8576 connectés
  Linux et OS Alternatifs
  Installation
  Xfree ne marche plus après un upgrade MDK 8.0 -> 9.0
n°221862
Combi_A_Ve​ndre
Posté le 09-02-2003 à 15:05:34  profilanswer
Bonjour à tous,
J'ai voulu upgradé ma Mandrake 8.0 vers 9.0, et Xfree ne marche plus (entre autres choses...)
Ma carte vidéo est une Nvidia Xentor 16 TNT2.
Voici le message d'erreur (XFree86.0.log) :
Code :
  1. XFree86 Version 4.2.1 / X Window System
  2. (protocol Version 11, revision 0, vendor release 6600)
  3. Release Date: 3 September 2002
  4. If the server is older than 6-12 months, or if your card is
  5. newer than the above date, look for a newer version before
  6. reporting problems.  (See http://www.XFree86.Org/)
  7. Build Operating System: Linux 2.4.18-23mdkenterprise i686 [ELF]
  8. Module Loader present
  9. Markers: (--) probed, (**) from config file, (==) default setting,
  10.          (++) from command line, (!!) notice, (II) informational,
  11.          (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
  12. (==) Log file: "/var/log/XFree86.0.log", Time: Sun Feb  9 21:24:25 2003
  13. (==) Using config file: "/etc/X11/XF86Config-4"
  14. (==) ServerLayout "layout1"
  15. (**) |-->Screen "screen1" (0)
  16. (**) |   |-->Monitor "monitor1"
  17. (**) |   |-->Device "device1"
  18. (**) |-->Input Device "Keyboard1"
  19. (**) Option "XkbModel" "pc105"
  20. (**) XKB: model: "pc105"
  21. (**) Option "XkbLayout" "fr"
  22. (**) XKB: layout: "fr"
  23. (WW) Option "XkbOptions" requires an string value
  24. (==) Keyboard: CustomKeycode disabled
  25. (**) |-->Input Device "Mouse1"
  26. (**) FontPath set to "unix/:-1"
  27. (==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
  28. (==) ModulePath set to "/usr/X11R6/lib/modules"
  29. (**) Option "AllowMouseOpenFail"
  30. Using vt 8
  31. (--) using VT number 8
  32. (II) Open APM successful
  33. (II) Module ABI versions:
  34. XFree86 ANSI C Emulation: 0.1
  35. XFree86 Video Driver: 0.5
  36. XFree86 XInput driver : 0.3
  37. XFree86 Server Extension : 0.1
  38. XFree86 Font Renderer : 0.3
  39. (II) Loader running on linux
  40. (II) LoadModule: "bitmap"
  41. (II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
  42. (II) Module bitmap: vendor="The XFree86 Project"
  43. compiled for 4.2.1, module version = 1.0.0
  44. Module class: XFree86 Font Renderer
  45. ABI class: XFree86 Font Renderer, version 0.3
  46. (II) Loading font Bitmap
  47. (II) LoadModule: "pcidata"
  48. (II) Loading /usr/X11R6/lib/modules/libpcidata.a
  49. (II) Module pcidata: vendor="The XFree86 Project"
  50. compiled for 4.2.1, module version = 0.1.0
  51. ABI class: XFree86 Video Driver, version 0.5
  52. (II) PCI: Probing config type using method 1
  53. (II) PCI: Config type is 1
  54. (II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
  55. (II) PCI: PCI scan (all values are in hex)
  56. (II) PCI: 00:00:0: chip 8086,7190 card 0000,0000 rev 03 class 06,00,00 hdr 00
  57. (II) PCI: 00:01:0: chip 8086,7191 card 0000,0000 rev 03 class 06,04,00 hdr 01
  58. (II) PCI: 00:04:0: chip 8086,7110 card 0000,0000 rev 02 class 06,01,00 hdr 80
  59. (II) PCI: 00:04:1: chip 8086,7111 card 0000,0000 rev 01 class 01,01,80 hdr 00
  60. (II) PCI: 00:04:2: chip 8086,7112 card 0000,0000 rev 01 class 0c,03,00 hdr 00
  61. (II) PCI: 00:04:3: chip 8086,7113 card 0000,0000 rev 02 class 06,80,00 hdr 00
  62. (II) PCI: 00:0a:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
  63. (II) PCI: 00:0b:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
  64. (II) PCI: 01:00:0: chip 10de,0028 card 14af,5810 rev 11 class 03,00,00 hdr 00
  65. (II) PCI: End of PCI scan
  66. (II) LoadModule: "scanpci"
  67. (II) Loading /usr/X11R6/lib/modules/libscanpci.a
  68. (II) Module scanpci: vendor="The XFree86 Project"
  69. compiled for 4.2.1, module version = 0.1.0
  70. ABI class: XFree86 Video Driver, version 0.5
  71. (II) UnloadModule: "scanpci"
  72. (II) Unloading /usr/X11R6/lib/modules/libscanpci.a
  73. (II) Host-to-PCI bridge:
  74. (II) PCI-to-ISA bridge:
  75. (II) PCI-to-PCI bridge:
  76. (II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
  77. (II) Bus 0 I/O range:
  78. [0] -1 0x00000000 - 0x0000ffff (0x10000) IX[B]
  79. (II) Bus 0 non-prefetchable memory range:
  80. [0] -1 0x00000000 - 0xffffffff (0x0) MX[B]
  81. (II) Bus 0 prefetchable memory range:
  82. [0] -1 0x00000000 - 0xffffffff (0x0) MX[B]
  83. (II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x88 (VGA_EN is set)
  84. (II) Bus 1 I/O range:
  85. (II) Bus 1 non-prefetchable memory range:
  86. [0] -1 0xe0000000 - 0xe1efffff (0x1f00000) MX[B]
  87. (II) Bus 1 prefetchable memory range:
  88. [0] -1 0xe1f00000 - 0xe3ffffff (0x2100000) MX[B]
  89. (II) Bus -1: bridge is at (0:4:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
  90. (II) Bus -1 I/O range:
  91. (II) Bus -1 non-prefetchable memory range:
  92. (II) Bus -1 prefetchable memory range:
  93. (--) PCI:*(1:0:0) NVidia RIVA TNT2/TNT2 Pro rev 17, Mem @ 0xe0000000/24, 0xe2000000/25, BIOS @ 0xe1ff0000/16
  94. (II) Addressable bus resource ranges are
  95. [0] -1 0x00000000 - 0xffffffff (0x0) MX[B]
  96. [1] -1 0x00000000 - 0x0000ffff (0x10000) IX[B]
  97. (II) OS-reported resource ranges:
  98. [0] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  99. [1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  100. [2] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
  101. [3] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
  102. [4] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  103. [5] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
  104. [6] -1 0x00000000 - 0x000000ff (0x100) IX[B]
  105. (II) Active PCI resource ranges:
  106. [0] -1 0xdf000000 - 0xdf0000ff (0x100) MX[B]
  107. [1] -1 0xdf800000 - 0xdf8000ff (0x100) MX[B]
  108. [2] -1 0xe4000000 - 0xe7ffffff (0x4000000) MX[B]
  109. [3] -1 0xe1ff0000 - 0xe1ffffff (0x10000) MX[B](B)
  110. [4] -1 0xe2000000 - 0xe3ffffff (0x2000000) MX[B](B)
  111. [5] -1 0xe0000000 - 0xe0ffffff (0x1000000) MX[B](B)
  112. [6] -1 0x0000b800 - 0x0000b8ff (0x100) IX[B]
  113. [7] -1 0x0000d000 - 0x0000d0ff (0x100) IX[B]
  114. [8] -1 0x0000d400 - 0x0000d41f (0x20) IX[B]
  115. [9] -1 0x0000d800 - 0x0000d80f (0x10) IX[B]
  116. (II) Active PCI resource ranges after removing overlaps:
  117. [0] -1 0xdf000000 - 0xdf0000ff (0x100) MX[B]
  118. [1] -1 0xdf800000 - 0xdf8000ff (0x100) MX[B]
  119. [2] -1 0xe4000000 - 0xe7ffffff (0x4000000) MX[B]
  120. [3] -1 0xe1ff0000 - 0xe1ffffff (0x10000) MX[B](B)
  121. [4] -1 0xe2000000 - 0xe3ffffff (0x2000000) MX[B](B)
  122. [5] -1 0xe0000000 - 0xe0ffffff (0x1000000) MX[B](B)
  123. [6] -1 0x0000b800 - 0x0000b8ff (0x100) IX[B]
  124. [7] -1 0x0000d000 - 0x0000d0ff (0x100) IX[B]
  125. [8] -1 0x0000d400 - 0x0000d41f (0x20) IX[B]
  126. [9] -1 0x0000d800 - 0x0000d80f (0x10) IX[B]
  127. (II) OS-reported resource ranges after removing overlaps with PCI:
  128. [0] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  129. [1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  130. [2] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
  131. [3] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
  132. [4] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  133. [5] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
  134. [6] -1 0x00000000 - 0x000000ff (0x100) IX[B]
  135. (II) All system resource ranges:
  136. [0] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  137. [1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  138. [2] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
  139. [3] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
  140. [4] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  141. [5] -1 0xdf000000 - 0xdf0000ff (0x100) MX[B]
  142. [6] -1 0xdf800000 - 0xdf8000ff (0x100) MX[B]
  143. [7] -1 0xe4000000 - 0xe7ffffff (0x4000000) MX[B]
  144. [8] -1 0xe1ff0000 - 0xe1ffffff (0x10000) MX[B](B)
  145. [9] -1 0xe2000000 - 0xe3ffffff (0x2000000) MX[B](B)
  146. [10] -1 0xe0000000 - 0xe0ffffff (0x1000000) MX[B](B)
  147. [11] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
  148. [12] -1 0x00000000 - 0x000000ff (0x100) IX[B]
  149. [13] -1 0x0000b800 - 0x0000b8ff (0x100) IX[B]
  150. [14] -1 0x0000d000 - 0x0000d0ff (0x100) IX[B]
  151. [15] -1 0x0000d400 - 0x0000d41f (0x20) IX[B]
  152. [16] -1 0x0000d800 - 0x0000d80f (0x10) IX[B]
  153. (II) LoadModule: "dbe"
  154. (II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
  155. (II) Module dbe: vendor="The XFree86 Project"
  156. compiled for 4.2.1, module version = 1.0.0
  157. Module class: XFree86 Server Extension
  158. ABI class: XFree86 Server Extension, version 0.1
  159. (II) Loading extension DOUBLE-BUFFER
  160. (II) LoadModule: "v4l"
  161. (II) Loading /usr/X11R6/lib/modules/drivers/linux/v4l_drv.o
  162. (II) Module v4l: vendor="The XFree86 Project"
  163. compiled for 4.2.1, module version = 0.0.1
  164. ABI class: XFree86 Video Driver, version 0.5
  165. (II) LoadModule: "extmod"
  166. (II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
  167. (II) Module extmod: vendor="The XFree86 Project"
  168. compiled for 4.2.1, module version = 1.0.0
  169. Module class: XFree86 Server Extension
  170. ABI class: XFree86 Server Extension, version 0.1
  171. (II) Loading extension SHAPE
  172. (II) Loading extension MIT-SUNDRY-NONSTANDARD
  173. (II) Loading extension BIG-REQUESTS
  174. (II) Loading extension SYNC
  175. (II) Loading extension MIT-SCREEN-SAVER
  176. (II) Loading extension XC-MISC
  177. (II) Loading extension XFree86-VidModeExtension
  178. (II) Loading extension XFree86-Misc
  179. (II) Loading extension XFree86-DGA
  180. (II) Loading extension DPMS
  181. (II) Loading extension FontCache
  182. (II) Loading extension TOG-CUP
  183. (II) Loading extension Extended-Visual-Information
  184. (II) Loading extension XVideo
  185. (II) Loading extension XVideo-MotionCompensation
  186. (II) LoadModule: "type1"
  187. (II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
  188. (II) Module type1: vendor="The XFree86 Project"
  189. compiled for 4.2.1, module version = 1.0.1
  190. Module class: XFree86 Font Renderer
  191. ABI class: XFree86 Font Renderer, version 0.3
  192. (II) Loading font Type1
  193. (II) Loading font CID
  194. (II) LoadModule: "freetype"
  195. (II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
  196. (II) Module freetype: vendor="The XFree86 Project"
  197. compiled for 4.2.1, module version = 1.1.10
  198. Module class: XFree86 Font Renderer
  199. ABI class: XFree86 Font Renderer, version 0.3
  200. (II) Loading font FreeType
  201. (II) LoadModule: "/usr/X11R6/lib/modules/extensions/libglx.so" (glx)
  202. (WW) LoadModule: given non-canonical module name "/usr/X11R6/lib/modules/extensions/libglx.so"
  203. (II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
  204. (II) Module glx: vendor="NVIDIA Corporation"
  205. compiled for 4.0.2, module version = 1.0.2802
  206. Module class: XFree86 Server Extension
  207. ABI class: XFree86 Server Extension, version 0.1
  208. (II) Loading extension GLX
  209. (II) LoadModule: "nvidia"
  210. (II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.o
  211. (II) Module nvidia: vendor="NVIDIA Corporation"
  212. compiled for 4.0.2, module version = 1.0.2802
  213. Module class: XFree86 Video Driver
  214. (II) LoadModule: "mouse"
  215. (II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
  216. (II) Module mouse: vendor="The XFree86 Project"
  217. compiled for 4.2.1, module version = 1.0.0
  218. Module class: XFree86 XInput Driver
  219. ABI class: XFree86 XInput driver, version 0.3
  220. (II) v4l driver for Video4Linux
  221. (II) NVIDIA XFree86 Driver  1.0-2802  Tue Mar  5 06:30:06 PST 2002
  222. (II) NVIDIA: NVIDIA driver for: RIVA TNT, RIVA TNT2, Vanta,
  223. RIVA TNT2 Ultra, RIVA TNT2 Model 64, Aladdin TNT2, GeForce 256,
  224. GeForce DDR, Quadro, GeForce2 MX/MX 400, GeForce2 MX 100/200,
  225. Quadro2 MXR/EX/Go, GeForce2 Integrated GPU, GeForce2 GTS,
  226. GeForce2 Ti, GeForce2 Ultra, Quadro2 Pro, GeForce4 MX 460,
  227. GeForce4 MX 440, GeForce4 MX 420, Quadro4 500XGL, Quadro4 200/400NVS,
  228. Quadro4 550XGL, GeForce3, GeForce3 Ti 200, GeForce3 Ti 500,
  229. Quadro DCC, GeForce4 Ti 4600, GeForce4 Ti 4400, GeForce4 Ti 4200,
  230. Quadro4 900XGL, Quadro4 750XGL, Quadro4 700XGL, GeForce2 Go,
  231. GeForce4 440 Go, GeForce4 420 Go, GeForce4 420 Go 32M,
  232. GeForce4 440 Go 64M, Quadro4 500 GoGL
  233. (II) Primary Device is: PCI 01:00:0
  234. (--) Assigning device section with no busID to primary device
  235. (--) Chipset RIVA TNT2 found
  236. (II) resource ranges after xf86ClaimFixedResources() call:
  237. [0] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  238. [1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  239. [2] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
  240. [3] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
  241. [4] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  242. [5] -1 0xdf000000 - 0xdf0000ff (0x100) MX[B]
  243. [6] -1 0xdf800000 - 0xdf8000ff (0x100) MX[B]
  244. [7] -1 0xe4000000 - 0xe7ffffff (0x4000000) MX[B]
  245. [8] -1 0xe1ff0000 - 0xe1ffffff (0x10000) MX[B](B)
  246. [9] -1 0xe2000000 - 0xe3ffffff (0x2000000) MX[B](B)
  247. [10] -1 0xe0000000 - 0xe0ffffff (0x1000000) MX[B](B)
  248. [11] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
  249. [12] -1 0x00000000 - 0x000000ff (0x100) IX[B]
  250. [13] -1 0x0000b800 - 0x0000b8ff (0x100) IX[B]
  251. [14] -1 0x0000d000 - 0x0000d0ff (0x100) IX[B]
  252. [15] -1 0x0000d400 - 0x0000d41f (0x20) IX[B]
  253. [16] -1 0x0000d800 - 0x0000d80f (0x10) IX[B]
  254. (II) resource ranges after probing:
  255. [0] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  256. [1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  257. [2] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
  258. [3] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
  259. [4] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  260. [5] -1 0xdf000000 - 0xdf0000ff (0x100) MX[B]
  261. [6] -1 0xdf800000 - 0xdf8000ff (0x100) MX[B]
  262. [7] -1 0xe4000000 - 0xe7ffffff (0x4000000) MX[B]
  263. [8] -1 0xe1ff0000 - 0xe1ffffff (0x10000) MX[B](B)
  264. [9] -1 0xe2000000 - 0xe3ffffff (0x2000000) MX[B](B)
  265. [10] -1 0xe0000000 - 0xe0ffffff (0x1000000) MX[B](B)
  266. [11] 0 0x000a0000 - 0x000affff (0x10000) MS[B]
  267. [12] 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
  268. [13] 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
  269. [14] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
  270. [15] -1 0x00000000 - 0x000000ff (0x100) IX[B]
  271. [16] -1 0x0000b800 - 0x0000b8ff (0x100) IX[B]
  272. [17] -1 0x0000d000 - 0x0000d0ff (0x100) IX[B]
  273. [18] -1 0x0000d400 - 0x0000d41f (0x20) IX[B]
  274. [19] -1 0x0000d800 - 0x0000d80f (0x10) IX[B]
  275. [20] 0 0x000003b0 - 0x000003bb (0xc) IS[B]
  276. [21] 0 0x000003c0 - 0x000003df (0x20) IS[B]
  277. (II) Setting vga for screen 0.
  278. (II) Loading sub module "vgahw"
  279. (II) LoadModule: "vgahw"
  280. (II) Loading /usr/X11R6/lib/modules/libvgahw.a
  281. (II) Module vgahw: vendor="The XFree86 Project"
  282. compiled for 4.2.1, module version = 0.1.0
  283. ABI class: XFree86 Video Driver, version 0.5
  284. (**) NVIDIA(0): Depth 16, (--) framebuffer bpp 16
  285. (==) NVIDIA(0): RGB weight 565
  286. (==) NVIDIA(0): Default visual is TrueColor
  287. (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
  288. (--) NVIDIA(0): Linear framebuffer at 0xE2000000
  289. (--) NVIDIA(0): MMIO registers at 0xE0000000
  290. (EE) NVIDIA(0): Failed to initialize the NVdriver kernel module!
  291. (EE) NVIDIA(0):  *** Aborting ***
  292. (II) UnloadModule: "nvidia"
  293. (II) UnloadModule: "vgahw"
  294. (II) Unloading /usr/X11R6/lib/modules/libvgahw.a
  295. (EE) Screen(s) found, but none have a usable configuration.
  296. Fatal server error:
  297. no screens found
  298. When reporting a problem related to a server crash, please send
  299. the full server output, not just the last messages.
  300. This can be found in the log file "/var/log/XFree86.0.log".
  301. Please report problems to xfree86@xfree86.org.
Et voici mon fichier de configuration XF86Config-4 :
Code :
  1. # File generated by XFdrake.
  2. # **********************************************************************
  3. # Refer to the XF86Config man page for details about the format of
  4. # this file.
  5. # **********************************************************************
  6. Section "Files"
  7.     # Multiple FontPath entries are allowed (they are concatenated together)
  8.     # By default, Mandrake 6.0 and later now use a font server independent of
  9.     # the X server to render fonts.
  10.     FontPath "unix/:-1"
  11. EndSection
  12. Section "ServerFlags"
  13.     #DontZap # disable <Crtl><Alt><BS> (server abort)
  14.     #DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching)
  15.     AllowMouseOpenFail # allows the server to start up even if the mouse doesn't work
  16. EndSection
  17. Section "Module"
  18.     Load "dbe" # Double-Buffering Extension
  19.     Load "v4l" # Video for Linux
  20.     Load "extmod"
  21.     Load "type1"
  22.     Load "freetype"
  23.     Load "/usr/X11R6/lib/modules/extensions/libglx.so"
  24. EndSection
  25. Section "InputDevice"
  26.     Identifier "Keyboard1"
  27.     Driver "Keyboard"
  28.     Option "XkbModel" "pc105"
  29.     Option "XkbLayout" "fr"
  30.     Option "XkbOptions" ""
  31. EndSection
  32. Section "InputDevice"
  33.     Identifier "Mouse1"
  34.     Driver "mouse"
  35.     Option "Protocol" "PS/2"
  36.     Option "Device" "/dev/psaux"
  37.     Option "Emulate3Buttons"
  38.     Option "Emulate3Timeout" "50"
  39. EndSection
  40. Section "Monitor"
  41.     Identifier "monitor1"
  42.     VendorName "Generic"
  43.     ModelName "800x600 @ 60 Hz"
  44.     HorizSync 31.5-37.9
  45.     VertRefresh 50-70
  46.
  47.     # Sony Vaio C1(X,XS,VE,VN)?
  48.     # 1024x480 @ 85.6 Hz, 48 kHz hsync
  49.     ModeLine "1024x480"    65.00 1024 1032 1176 1344   480  488  494  563 -hsync -vsync
  50.
  51.     # TV fullscreen mode or DVD fullscreen output.
  52.     # 768x576 @ 79 Hz, 50 kHz hsync
  53.     ModeLine "768x576"     50.00  768  832  846 1000   576  590  595  630
  54.
  55.     # 768x576 @ 100 Hz, 61.6 kHz hsync
  56.     ModeLine "768x576"     63.07  768  800  960 1024   576  578  590  616
  57. EndSection
  58. Section "Device"
  59.     Identifier "device1"
  60.     VendorName "nVidia Corporation"
  61.     BoardName "RIVA TNT2"
  62.     Driver "nvidia"
  63.     Option "DPMS"
  64. EndSection
  65. Section "Screen"
  66.     Identifier "screen1"
  67.     Device "device1"
  68.     Monitor "monitor1"
  69.     DefaultColorDepth 16
  70.
  71.     Subsection "Display"
  72.         Depth 8
  73.         Modes "800x600" "640x480"
  74.     EndSubsection
  75.
  76.     Subsection "Display"
  77.         Depth 15
  78.         Modes "800x600" "640x480"
  79.     EndSubsection
  80.
  81.     Subsection "Display"
  82.         Depth 16
  83.         Modes "800x600" "640x480"
  84.     EndSubsection
  85.
  86.     Subsection "Display"
  87.         Depth 24
  88.         Modes "800x600" "640x480"
  89.     EndSubsection
  90. EndSection
  91. Section "ServerLayout"
  92.     Identifier "layout1"
  93.     InputDevice "Keyboard1" "CoreKeyboard"
  94.     InputDevice "Mouse1" "CorePointer"
  95.     Screen "screen1"
  96. EndSection
Quelqu'un peut m'aider?
Merci,
vw.
The best way to accelerate a computer running windows is at 9.8m.s-2
n°221871
Mjules
Parle dans le vide
Posté le 09-02-2003 à 15:09:55  profilanswer
est ce que tu as recompilé tes drivers Nvidia pour le nouveau noyau/XFree ?
ou installé ceux pour MDK 9 ?
si la réponse est non, cherche pas + loin.
NB : ton XF86config a l'air bon.
Message édité par Mjules le 09-02-2003 à 15:10:36
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°221875
Combi_A_Ve​ndre
Posté le 09-02-2003 à 15:22:30  profilanswer
J'ai installé :
NVIDIA_GLX-1.0-2802.src.rpm
et
NVIDIA_kernel-1.0-2802.src.rpm
J'utilise un pauvre écran générique 800x600
vw
Message édité par Combi_A_Vendre le 09-02-2003 à 15:23:27
n°221877
Mjules
Parle dans le vide
Posté le 09-02-2003 à 15:27:07  profilanswer
Ok, mais les as tu recompilé après avoir installé le nouveau XFree ? ou tu as installé ceux que tu avais compilé pour la 8.0 ?
http://www.nvidia.fr/view.asp?IO=l [...] .0-4191_fr
essayes de les mettre à jour avec les pilotes MDK 9 :
ou de les recompiler avant de les réinstaller.
n°221878
fl0ups
東京 - パリ - SLP
Posté le 09-02-2003 à 15:29:07  profilanswer
src.rpm = sources
soit tu compiles ces rpm sources, soit tu installes directement des binaires.
Je te conseille de prendre les derniers src.rpm de la série 33.XX (les 40XX sont très lents en 2D sous Gnome), de les recompiler, et d'installer les ix86.rpm qui découleront de ta recompilation
n°221879
Combi_A_Ve​ndre
Posté le 09-02-2003 à 15:29:12  profilanswer
Ben en fait je sais pas trop. Il faut desinstaller les anciens drivers? comment on fait?
vw
n°221880
Mjules
Parle dans le vide
Posté le 09-02-2003 à 15:31:03  profilanswer
pas besoin de désinstaller les anciens drivers.
http://linux-wizard.tuxfamily.org/howto_nvidia.html
n°221892
Combi_A_Ve​ndre
Posté le 09-02-2003 à 15:53:48  profilanswer
C'est ce que j'ai fait.
Quand j'en suis à
rpm -Uvh /usr/src/RPM/RPMS/i686/NVIDIA_kernel-1.0-2960.i686.rpm
J'ai :
"package NVIDIA_kernel-1.0.2802 is already installed"
C'est normal?
vw
n°221900
Mjules
Parle dans le vide
Posté le 09-02-2003 à 16:08:57  profilanswer
bon, ben faut les désinstaller alors :
urpme NVIDIA
n°221952
Combi_A_Ve​ndre
Posté le 09-02-2003 à 18:29:19  profilanswer
urpme NVIDIA
Ca me dit :
"Le retrait du paquetage NVIDIA_kernel-1.0-2802 rendra votre système inutilisable" Et les paquetages ne sont pas enlevés.
vw
n°221953
Mjules
Parle dans le vide
Posté le 09-02-2003 à 18:32:12  profilanswer
tu fais ça dans un terminal sous X non ?
et ben il va falloir l'arrêter : telinit 3
tu va te retrouver en ligne de commande et là, il ne devrait plus te poser de pb.
pour revenir au mode graphique : telinit 5
n°221957
Combi_A_Ve​ndre
Posté le 09-02-2003 à 18:37:52  profilanswer
Je ne suis pas sous X, vu que ça démarre pas. J'ai essayé ce que tu a écrit, c'est pareil.
Et si je désintalle XFree ?
vw
n°221962
Mjules
Parle dans le vide
Posté le 09-02-2003 à 18:44:01  profilanswer
bon, on ve le forcer à faire ce qu'on veut cet imbécile  :fou:
rpm -Uvh --replacepkgs blabla.rpm
n°221969
Combi_A_Ve​ndre
Posté le 09-02-2003 à 19:00:06  profilanswer
Ca fait pareil, j'ai toujours le même message d'erreur quand je lance startx.... :
Failed to initialize NVidia kernel module!
vw
Message édité par Combi_A_Vendre le 09-02-2003 à 19:02:22
n°221973
Mjules
Parle dans le vide
Posté le 09-02-2003 à 19:08:32  profilanswer
si tu as bien installé GLX et KERNEL, alors là, je sèche.
n°221977
zeb_
Posté le 09-02-2003 à 19:17:39  profilanswer
Cette fois tu as bien pris les paquets pour la 9, pas pour la 8 ?
Quel kernel tu as ? la 9.0 a eu une update kernel.
Le mieux est de prendre les drivers .tgz et de recompiler comme expliqué dans le site de Dark Schneider. Tu as besoin des sources de ton kernel en cours.
n°222100
Combi_A_Ve​ndre
Posté le 10-02-2003 à 07:06:55  profilanswer
Pour upgrader la Mandrake, j'ai re-installer linux par dessus la 8.0, apres, je ne sais pas trop ce qui a ete fait pour les sources du kernel.
Pour les drivers, j'ai pris les src et j'ai fait comme sur le site de Dark Schneider.
vw
n°222103
zeb_
Posté le 10-02-2003 à 08:43:36  profilanswer
vw
C'est ça ton problème : tu dois recompiler les drivers sur les sources correspondant à ton kernel
Vérifie les versions installées :
rpm -qi kernel
rpm -qi kernel-source
Message édité par zeb_ le 10-02-2003 à 10:18:41
n°222168
Bitman
STAY APART
Posté le 10-02-2003 à 12:36:26  profilanswer
moi j'avais fait rpm --rebuil les2machins.src.rpm, puis g installé les rpm (le kernel puis le glx), apres un ptit coup d'oeil dans xf86config-4 pour voir si driver=nvidia etc et ca roulaize  :)
n°222768
apolon34
Vive Linux!!
Posté le 11-02-2003 à 21:49:12  profilanswer
contentes toi de faire ca:
 - recuperer les paquets precompiles pour mandrake 9.0
 - tu installes les deux, en forcant.
tu fais un depmod -a && modprobe nvidia
tu lances xfree.
ca doit partir du premier coup avec ca.
  Installation
[AC97] je crois que j'ai mis le bordel, et ca ne marche toujours pas[exim]envoi avec la commande mail qui marche a moitié
ca marche comment l'initialisation ?C'est quoi cette version d'XFree ?
Bp Mdk 9 & RnisMDK 9.1b3: quels CD?
[CHELOU] New pb, xfree ne se lance ke en root !!!![tv streaming] ca marche!!!!! :) resolu!
Linux et controlleur promise raid-0 ca marche?Problème Woody et XFree
Plus de sujets relatifs à : Xfree ne marche plus après un upgrade MDK 8.0 -> 9.0
