4959 connectés
  C#/.NET managed
  [vb.net] création composant
n°1017428
Emcy38
Posté le 18-03-2005 à 14:23:12  profilanswer
Bonjours,
j'ai créer dans un userform, un label deplaçable et redimensionnable en hauteur : je voudrais pouvoir créer simplement autant d'element de ce type que je veux. Comment faire ? je crois qu'il faut que je crée un controle mais je n'y arrive pas : pouvez-vous m'aidez ?
voici le code complet de mon userfrom :
Code:
Imports System
Imports System.Drawing
Imports System.Windows.Forms
Namespace zone1
   Public Class MainForm
      Inherits System.Windows.Forms.Form
      Private labelmilieu As System.Windows.Forms.Label
      Private labelhaut As System.Windows.Forms.Label
      Private labelbas As System.Windows.Forms.Label
      Public Shared Sub Main
         Dim fMainForm As New MainForm
         fMainForm.ShowDialog()
      End Sub
      Public Sub New()
         MyBase.New
         ' The Me.InitializeComponent call is required for Windows Forms designer support.
         ' TODO : Add constructor code after InitializeComponents
      End Sub
      #Region " Windows Forms Designer generated code "
      ' This method is required for Windows Forms designer support.
      ' Do not change the method contents inside the source code editor. The Forms designer might
      ' not be able to load this method if it was changed manually.
      Private Sub InitializeComponent()
         Me.labelbas = New System.Windows.Forms.Label
         Me.labelhaut = New System.Windows.Forms.Label
         Me.labelmilieu = New System.Windows.Forms.Label
         Me.SuspendLayout
         'labelbas
         Me.labelbas.BackColor = System.Drawing.Color.Gray
         Me.labelbas.Location = New System.Drawing.Point(160, 216)
         Me.labelbas.Name = "labelbas"
         Me.labelbas.Size = New System.Drawing.Size(128, 8)
         Me.labelbas.TabIndex = 1
         Me.labelbas.Text = "label2"
         AddHandler Me.labelbas.MouseUp, AddressOf Me.LabelbasMouseUp
         AddHandler Me.labelbas.MouseMove, AddressOf Me.LabelbasMouseMove
         AddHandler Me.labelbas.MouseDown, AddressOf Me.LabelbasMouseDown
         'labelhaut
         Me.labelhaut.BackColor = System.Drawing.Color.IndianRed
         Me.labelhaut.Location = New System.Drawing.Point(160, 120)
         Me.labelhaut.Name = "labelhaut"
         Me.labelhaut.Size = New System.Drawing.Size(128, 8)
         Me.labelhaut.TabIndex = 2
         Me.labelhaut.Text = "label3"
         AddHandler Me.labelhaut.MouseMove, AddressOf Me.LabelhautMouseMove
         AddHandler Me.labelhaut.MouseDown, AddressOf Me.LabelhautMouseDown
         'labelmilieu
         Me.labelmilieu.BackColor = System.Drawing.SystemColors.ActiveCaption
         Me.labelmilieu.Location = New System.Drawing.Point(160, 128)
         Me.labelmilieu.Name = "labelmilieu"
         Me.labelmilieu.Size = New System.Drawing.Size(128, 88)
         Me.labelmilieu.TabIndex = 0
         Me.labelmilieu.Text = "label1"
         AddHandler Me.labelmilieu.MouseUp, AddressOf Me.LabelmilieuMouseUp
         AddHandler Me.labelmilieu.MouseMove, AddressOf Me.LabelmilieuMouseMove
         AddHandler Me.labelmilieu.MouseDown, AddressOf Me.LabelmilieuMouseDown
         'MainForm
         Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13)
         Me.ClientSize = New System.Drawing.Size(608, 398)
         Me.Controls.Add(Me.labelhaut)
         Me.Controls.Add(Me.labelbas)
         Me.Controls.Add(Me.labelmilieu)
         Me.Name = "MainForm"
         Me.Text = "MainForm"
         AddHandler Load, AddressOf Me.MainFormLoad
         Me.ResumeLayout(false)
      End Sub
      #End Region
      Private Xp, Yp As Integer
      Private Sub LabelMilieuMouseDown(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
         Xp = e.x
         Yp = e.y
      End Sub
      Private Sub LabelHautMouseDown(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
         Xp = e.x
         Yp = e.y
      End Sub
      Private Sub LabelBasMouseDown(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
         Xp = e.x
         Yp = e.y
      End Sub
      Private Sub LabelMilieuMouseMove(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
      'deplace le label
         Dim LabelTop, LabelLeft as integer
         'MessageBox.Show("Bonjour" )
         If e.Button   = MouseButtons.Left Then
            LabelTop = LabelMilieu.Top - Yp + e.y
            LabelLeft = LabelMilieu.Left - Xp + e.x
            Me.LabelMilieu.Top = LabelTop
            Me.LabelMilieu.Left = LabelLeft
            Me.LabelHaut.Top = LabelTop - 8
            Me.LabelHaut.Left = LabelLeft
            Me.LabelBas.Top = LabelTop + LabelMilieu.Height
            Me.LabelBas.Left = LabelLeft
         end if
      End Sub
      Private Sub LabelHautMouseMove(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
      'redimensionne le label
         Dim AgrandissementY as Integer
         Dim NewHeight As Integer
            AgrandissementY = - Yp + e.y
            NewHeight = Me.LabelMilieu.Height - AgrandissementY
            if NewHeight < 16 then 'empeche que le label soit inférieur à 16px
               Me.LabelMilieu.Top = Me.LabelBas.Top - 16
               Me.LabelMilieu.Height = 16
               Me.LabelHaut.Top = Me.LabelMilieu.Top - 8
            Else
               Me.LabelHaut.Top = Me.LabelHaut.Top + AgrandissementY
               Me.LabelMilieu.Top = Me.LabelMilieu.Top + AgrandissementY
               Me.LabelMilieu.Height = NewHeight
            end if
         End if
      End Sub
      Private Sub LabelBasMouseMove(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
            NewHeight = Me.LabelMilieu.Height + AgrandissementY
               Me.LabelBas.Top = Me.LabelMilieu.Top + 16
            Else
               Me.LabelBas.Top = Me.LabelBas.Top + AgrandissementY
            End if
         End if
      End Sub
      Private Sub LabelmilieuMouseUp(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
      End Sub
      Private Sub LabelbasMouseUp(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
      End Sub
      Private Sub MainFormLoad(sender As System.Object, e As System.EventArgs)
         SetStyle(ControlStyles.DoubleBuffer Or ControlStyles.UserPaint Or ControlStyles.AllPaintingInWmPaint , True)
             SetStyle(ControlStyles.ResizeRedraw, True) 'le controle est redissiné lors de son redimensionnement
             SetStyle(ControlStyles.SupportsTransparentBackColor, True) 'gère les couleurs transparentes
      End Sub
      Private Sub AlphaBlendTextBox1TextChanged(sender As System.Object, e As System.EventArgs)
      End Sub
   End Class
End Namespace
n°1017780
liink
Posté le 18-03-2005 à 17:23:23  profilanswer
Tu dois creer un controle utilisateur. Cherche de ce coté, y'a plein de doc.
  C#/.NET managed
[C#] Composant perso utilisant une collection[ASPX][C#] Création d'un composant
PostgreSQL/Linux : probleme de création de table [résolu]spécification des droits lors de la création d'un fichier
creation d'un bouton pour executer une macro outlookCréation d'un Webmail, Etape par Etape
Creation de Repertoires soumis à conditionsEchec lors de la création ...création d'un composant rouge à la place
[ASPX][C#] Création d'un nouveau composant, pb de conception[Delphi 6] création de composant... contenant une image...
Plus de sujets relatifs à : [vb.net] création composant
