9049 connectés
  Linux et OS Alternatifs
  Installation
  Serveur X RedHat 5.2
n°1146402
Narkadaie
Posté le 03-07-2009 à 14:44:22  profilanswer
Un petit problème sur un serveur lame que j'ai voulu démarrer en init5.
Il a planté et j'ai redémarré en init3 et fais un startx : voila le résultat :
[root@epsilon etc]# startx
xauth:  creating new authority file /root/.serverauth.13120
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: Linux 2.6.9-67.0.7.ELsmp x86_64 Red Hat, Inc.
Current Operating System: Linux epsilon 2.6.18-92.el5 #1 SMP Tue Apr 29 13:16:15 EDT 2008 x86_64
Build Date: 02 April 2008
Build ID: xorg-x11-server 1.1.1-48.41.el5
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul  3 14:41:27 2009
(EE) Unable to locate/open config file
New driver is "ati"
(==) Using default built-in configuration (55 lines)
(EE) open /dev/fb0: No such file or directory
(**) RADEON(0): RADEONPreInit
(**) RADEON(0): RADEONScreenInit d8000000 0
(**) RADEON(0): Map: 0xd8000000, 0x01000000
(**) RADEON(0): RADEONSave
(**) RADEON(0): RADEONSaveMode(0x6429880)
(**) RADEON(0): Read: 0x0000000c 0x00030065 0x00000000
(**) RADEON(0): Read: rd=12, fd=101, pd=3
(**) RADEON(0): RADEONSaveMode returns 0x6429880
(**) RADEON(0): RADEONInitMemoryMap() :
(**) RADEON(0):   mem_size         : 0x04000000
(**) RADEON(0):   MC_FB_LOCATION   : 0xdbffd800
(**) RADEON(0):   MC_AGP_LOCATION  : 0xffffffc0
(**) RADEON(0): RADEONModeInit()
1600x1200     202.50  1600 1664 1856 2160  1200 1201 1204 1250 (24,32) +H +V
(**) RADEON(0): Pitch = 13107400 bytes (virtualX = 1600, displayWidth = 1600)
(**) RADEON(0): dc=20250, of=20250, fd=90, pd=1
(**) RADEON(0): RADEONInit returns 0x642a230
(**) RADEON(0): RADEONRestoreMode()
(**) RADEON(0): RADEONRestoreMemMapRegisters() :
(**) RADEON(0):   Map Changed ! Applying ...
(**) RADEON(0):   Map applied, resetting engine ...
(**) RADEON(0): Updating display base addresses...
(**) RADEON(0): Memory map updated.
(**) RADEON(0): Programming CRTC1, offset: 0x00000000
(**) RADEON(0): Wrote: 0x0000000c 0x0000005a 0x00000000 (0x0000a500)
(**) RADEON(0): Wrote: rd=12, fd=90, pd=0
(**) RADEON(0): GRPH_BUFFER_CNTL from 20005c5c to 20185c5c
(**) RADEON(0): RADEONSaveScreen(0)
(**) RADEON(0): Setting up initial surfaces
(**) RADEON(0): Initializing fb layer
(**) RADEON(0): Setting up accel memmap
(**) RADEON(0): Initializing backing store
(**) RADEON(0): Setting up final surfaces
(**) RADEON(0): Initializing Acceleration
(**) RADEON(0): EngineInit (32/32)
(**) RADEON(0): Pitch for acceleration = 200
(**) RADEON(0): EngineRestore (32/32)
(**) RADEON(0): Initializing DPMS
(**) RADEON(0): Initializing Cursor
(**) RADEON(0): Initializing color map
(**) RADEON(0): Initializing DGA
(**) RADEON(0): Initializing Xv
(**) RADEON(0): RADEONScreenInit finished
Backtrace:
0: X(xf86SigHandler+0x71) [0x4a0b51]
1: /lib64/libc.so.6 [0x336c0301b0]
Fatal server error:
Caught signal 11.  Server aborting
(**) RADEON(0): RADEONLeaveVT
(**) RADEON(0):   MC_FB_LOCATION   : 0xffff0000
(**) RADEON(0):   MC_AGP_LOCATION  : 0x003fffc0
(**) RADEON(0): Wrote: 0x0000000c 0x00030065 0x00000000 (0x0000a500)
(**) RADEON(0): Wrote: rd=12, fd=101, pd=3
(**) RADEON(0): Ok, leaving now...
XIO:  fatal IO error 104 (Connection reset by peer) on X server ":0.0"
      after 0 requests (0 known processed) with 0 events remaining.
Une aide serait la bienvenue.
n°1146408
Narkadaie
Posté le 03-07-2009 à 15:14:21  profilanswer
En complément :
[root@epsilon X11R6]# X -configure
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul  3 15:12:52 2009
List of video drivers:
        radeon
        nv
        tdfx
        siliconmotion
        cirrus
        sis
        s3
        ati
        ati_tp
        trident
        radeon_tp
        ast
        sisusb
        via
        savage
        intel
        voodoo
        dummy
        s3virge
        i810
        vmware
        atimisc
        mga
        r128
        fbdev
        vesa
        vga
(++) Using config file: "/root/xorg.conf.new"
Xorg detected your mouse at device /dev/input/mice.
Please check your config if the mouse is still not
operational, as by default Xorg tries to autodetect
the protocol.
Your xorg.conf file is /root/xorg.conf.new
To test the server, run 'X -config /root/xorg.conf.new'
n°1146409
Narkadaie
Posté le 03-07-2009 à 15:15:13  profilanswer
Et le test :
[root@epsilon X11R6]# X -config /root/xorg.conf.new
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul  3 15:14:36 2009
(**) RADEON(0): RADEONSaveMode(0x9fdc140)
(**) RADEON(0): RADEONSaveMode returns 0x9fdc140
(**) RADEON(0): RADEONInit returns 0x9fdcaf0
Fri Jul  3 15:14:38 2009
 vncext:      VNC extension running!
 vncext:      Listening for VNC connections on port 5900
 vncext:      created VNC server for screen 0
Backtrace:
Fatal server error:
Aborted
  Installation
Installation de 2 postes serveur (1 de secour) comment faireProblème de droits avec le serveur apache
Mib HP pour serveur proliantRedirections sur IP locale à partir de nom de serveur internet
MAC OS Xchoix distribution pour transformation de mon eeebox en serveur perso
Aix et Serveur d'impression Linux[ Fedora 6 ] Pb serveur VNC
FOG : solution de ghosting libre client/serveur[Echec - investigation] Apache : lecture d'une page web en interne
Plus de sujets relatifs à : Serveur X RedHat 5.2
