4035 connectés
  CPU
  Pb frequence mémoire
n°1737133
nene9134
Posté le 21-04-2008 à 20:28:53  profilanswer
Bonjour a tous
Je suis débutant et j'ai déjà un problème :)
Sous CPU-Z ma ram est considéré comme de la 5300 alors que j ai acheté de la 6400.
http://valid.x86-secret.com/show_oc.php?id=349932
Que dois je faire pour rectifier le tir :)
Merci :)
ps: voila les caractéristiques de la mémoire :)
Memory type:   DDR2 SDRAM
Error correction:   NONE
Voltage interface level:  SSTL (1.8V)
Data width:   64 bits
Number of physical banks:  2 (double sided)
Number of logical banks:  4
Number of row addresses:  14       14
Number of col addresses:  10       10
Bank density:   512  512 MB
Primary RAM Width:  8        8 bits
Error checking RAM Width:  0        0 bits
Module density:   1024 MB
Refresh rate:   7812.500 us
Self-refresh:   Oui
Burst lengths supported:     4 8
CAS 3.0:
 Cycle time (tCYC) =    5.000 ns fMax =  200.000 Mhz
 Access time (tAC) =    0.600 ns fMax = 1666.667 MHz
CAS 4.0:
 Cycle time (tCYC) =    4.300 ns fMax =  232.558 Mhz
 Access time (tAC) =    0.500 ns fMax = 2000.000 MHz
CAS 5.0:
 Cycle time (tCYC) =    3.000 ns fMax =  333.333 Mhz
 Access time (tAC) =    0.450 ns fMax = 2222.222 MHz
InconnuInconnuMin delay, Bk/Bk random cols: 0 clocks
Min row precharge time (tRP): 15.000   ns
Min row active delay (tRRD):  7.500    ns
Min RAS to CAS delay (tRCD): 15.000   ns
Min Actv to precharge (tRAS): 45.000   ns
Addr/Cmd setup time:  0.200    ns
Addr/Cmd hold time:  0.270    ns
Data setup time:   0.100    ns
Data hold time:   0.170    ns
Write recovery time (tWR)  15.000   ns
Int Wr to Rd Cmd Dly (tWTR)  7.500    ns
Int Rd to Pchg Cmd Dly (tRTP) 7.500    ns
Min Act/Auto-Rfrsh Time (tRC) 60.000   ns
Min Auto-Rfrsh/Act Cmd (tRFC) 105.000  ns
Max Dev Cycle time (tCK max) 8.000    ns
Max DQS-DQ Skew (tDQSQ max) 2.400    ns
Rd data hold skew Fctr (tQHS) 3.400    ns
PLL relock time   0.000    ns
Memory analysis probe chars:  00
DIMM type:                   UDIMM (module width = 133.35mm)
FET switch external enable:  Non
Analysis probe installed:  Non
Includes weak driver:  Oui
Manufacturer's JEDEC ID code: 00000000 0000987f
Module manufacturing location: 4 (manufacture dependant)
Module part number:  99C5316-019.A00LF
Module revision code:  0 (manufacture dependant)
Module manufacturing date:  Wk 7  of 2008
Module serial number:  78cc1c8c
SPD revision:   1.1
Message édité par nene9134 le 21-04-2008 à 21:00:24
n°1737166
nene9134
Posté le 21-04-2008 à 22:02:16  profilanswer
up :)
n°1737332
fcouma
Posté le 22-04-2008 à 13:09:04  profilanswer
C'est pas au niveau du BIOS que tu as un soucis ?
La vitesse ddr est en Auto dans le bios ?
  CPU
La frequence de la ram est bridee, pourquoi ?4Go mémoire : 4 x 1Go ou 2 x 2Go pour overclocking ?
Overclock Q6600 à 3,3Ghz : Vidage mémoire à 68°C...réglage mémoire
ntune ne garde pas mon augmentation de fréquence GPUfrequence bloque apres overclock
frequence ati tool bizarre x1950xtHELP fréquence pour 7900gs en 7900gtx
Fréquence GEforce go 7800 GTX!probléme memoire
Plus de sujets relatifs à : Pb frequence mémoire
