8728 connectés
 Page :   1  2  3  4  5  6  7  8  ..  20  21  22  23  24  25
[CG] Corsair- Compte d'oc-wear crédité - Reception de tous les cheques
n°547491
igor
Posté le 09-07-2002 à 12:08:47  profilanswer
nasdak a écrit a écrit :
lol
bon igor on cloture quand, la ddr va remonter
demain soir
n°547500
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 12:10:56  profilanswer
http://www.n3dt.com/reviews/mem/Xt [...] eddr1.html
ce lien ne fonctionne pas chez moi, kelk'un peut tester???
Votre Installation Home-Cinema ici : installations-home-cinema.eu
n°547502
cpulloverc​lock
Posté le 09-07-2002 à 12:13:05  profilanswer
Impossible d'afficher la page
n°547508
nasdak
Posté le 09-07-2002 à 12:15:55  profilanswer
moi ca marche
mais cé pas dla corsair
n°547517
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 12:18:45  profilanswer
:cry:
n°547524
nasdak
Posté le 09-07-2002 à 12:22:27  profilanswer
Now for my conclusions on XtremeDDR 3200 DDR.
We can easily see from the previous pages that this memory is what it says it is and a little more. I find this memory to be a good solid performer all the way through the speed scales and has proved itself to be a performer bar none. Even with the system being pushed and the memory timings set faster than the default SPD settings, this memory still proves to hold it's own.
I would definitely put my mark on this DDR as a plus buy as it not only performs at rated specs but better. I feel you can't go wrong with this memory.
2 Thumbs Up for XtremeDDR. I give this a true Natural Buy choice. At only $90 USD you can't go wrong.
n°547528
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 12:24:28  profilanswer
je sais toujours pas koi prendre, je pense ke ça sera platinium pour le style mais bon :??:
n°547529
nasdak
Posté le 09-07-2002 à 12:25:18  profilanswer
pareil..
le style je m'en fous...
dur dur!!
n°547530
Oxygen3
Tears from the moon
Posté le 09-07-2002 à 12:28:46  profilanswer
ah si j'avais les sous  :cry:
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°547531
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 12:29:17  profilanswer
bah on verra les prix ce soir...
 :sleep:
n°547541
Oxygen3
Tears from the moon
Posté le 09-07-2002 à 12:34:58  profilanswer
 :sleep:
j'aurais pas les sous de ttes facons :/
sauf si kkun me reprend mes 512 de kingmax 333 5ns à 200?  :o
n°547543
nasdak
Posté le 09-07-2002 à 12:36:01  profilanswer
200? cé pas gagné jespere vendre les miennes vers 180 avec la montée de la drr
a combien tu le spousses tes kingmax
n°547545
Oxygen3
Tears from the moon
Posté le 09-07-2002 à 12:36:33  profilanswer
178 cas2 2.9V sur le 2312
mais c mm pas la peine, j'aurais pas le fric donc bon  :sweat:
Message édité par Oxygen3 le 09-07-2002 à 12:37:01
n°547547
nasdak
Posté le 09-07-2002 à 12:37:08  profilanswer
et 2.5?
moi 195 max
n°547549
Oxygen3
Tears from the moon
Posté le 09-07-2002 à 12:38:38  profilanswer
et 2.5?
moi 195 max
2.5 j'ai pas testé, je savais pas que le coef 14 et 15 était 5 et 5.5 sur les durons
et il refusait de faire plus de 185-190x6
Message édité par Oxygen3 le 09-07-2002 à 12:39:01
n°547551
nasdak
Posté le 09-07-2002 à 12:39:19  profilanswer
ok
a koi ca te sert alors dla corsair
n°547553
Oxygen3
Tears from the moon
Posté le 09-07-2002 à 12:39:50  profilanswer
ok
a l'xpai qui devrait se delock :o
Message édité par Oxygen3 le 09-07-2002 à 12:40:02
n°547567
igor
Posté le 09-07-2002 à 12:47:42  profilanswer
titi38 a écrit a écrit :
je sais vous commander des PC3000 et PC3200,
tu prends des barettes titi??
n°547572
igor
Posté le 09-07-2002 à 12:48:35  profilanswer
Pour etre sur que je n'oublie personne, verifier en 1 ere page que vous etes bien sur la liste et que j'ai bien noté ce que vous voulez.
n°547574
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 12:49:49  profilanswer
il manque une personne et deux pour etre sur!!! :cry:
n°547576
akhnotpier​rot
Internaute
Posté le 09-07-2002 à 12:50:33  profilanswer
si on me l'avance sur 1 mois j'en prend une de 256 pc3200
voir 2
Message édité par akhnotpierrot le 09-07-2002 à 12:50:41
[HFR] AKHnoT [:akhnotpierrot] Membre de la team [HFR] BattleTeam
n°547578
igor
Posté le 09-07-2002 à 12:50:57  profilanswer
Cela devrait allé, y en a 3-4 interessé, mais pas comfirmé
n°547579
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 12:51:08  profilanswer
désolé je peux pas t'aider la!!! :cry:
n°547584
igor
Posté le 09-07-2002 à 12:52:24  profilanswer
voir 2
fais gaffe sur le pdf de Corsair, ils disent que la RAM n'est pas certifié à la meme frequence en mono et multi barette.
Message édité par igor le 09-07-2002 à 12:52:37
n°547593
Posté le 09-07-2002 à 12:56:34  answer
En attente des prix : 256 Mo pC3200 pour moi.
Par contre, le platinium, c'est juste la couleur des barrettes ou il y a quelque chose en plus ?
n°547594
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 12:57:58  profilanswer
ça serait des chips winbond au lieu des rev C samsung
n°547598
uGHazE
Posté le 09-07-2002 à 12:59:35  profilanswer
erF ya des tests sur les chips winbond qq part ? :sarcastic:
n°547599
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 13:00:04  profilanswer
j'ai pas vu, je chercherais cette apres midi
n°547604
Posté le 09-07-2002 à 13:02:10  answer
ok.
Mais si je veux des platinium, il faut prendre des 512Mo.
Suivant les prix, peut-etre que je prendrai des 512 ;)
n°547605
johnbroot
n00b Inside
Posté le 09-07-2002 à 13:03:20  profilanswer
je me tate pour une 512pc3200 bekause j'ai toujours mes 2x256 pc3000 de mush rev D :gun:
n°547606
igor
Posté le 09-07-2002 à 13:04:00  profilanswer
ok.
oki, mais le pb c'est que le prix dépend de ce que vous prenez. Donc pour 512, tapez sur 227euros (- entre 5 et 10 euros je pense)
n°547612
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 13:08:26  profilanswer
pour le winbond je trouve pas trop d'info...
sur le test de hardware.fr la winbond 2700 vaut la nanya...
Mais sur vr-zone elle fait legerement moins bien ke la 2700 samsung...
n°547615
igor
Posté le 09-07-2002 à 13:10:12  profilanswer
Mais je pense pas que cela soit les meme chips.
n°547617
ompopeye
Posté le 09-07-2002 à 13:11:06  profilanswer
Salut je serai interesser par une 512Mo PC3200 platinium mais c'est pas sur car en fait j'avais commander 512Mo chez Mushkin :( donc j'ai envoyer un mail pour annuler ma commande et j'espere avoir une reponse de leur part avant que tu ferme la CG.
Message édité par ompopeye le 09-07-2002 à 13:11:57
n°547620
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 13:13:05  profilanswer
chez mushkin si tu n'envoies un e-mail ou un fax avec un relevé de compte ta commande ne marchera pas...
Sinon je trouve rien sur la winbond...
n°547623
igor
Posté le 09-07-2002 à 13:14:17  profilanswer
On verra mais cloture demain. dsl si jamais tu n'as pas eu de réponse de Mushkin
n°547638
titi38
Posté le 09-07-2002 à 13:23:56  profilanswer
Non Moi j'en prends pas, j'attends vendredi une 512 PC3000 des US(j'ai la chance d'avoir des collegues qui travaillent aux US et qui me ramene cela dans leurs valises).
Pour infos une 512 mo PC3000 vaut 169 dollars aux Us soit 170 euros Hors Taxes, mais si passage dans la valise c'est 99,9 % de chance que c'est hors taxes.....
n°547833
igor
Posté le 09-07-2002 à 15:17:37  profilanswer
c'est bien calme en ce moment. Avec un petit effort, on devrais atteindre 15 barettes.
Allez plus que 29 Heures avant la cloture.
n°547850
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 15:31:15  profilanswer
29h + réception des chekes!!!
Bah pour nous ça devrait aller vite  ;)
n°547855
nasdak
Posté le 09-07-2002 à 15:34:37  profilanswer
le pbme c'est k'on sait toujours pas ce quon prend
n°547857
nikopop
凸(`0´)凸
Posté le 09-07-2002 à 15:35:53  profilanswer
pile ou face???  :D
2*256 Mo DDR PC 3000 Corsair, ça s'o/c bien ou pas ?Comment savoir si la Corsair PC3200 est de la Samsung Rev C ou D ?
[CG] Kit reliage pont L1 => En attente des Cheques !!!![CG]-S2, S3, DocMicro -debut des envois, non reception de 9 cheques-
[Rech] Super prix pour Corsair Micro DIMM 512Mo - DDR PC-3200 CAS 2.5Je compte m'équiper d'un XP 2000+ et ...
info ddr corsair Corsair 3000 256 mb qu'en pensez-vous ?
Que pensez vous de le DDRAM Corsair 3000 ?
Plus de sujets relatifs à : [CG] Corsair- Compte d'oc-wear crédité - Reception de tous les cheques
