGP
Type AGP
Characteristics 3.3V
Data Bus Width 32 b
Details Available, Long
IRQ 0
Slot 2/6 (PCI)
Order 1
Designation PCI1
Type PCI
Characteristics 5.0V, PME Signal
Data Bus Width 32 b
IRQ 0
Slot 3/6 (PCI)
Order 2
Designation PCI2
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 4/6 (PCI)
Order 3
Designation PCI3
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 5/6 (PCI)
Order 4
Designation PCI4
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 6/6 (PCI)
Order 5
Designation PCI5
Type PCI
Data Bus Width 32 b
IRQ 0
System Devices
Name Intel(R) 82801EB PCI Bridge - 244E
Manufacturer Intel
Name Intel(R) 82801EB LPC Interface Controller - 24D0
Manufacturer Intel
Name Intel(R) 82801EB SMBus Controller - 24D3
Manufacturer Intel
Name Intel(R) 82875P Memory Controller Hub - 2578
Manufacturer Intel
Name Intel(R) 82875P Processor to AGP Controller - 2579
Manufacturer Intel
USB Devices
Description Concentrateur USB racine
Driver Date 7-1-2001
Driver Version 5.1.2600.1106
Device Class Universal Serial Bus Controller
Description Concentrateur USB gnrique
Driver Version 5.1.2600.0
Description Logitech Extreme 3D Pro USB
Driver Date 3-25-2003
Driver Version 4.25.161.0
Device Class Human Interface Device
Description Logitech Cordless USB Mouse
Driver Date 11-7-2003
Driver Version 9.79.0.0
Description Prise en charge d'impression USB
Description Priphrique de stockage de masse USB
Description Priphrique d'interface utilisateur USB
Driver Version 5.1.2600.2180
Description SNAPSCAN 1212U_2
Driver Date 5-31-2001
Device Class Imaging Device
FireWire Devices
Description Carte rseau 1394
Driver Version 5.1.2535.0
Device Class Network Adapter
Monitor Info
Monitor 1/3
Name cran par dfaut
Manufacturer (Types d'crans standard)
Max Width 0 px
Max Height 0 px
Monitor 2/3
Name cran par dfaut
Max Width 0 px
Max Height 0 px
Monitor 3/3
Name Dell M770
Manufacturer Dell Computer Corp.
Max Width 1280 px
Max Height 1024 px
Operating System Info
Operating System Microsoft Windows XP
Version 5.1.2600
Service Pack Service Pack 2
Windows Environment 32-bit
Locale FR
Desktop Width 800 px
Desktop Height 600 px
Desktop BPP 32 b
DEP
Hardware Support false
Applications Protected false
Drivers Protected false
User Option On for essential Windows programs and services only
Open Processes
Name PID Memory Usage
3DMark05.exe 2436 12 MB
ADSL Autoconnect.exe 1736 4 MB
alg.exe 2896 4 MB
AsusProb.exe 1760 6 MB
ati2evxx.exe 1224 3 MB
ati2evxx.exe 188 3 MB
ATITool.exe 3980 2 MB
ATKKBService.exe 288 2 MB
CLI.exe 3644 6 MB
CLI.exe 2352 6 MB
csrss.exe 956 7 MB
ctfmon.exe 3660 4 MB
CTHELPER.EXE 3580 6 MB
CTSVCCDA.EXE 300 1 MB
daemon.exe 3568 13 MB
DRIVES~1.EXE 3000 4 MB
EM_EXEC.EXE 3416 7 MB
explorer.exe 1496 17 MB
gearsec.exe 352 1 MB
iPodService.exe 2416 6 MB
iTouch.exe 2484 6 MB
iTunesHelper.exe 3044 7 MB
kav.exe 1280 1 MB
kavsvc.exe 3096 28 MB
LIENCINE32.EXE 3616 3 MB
lsass.exe 1048 8 MB
MDM.EXE 424 3 MB
msmsgs.exe 3652 5 MB
MsPMSPSv.exe 924 2 MB
nbpro.exe 852 17 MB
ntvdm.exe 3612 2 MB
PQV2iSvc.exe 844 25 MB
realsched.exe 2824 164 KB
services.exe 1036 5 MB
Smc.exe 1444 9 MB
smss.exe 904 720 KB
spampal.exe 1780 2 MB
spoolsv.exe 1676 8 MB
svchost.exe 1240 9 MB
svchost.exe 1320 7 MB
svchost.exe 1408 34 MB
svchost.exe 1520 4 MB
svchost.exe 192 5 MB
svchost.exe 624 5 MB
System 4 240 KB
System Idle Process 0 16 KB
wdfmgr.exe 712 2 MB
winlogon.exe 992 15 MB
wmiprvse.exe 1824 6 MB
Logical Drives
Letter Label Type Capacity Available
A: Floppy 0 B 0 B
C: SYSTEM Hard Disk 30.44 GB 13.14 GB
D: SECONDAIRE Hard Disk 57.27 GB 6.64 GB
E: DATA Hard Disk 249.03 GB 84.11 GB
F: COMPILE_X_VOL_2 CD-ROM 636 MB 0 B
G: Disney CD-ROM 1.29 GB 0 B
I: CD-ROM 0 B 0 B
J: Floppy 0 B 0 B
K: Floppy 0 B 0 B
L: CD-ROM 0 B 0 B
M: Floppy 0 B 0 B
O: CD-ROM 0 B 0 B
P: Floppy 0 B 0 B
Q: IOMEGA_HDD Hard Disk 232.88 GB 104.29 GB
avec tout ca je fait seulement 5400 sur 3dmark 2005.
il doit y avoir un probleme quelque part, mais ne m'y connais pas trop sur les tests de carte
désolé pour la longueur mais comme ca vous savez tout!
