4310 connectés
  Linux et OS Alternatifs
  réseaux et sécurité
  Problème nagios sous mandraker 9.1
n°303344
sono77
Posté le 08-08-2003 à 13:29:16  profilanswer
Bonjour j'ai bien installé le logiciel nagios avec ses plugins comme dans la doc, j'arrive à voir la 1er page mais des que je clique sur un lien j'ai impossible d'afficher la page.
j'ai essaye de restart le service nagios et j'obtiens ce message
Running configuration check...
Nagios 1.1
Copyright (c) 1999-2003 Ethan Galstad (nagios@nagios.org)
Last Modified: 06-02-2003
License: GPL
Reading configuration data...
Running pre-flight check on configuration data...
Checking services...
 Checked 38 services.
Checking hosts...
 Checked 15 hosts.
Checking host groups...
 Checked 6 host groups.
Checking contacts...
 Checked 2 contacts.
Checking contact groups...
 Checked 6 contact groups.
Checking service escalations...
 Checked 2 service escalations.
Checking host group escalations...
 Checked 2 host group escalations.
Checking service dependencies...
Error: Dependent service specified in service dependency for service 'Website #2' on host 'nt1' is not defined anywhere!
Error: Service specified in service dependency for service 'Website #2' on host 'nt1' is not defined anywhere!
Error: Service dependency definition for service 'Website #2' on host 'nt1' is circular (it depends on itself)!
Error: Dependent service specified in service dependency for service 'Website #1' on host 'nt1' is not defined anywhere!
Error: Service specified in service dependency for service 'Website #1' on host 'nt1' is not defined anywhere!
Error: Service dependency definition for service 'Website #1' on host 'nt1' is circular (it depends on itself)!
 Checked 4 service dependencies.
Checking host escalations...
 Checked 0 host escalations.
Checking host dependencies...
 Checked 0 host dependencies.
Checking commands...
 Checked 22 commands.
Checking time periods...
 Checked 4 time periods.
Checking for circular paths between hosts...
Checking for circular service execution dependencies...
Checking global event handlers...
Checking obsessive compulsive service processor command...
Checking misc settings...
Total Warnings: 0
Total Errors:   12
***> One or more problems was encountered while running the pre-flight check...
     Check your configuration file(s) to ensure that they contain valid
     directives and data defintions.  If you are upgrading from a previous
     version of Nagios, you should be aware that some variables/definitions
     may have been removed or modified in this version.  Make sure to read
     the HTML documentation on the main and host config files, as well as the
     'Whats New' section to find out what has changed.
failed - aborting reload.
merci de votre aide
sono77
n°303413
C_Po_Ma_Fa​ute
Posté le 08-08-2003 à 15:27:20  profilanswer
il faut configurer les hôtes et services à surveiller, par défaut les fichiers de config correspondants (hosts.cfg et services.cfg) sont remplis d'exemples qui n'ont probablement rien à voir avec ce que toi tu veux surveiller
Message édité par C_Po_Ma_Faute le 08-08-2003 à 15:29:20
  réseaux et sécurité
Problème iptables + FTP[Debian] problème apt
Problème de boot avec le kernel 2.6.0test2Probleme avec le Logiciel VFAPI
probleme de comilation noyau : libncursesProblème avec linux pour installer carete Ethernet d'un Shuttle SN41G2
Problème amorçage Mandrake 9.1 à cause de SCSI...Problème avec transcode sur Mdk 9.1
Problème partimage[Bash] Problème de script dans un if.. fi
Plus de sujets relatifs à : Problème nagios sous mandraker 9.1
