3882 connectés
  VB/VBA/VBS
  faire cohabiter 2 macro dans un module sous excel??
n°1193146
archi57
Posté le 06-09-2005 à 13:00:12  profilanswer
Bsr,
voilà j'ai une macro (D2_A) dans le module 1 et une autre (D2_X) dans le module 2.
La question est: comment faire cohabiter ces deux macros dans un seul module ??
bye
Macro (D2_A):
Option Explicit
Public Const WSBase As String = "Feuille D2"
Sub D2_A()
Dim Rangebase As String
Dim RangeCount As String
Dim RangeCopy As String
Dim RowCopy As Integer
Dim i As Byte
    For i = 1 To 4
        Select Case i
        Case 1
            Rangebase = "C2"
            RangeCount = "D5:D8"
            RangeCopy = "B5"
            RowCopy = 4
        Case 2
            Rangebase = "C10"
            RangeCount = "D13:D16"
            RangeCopy = "B13"
            RowCopy = 12
        Case 3
            Rangebase = "C18"
            RangeCount = "D21:D24"
            RangeCopy = "B21"
            RowCopy = 20
        Case 4
            Rangebase = "C26"
            RangeCount = "D29:D32"
            RangeCopy = "B29"
            RowCopy = 28
        End Select
        Equipe Rangebase, RangeCount, RangeCopy, RowCopy
    Next i
End Sub
Sub Equipe(Rangebase As String, RangeCount As String, RangeCopy As String, RowCopy As Integer)
Dim Nom As String
Dim Lig1 As Integer, Lig2 As Integer
Dim i As Integer
Application.ScreenUpdating = False
    With Sheets(WSBase).Range(Rangebase)
        If InStr(1, .Value, " " ) < 1 Then Exit Sub
        Nom = Left(.Value, InStr(1, .Value, " " ) + 1) + "."
        Nom = Application.WorksheetFunction.Proper(Nom)
    End With
    With Sheets(Nom)
        Lig1 = .Range("A10000" ).End(xlUp).Row
        Range(.Range("H" & Lig1 + 1), .Range("H" & Lig1 + 3)).Clear
    End With
    With Sheets(WSBase)
        i = Application.CountA(.Range(RangeCount))
        .Range(RangeCopy & ":I" & RowCopy + i).Copy
    End With
    With Sheets(Nom)
        .Range("A65536" ).End(xlUp).Offset(1, 0).PasteSpecial Paste:=xlPasteFormats
        .Range("A65536" ).End(xlUp).Offset(1, 0).PasteSpecial Paste:=xlPasteValues
        Range(.Range("A4" ), .Range("H" & Lig1)).Validation.Delete
        Lig1 = .Range("A65536" ).End(xlUp).Row
        Lig2 = .Range("J65536" ).End(xlUp).Row + 1
        .Range("A4:H" & Lig1).Validation.Delete
        Range(.Range("A4" ), .Range("H" & Lig1)).Sort Key1:=.Range("A4" ), Order1:=xlAscending
        Range(.Range("J" & Lig2 - 1), .Range("M" & Lig2 - 1)).AutoFill _
        Destination:=Range(.Range("J" & Lig2 - 1), .Range("M" & Lig1)), Type:=xlFillDefault
    End With
Sheets("D2" ).Activate
Range("C5" ).Select
Application.ScreenUpdating = True
End Sub
Macro (D2_X):
Option Explicit
Sub D2_X()
Dim i As Byte
    For i = 1 To 4
        Select Case i
        Case 1
            Rangebase = "C34"
            RangeCount = "D37:D40"
            RangeCopy = "B37"
            RowCopy = 36
        Case 2
            Rangebase = "C42"
            RangeCount = "D45:D48"
            RangeCopy = "B45"
            RowCopy = 44
        Case 3
            Rangebase = "C50"
            RangeCount = "D53:D56"
            RangeCopy = "B53"
            RowCopy = 52
        Case 4
            Rangebase = "C58"
            RangeCount = "D61:D64"
            RangeCopy = "B61"
            RowCopy = 60
        End Select
    Next i
End Sub
Dim Nom As String
Dim i As Integer
    End With
    With Sheets(Nom)
    End With
    With Sheets(WSBase)
    End With
    With Sheets(Nom)
    End With
Range("C38" ).Select
End Sub
Message édité par archi57 le 06-09-2005 à 13:02:28
n°1193261
aknott31
Que la fête commence...
Posté le 06-09-2005 à 15:26:56  profilanswer
copier-coller
si la sub equipe est la meme une seule suffira
donc ca donne :
Option Explicit
Sub D2_A()
Dim i As Byte
   For i = 1 To 4
     Select Case i
     Case 1
       Rangebase = "C2"
       RangeCopy = "B5"
       RowCopy = 4
     Case 2
       Rangebase = "C10"
       RangeCopy = "B13"
       RowCopy = 12
     Case 3
       Rangebase = "C18"
       RangeCopy = "B21"
       RowCopy = 20
     Case 4
       Rangebase = "C26"
       RangeCopy = "B29"
       RowCopy = 28
     End Select
   Next i
End Sub
Dim Nom As String
Dim i As Integer
   End With
   With Sheets(Nom)
   End With
   With Sheets(WSBase)
   End With
   With Sheets(Nom)
   End With
Range("C5" ).Select
End Sub
Sub D2_X()
Dim i As Byte
   For i = 1 To 4
     Select Case i
     Case 1
       Rangebase = "C34"
       RangeCopy = "B37"
       RowCopy = 36
     Case 2
       Rangebase = "C42"
       RangeCopy = "B45"
       RowCopy = 44
     Case 3
       Rangebase = "C50"
       RangeCopy = "B53"
       RowCopy = 52
     Case 4
       Rangebase = "C58"
       RangeCopy = "B61"
       RowCopy = 60
     End Select
   Next i
End Sub
n°1193266
aknott31
Posté le 06-09-2005 à 15:28:25  profilanswer
les trois sub sont donc dans le meme module avec la constant WBase déclarée une seule fois
apres ca tu peux supprimer le module en trop.
tout simplement...
n°1193473
archi57
Posté le 06-09-2005 à 18:40:28  profilanswer
merci pour tous je vais me mettre au boulot
pour ce qui est de la constant Wbase, j'enlève quoi dans les lignes:
Option Explicit
car j'ai d'autres modules de ce genre ??
PS: étons obligé de passer par des modules pour ce genre de macro ??
bye
Message édité par archi57 le 06-09-2005 à 18:44:57
n°1195539
aknott31
Posté le 08-09-2005 à 21:40:59  profilanswer
un seul module donc les deux doivent etre presentes mais une seule fois
  VB/VBA/VBS
Cherche macro pour incrémenter une chaine nombre dans un texte[RESOLU] macro,plus de macro...comprend pas tout... (excel)
Macro dans Macro[RESOLU] Excel : macro qui marche, mais boutton qui marche pas !
Module de Classe et Type defini par l'utilisateurCopier par macro une page d'un userform
Sauvegarde Classeur Excel dans un VBS[RESOLU] Date: mois-année, bien la galere... (excel)
Plus de sujets relatifs à : faire cohabiter 2 macro dans un module sous excel??
