6276 connectés
 Page :   1  2  3  4  5  ..  399  400  401  ..  1427  1428  1429  1430  1431  1432
[ FOR OVERCLOCKERS FOUS et Retraités ] Saloon des habitués !
n°884841
Learn
Tigre & Dragon
Posté le 25-09-2003 à 15:31:49  profilanswer
 :hello:  :sleep:
2003-09-22
Hobro, Denmark
Chip-con ApS changes company name to nVENTIV A/S. The change will be effective immediately.
We are also happy to inform that a new company has been formed in Germany under the name - nVENTIV GmbH. Our German company will handle all German activities
The decision has been taken following a thorough analysis aimed at defining the best communications platform for building a new, global brand. The conclusion was that from a business- and marketing point of view, the use of nVENTIV as company name would offer better possibilities than the previous company name.
For further information, please visit Press Release under Press
2e fx que je vois a + de 2800MHz...
http://www.aceshardware.com/read.jsp?id=60000268
ASUS' Secret BIOS
When working with this system, a few interesting facts popped up. The system was actually running at 14 x 200 MHz, and could be set at multipliers ranging from 4 (800 MHz) to 14 (2.8 GHz). All AMD Athlon 64 FX are de facto unlocked and it seems that the maximum multiplier for this stepping is 14.
The only thing from stopping you from overclocking with the multiplier seems to be the BIOS. The ASUS SK8N inside the nVENTIV Mach II featured a special ASUS bios that allowed us to change the CPU core voltage and multiplier.
http://www.aceshardware.com/articl [...] tiasus.jpg
For 2.8 GHz, the AMD Athlon 64 FX needs 1.75V it seems. According to nVENTIV this high core voltage should not reduce the lifetime of your CPU dramatically. Our sources in the semiconductor industry contradict each other, so please enlighten us at the message board if you know more.
L'obscurité ne peut pas chasser l'obscurité ; seule la lumière le peut. La haine ne peut pas chasser la haine ; seul l'amour le peut. Martin Luther King
n°884848
niaboc79
www.nirvana-records.be
Posté le 25-09-2003 à 15:38:15  profilanswer
learn a écrit :
:hello:  :sleep:
2003-09-22
Hobro, Denmark
ASUS' Secret BIOS
2800Mhz avec 1.75v sur prommy  :love:
Imaginé 240*14 à 2v  :pt1cable:
Nirvana Records
n°884855
nasdak
Posté le 25-09-2003 à 16:11:55  profilanswer
doit faire  mal a 2800 kan meme
n°884857
cpulloverc​lock
Posté le 25-09-2003 à 16:13:17  profilanswer
ma P4C800 dlx
http://membres.lycos.fr/cpulloverclock79/mobo.jpg
http://membres.lycos.fr/cpulloverclock79/mobo2.jpg
n°884859
nasdak
Posté le 25-09-2003 à 16:14:28  profilanswer
tiens ta un apn maintenant
c une impression ou elle est pourrite?
Message édité par nasdak le 25-09-2003 à 16:15:14
n°884860
cpulloverc​lock
Posté le 25-09-2003 à 16:14:45  profilanswer
oui avec LN2 seulement et encore meme pas sur
jai calcule et pour avoir une config a base de fx il faut au moins depenser 1800?
n°884861
cpulloverc​lock
Posté le 25-09-2003 à 16:14:59  profilanswer
non c pas un apn
n°884863
reglisse
Posté le 25-09-2003 à 16:17:19  profilanswer
clair la DDR ecc c hors de prix  :??: et P4EE a plus de 800?  :??: bref pas pres d'investir dans un nouveaux pro moi  :sweat:
Message édité par reglisse le 25-09-2003 à 16:18:32
n°884865
nasdak
Posté le 25-09-2003 à 16:19:42  profilanswer
ca va vite baisser
n°884866
cpulloverc​lock
Posté le 25-09-2003 à 16:19:52  profilanswer
reglisse a écrit :
clairla DDR ecc c hors de prix  :??: et P4EE a plus de 800?  :??: bref pas pres d'investir dans un nouveaux pro moi  :sweat:
jattends le prescott
de tte maniere a64 ya presque aucune diff de perf par rapport a un P4C, le FX trop cher et il sera surement mons perf que le prescott
enfin de tte maniere jattends, je prend aucun risque comme ca
et pis si prescott = juste achat du proc, pas besoin de racheter une mobo alords que passage chez AMD faut racheter mobo + proc et suivant le proc de la Ram ECC
ca vaut pas le coup
je pense que la plupart upgraderont debut 2004
je verrai en 2004
Message édité par cpulloverclock le 25-09-2003 à 16:20:30
n°884868
reglisse
Posté le 25-09-2003 à 16:24:30  profilanswer
tu penses que le prescoot sera compatible sur une p4c800 deluxe mais pas E ???
n°884869
nasdak
Posté le 25-09-2003 à 16:25:00  profilanswer
ca vaut pas le coup
je verrai en 2004
vire ton rib c dangereux parait-il
n°884871
nicko500
Framerate is Life.
Posté le 25-09-2003 à 16:30:28  profilanswer
vous avez pas vu l emmission sur le typê qui prenais des credit en volant des RIB   :whistle:
n°884884
bothary
pas barbare, tasmanien !!
Posté le 25-09-2003 à 16:52:20  profilanswer
dans la base o/c de hardware ya plus les barton  :heink:
on a toujours acces a ses o/c mais il n'y a plus les barton dans la liste
...Tuco Benedictio Pacifico Juan Maria Ramirez "dit LE PORC"...
n°884889
syfer10
intel ATI RULEZZZZZZZ
Posté le 25-09-2003 à 17:01:15  profilanswer
salut les gars je me suis mis depuis peu à l'overcloking et j'ai pu constaté ke.... ca chauffe et c pour cela ke je voudrai investir ds un systeme de watercooling , les tours de koolance m'ont l'air pas mal :love:  z'en penez koi? vous les pro  :p
 [:azzaro75]  [:burtonsnowboard]
n°884890
Neo_XP
Dawa'z addict
Posté le 25-09-2003 à 17:02:50  profilanswer
home made.
Mais ouais
n°884892
syfer10
Posté le 25-09-2003 à 17:03:35  profilanswer
ah?
n°884895
xigfrid
Tjs vivant
Posté le 25-09-2003 à 17:08:09  profilanswer
n°884901
zytrahus5
wait what?
Posté le 25-09-2003 à 17:11:30  profilanswer
aircooling et une freon case pour tenter de bons o/c :o
je deviens flemmard y a trop de contrainte dans le WC pour une utilisation quotidienne :p
Message édité par zytrahus5 le 25-09-2003 à 17:12:25
http://www.zytratech.com
n°884906
reglisse
Posté le 25-09-2003 à 17:19:18  profilanswer
http://membres.lycos.fr/reglisseme [...] o=Amd&dp=0
Message édité par reglisse le 25-09-2003 à 17:26:43
n°884911
Jennifer
Posté le 25-09-2003 à 17:28:51  profilanswer
lol aujourd'hui ont bizutait les 1eres années
bilan :
le dirlo ainsi que la cpe sont venu nous voir sur la route ( pas dans le lycée donc )
-j'ai balancé un paquet de farine sur le dirlo ( ca l'a touché mais le paquet ne s'est pas versé sur lui)
-j'ai jeté de la farine en pleine tete sur la cpe : elle m'a foutu une claque cette conne
  :lol:  :lol:  :lol:  :lol:  :lol:  , ct drole quand meme  :lol:
n°884912
bothary
Posté le 25-09-2003 à 17:29:27  profilanswer
je suis déja dans ta base  :D
ct juste pour signaler ce petit manque dans celle de hardware  :p
n°884919
cpulloverc​lock
Posté le 25-09-2003 à 17:53:05  profilanswer
bah c quen MP que jai poste ca
n°884923
Oxygen3
Tears from the moon
Posté le 25-09-2003 à 18:00:15  profilanswer
nicko500 a écrit :
ouais enfin via ca fait un moment qu il est largué et pas qu' a cause du dual ...
plus avec l'a64
ils ont trop misé sur l'a64 et avaient plus d'ingés sur le socketA en gros
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°884925
nicko500
Framerate is Life.
Posté le 25-09-2003 à 18:04:17  profilanswer
haha :D
n°884926
nikopop
凸(`0´)凸
Posté le 25-09-2003 à 18:05:32  profilanswer
bah oui :o
Votre Installation Home-Cinema ici : installations-home-cinema.eu
n°884929
jln2
Posté le 25-09-2003 à 18:15:24  profilanswer
C'est possible de faire fonctionner le chispet d'une nf7-s revision 1.1 en passif?(avec un fsb 200@1.7v)
merci :hello:
n°884934
pgeo
Posté le 25-09-2003 à 18:27:21  profilanswer
bilan :
t'a pas fariné ma fille ???  :heink:
sinon ça va chier [:albator7k]
n°884943
pipoo51
Bouyaka
Posté le 25-09-2003 à 18:40:57  profilanswer
salut, je voulais savoir ds quel sens on fixe le ventillo sur un rad ???
n°884944
papayou
Coin Coin
Posté le 25-09-2003 à 18:42:56  profilanswer
l'axe du ventilo perpendiculaire au processeur ...
y a rien de mieux  :o
Slide control makes you feel strange...
n°884945
nicko500
Framerate is Life.
Posté le 25-09-2003 à 18:43:06  profilanswer
[:al zheimer]
n°884946
pipoo51
Bouyaka
Posté le 25-09-2003 à 18:45:26  profilanswer
bandes de cake, je vous parles du sens de circulation de l'air
(si ça doit aspiré l'air du rad, ou souffler ds le rad)
n°884947
pipoo51
Bouyaka
Posté le 25-09-2003 à 18:47:51  profilanswer
c vrai ke vs etes né en sachant tout sur tout sur les pc...
n°884954
bothary
Posté le 25-09-2003 à 18:51:11  profilanswer
non mais on a  appris en demandant poliment et en lisant les docs  :o
n°884955
papayou
Coin Coin
Posté le 25-09-2003 à 18:51:19  profilanswer
ben vi ... on est pas tous egaux a la naissance...
c'est bien t'as franchis la premiere étape, tu t'es apercu que tu est une truffe  :hello:
n°884956
nicko500
Framerate is Life.
Posté le 25-09-2003 à 18:51:25  profilanswer
:jap:  :D
n°884958
bothary
Posté le 25-09-2003 à 18:53:29  profilanswer
un client me demande une config pour SOLIDWORKS
g une vague idée pour la mobo, le proc et la ram
mais aucune pour la carte graphique qqu'un peut me renseigner  :jap:
n°884959
jln2
Posté le 25-09-2003 à 18:53:33  profilanswer
merci :hello:
n°884962
papayou
Coin Coin
Posté le 25-09-2003 à 18:54:59  profilanswer
 nvidia moddée en quadro :o
n°884963
nicko500
Framerate is Life.
Posté le 25-09-2003 à 18:55:09  profilanswer
bah peut importe je pense
une ati pour la qualitée des couleurs  [:proy]
n°884966
nicko500
Framerate is Life.
Posté le 25-09-2003 à 18:56:36  profilanswer
c de la 3d opengl solidworks ?  :heink:
[ FOR OVERCLOCKERS FOUS ] - Saloon des habitués -[ FOR OVERCLOCKERS FOUS ] ?¤¤Saloon des habitués¤¤?
Plus de sujets relatifs à : [ FOR OVERCLOCKERS FOUS et Retraités ] Saloon des habitués !
