3762 connectés
  Catalyst 3.7 OUT ! (Voir topic R9xxx)
n°2708324
raydi
Maître Polisseur
Posté le 04-09-2003 à 23:40:03  profilanswer
TJS plus de drivers...
Lien ATI 3.7 :
http://www.ati.com/support/drivers [...] submit.y=3
FIX:
Running MS Links 2003 with Anisotropic filtering and Anti-Aliasing enabled results in vertical and horizontal lines being displayed within the game. This issue is known to occur under Windows XP with a RADEON? 9700 series card installed
Switching the display resolution mode when playing Jedi Knight II or Quake 3 no longer results in display corruption being displayed on the top of the menu screen
Unreal Tournament 2003 highlight corruption is no longer seen when the pull down menu bar is used to choose a selection
The Windows XP system not responding when attempting to launch IL2 Sturmovik Forgotten Battles if the display resolution is set to 1024x768 32bpp is now resolved. This issue was known to occur on the RADEON? 9700, 9600, and 9500 series of cards
The Windows XP operating system no longer stop responding when switching the display resolution from 1280x1024 to 1600x1200 when playing Jedi Knight II
Configuring the game NASCAR Racing to 1600x1200 32 bpp under Windows ME with a RADEON? 9600 series card installed no longer results in the system not responding
Selecting the pin camera in the game MS Links 2003 no longer results in the ground not being drawn correctly in the sub window. This issue was known to occur under Windows XP with the RADEON? 9000 series card installed
Playing a multiplayer game in the lost city map in the game Will Rock no longer results in the sky flashing black images. This issue was known to occur under Windows XP with the RADEON? 9000 series card installed
Slow playback of the game Remington Big Buck Trophy Hunt is now resolved. This issue was known to occur under Windows XP with a RADEON? 9700, 9600 TX or 9500 series card installed
Configuring the game NeverWinter Nights with Nice 4 Sample Anti-Aliasing enabled and attempting to launch the game no longer results in the system failing to respond. This issue was known to occur under Windows XP with a RADEON? 9800 SE or 9500 series card installed
Enabling Anti-Aliasing and attempting to take a screen shot results in a corrupt capture when running OpenGL games such as, CounterStrike, Half-Life, Quake III or Medal of Honour: Allied Assault
The Tron 2 demo no longer runs slowly on the RADEON? 7200 and 9000 series
Anti-Aliasing support is now available for the game Giants Citizen Kabuto
The shadow image is no longer missing in the demo named Miracle
Setting the display resolution to 1024x768 32bpp and running D3D DolphinVS DX8.1 no longer results in display corruption under the Japanese version of Windows XP
Starting the TV in a windowed mode on a RADEON? 7200 All-In-Wonder series no longer results in the display going blank and the Windows XP operating system failing to respond
Running Hydravision with the Transparency feature enabled and setting the display resolution to 1024x768 16bpp no longer results in display corruption being left behind when dragging an MS Paint window over a DVD image
Tiling corruption noticed under the Windows 9X operating system when the display is set to an interlaced mode is now resolved
Changing the compatibility settings in the ATI OpenGL tab now results in the users' setting being retained when the system reboots
Setting the secondary desktop to panning mode and the primary desktop to normal mode, followed by enabling Overlay Theater Mode no longer results in display corruption being displayed on the secondary display
Installing a RADEON? 8500 series card that has two CRT connectors under Windows XP, no longer results in the display not being available on the second CRT
Connecting two display devices to a RADEON? 9700 series card no longer results in display corruption being seen in Overlay Theater Mode when playing an HDTV source
Running the 3D Pipes screen saver for an extended period of time (24 hours or longer) produces an error message indicating that the virtual memory is not enough
Resuming from suspend mode under Windows ME no longer results in the system not responding
Setting the display to 2048x1536 followed by installing the latest version of Hydravision no longer results in display corruption when relaunching the Windows Explorer
Setting the desktop display to 1024x768 32bpp and enabling OTM no longer results in display corruption when toggling between expansion and non-expansion mode while playing an MPG1 file
Help is now available when entering the Adjustments page found under the Displays tab for HDTV
Enabling clone mode followed by setting the display resolution to 1200x800 no longer results in the CRT being in pan mode
The ATI Options page no longer displays incorrect information about the graphic card's memory size under the traditional Chinese version of Windows XP
The Video BIOS number now reflects the current version number in the control panel
Text no longer appears blurred when font smoothing is enabled and set to Standard. This issue was known to occur under Windows XP with a RADEON? 8500 or 9100 series card installed
The driver component that interfaces to the DDC/CI is now working properly
When the AGP Fastwrite is disabled it no longer appears to be enabled in both the Private and Public SmartGart control panels
The option buttons for Digital Video Interface are now function correctly when the system is set to extended desktop mode
Disabling Extended Desktop with two Adapters and four Displays no longer results in corruption on one display
Sources: ATI.com
Message édité par raydi le 04-09-2003 à 23:47:25
n°2708424
PlayTime
Posté le 05-09-2003 à 01:10:23  profilanswer
les perf avec les ps amélioré, ouf, yavait besoin :D
n°2708431
dWarFy81
Super-Connard
Posté le 05-09-2003 à 01:26:13  profilanswer
+200 à 3dm03
et enfin le bug de l'overlay en theater mode fixé
j'en demandais pas plus :love:
n°2708438
mareek
Et de 3 \o/
Posté le 05-09-2003 à 01:54:39  profilanswer
Pour enterrer encore plus les GFFX ? :whistle:
"I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack
n°2708457
lapin
Posté le 05-09-2003 à 02:26:34  profilanswer
DRAPAL à PULL
n°2708465
dWarFy81
Super-Connard
Posté le 05-09-2003 à 03:31:11  profilanswer
de Terry Makedon:
I would also like to point out at this time that CATALYST public driver posting frequence has been improved to a minimum of twelve (12!) times a year.
et ben, c'est parti pour une release par mois on dirait :wahoo:
n°2708467
PlayTime
Posté le 05-09-2003 à 03:54:35  profilanswer
Tu va voir les nvidiots avec leur detonator 50.xx, ils auront moins d'améliorations que la avec les catalyst 3.7 :D .
n°2708468
dWarFy81
Super-Connard
Posté le 05-09-2003 à 04:03:34  profilanswer
n°2708472
LeKeiser
Appelez moi Marcel.
Posté le 05-09-2003 à 05:36:40  profilanswer
tant que tout marche bien, pourquoi changer?
n°2708486
chrisleurn
Hardcore Will Never Die !
Posté le 05-09-2003 à 08:14:58  profilanswer
[:drapo]
Vais ptet changer mes cata 3.5 :whistle:
n°2708489
skeye
Posté le 05-09-2003 à 08:21:07  profilanswer
Si tout marche pour toi change pas...mais pour certains ca peut servir, cf au-dessus! [:skeye]
n°2708491
Beegee
Posté le 05-09-2003 à 08:22:04  profilanswer
quel bug ?
n°2708727
dWarFy81
Super-Connard
Posté le 05-09-2003 à 11:28:56  profilanswer
Beegee a écrit :
quel bug ?
celui de l'overlay en mode theatre.
n°2708728
bothary
pas barbare, tasmanien !!
Posté le 05-09-2003 à 11:30:01  profilanswer
ChrisLeurn a écrit :
[:drapo]
attend les omega 3.7  :D
...Tuco Benedictio Pacifico Juan Maria Ramirez "dit LE PORC"...
n°2708894
chrisleurn
Posté le 05-09-2003 à 13:04:01  profilanswer
Les Omega spour les noobs [:ddr555], t'as rien a faire, tout est dedans, spa drole [:joce]
n°2708910
Beegee
Posté le 05-09-2003 à 13:19:49  profilanswer
oui, j'avais bien compris :lol:
mais ça se traduisait comment ? moi j'ai jamais eu de problème en theater mode avec une 8500 et une 9700 ...
n°2708925
dWarFy81
Super-Connard
Posté le 05-09-2003 à 13:29:35  profilanswer
et ben alors tant mieux, qu'est-ce que tu veux que je te dise ? ca t'avancera à quoi de savoir ce que c'est puisque de toute facon t'es pas concerné ?
(sinon, il est décrit dans la page où ATI raconte ce qu'il y a de nouveau dans ces drivers, si vraiment tu veux tout savoir)
n°2708943
drakkeng
Posté le 05-09-2003 à 13:39:13  profilanswer
bien sur ça resoud pas le probléme de windows xp qui crash et switch en 640*480 sur les radeon 9500/9700 :fou:
ati :gun:
Message édité par drakkeng le 05-09-2003 à 13:39:58
n°2708961
mareek
Et de 3 \o/
Posté le 05-09-2003 à 13:55:01  profilanswer
ati :gun:
désactive l'AGP fast write
n°2708967
drakkeng
Posté le 05-09-2003 à 13:59:22  profilanswer
c'est fait depuis hier je croise les doigts visiblement ça a un impact minim sur les perfs.
n°2709022
mareek
Et de 3 \o/
Posté le 05-09-2003 à 14:38:08  profilanswer
ben oui, c'est un pb connu [:spamafote]
n°2709039
bothary
Posté le 05-09-2003 à 14:44:13  profilanswer
et ca marche en plus [:ddr555]
n°2709080
syntaxx_er​ror
Posté le 05-09-2003 à 15:05:54  profilanswer
Elle sort quand la 9900 ou 9800XT ?
n°2709086
krumli
Posté le 05-09-2003 à 15:08:09  profilanswer
http://rage3d.com/board/showthread [...] d=33708513
CAT 3.8 the biggest most innovative driver posting ever!
Par Terry Makedon / Responsable des drivers Catalyst  :whistle:
n°2709087
mareek
Et de 3 \o/
Posté le 05-09-2003 à 15:08:15  profilanswer
tu vas poser cette question sur tous les topics ?
n°2709107
syntaxx_er​ror
Posté le 05-09-2003 à 15:17:07  profilanswer
oui, puisque personne répond...Ca sera du harcellement jusqu'à plus soif... :o
n°2709113
mareek
Et de 3 \o/
Posté le 05-09-2003 à 15:20:17  profilanswer
en fait on sait pas, beintot [:spamafote]
n°2709125
PlayTime
Posté le 05-09-2003 à 15:28:26  profilanswer
En fait , la gf fx5900 est même pas totalement directx 9 :
"Les spécifications de DirectX 9 mentionnent la nécessité d'avoir 12 buffers au moins pour le processeur graphique. Les FX 5800 et FX5900 n'en possèdent que 2 !"
Bouh Nvidia  :kaola:
Pr lire l'article en entier sur les ps 2.0 :
http://www.onversity.com/cgi-bin/p [...] P=last#060
n°2709128
Rio Grande
bande de nains
Posté le 05-09-2003 à 15:30:22  profilanswer
Bouh Nvidia  :kaola:
[:plusun]
Topics : NFSU2 - NFS : Most Wanted - Volant PC Site :  NFS-Mania.com
n°2709401
AlCorTha
Ainsi soit-il
Posté le 05-09-2003 à 18:39:40  profilanswer
Bouh Nvidia  :kaola:
Yen a qui lisent les news de www.tt-hardware.com  :)
Mes photos sont sur : http://alacorte.free.fr
n°2709413
ragnar
Posté le 05-09-2003 à 18:48:51  profilanswer
Comment on les installe puique le contol panel est dedans. On vire les anciens drivers et l'ancien control panel et ensuite on met simplement le pack de driver ?
n°2709416
mareek
Et de 3 \o/
Posté le 05-09-2003 à 18:51:47  profilanswer
ben oui [:spamafote]
n°2709423
6fusion7
Posté le 05-09-2003 à 18:54:54  profilanswer
et quand on a une R9700 o/c par soft on fait quoi ?  :sweat:
bon j'arrete de me plaindre parce que je les ai choisi les Omega, alors si j'accepte les avantages faudra aussi accepter les inconvénients  [:spamafote]
Message édité par $$$$$$TENSHI$$$$$$ le 05-09-2003 à 18:55:15
n°2709426
mareek
Et de 3 \o/
Posté le 05-09-2003 à 18:57:19  profilanswer
On se suicide parce que c'est impossible d'attendre plus de 48H pour installer les derniers drivers sortis.
n°2709428
bothary
Posté le 05-09-2003 à 18:57:58  profilanswer
tu attend les omega 3.7  :whistle:
ou alors tu d/l radclock et tu l'installe seul  :sol:
n°2709430
KIKAduKANA
Le JungleCore, ça pootre!!
Posté le 05-09-2003 à 18:58:32  profilanswer
bon je fais 3300 avec les derniers catalyst sur une radeon 9700 flashée en 9700 pro ...
j'viens juste d'installer la carte ...
c une club 3d
Message édité par KIKAduKANA le 05-09-2003 à 18:58:47
n°2709436
mareek
Et de 3 \o/
Posté le 05-09-2003 à 19:00:56  profilanswer
c une club 3d
looser :o
moi je fais 157238 :o
n°2709474
TotalRecal​l
Posté le 05-09-2003 à 19:26:49  profilanswer
(intéressant)
Topic .Net - C# @ Prog
Catalyst et direct 3D[NVidia/XP] Overlay violet en TV Out avec NVidia
Les meilleurs drivers:detonators ou catalyst ?Urgent: Branchement Port PS/2 ( Clavier ) - Video OUT ( Jack Jaune ) ?
probleme affichage radeon8500le RDC windows XP avec Catalyst 3.6difference entre omega et catalyst
catalyst 3.6Rafraichissement > 60 Hz impossible en 1152*864 avec ATI Catalyst !
comment activé l'overscan avec les catalyst 3.2ATI Catalyst 3.6 Driver OUT
Plus de sujets relatifs à : Catalyst 3.7 OUT ! (Voir topic R9xxx)
