7662 connectés
 Page :   1  2  3  4  5  ..  119  120  121  ..  1548  1549  1550  1551  1552  1553
[UBUNTU] 26.10 'Stonking Stingray' - Topic dédié
n°750023
madkat
Posté le 08-11-2005 à 12:09:34  profilanswer
ou bogue :o
Je suis d'accord.
n°750070
gee
Bon ben hon
Posté le 08-11-2005 à 14:35:38  profilanswer
sebchap a écrit :
DirectX9 [:petrus dei]
Pour composite, le seul cas dans lequel ca plante chez moi, c'est quand je kill xcompmgr (manuellement ou quand ut2004 s'en charge) et je j'essaye de le remettre
hmm
c'est vrai qu'on a pas de dx9 mais :
Ok. I've read every post, and tried to fiddle with it myself. I think I got this thing figured out.
Everyone with ATI cards on this thread says that the shadows work well, but fading doesn't. On my desktop ( A P4 2.6GZ with a 128mb 9600 pro ATI card) this is exactly the case. Drop shadows work fine, but fading slows everything to a crawl.
On my girlfriend's laptop (a celeron 1.7 GHz with a 16MB or 32MB Nvidia Geforce 420 Go) I have the nvidia drivers working and fading works great (it hard to describe, but its the best eyecandy I've ever seen. It removes my biggest complaint of Gnome with this Nvidia card- how ugly windows look when minimized. With this, on her laptop, they look great. Yet shadows won't work on hers. My guess is (based on the other people with Nvidia cards that have posted problems with this feature) that pre-directx9 cards- anything before the 5xxx FX series- won't do it. But thats just a guess.
I'll know soon, tonight I will buy an Nvidia card. Goodby ATI, hello fading. Changed my life this howto did...
n°750072
huit
Posté le 08-11-2005 à 14:42:33  profilanswer
je vien d'installer xfce4, et dans xffm, ya la partie samba gérée par xfsamba4,
j'arrive pas a me loguer avec un identifiant, jai remplit une variable d'environnement $SMB_USER (si je fait un echo dans un terminal c'est bon)
mais il indique dans le "debug" :
Domain=[DOMAINE] OS=[Windows 5.1] Server=[Windows 2000 LAN Manager]
Anonymous login successful
XFSAMBA> smbclient -N -L //SERVEUR
si quelqu'un peut m'aider :)
n°750075
Posté le 08-11-2005 à 14:53:50  answer
huit a écrit :
ouéoué je sais , mais jtrouve ca naze :D, comme je trouve naze que notre chere académie instaure des mots comme blogue mél ou cédérom
ça n'a rien à voir : au temps n'est pas une création de l'académie
sinon j'aime bien l'influence du quebec : butineur, courriel, pourriel...
n°750128
korny
Posté le 08-11-2005 à 17:58:53  profilanswer
JerryCrazy a écrit :
Tu as quoi comme modem/routeur au faite ?  :D
un thomson alcatel speedtouch 510 :)
n°750131
JerryCrazy
Le plus crazy des crazy
Posté le 08-11-2005 à 18:09:09  profilanswer
Faudrait que je trouve d'où vient le problème, apparement, sur toutes les distrib linux que j'ai testé
C'est le même, donc, je pense que les problèmes viennent des firmwares
Peut être que c'est la version de l'application qui récupère les DNS inclus dans le firmware qui est pas assez récente :D
Ou tout simplement le DHCP
Bref, c'est facile a contourner :D (quand j'ai reçu mon modem, j'ai faillit peter un câble pour trouver comment régler le problème, surtout que sur ma Mandriva a l'époque, certains logiciels passaient et d'autre pas [:joce])
My Digital Life - Ferrovia - FerroviaClub - Jeux Linux
n°750170
alien cons​piracy
hardtrance addict
Posté le 08-11-2005 à 19:41:28  profilanswer
Je rappel qu'une bonne documentation se trouve sur www.ubuntu-fr.org
n°750323
Posté le 09-11-2005 à 01:54:58  answer
Peut-on configurer nautilus pour qu'un double clic sur une image lance Gthumb plutôt que Eye of Gnome ?
Message édité par Profil supprimé le 09-11-2005 à 01:56:23
n°750326
gee
Bon ben hon
Posté le 09-11-2005 à 03:30:03  profilanswer
n°750399
belgique
Posté le 09-11-2005 à 12:12:36  profilanswer
Franchement antistress, on veut bien t'aider mais t'abuses :/
n°750428
l0ky
Posté le 09-11-2005 à 13:40:46  profilanswer
Faut créer un topic unik antistress [:klem3i1]
n°750466
Enzo974
Posté le 09-11-2005 à 15:03:29  profilanswer
voila j'ai installer ubuntu 5.10 sur mon pc de bureau et je suis déçu car la seul chose qui m'empeche de passer directement sous linux c'est le fait que je ne puisse pas utiliser ma connexion ma connexion (modem). Si quelqu'un aurait une solution pour installé les rivers de mon modem !!! ce sera sympa de me le signaler, je pensais utilisé WineX...
Qu'en pensez-vous ? Si une solution m'est apporté je pourrais enfin utilisé pleinement linux !
n°750468
belgique
Posté le 09-11-2005 à 15:04:46  profilanswer
Winex pour utiliser le modem: nan ça va pas marcher du tout ça. Question intéressante: quel est ton modem?
n°750470
Enzo974
Posté le 09-11-2005 à 15:06:09  profilanswer
c'est un Sitecom dc-002 !
n°750471
JerryCrazy
Posté le 09-11-2005 à 15:06:26  profilanswer
C'est clair que si on ne connait même pas ton modem, on va pas pouvoir t'aider mon grand [:petrus75]
n°750477
ory
Posté le 09-11-2005 à 15:20:09  profilanswer
ca sent le winmodem ça  :sweat:
n°750483
gee
Bon ben hon
Posté le 09-11-2005 à 15:28:40  profilanswer
et faudrait changer de pseudo aussi bientot je pense.
n°750527
sebfun
Posté le 09-11-2005 à 18:49:31  profilanswer
bonsoir , j'ai essayé d'installé unbutu 5.10 sur amd 64 (jai prit la bonne version )
et il me dit apres installation que mon server X est probablement mal configuré (or a part les resolution il ne ma rien demandé d'autre)
que faire car du coup j'ai pas d'interface suis en mode texte , :/
n°750529
alien cons​piracy
hardtrance addict
Posté le 09-11-2005 à 18:52:32  profilanswer
Quel carte graphique ?
n°750532
alien cons​piracy
hardtrance addict
Posté le 09-11-2005 à 18:54:46  profilanswer
Un driver linux est disponible sur le site du constructeur : www.sitecom.com
Message édité par alien conspiracy le 09-11-2005 à 18:56:47
n°750550
ssertsitna
Posté le 09-11-2005 à 19:38:30  profilanswer
ben moi j'aime bien ses questions ;-)
n°750552
Posté le 09-11-2005 à 19:39:45  answer
merci!
n°750554
Posté le 09-11-2005 à 19:43:24  answer
en fait j'ai fouillé dans les options avant de poser la question : je pensais que "applications péréférées" ou le menu édition>préférences de Nautilus permettrait cette manip mais j'ai rien trouvé :(
n°750589
JerryCrazy
Posté le 09-11-2005 à 21:03:42  profilanswer
Là, quand même, t'exagère, un clic droit sur le fichier > Propriétés ... :heink:
C'est le premier endroit où tout le monde cherche [:meganne lapin]
Message édité par JerryCrazy le 09-11-2005 à 21:03:56
n°750625
sebfun
Posté le 09-11-2005 à 22:10:55  profilanswer
bonsoir je possede une ati x800 xl powercolor , le tout sur plateforme nforce 4 ultra
voila
aidez moi please  :cry:  :cry:
n°750642
Posté le 09-11-2005 à 23:03:33  answer
c'est tout c*n en effet, mais fallait le savoir!
Désolé si je pose des questions stupides, mais j'ai des reflexes de windowsien et pas (encore) de linuxien (sous windows les propriétés des fichiers sont pas éditables comme ça!)
n°750658
phoenix-da​rk
SyStEm Of A dOwN
Posté le 10-11-2005 à 00:17:16  profilanswer
sisi, clic droit -> ouvrir avec
n°750666
sebfun
Posté le 10-11-2005 à 01:36:58  profilanswer
pfiouuuuuuuu enfin
j'ai selectionné le driver vesa plutot que ati
ensuite j'ai pu avoir acces a l'interface graphique
puis j'ai installé les drivers ati et en meme temps configurez mon bi ecran
pfiouuuu
n°750667
gee
Bon ben hon
Posté le 10-11-2005 à 01:37:14  profilanswer
voila
sudo dpkg-reconfigure xorg-server
n°750669
THRAK
- THR4K -
Posté le 10-11-2005 à 02:11:21  profilanswer
 :sarcastic:
Oh ben ça alors ! le beau multi que voilà  :o
Message édité par THRAK le 10-11-2005 à 02:13:04
THRAK (def.) : 1) A sudden and precise impact moving from intention, direction and commitment, in service of an aim. 2) 117 guitars almost striking the same chord simultaneously.
n°750674
sebfun
Posté le 10-11-2005 à 02:53:14  profilanswer
oui c'est ce que j'ai fais  ;)
bon maintenant faut que j'installe mldonkey
Message édité par sebfun le 10-11-2005 à 02:53:36
n°750709
Posté le 10-11-2005 à 10:14:48  answer
THRAK a écrit :
:sarcastic:
Message édité par Profil supprimé le 10-11-2005 à 10:15:08
n°750712
sebfun
Posté le 10-11-2005 à 10:20:31  profilanswer
question : j'ai brancher un second dd en ntfs que j'utilisais sous windows xp (dedans ya des documents etc )
et j'aimerais pouvoir les lire maintenant
probleme il me dit que j'ai pas les droit , j'arrive a voir les fichier que sous le gestionnaire de disque :/
je sais qu'il ya une commande fstab (un truc comme sa) mais j'en sais pas plus , pourriez vous m'éclairez svp
n°750714
Goon
Posté le 10-11-2005 à 10:33:50  profilanswer
qu'est-ce que tu appelles le gestionnaire de disque ?
n°750715
minux
On Linux ...
Posté le 10-11-2005 à 10:35:33  profilanswer
Pensez à faire une recherche dans le wiki, c'est fait pour ça, et y'a pratiquement toutes les réponses aux questions "simples" comme celle-ci et qui reviennent trop souvent ;)
C'est ici pour toi Sebfun : http://wiki.ubuntu-fr.org/installa [...] ns_windows
n°750723
sebfun
Posté le 10-11-2005 à 10:59:20  profilanswer
oui ben sa m'aidepas plus , j'ai déja été voir cela , et je monbte le disque comme ils disent en tapant /mnt/mesdocs
mais je ne peux l'activer :/
n°750725
minux
On Linux ...
Posté le 10-11-2005 à 11:00:52  profilanswer
Donne le contenu de ton fstab, on va voir ça ;)
n°750731
sebfun
Posté le 10-11-2005 à 11:18:15  profilanswer
c'est bon j'avais mit sev/sdb1
au lieu de dev/sdb1  :whistle:  :whistle:
bon j'ai encore plein de question :d
-bizarrement quand je réduit une fenetre , au debut je l'avais dans la barre des taches (enfin la barre en bas ^^) maintenant sa ny vas plus  :sweat: , suis légèrement dans la merde pour retrouver une fentre reduits mais pas dans la barre.que faire ??
-ensuite , j'ai vu que easy ubuntu étais un bon truc pour les noobs , comment l'installer svp ??
n°750802
alien cons​piracy
hardtrance addict
Posté le 10-11-2005 à 14:45:56  profilanswer
http://placelibre.ath.cx/keyes/ind [...] asy-ubuntu
n°750841
shaddy
j'aime la gym
Posté le 10-11-2005 à 16:37:30  profilanswer
pour easyubuntu fais attention la 2.4 est encore en beta, tout ne marchera peut-être pas.
Ubuntu c'est nul ! Tu l'installes et puis ça marche ... y a rien à bidouiller. rm -rf /
n°750843
sebfun
Posté le 10-11-2005 à 16:41:27  profilanswer
oué wait and see ;)
j'lai mise là :)
sinon pour mon premier probleme ??
je réexplique
quand j'ouvre par exemplr un terminal ou firefox  , que je veux le reduire , il ne vas pas dans la barre en bas mais va je ne sais ou .... ce qui fais qque je ne peux le remettre  :/
edit a ben cé bon j'ai trouver , je n'ai eu qua faire clic droit sur la barre et ajouter "fenetre machin chose ^^"
Message édité par sebfun le 10-11-2005 à 16:49:56
encore un topic sur les températures[RESOLU] mount_data version 1919251317 is not supported
linux version disquetteLa version 10 de la mandrake dispo en magazine?
Topic Modifier les partitions sous Linux ("Partition Magic")Reiser 4 -- Version finale out - Faq : " Montre moi tes FS"
[Topic Unique] ROX-Filer[hébergement] serveur dédié
[Topic unique] Rox (-Filer) + X Files Explorer[Linux] Je recherche la version de Woody sur DVD
Plus de sujets relatifs à : [UBUNTU] 26.10 'Stonking Stingray' - Topic dédié
