5629 connectés
  la limite des 71 minutes en capture video
n°50206
arnaud_68
Posté le 05-03-2001 à 15:45:04  profilanswer
beaucoup de carte d'aquisition video bloque entre la 71eme et la 72eme minutes de captures videos, et ceux, avec n'importe quel codec et taux de compression.c'est un probleme de driver et du nombre max de frames qu'il peux capturer.
j'aimerais savoir qui a deja rencontrer ce probleme, avec quel carte et surtout avec quel driver.
Je commence:
La miro PCTV avec driver 3.00 -> bloque a 71eme minute
Miro DC10 (pas la plus) avec drivers 1.21 ->bloque a la 71eme minutes
a vous :
n°50504
arnaud_68
Posté le 06-03-2001 à 07:39:10  profilanswer
Suis je le seul confronté au probleme ?
pourtant, C un bug tres connu, il figure meme dans la doc de virtualdub:
Why does my capture stop at 1 hour, 11 minutes?
This is a bug in many video capture drivers. The exact limit is actually 232 microseconds, or 1 hour, 11 minutes, 34 seconds. Many TV tuner devices are susceptable to this bug, as are the miro/Pinnacle DCxx devices; you may be able to fix the problem simply by upgrading to the latest capture drivers. There are two incarnations of this problem. In the non-fatal version, video frames are still sent to the application, but the timestamp on the video stream starts over from zero. VirtualDub will correct for this problem automatically, allowing you to capture beyond 71 minutes. The other possibility is that the driver stops sending data altogether. VirtualDub will notify you if this occurs, but will not be able to capture past 71 minutes in this case.
Vanilla capture devices based on the Conexant/Brooktree BT848/878 reference drivers are usually either immune to the problem or have the non-fatal form of it. I'm told that the bug in Pinnacle's DC30(+) drivers still exists but is nonfatal as of the 1.41a drivers. As of this writing, the bug in the DC10/10+/20/20+ drivers is fatal and cannot be worked around.
There are apparently a few drivers that are even susceptable to half this limit (35 min.) due to using signed 32-bit arithmetic.
n°50506
z0rglub
Posté le 06-03-2001 à 07:53:27  profilanswer
perso je peux enregistrer jusqu'à la limite de la taille d'un fichier sous windows 98 soit 4 Go, j'ai donc déjà fait plus de 3 heures...avec ma AIW 128 32Mo
n°50507
arnaud_68
Posté le 06-03-2001 à 08:03:02  profilanswer
apparament, les ATI ne sont pas touché par ce probleme
n°50508
rufo
Pas me confondre avec Lycos!
Posté le 06-03-2001 à 08:04:42  profilanswer
j'ai une ati aiw 128 et j'ai pas de pb non plus :)
n°50613
arnaud_68
Posté le 06-03-2001 à 15:03:48  profilanswer
apparament, la Mise a jour 1.06 de la DC10+ ne resout toujours pas ce probleme:
Studio DC10plus peut
maintenant capturer d ela vidéo jusqu'à ce que
votre disque soit plein, en créant
automatiquement de multiples fichiers de 2Go. La
capture peut continuer jusqu'à ce que le disque
soit plein, ou jusqu'à 100 fichiers, ou jusqu'à
70 minutes,  suivant le cas arrivant le premier
quelqu'un peut il confirmer ?
et est ce qu'en remplacant les drivers par ceux de la DC30+, ca change ?
n°70928
obiwan71
Posté le 04-05-2001 à 16:31:50  profilanswer
Il y a effectivement un problème de capture - plantage net avec arrêt de l'acquisition - à la 71ème minute. J'en ai fait la triste expérience ce matin en enregistrant "Un plan simple"...dommage, vu la qualité de l'acquisition (satellite numérique, je précise) !
J'ai acheté ma carte tout récemment, avec Studio 1.06 donc. Je précise quand même que ce problème ne semble pas toucher Studio (j'ai pu enregistrer près de 2 heures depuis une VHS) ! Mais j'utilise plutôt FreeVCR, et là, ça coince !
Au fait, ma carte graphique est une ATI Xpert@Play...
n°71606
arnaud_68
Posté le 07-05-2001 à 09:36:13  profilanswer
effectivement, avec la DC10+, le seul moyen pour enregistrer plus de 71 minutes est d'utiliser studio 1.06.
avec un autre logiciel de capture (vidcap,freeVCR,virtualdub,...) ca plante !
n°71610
dafl
Posté le 07-05-2001 à 10:18:38  profilanswer
pour la miro pc tv avec les drivers 4.01 résout le problème
n°71623
obiwan71
Posté le 07-05-2001 à 11:49:14  profilanswer
FreeVCR est très bon au niveau synchronisation image/son. Mais est-ce-que Studio 1.06 permet de garder une bonne synchronisation ? Vu qu'on est obligé de passer par ce soft pour capturer plus de 71 minutes...
n°71645
arnaud_68
Posté le 07-05-2001 à 13:07:11  profilanswer
la synchro est niquel avec la 1.06 !
n°71684
obiwan71
Posté le 07-05-2001 à 15:19:51  profilanswer
OK !
Mais je viens de refaire un essai d'acquisition avec Studio pour cette histoire des 71 minutes ("à vide", je précise - sans source connectée en entrée), et l'acquisition s'est arrêtée  après 70 minutes !!
n°71690
arnaud_68
Posté le 07-05-2001 à 15:39:30  profilanswer
deja, mets qlq chose en entrée ! ensuite n'oublie pas de preciser que tu veux capturer plus de 70 minutes a la fenetre quand tu clique sur capture !
n°75269
obiwan71
Posté le 18-05-2001 à 17:00:38  profilanswer
Avec un peu de retard...
Merci de m'avoir rappelé ce "détail" pour la limite des 71 minutes ! :D
Par contre, aucun problème même si aucune source n'est connectée en entrée...cela ne m'a pas empêché de faire mes tests !
n°75319
Slyde
Lizard of the Coast
Posté le 18-05-2001 à 19:01:14  profilanswer
J'ai jamais eu le problème avec la DC10+, je fais souvent 1h30 d'affilé, sans problème
Par contre j'ai le pb avec ma PCTV et les derniers pilotes ! à 71 Min paf bloqué
Je suspècte les partages d'irq, j'ai ce blocage depuis que ma carte est en partage avec ma carte son qu'a bougé du jour au lendemain d'irq comme ca toute seule...
S-Vidéo et compositecarte graphique pour acquisition video ?
Acquisition Video avec carte RADEONcapture et pctvcap.dll ...
GeForce et vidéo ...COMMENT ENREGISTRER DU REAL VIDEO ?
Capture PCTV limité à 384*288, possible de dépasser ?cherche décodeur C+ sous NT4 qui sais capturer en VIDEO
Capture vidéo avec la Radeon 64 ddr
Plus de sujets relatifs à : la limite des 71 minutes en capture video
