2929 connectés
  Java
  Probleme executer jar sur Linux
n°1960358
lezert
Posté le 26-01-2010 à 09:37:14  profilanswer
Je n'arrive pas à exécuter min Jar sous linux alors que sous windows ça marche:
Je fais: java -jar geowebpurge.jar
Code :
  1. java.lang.ClassNotFoundException: com/atosorigin/lbs/purge/Programme
  2.    at java.lang.VMClass.forName(Native Method)
  3.    at java.lang.Class.forName(Class.java:233)
  4.    at jamvm.java.lang.JarLauncher.main(JarLauncher.java:46)
Sachant que l'architecture du fichier jar est la suivante:
Mon Manifest:
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.1
Created-By: 11.3-b02 (Sun Microsystems Inc.)
Main-Class: com/atosorigin/lbs/purge/Programme
Class-Path: log4j-1.2.13.jar mysql-connector-java-5.0.5-bin.jar
Mon Archive:
Archive:  geowebpurge.jar   10757 bytes   21 files
drwxr-xr-x  2.0 unx        0 bx stor 26-Jan-10 08:39 META-INF/
-rw-r--r--  2.0 unx      215 b- defN 26-Jan-10 08:39 META-INF/MANIFEST        .MF
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 com/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 com/atosorigin/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 com/atosorigin/lb        s/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 com/atosorigin/lb        s/purge/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 com/atosorigin/lb        s/purge/conf/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 com/atosorigin/lb        s/purge/dao/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 com/atosorigin/lb        s/purge/metier/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 test/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 test/com/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 test/com/atosorig        in/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 test/com/atosorig        in/lbs/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 test/com/atosorig        in/lbs/purge/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 test/com/atosorig        in/lbs/purge/dao/
drwxr-xr-x  2.0 unx        0 b- stor 26-Jan-10 08:39 test/com/atosorig        in/lbs/purge/metier/
-rw-r--r--  2.0 unx      674 b- defN 26-Jan-10 08:39 com/atosorigin/lb        s/purge/Programme.class
-rw-r--r--  2.0 unx     3150 b- defN 26-Jan-10 08:39 com/atosorigin/lb        s/purge/conf/Configuration.class
-rw-r--r--  2.0 unx     4474 b- defN 26-Jan-10 08:39 com/atosorigin/lb        s/purge/dao/BDservice.class
-rw-r--r--  2.0 unx     4568 b- defN 26-Jan-10 08:39 com/atosorigin/lb        s/purge/dao/FichierService.class
-rw-r--r--  2.0 unx     2911 b- defN 26-Jan-10 08:39 com/atosorigin/lb        s/purge/metier/AnonymerService.class
21 files, 15992 bytes uncompressed, 7977 bytes compressed:  50.1%
Merci d'avance pour vos réponses
n°1960371
jogrey
Posté le 26-01-2010 à 10:17:44  profilanswer
le mysql-connector-java-5.0.5-bin.jar et le log4j-1.2.13.jar sont ou ?
n°1960532
lezert
Posté le 26-01-2010 à 15:39:41  profilanswer
Je viens de résoudre mon problème, il y a eu un problème lors de la création du jar.
Je l'ai recréer et c'est bon ça marche.
Merci quand même d'avoir voulu m'aider.
  Java
Problème de débutantProblème lien hypertext en localhost
Problème code pour mot de passeProbleme Loader et URLRequest en AS3
Notice: Undefined index: site in... =>problème lecture dans sgbd[Resolu] Problème de récupération d'un fichier résultat de POST (API)
Problème conditions requete SQLprobleme de redirection
probleme IE - site EXTENSIBLE -- site d'archiProblème avec un site full flash
Plus de sujets relatifs à : Probleme executer jar sur Linux
