3213 connectés
  [XSL] petit problème de débutant
n°35724
prettysmil​e
Sourire est un devoir social
Posté le 30-05-2001 à 17:18:24  profilanswer
quand xml edit analyse ce code:
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:fo="http://www.w3.org/1999/XSL/Format">
<xsl:template match="/">
<html>
    <body>
       <FONT face="helvetica,arial,sans-serif" color="green" size="+2">PRIMITIVES.</FONT>
               <xsl:for-each select="primitive" order-by="+ p_name"/>
                    <p>
                          <xsl:value-of select="p_name"/>
                          <xsl:value-of select="list"/>
                   </p>
              </xsl:for-each>
     <FONT face="helvetica,arial,sans-serif" color=green size=+2>CLASSES.</FONT>
              <xsl:for-each select="class" order-by="+ c_name" />
                  <p>
                          <xsl:value-of select="c_name"/>
                          <xsl:value-of select="c_desc"/>
                          <xsl:value-of select="subclass"/>
                          <xsl:value-of select="c_att"/>
                          <xsl:value-of select="content"/>
                  </p>
               </xsl:for-each>
      <FONT face="helvetica,arial,sans-serif" color=green size=+2>NODES.</FONT>
            <xsl:for-each select="node" order-by = "+ n_name"/>
                  <p>
                       <xsl:value-of select="n_name"/>
                       <xsl:value-of select="n_desc"/>
                        <xsl:value-of select="memberof"/>
                         <xsl:value-of select="in_att"/>
                        <xsl:value-of select="ex_att"/>
                 </p>
           </xsl:for-each>
</body>
  </html>
</xsl:template>
</xsl:stylesheet>
il repond:
"this file is not well formed body closing element name expected" :eek2:
qqu'un peut il m'aider?
n°35747
brascoo
Posté le 30-05-2001 à 17:54:34  profilanswer
Mais tu as du kk dans les yeux ??? non, je deconne,c normal , il y a plusieurs fotes (en tout 5 ou 6 , a toi de voir la difference) !!!!! :))
Voici la correction :
<html>
    <body>
               <xsl:for-each select="primitive" order-by="+ p_name">
                    <p>
                   </p>
              </xsl:for-each>
     <FONT face="helvetica,arial,sans-serif" color="green" size="+2">CLASSES.</FONT>
              <xsl:for-each select="class" order-by="+ c_name" >
                  <p>
                  </p>
               </xsl:for-each>
      <FONT face="helvetica,arial,sans-serif" color="green" size="+2">NODES.</FONT>
            <xsl:for-each select="node" order-by = "+ n_name">
                  <p>
                 </p>
           </xsl:for-each>
</body>
  </html>
</xsl:template>
</xsl:stylesheet>
n°35906
prettysmil​e
Posté le 31-05-2001 à 10:30:58  profilanswer
ok, c'est corrigé,merci.
sans vouloir abuser, comment dans ce document xsl, je fais référence à ma dtd? (référence que réclame xml spy, alors que ma dtd est interne)
n°35979
prettysmil​e
Posté le 31-05-2001 à 11:48:12  profilanswer
je ne comprends vraiement pas pourquoi il me réclame la dtd dans le .xsl.
 :crazy:
[edit]--Message édité par prettysmile--[/edit]
n°37036
prettysmil​e
Posté le 05-06-2001 à 14:19:45  profilanswer
HELP!!!!  :crazy:
n°37056
prettysmil​e
Posté le 05-06-2001 à 15:13:57  profilanswer
:) bon, la transfo marche, meme si Spy estime ma feuille xsl non valide.
voici un autre petit pb de débutant:
dans mon doc xml, j'ai un élément <primitive> qui contient 1 <p_name> et plusieurs <list>. quand j'effectue la transo XSL, seul le premier élément est affiché. Comment afficher les autres?
n°37148
BifaceMcLe​OD
The HighGlandeur
Posté le 05-06-2001 à 20:35:55  profilanswer
C'est normal, dans l'inline template qui traite l'élément primitive, tu n'itères pas sur les éléments enfants.
A la place de ton :
Code :
  1. <xsl:value-of select="list"/>
Il faudrait que tu écrives:
Code :
  1. <xsl:apply-templates select="list"/>
Avec un petit:
Code :
  1. <xsl:template select="list">
  2.   <!-- Traitement d'un élément "list" -->
  3. </xsl:template>
après ton template principal.
n°37249
prettysmil​e
Posté le 06-06-2001 à 09:03:22  profilanswer
donc j'écris:
<?xml version="1.0" encoding="ISO-8859-1"?>
<html>
....blablabla.....
</html>
</xsl:template>
<br><xsl:value-of select="list"/></br>
</xsl:template>
et là : ben ca foire, alors je remplace <xsl:template select="list"> par <xsl:template match="list"> là, spy me fait la transfo mais rien ne s'affiche!!!!
 :crazy:
n°37284
prettysmil​e
Posté le 06-06-2001 à 10:41:04  profilanswer
petite précision: rien ne s'affiche mais le bon nombre de ligne à été sauté là où devraient apparaitre les différent éléments list
n°37289
prettysmil​e
Posté le 06-06-2001 à 10:57:24  profilanswer
pour ceux que ca interesse, a force de bidouille j'ai trouvé la soluce:
<html>
    <body>
 <h1>PRIMITIVES</h1>
        <br/>   <xsl:for-each select="schema/primitive" >
  <p>
                <h2><br><xsl:value-of select="p_name"/></br></h2>
  <br>{</br>
  <br>}</br>
                </p>
               </FONT>
  </xsl:for-each>
</body>
  </html>
</xsl:template>
<xsl:template match="schema/primitive/list">
 <br><xsl:value-of select="."/></br>
</xsl:template>
</xsl:stylesheet>
 :bounce:
n°37444
nabab
I'm blogging this.
Posté le 06-06-2001 à 16:56:24  profilanswer
Les accolades sont la pour faire ressortir une instruction ou appartiennent rellement à ton document ?
Sinon Quel parseur utilises tu car il ne devrait pas etre necessaire de donner le XPath entier des elements lists dans le gabarit que tu presentes et au vu d'ou il est appelé ...
D'ailleurs l'interpretation du XSL depend bcp du parseur utilise, Microsoft, IBM, ... du fait de la non finalisation de la standardisation.
Ce qui vaut la peine d'être fait vaut la peine d'être bien fait
[HTML/JavaScript/ASP] Problème avec Netscape[HTML] Un probleme a la con ...
[JAVA] Exercise pour Débutant!!!!!petit pb en php sans dout très con
[Java] Problème lors de transfert de fichiers (pourrissage)[C++] Un problème bizarre ....
Gros probléme de serveur ASPprobleme de librairie sous VC++
Problème de Variables sous VB6[PHP] Probleme d'affichage !
Plus de sujets relatifs à : [XSL] petit problème de débutant
