4161 connectés
  CG - superbe Waterblock spirale - lancement en septembre - UPPEZ !
n°537865
maxicool
Posté le 02-07-2002 à 10:09:12  profilanswer
Salut
Je viens de trouver un superbe waterblock en vente chez DTek !!
http://dtekcustoms.safeshopper.com/18/31.htm?407
http://dtekcustoms.safeshopper.com/images/bg1d03d6.jpg
Poly Topped Copper Spir@l Waterblock
Les spécifications
This Poly topped Spir@l Waterblock is the hottest on the market to date. Clear and Extremely durable Polycarbonate topped to watch the water flow. O-ring sealed to provide the option of removal for cleaning. The unique Cad designed 1/2" spir@l will supply the highest flow rates of any block on the market. This is a new version of the original Spir@l which now utilizes ribbed channels, Polycarbonate top and hose barb options. There will also be bolt on P-4 tops in the near future. Price will include mounting kit. Pricing and more information will be available by the end of the week.
Comes pressure tested, lapped and equipped with Chrome hose barbs (1/2" only) or 3/8" (brass) or Polypropylene barbs. The all metal mounting kit resists stretching with 4-bolts, 4-nuts, 4-springs, 12-nylon washers, and 4-brass knurled nuts for easy tightening and adjustment.
Dimensions: 2.5"Wide" X 3"Long x .85"High
Weight 1.0 LBS approx.
Soit :
- embouts 1/2" (12,5 externe et 9,5 interne)
- dessus plexi polycarbonate
- dessus pour P4 vendu prochainement
- embouts chrome 1/2"
- embouts cuivre ou polypropylène 3/8"
- poids : 450 grs
- kit de fixation inclus (en nylon)
(ne pas se soucier du waterblock différent > photographie uniquement mise en ligne pour le kit de fixation)
http://dtekcustoms.safeshopper.com/images/bw19xxky.jpg
Prix
55 ? TTC
(mail envoyé par DTek posté plus loin en dessous)
Personnes intéressées
- maxicool
- zeratul
- morrison67
Remarques
1) Je pars en vacances du 30/07 au 01/09 (en Syrie) donc je relancerais cette commande groupée à la rentrée.
2) La commande ne sera effectuée que si 20 waterblocks sont vendus, sinon ça revient trop cher !
Vous pouvez upper le topic de temps en temps, et même le mettre à jour si des personnes sont intéressées !!
Message édité par maxicool le 28-07-2002 à 10:14:05
n°537876
XTinX
Amicalement votre
Posté le 02-07-2002 à 10:28:24  profilanswer
C est combien le prix ?????
n°538260
ZeBorG
Yes we can!
Posté le 02-07-2002 à 17:07:58  profilanswer
c'est vrai qu'il à l'aire bien mais 500g :/
n°538277
aspegic500​mg
Posté le 02-07-2002 à 17:32:22  profilanswer
Vaut mieux un zalman de 900g  :lol:
Nan mais 500g c'est pas mechant,et c'est fixé sur les trou de la carte mere,moi je suis sur alpha pal8045 + noiseblocker S2, j'ai pas pesé mais je dirai que ca fait 500g environ,et puis la qualité a un poids,je pense que je vais bientot me mettre au watercooling,vu les waterblock qui sortent,ca devient bien interressant,enfin faut voir les perfs,pour l'instant j'ai pas le budjet(meme pas 100 euro pour le tout, en ce moment je suis short :sarcastic: )
Et surtout je veux que ca soit transportable sans probleme,pour les LAN  :heink:
n°538288
maxicool
Posté le 02-07-2002 à 17:54:42  profilanswer
En fait, c'est un moins  :D
1 pound  = 0.45359237 kg
n°538952
maxicool
Posté le 02-07-2002 à 23:11:53  profilanswer
:bounce:
n°538956
Cap'tain K​averne
Posté le 02-07-2002 à 23:14:15  profilanswer
Pas trop cher , je suis tenté :love:
mais j'hesite ...
on a des results?
........_o
n°539030
fireman
Posté le 03-07-2002 à 00:36:34  profilanswer
il a l'air sympa est bien moins chers que le maze 3 si 45 euros
Edité par Fire
n°539034
246tNt
Resistance is futile
Posté le 03-07-2002 à 00:44:26  profilanswer
45 ? je crois que tu reve un peu la ...
Compte +- 54-55 ?, il faut ajouter frais de port, taxe, frais bancaire, ...
n°539111
maxicool
Posté le 03-07-2002 à 09:37:12  profilanswer
On verra... Mais je pense que c'est possible de les avoir autour de 50 ? (tous frais compris avec une petite réduction de leur part). Je leur ai envoyé un mail hier, on attend une réponse, je leur ai demandé un "spécial price" pour 20 blocks.
n°539132
fireman
Posté le 03-07-2002 à 10:15:02  profilanswer
[:yaisse2]
Edité par Fire
n°543679
zeratul
Empêcheur de tourner carré
Posté le 07-07-2002 à 00:30:29  profilanswer
je seré interressé! :D
n°563615
maxicool
Posté le 25-07-2002 à 19:39:38  profilanswer
HI Frédéric,
I am very sorry, but I was working on a price list and did not realize that you wanted just the spir@l block. Ok you are correct about the size of the hose barbs. The poly top is 3/8" thick. The P-4 tops are in process and should be available in 2-week. The retail price is $52.00 including the mounting kit. For 20 blocks I will let them go for $46.00 ea. Bank transfer payment  would be required and shipping would run around $170 (estimate) using UPS Worldwide 3-4 day. That is the only shipper we would use for this type of order. USPS is a joke when it comes to paying for lost packages. I hope I was able to answer all your questions. If you have more please let me know. Wer only have 15 spir@ls still in stock, but I will have more soon if you need to make the order
Voilà donc les prix...
46 $ pour le waterblock et sa fixation
+ frais bancaires et frais d'envoi : 170 $ (par UPS envoi express en 3 ou 4 jours) à se partager
> Si 20 blocks = 8,5 $
PRIX TOTAL = 46 + 8,5 $ = 54,5 $
Le dessus P4 sera donc dispo dans 2 semaines.
Vous pouvez upper le topic de temps en temps, et même le mettre à jour si des personnes sont intéressées.
n°563662
morrison67
Posté le 25-07-2002 à 20:38:02  profilanswer
ouai moi pour mon pquatre
je sais po encore quoi prendre en embout je penche pour le 1/2
chrome
n°563756
maxicool
Posté le 25-07-2002 à 22:41:54  profilanswer
:bounce:
n°563804
morrison67
Posté le 25-07-2002 à 23:35:20  profilanswer
bon ben du 3/8 pour moi
n°564148
]sTa[$hark
Posté le 26-07-2002 à 12:23:33  profilanswer
maxicool a écrit a écrit :
 :bounce:
je veux pas te vexer mais je pense que le 1/2 ca fait du 12 mm en interne, et pas en externe, car en externe c'est plutot du 12.7 mm (vu que les embouts font pas 1.5 mm d'épaisseur comme tu dis, on arrive à 12 mm)
en fait 1/2 faut compter 12 mm interne et prendre des tuyaux de 12/16 ... à ce moment la c'est parfait !
Maze 3 inside Powaaaaaaaaaaaaaaaaaaa :love:
Message édité par ]sTa[$hark le 26-07-2002 à 12:24:28
<***/\/\  AMD64 3200+ @ 2200 Mhz   /\/\*** >
n°564801
maxicool
Posté le 27-07-2002 à 02:21:26  profilanswer
Non, c'est toi qui te trompe...
C'est du 12 externe, car les bords des embouts font 1,5 mm
n°565462
maxicool
Posté le 28-07-2002 à 10:15:28  profilanswer
:bounce:
n°566201
pol
Posté le 29-07-2002 à 09:56:32  profilanswer
:bounce:
n°566207
Killall-9
+on&2foo...
Posté le 29-07-2002 à 10:09:24  profilanswer
Y'a du plexi? Beuark, j'en veux pas!
J'ai soupé du plexi, j'ai un WB qui a explosé, et j'avais même pas serré... Si encore j'avais serré comme un bouricot je me serais dit "tant pis t'est trop con", mais dans mon cas non...
Moralité: Le plexi c'est pour les jacky, pour moi c'est cuivre, alu, ou PVC, bien plus résistants.
n°566222
maxicool
Posté le 29-07-2002 à 10:36:34  profilanswer
Si tu as utilisé du 4 mm, c'est normal  :D  ;)
Tu as trop serré...
TOUS les constructeurs les plus connus proposent des dessus plexi, ils ne sont quand même pas tous "bouricots" en même temps...  :D
Message édité par maxicool le 29-07-2002 à 10:37:39
n°566225
Killall-9
+on&2foo...
Posté le 29-07-2002 à 10:42:51  profilanswer
Le WM qui a explosé est un Twinplex pour carte graphique, avec un bloc de plexi de près de 12mm d'épaisseur...
 http://217.172.178.216/prodimg/tpconfig/cg10.jpg
Donc c'est pas du 4, donc je confirme, le plexi en ce qui me concerne c'est desormais non!
Innovatech n'utilise pas de plexi. Leur priorité n'est pas le look mais la performance.
n°566226
Killall-9
+on&2foo...
Posté le 29-07-2002 à 10:45:14  profilanswer
Et oui, si ça a explosé, c'est que j'ai trop serré pour le materiau.
Mais si je serrais moins, ça fuyait (joint neuf, je précise).
Donc le materiau n'est pas adapté au besoin, donc le plexi n'est pas adapté au watercooling.
CQFD.
n°566296
maxicool
Posté le 29-07-2002 à 12:03:15  profilanswer
Ouais, enfin, tu dois être tombé sur un mauvais block, car tous les possesseurs de WB plexi ne se plaignent pas de fuite alors...
Tu voulais quoi au fait en postant sur ma proposition de commande groupée ? Me la saborder ?
n°566530
Killall-9
+on&2foo...
Posté le 29-07-2002 à 17:11:31  profilanswer
Non, c'est pas mon intention, qu'est-ce que j'aurais à y gagner? J'y ai pas reellement pensé, et je l'ai un peu mauvaise... C'etait plutôt un exutoire à ma mauvaise humeur, et un moyen d'informer les gens sur les risques du plexi...
Pour parler de ta commande, c'est un beau Maze, et pas très cher. En tout cuivre il aurait franchement pu m'interesser.
Remarque, si le plexi pète, il est très facile de refaire un couvercle, éventuellement en metal: une plaque, 2 gros trous, 8 petits, et c'est fait.
Dans mon cas, c'est une autre paire de manches...
n°576810
Cyanur
De tout un peu...
Posté le 13-08-2002 à 14:42:20  profilanswer
Je me tâte... ça fait un moment que je pense au watercooling...
Rien ni personne n'a tout à fait tort : même une horloge arrêtée a raison deux fois par jour. (John Steinbeck)
Waterblock parfait...[ WaterBlock CPU ] C'est quoi le top pour un proco Socket A?
Waterblock SPACE 2000 et fixation[CG] Waterblock spirale (P4 et Socket A - AMD) - 40 à 50 ? TTC
C'est bien l'alu massif pour un waterblock ?Mon waterblock dans mon pieux pour refroidir mes testicouilles. photos
conseil waterblockChoix d'un WaterBlock
[ACH] WATERBLOCK
Plus de sujets relatifs à : CG - superbe Waterblock spirale - lancement en septembre - UPPEZ !
