3862 connectés
MSI 865PE Neo2
n°1056886
Goddy
Posté le 15-07-2004 à 01:12:56  profilanswer
Voila, je vien de recup' une mobo MSI 865PE Neo2 et quelques question viennent se poser en ce qui concerne model, ventillo, sondes etc ...
La première sera de savoir quelle CM correspond la mienne car entre la doc est le site c'est pas vraiment indiqué... cad entre :
  • FIS2R
  • PS
  • PLS
  • PFS
  • PFISR
Pour info cette mobo est composée de :
  • 2 SATA
  • 10/100
  • 8 USB2
  • 4 ATA (ide)
  • 1 AGP 8x + 5 PCI
  • Carte son AC97
  • et le reste des "buibui"
Ensuite la question est de savoir quelle sonde correspond a quoi et ou ellle est placée ...
donc j'ai linux debian et avec lm_sensor j'ai :
  • sans charge particuliere
[01:04]-[god@godstation]~$ sensors
w83627hf-isa-0290
Adapter: ISA adapter
VCore 1:   +1.52 V  (min =  +0.01 V, max =  +0.01 V)
VCore 2:   +1.57 V  (min =  +0.01 V, max =  +0.01 V)
+3.3V:     +3.30 V  (min =  +3.14 V, max =  +3.48 V)
+5V:       +5.12 V  (min =  +4.77 V, max =  +5.25 V)
+12V:     +11.94 V  (min = +10.84 V, max = +13.21 V)
-12V:     -12.01 V  (min = -13.16 V, max = -10.77 V)
-5V:       -5.08 V  (min =  -5.23 V, max =  -4.73 V)
V5SB:      +5.49 V  (min =  +4.77 V, max =  +5.25 V)
VBat:      +3.12 V  (min =  +2.40 V, max =  +3.60 V)
fan1:     2986 RPM  (min = 67500 RPM, div = 2)
fan2:        0 RPM  (min = 10887 RPM, div = 2)
fan3:        0 RPM  (min = 21093 RPM, div = 8)
temp1:       +40°C  (high =  -127°C, hyst =   -84°C)
temp2:     +40.5°C  (high =   +44°C, hyst =   +44°C)
temp3:     +56.0°C  (high =  +120°C, hyst =  +115°C)
vid:      +0.000 V
  • Avec charge a 100%
[01:05]-[god@godstation]~$ sensors
w83627hf-isa-0290
VCore 2:   +1.56 V  (min =  +0.01 V, max =  +0.01 V)
+3.3V:     +3.29 V  (min =  +3.14 V, max =  +3.48 V)
+5V:       +5.09 V  (min =  +4.77 V, max =  +5.25 V)
+12V:     +12.00 V  (min = +10.84 V, max = +13.21 V)
-12V:     -12.09 V  (min = -13.16 V, max = -10.77 V)
V5SB:      +5.47 V  (min =  +4.77 V, max =  +5.25 V)
VBat:      +3.00 V  (min =  +2.40 V, max =  +3.60 V)
temp1:       +41°C  (high =  -127°C, hyst =   -84°C)
temp2:     +52.5°C  (high =   +44°C, hyst =   +44°C)
temp3:     +56.5°C  (high =  +120°C, hyst =  +115°C)
je vais laisser supposer que celui qui augmente le plus est le processeur mais il y a celui a 56° qui m'intrigue ...
J'ai vu sur des forum que CT une valeur bidon ..??? je ne sais pas
ce serai la valeur du NorthBridge chip, celui qui a un ventillo du tonnere qui tourne a 5000tm (que G desactivé a cause du bruit mais en laissant le rad, a savoir que le fait de l'avoir enlevé ne change pas grand chose a la valeur de °)
Pour finir savoir OU sont placé ces 3 SONDEs (a gauche, a droite, etc ...)
Merci pour les réponses
Message édité par Goddy le 15-07-2004 à 01:20:40
n°1056893
tomtom41
It's not a bug, it's a feature
Posté le 15-07-2004 à 01:22:18  profilanswer
je possède une i875pe neo2 et j'ai la même valeur que toi (56°). c'est valeur ne correspond à rien :/
n°1056895
Goddy
Posté le 15-07-2004 à 01:24:27  profilanswer
ok la dessus je suis fixé merci
n°1056950
crane
Mort de soif !
Posté le 15-07-2004 à 10:25:00  profilanswer
pour le modèle de la cm ca doit etre ecrit qq part dessus normalement
n°1056990
Goddy
Posté le 15-07-2004 à 11:25:30  profilanswer
oué dessus ya ecrit : MSI 6728 VER : 1
n°1056992
Goddy
Posté le 15-07-2004 à 11:29:59  profilanswer
865 PE Neo 2
MSI 6728 VER : 1
entre les ports PCI
n°1057004
crane
Mort de soif !
Posté le 15-07-2004 à 11:41:55  profilanswer
Bon le modèle dépend de ce que tu as sur la carte. Je sais c'est pas évident chez MSI, mais regarde sur leur site, il doit y avoir tout les modèles et tu trouvera celui qui correspond a ta carte
n°1057018
Goddy
Posté le 15-07-2004 à 11:55:43  profilanswer
  • 865PE Neo2-PS [Version Standard, Serial ATA]
  • 865PE Neo2-PLS [Réseau 10/100, Serial ATA]
  • 865PE Neo2-PFS [Réseau 10/100/1000, Serial ATA]
  • 865PE Neo2-PFISR [Réseau 10/100/1000, IEEE1394, Serial ATA RAID]
J'ai trouvé ca mais pourquoi "VER : 1" alors que la version standar n'a pas de 10/100
n°1057090
crane
Mort de soif !
Posté le 15-07-2004 à 13:54:35  profilanswer
donc visiblement tu as une PLS. Le VER : 1 ca doit etre la revision 1, un truc du style
n°1057227
tiboz
Posté le 15-07-2004 à 17:03:12  profilanswer
raté !!! moi j ai l ancienne version de cette carte mere et c est une msi 865 pe neo2 LS ( exactement cette reference MSI 6728 VER : 1
n°1057229
tiboz
Posté le 15-07-2004 à 17:05:24  profilanswer
il faut diferencier 2 cartes meres a base  de i865. en ce qui concerne la temperature du NB , c est rien ca a toujours été comme sa . moi ca fai 1 an qu il y a plus de ventilo dessus lol
http://www.msi-computer.fr/index.p [...] b312a5705c
n°1057235
Goddy
Posté le 15-07-2004 à 17:12:26  profilanswer
As tu un port ETHERNET ? sur t'a mobo ? parce que moi j'en ai un
n°1057695
crane
Mort de soif !
Posté le 16-07-2004 à 08:47:49  profilanswer
En meme temps ta carte n'est pas referencée chez msi... 848 LS ok, mais pas 865 LS
msi gforce4400MSI K8T NEO (k8t800) premiere du nom en socket 754
>> [ Athlons supportés par une MoBo MSI MS6330 KT133 Turbo II ]>> [ Athlons supportés par une MoBo MSI MS6330 KT133 Turbo II ]
Zalman ZM80C-HP + msi 865 PE neo 2OC mon p4 de 2.6c sur une msi i848p neo LS
Le topic des overclocking sur carte mères MSI k7N2 DELTAquel est le meilleur bios pour 1 msi k7n2 delta pour oc ?
[Mod Vcore] MSI KT4V: Comment savoir cb de volts sont gagnés?O/C et tension P4a avec MSI 865pe neo2
Plus de sujets relatifs à : MSI 865PE Neo2
