6709 connectés
  C++
  probleme completement inexplicable avec les sockets sous windows c++
n°1094244
toeboe
toytoy
Posté le 23-05-2005 à 23:10:32  profilanswer
slt !!
je debute a la programmation reseaux en c++,et afin de developpez mes capacites j'ai decide de programmer le plus simplement possible un client/serveur du chate sous dos mais le probleme c'est ke le client n'arrive pas a se connecte au svr je vous pris de m'aider les gaz svp
voici les deux codes:
[cpp]
********************le client***************************************
#include<iostream.h>
#include<stdio.h>
#include<winsock2.h>
#pragma comment(lib,"ws2_32.lib" )
void main()
 WSADATA wsa;
 WSAStartup(MAKEWORD(2,0),&wsa);
        char ip[20];
       cout<<"tapez l adresse ip du serveur"<<endl;
       cin>>ip;
 SOCKET sock;
 SOCKET serveur;
 SOCKADDR_IN option;
 option.sin_addr.s_addr=inet_addr(ip);
 option.sin_family= AF_INET;
 option.sin_port=htons(50);
 sock=socket(AF_INET,SOCK_STREAM,0);
 serveur=socket(AF_INET,SOCK_STREAM,0);
 char buff[222],buff1[222];
 while(1)
 connect(sock,(SOCKADDR*)&option,sizeof(option));
  while(int(connect(sock,(SOCKADDR*)&option,sizeof(option)))!=INVALID_SOCKET)
   cout<<"connection etablie"<<endl;
   for(;;)
   cout<<"client = "<<endl;
   gets(buff);
   send(serveur,buff,sizeof(buff),0);
   cout<<endl;
   recv(sock,buff1,sizeof(buff1),0);
   cout<<endl;
******************************le serveur**************************
#include<stdio.h>
void main()
 WSADATA mywinsock;
 WSAStartup(MAKEWORD(2,0),&mywinsock);
 SOCKET sock;
 SOCKET serveur;
 SOCKADDR_IN option;
 SOCKADDR_IN client;
    option.sin_addr.s_addr = htonl(INADDR_ANY);
 option.sin_family=AF_INET;
 bind(sock,(SOCKADDR*)&option,sizeof(option));
 int americ=sizeof(option);
 char recevoir[222];
 char envoyer[222];
 listen(sock,0);
 while(1)
  accept(sock,(SOCKADDR*)&client,&americ);
        if(accept(sock,(SOCKADDR*)&client,&americ)!=INVALID_SOCKET)
  cout<<"connection etablie!!"<<endl;
        while(1)
  recv(serveur,recevoir,sizeof(recevoir),0);
  cout<<recevoir<<endl;
  gets(envoyer);
  cout<<endl;
  send(sock,envoyer,sizeof(envoyer),0);
enfin,je vous assure ke jai essaye de le corrige mais sans resultat et merçi d'avance pour votre aide
n°1094246
Joel F
Real men use unique_ptr
Posté le 23-05-2005 à 23:16:28  profilanswer
balise [ cpp] svp :o
n°1094248
chrisbk
Posté le 23-05-2005 à 23:20:19  profilanswer
tu lis pas sur la bonne socket
NP: HTTP Error 764 Stupid coder found
n°1094279
toeboe
toytoy
Posté le 23-05-2005 à 23:58:45  profilanswer
mais si je lis sur la bonne socket (sock),c'est ke j'ai binde !!!!!!
n°1094282
chrisbk
Posté le 24-05-2005 à 00:11:29  profilanswer
pas bonne socket, cf aide de "accept"
et en plus tu as deux accept, c'est pas bon
n°1094291
toeboe
toytoy
Posté le 24-05-2005 à 00:27:54  profilanswer
mais pk pas bonne socket!!!
serveur est socket ki represente le client de ki elle va recevoir les strings
n°1094292
toeboe
toytoy
Posté le 24-05-2005 à 00:28:22  profilanswer
pas logik !!!!!!!!!!!!!
n°1094306
toeboe
toytoy
Posté le 24-05-2005 à 01:45:19  profilanswer
ne trouvez pas kil n y aucune erreur dans ce prog?,n'est il pas inexplikable kil ne fonctionne pas correctement??
n°1094307
toeboe
toytoy
Posté le 24-05-2005 à 01:55:07  profilanswer
j'ai teste ce malin prog avec moi meme,le norton me signale une connection je coche permit mais sans resultat et kand je le teste avec des amis,on ne constate rien comme si le client ne se connecte pas eu serveur,si klkin de vous ne me crois pas je suis pret a le tester avec lui,lui meme il va compile le serveur ou le client
n°1094308
toeboe
toytoy
Posté le 24-05-2005 à 01:56:08  profilanswer
je vous ensupplie de m'aider a trouve la solution svp ctrop !!!!!!!!!!
n°1094328
cricri_
Posté le 24-05-2005 à 07:33:44  profilanswer
Tout le monde te l'a déjà dit, tu te mélanges les pinceaux avec tes sockets ...
n°1094375
chrisbk
Posté le 24-05-2005 à 08:46:00  profilanswer
Il est perclu d'erreurs ton pauvre programme de merde, c'est pas inexplicable qu'il ne marche pas, c'est meme une chance qu'il deconne, ca nous prouve qu'il reste encore en ce bas monde des choses comprehensibles
Alors vu que t'es un peu dur de la feuille je te le redis :
1/ tu as deux accept => pas bon
2/ tu ne lis pas (coté serveur) sur la bonne socket => cf doc de accept
3/ (bonus) des exemples de client serveur qui marchent, y'en a plein le net
et arrete d'écrire comme un triso, ca saoule
n°1094386
Harkonnen
Un modo pour les bannir tous
Posté le 24-05-2005 à 09:00:54  profilanswer
on t'a déja donné la réponse, tu crois pas qu'il serait temps de brancher tes neurones et de réflechir un coup ?
et tu serais gentil d'écrire correctement stp, sans ça je me verrais dans l'obligation de fermer ton topic
J'ai un string dans l'array (Paris Hilton)
n°1094599
toeboe
toytoy
Posté le 24-05-2005 à 11:06:15  profilanswer
tout d'abord je m'execuse pour mon ecriture,meme si j'ai
remplaçe recv(serveur,,)par recv(sock,,)ça na rien donne
en plus çe n'est pas faux d'ecrire accept()dans le while
parceke j'essaye de recuper la valeur retourne par accept()
sans declarer de nouveaux variable,enfin si vous avez un
autre avis ke le mien essayez plus clair s'il vous plait
n°1094676
toeboe
toytoy
Posté le 24-05-2005 à 11:42:36  profilanswer
chrisbk =
1-cpas faux les deux accept()
2-je lis sur la bonne socket,tu constate pas que sock est le nom de socket que j'ai binde(coller)????
je crois que je tai explique tous monsieur chrisbk
n°1094691
zedar
Posté le 24-05-2005 à 11:49:16  profilanswer
Bon ben chrisbk, il te reste plus qu'à le remercier...
Sincèrement, tu n'as même pas essayé la solution, tu n'es pas poli, tu ne fais aucun effort d'écriture (bon vu ta ville dans le profil, ça peut éventuellement s'excuser sur le fond), et tu te permets d'envoyer bouler...
ça donne envie de répondre tiens
n°1094712
chrisbk
Posté le 24-05-2005 à 11:58:04  profilanswer
toeboe a écrit :
chrisbk =
tu comptes lire cette bondieu de doc sur "accept" un jour ou pas ?
Message édité par chrisbk le 24-05-2005 à 11:58:38
n°1094731
toeboe
toytoy
Posté le 24-05-2005 à 12:08:47  profilanswer
je suis pret a tester avec toi monsieur chrisbk parceke je
top de sur que tu ne sais pas ce ke tu dit meme en socket
je crois pas ke tu sais les utiliser !!!!!!!
n°1094736
Harkonnen
Posté le 24-05-2005 à 12:09:41  profilanswer
toeboe a écrit :
chrisbk =
mais bien sur que si c'est faux, bougre d'étron entété !! tu acceptes la connection une fois, c'est pas pour la réaccepter une seconde fois ! dégage donc le 1er "accept" et garde celui qui est dans le if()
tu lis sur la socket du client !! il faut lire sur la socket du serveur ! comme le dit chrisbk, cf doc de accept() :
http://publib.boulder.ibm.com/info [...] pc1m3j.htm
et tu serais gentil d'arréter de prendre les gens de haut, surtout quand tu as tout faux comme c'est le cas actuellement. ton programme est faux et archi faux, et tu te permets de la ramener et de dire à chrisbk qu'il a tort ! je pense que si des mecs comme chrisbk ou Taz ou Delahaye ou autres te disent des trucs, tu peux leur faire une confiance quasi aveugle ! alors arrête un peu ton cinéma, et comme je te l'ai dit, met les neurones en marche !
n°1094737
Harkonnen
Posté le 24-05-2005 à 12:10:26  profilanswer
un conseil, ferme là et lis mon post au dessus ! je suis à 2 doigts de te bannir là
n°1094739
toeboe
toytoy
Posté le 24-05-2005 à 12:11:28  profilanswer
meme si jen doute que tas le courrage d'accepter ce defi!!!!!!!!!!!!!!
n°1094741
Harkonnen
Posté le 24-05-2005 à 12:11:59  profilanswer
bon allez, télétubbies, parce que là tu m'énerves royalement
n°1094746
chrisbk
Posté le 24-05-2005 à 12:14:21  profilanswer
bin si tu veux, en attendant mon client/serveur marche, le tiens non [:el g]
Et donc, je demandais, tu comptes lire la doc sur accept ou non ?
n°1094748
chrisbk
Posté le 24-05-2005 à 12:15:26  profilanswer
bah, jpense pas que je suis admissible dans les para olympiques
n°1094775
Taiche
Posté le 24-05-2005 à 12:23:51  profilanswer
Moi je pense aussi que chrisbk sait pas utiliser les sockets :o Il fait son malin et tout mais il sait pas faire :o
Everyone thinks of changing the world, but no one thinks of changing himself  |  It is the peculiar quality of a fool to perceive the faults of others and to forget his own  |  Early clumsiness is not a verdict, it’s an essential ingredient.
n°1094777
chrisbk
Posté le 24-05-2005 à 12:24:50  profilanswer
J'avoue :/
c'est quoi une socket ?
n°1094778
Taiche
Posté le 24-05-2005 à 12:25:29  profilanswer
C'est ça : http://dreamfish.org.uk/images/socket.jpg
n°1094779
chrisbk
Posté le 24-05-2005 à 12:26:15  profilanswer
ah bin c'est bien ce que je dis, il utilisait pas la bonne [:zaib3k]
n°1094787
WhatDe
Posté le 24-05-2005 à 12:31:44  profilanswer
chrisbk a écrit :
J'avoue :/
http://www.ozinetperformancewear.com.au/pics/Sockette_2.jpg
[:whatde]
n°1094819
KrisCool
“Verbeux„
Posté le 24-05-2005 à 12:54:14  profilanswer
Le coup des 2 sockets [:rofl] [:rofl][:rofl][:rofl]
Message édité par KrisCool le 24-05-2005 à 12:56:59
Loose Change Lies | Bars | Last.fm
  C++
probleme .htaccessProbleme de session avec Firefox et pas avec IE
probleme telnetProblème avec la commande set Path
probleme jmf + linux[html] Problème niais
probleme en javaProblème de caractère '
[ASP] Probleme pour un appel à une fonction asp sous htmlthread sous windows
Plus de sujets relatifs à : probleme completement inexplicable avec les sockets sous windows c++
