6235 connectés
  VB/VBA/VBS
  VB6 recuperer le nom dutilisateur sous windows
n°302750
rik
Posté le 05-02-2003 à 22:34:43  profilanswer
comment recuperer le nom dutilisateur connecté sous nimporte kel windows ?
Message édité par rik le 05-02-2003 à 22:35:55
n°302761
drasche
Posté le 05-02-2003 à 22:39:32  profilanswer
Private Const UNLEN As Integer = 256
Private Declare Function GetUserNameEx _
                Lib "advapi32.dll" _
                Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long
Private Function GetUserName() As String
    Dim strUserName         As String
    Dim lSize               As Long
    Dim lValue              As Long
    ' Get Username
    lSize = UNLEN
    strUserName = Space$(UNLEN)
    lValue = GetUserNameEx(strUserName, lSize)
    If lValue > 0 Then
        GetUserName = Mid$(strUserName, 1, lSize - 1)
    Else
        GetUserName = ""
    End If
End Function
j'ai pas compilé mais bon ça doit marcher ;)
Whichever format the fan may want to listen is fine with us – vinyl, wax cylinders, shellac, 8-track, iPod, cloud storage, cranial implants – just as long as it’s loud and rockin' (Billy Gibbons, ZZ Top)
n°302764
rik
Posté le 05-02-2003 à 22:42:15  profilanswer
merci ! ton code marche
n°302917
[SDF]Poire
Vive Grumly
Posté le 06-02-2003 à 09:50:49  profilanswer
Declare Function GetComputerName Lib "kernel32" Alias "GetComputerNameA" (ByVal lpBuffer As String, nSize As Long) As Long
'Pour obtenir le nom de l'ordinateur
Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long
'Pour obtenir le nom de l'utilisateur
Public Function Get_UserName() As String
'Retourne le nom de l'utilisateur
Dim StrUser As String
Dim LTemp As Long
    StrUser = String$(255, vbNullChar)
    LTemp = GetUserName(StrUser, Len(StrUser))
    LTemp = InStr(StrUser, Chr$(0)) - 1
    Get_UserName = Mid(StrUser, 1, LTemp)
End Function
Public Function Get_ComputerName() As String
Dim StrComputer As String
Dim LTemp As Long
    StrComputer = String$(255, vbNullChar)
    LTemp = GetComputerName(StrComputer, Len(StrComputer))
    LTemp = InStr(StrComputer, Chr$(0)) - 1
    Get_ComputerName = Mid(StrComputer, 1, LTemp)
End Function
Des bons sites pour Delphi? http://forum.hardware.fr/forum2.php3?post=16838&cat=10 -- informaticien -- http://www.z0rglub.com/phpwebgallery/ -- Delphi :love:
  VB/VBA/VBS
Piloter Excel par VB6 et bloquer l'accès à la feuille durant l'éxec.comment recuperer la date de modif d'un fichier ?
Comment désactiver l'apparition d'une fenêtre dos sous WIndows ?question : recuperer une valeur à l'ecran ?
[JS] récupérer mon adresse ipAppel système sous Windows : pb de guillemets
VB6 et objets graphiques en 3dComment savoir si un control a le focus en VB6
[JAVA] - Récupérer le contenu d'un champ
Plus de sujets relatifs à : VB6 recuperer le nom dutilisateur sous windows
