4889 connectés
  Shell/Batch
  [SCRIPT UNIX]Pb avec sed
n°1461125
sylvainlel​eu
Posté le 20-10-2006 à 09:58:19  profilanswer
Voici le script en question :
Code :
  1. for FICHIER in `ls $REP_SOURCE`
  2. do
  3.         R=$RANDOM
  4.         while [ $R -le 0 -o R -ge 8000 ]
  5.         do
  6.                 R=$RANDOM
  7.         done
  8.         COUNT=1
  9.         while [ $COUNT -le $NB_RECOPIES ];
  10.         do
  11.                 cp $REP_SOURCE/$FICHIER $REP_TMP/$COUNT
  12.                 TEST="'s/$CHAINE_A_REMPLACER/IMP-$R/g' $REP_TMP/$COUNT > $REP_TMP/$COUNT.dat "
  13.                 sed -e $TEST
  14.                 echo $CHAINE_A_REMPLACER
  15.                 COUNT=`expr $COUNT + 1`
  16.         done
  17. done
et ce qu'il donne :
Code :
  1. + [ 1 -le 3 ]
  2. + cp /webapp/hff/source_jetform/toto /opt/adobe/central/server/tmp/1
  3. + TEST='s/VANCOUV_LAS_UNFR_080/IMP-1657/g' /opt/adobe/central/server/tmp/1 > /opt/adobe/central/server/tmp/1.dat
  4. + sed -e 's/VANCOUV_LAS_UNFR_080/IMP-1657/g' /opt/adobe/central/server/tmp/1 > /opt/adobe/central/server/tmp/1.dat
  5. sed: 's/VANCOUV_LAS_UNFR_080/IMP-1657/g' is not a recognized function.
  6. + echo VANCOUV_LAS_UNFR_080
  7. VANCOUV_LAS_UNFR_080
  8. + + expr 1 + 1
  9. COUNT=2
  10. + [ 2 -le 3 ]
  11. + cp /webapp/hff/source_jetform/toto /opt/adobe/central/server/tmp/2
  12. + TEST='s/VANCOUV_LAS_UNFR_080/IMP-1657/g' /opt/adobe/central/server/tmp/2 > /opt/adobe/central/server/tmp/2.dat
  13. + sed -e 's/VANCOUV_LAS_UNFR_080/IMP-1657/g' /opt/adobe/central/server/tmp/2 > /opt/adobe/central/server/tmp/2.dat
  14. sed: 's/VANCOUV_LAS_UNFR_080/IMP-1657/g' is not a recognized function.
  15. + echo VANCOUV_LAS_UNFR_080
  16. VANCOUV_LAS_UNFR_080
  17. + + expr 2 + 1
  18. COUNT=3
  19. + [ 3 -le 3 ]
  20. + cp /webapp/hff/source_jetform/toto /opt/adobe/central/server/tmp/3
  21. + TEST='s/VANCOUV_LAS_UNFR_080/IMP-1657/g' /opt/adobe/central/server/tmp/3 > /opt/adobe/central/server/tmp/3.dat
  22. + sed -e 's/VANCOUV_LAS_UNFR_080/IMP-1657/g' /opt/adobe/central/server/tmp/3 > /opt/adobe/central/server/tmp/3.dat
  23. sed: 's/VANCOUV_LAS_UNFR_080/IMP-1657/g' is not a recognized function.
  24. + echo VANCOUV_LAS_UNFR_080
  25. VANCOUV_LAS_UNFR_080
  26. + + expr 3 + 1
  27. COUNT=4
Je ne vois pas pourqui sed me fait une erreur alors que si je tape
en ligne de commande cela passe sans pb.
Merci de votre aide.
n°1461133
Elmoricq
Posté le 20-10-2006 à 10:13:42  profilanswer
essaie avec eval
n°1461142
sylvainlel​eu
Posté le 20-10-2006 à 10:26:05  profilanswer
Ca marche merci.
n°1465680
Sve@r
Posté le 26-10-2006 à 19:17:43  profilanswer
do
done
Cette structure pose un gros problème car le "for" utilise l'espace comme séparateur. Et dans le cas où un des fichiers possède un espace dans son nom, le "for" fera alors 2 itérations en découpant le nom sur la 1ère partie puis la 2° partie mais aucune itération ne traitera le fichier lui-même. Au final, il restera non traité
Solution permettant d'éviter cela: utiliser le "read" qui se base sur le "return" pour découper ses infos.
ls $REP_SOURCE |while read FICHIER
do
done
Inconvénient: comme le pipe génère un sous-processus, si on implémente une variable (style un compteur) dans le "do", elle est perdue en fin de "done" car le processus disparaît et ses variables avec...
Vous ne pouvez pas apporter la prospérité au pauvre en la retirant au riche.
n°1466065
aigles
Posté le 27-10-2006 à 13:42:30  profilanswer
do
done
Ceci ne résout pas tous les problèmes car read supprime tous les espaces en début et en fin de ligne.
Une solution est de forcer le séparateur de champ IFS au moment de la lecture (fonctionne trés bien en KSH, à vérifier en SH et BASH) :
ls $REP_SOURCE |while IFS= read FICHIER
do
done
Ce problème est résolu par KSH, et je pense qu'il en est de même avec BASH.
Jean Pierre.
n°1466669
Sve@r
Posté le 28-10-2006 à 19:10:20  profilanswer
Et en quoi est-ce un problème dans ce cas précis ? Peut-on avoir des fichiers dont le nom contient un espace en début ou fin ???
Absolument pas. Il est vrai qu'en ksh une variable déclarée dans le do... done est automatiquement remontée au-dessus du pipe mais ce comportement n'a pas été répliqué dans le sh ou bash  Peut-être zsh...
Message édité par Sve@r le 28-10-2006 à 19:13:54
  Shell/Batch
script multi upload multi site[oracle] script affichant base connecté
Script de connexion WSH[Résolu][Script aculo us] Sortable.create
[Shell / C] Script shell en tant que démon ?Code retour Java sous Unix
Besoin d'explications sur un script CGI/Perlscript
Changer image de banniére, avec script ou non?[script shell] grep -f sur de grandes quanités de données
Plus de sujets relatifs à : [SCRIPT UNIX]Pb avec sed
