9313 connectés
  SQL/NoSQL
  [mysql] PB requete avec des select imbriqués
n°402825
BiOxyde
Posté le 21-05-2003 à 14:59:11  profilanswer
voici mon code
Code :
  1. $sql = "delete from POST where POST.POST_TOPIC_CODE in (";
  2. $sql = $sql . " select TOPIC_CODE from TOPIC where TOPIC.TOPIC_THEME_CODE in (";
  3. $sql = $sql . " select THEME_CODE from THEME where THEME.THEME_SECTION_CODE = " . $section_code . " ) );";
  4. echo $sql ."<br><br>";
  5. mysql_query($sql,$link) or die("<br>[ INVALID QUERY ] : " . mysql_error());
Resultat:
delete from POST where POST.POST_TOPIC_CODE in ( select TOPIC_CODE from TOPIC where TOPIC.TOPIC_THEME_CODE in ( select THEME_CODE from THEME where THEME.THEME_SECTION_CODE = 1 ) );
[ INVALID QUERY ] : You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'select TOPIC_CODE from TOPIC where TOPIC.TOPIC_THEME_CODE in (
Par contre quand j'utilise des requetes successives ca marche. Donc pas de problèmes de sql en théorie:
Code :
  1. $toto = "";
  2. $tata = "";
  3. $sql = "select THEME_CODE from THEME where THEME.THEME_SECTION_CODE = " . $section_code . ";";
  4. $rs1 = mysql_query($sql,$link) or die("<br>[ INVALID QUERY 1] : " . mysql_error());
  5. while ($row1 = mysql_fetch_array($rs1,MYSQL_ASSOC))
  6. {
  7.  $toto = $toto . "," . $row1["THEME_CODE"];
  8. }
  9. $sql = "select TOPIC_CODE from TOPIC where TOPIC.TOPIC_THEME_CODE in (0 " . $toto . " );";
  10. $rs1 = mysql_query($sql,$link) or die("<br>[ INVALID QUERY 2] : " . mysql_error());
  11. while ($row1 = mysql_fetch_array($rs1,MYSQL_ASSOC))
  12. {
  13.  $tata = $tata . "," . $row1["TOPIC_CODE"];
  14. }
  15. $sql = "delete from POST where POST.POST_TOPIC_CODE in (0 " . $tata . " );";
  16. $row1 = mysql_query($sql,$link) or die("<br>[ INVALID QUERY 3] : " . mysql_error());
EDIT: ah oui j'oubliais, j'ai bien la version 4.0.13 de MySQL.
REEDIT: en fait non je ne suis pas en 4.0.13 :(
sous phpinfo(), ca m'affiche Client API version 3.23.49.
Pourtant j'ai bien installé MySQL 4.0.13 puis PHP 4.3.1 (la version installer pour win32). Et le numéro de version reste le même...
n°402842
simogeo
j'ai jamais tué de chats, ...
Posté le 21-05-2003 à 15:04:06  profilanswer
il me semble que les requêtes imbriquées c'est en version > 4.1 pour MySQl [:psywalk]
from here and there -- \o__________________________________ -- la révolution de la terre, en silence
  SQL/NoSQL
Un message d'erreur qui emêche l'utilisation de MySql sur mon pcAffichage résultat d'une requête sur plusieurs pages
[PHP/MYSQL]Désolé...encore besoin d'aiderequète sql en php modifiant plusieurs enregistrements
Requete SQL sous SQLserver : ca marche pas ... RESOLU !!!![MySQL] Aide pour requête de recherche
PB sur requete[asp] probleme a une requete
comment faire une somme directement dans la BDD mysql ?
Plus de sujets relatifs à : [mysql] PB requete avec des select imbriqués
