3781 connectés
 Page :   1  2
Page Suivante
Sensors lm_sensors ca fonctionne pas :??:
n°310710
Tomate
Posté le 21-08-2003 à 00:25:30  profilanswer
desch3 a écrit :
J'ai tout reinstallé :D
la j'ai un bo no sensors found. J'ai deja vu des posts parlant de ca, je recherche
ca c kan tu lances sensors ;)
et sensors-detect ?
:: Light is Right ::
n°310716
desch3
Posté le 21-08-2003 à 00:29:31  profilanswer
Code :
  1. Some chips are also accessible through the ISA bus. ISA probes are
  2. typically a bit more dangerous, as we have to write to I/O ports to do
  3. this.  Do you want to scan the ISA bus? (YES/no):
  4. Probing for `National Semiconductor LM78'
  5. Character in "C" format wrapped at /usr/sbin/sensors-detect line 1068.
  6.   Trying address 0x0290... Failed!
  7. Probing for `National Semiconductor LM78-J'
  8. Character in "C" format wrapped at /usr/sbin/sensors-detect line 1068.
  9.   Trying address 0x0290... Failed!
  10. Probing for `National Semiconductor LM79'
  11. Character in "C" format wrapped at /usr/sbin/sensors-detect line 1068.
  12.   Trying address 0x0290... Failed!
  13. Probing for `Winbond W83781D'
  14. Character in "C" format wrapped at /usr/sbin/sensors-detect line 1068.
  15.   Trying address 0x0290... Failed!
  16. Probing for `Winbond W83782D'
  17. Character in "C" format wrapped at /usr/sbin/sensors-detect line 1068.
  18.   Trying address 0x0290... Failed!
  19. Probing for `Winbond W83627HF'
  20. Character in "C" format wrapped at /usr/sbin/sensors-detect line 1068.
  21.   Trying address 0x0290... Failed!
  22. Probing for `Winbond W83697HF'
  23. Character in "C" format wrapped at /usr/sbin/sensors-detect line 1068.
  24.   Trying address 0x0290... Failed!
  25. Probing for `Silicon Integrated Systems SIS5595'
  26.   Trying general detect... Failed!
  27. Probing for `VIA Technologies VT82C686 Integrated Sensors'
  28.   Trying general detect... Failed!
  29. Probing for `VIA Technologies VT8231 Integrated Sensors'
  30.   Trying general detect... Failed!
  31. Probing for `ITE IT8705F / IT8712F / SiS 950'
  32. Character in "C" format wrapped at /usr/sbin/sensors-detect line 1068.
  33.   Trying address 0x0290... Failed!
  34. Probing for `IPMI BMC KCS'
  35.   Trying address 0x0ca0... Failed!
  36. Probing for `IPMI BMC SMIC'
  37.   Trying address 0x0ca8... Failed!
  38. Now follows a summary of the probes I have just done.
  39. Just press ENTER to continue:
  40. I will now generate the commands needed to load the I2C modules.
  41. Sometimes, a chip is available both through the ISA bus and an I2C bus.
  42. ISA bus access is faster, but you need to load an additional driver module
  43. for it. If you have the choice, do you want to use the ISA bus or the
  44. I2C/SMBus (ISA/smbus)?
  45. WARNING! If you have some things built into your kernel, the
  46. below list will contain too many modules. Skip the appropriate ones!
  47. To load everything that is needed, add this to some /etc/rc* file:
  48. #----cut here----
  49. # I2C adapter drivers
  50. # I2C chip drivers
  51. #----cut here----
  52. To make the sensors modules behave correctly, add these lines to either
  53. /etc/modules.conf or /etc/conf.modules:
  54. #----cut here----
  55. # I2C module options
  56. alias char-major-89 i2c-dev
  57. #----cut here----
  58. Do you want to generate /etc/sysconfig/lm_sensors? (YES/no):
  59. Copy prog/init/lm_sensors.init to /etc/rc.d/init.d/lm_sensors
  60. for initialization at boot time.
Mais je retrouve pas le .init a la fin pour le copier :(
n°310719
Tomate
Posté le 21-08-2003 à 00:32:35  profilanswer
desch3 a écrit :
Code :
kel .init ?? [:mlc]
le pb vient de la :
#----cut here----
# I2C chip drivers
#----cut here----
#----cut here----
#----cut here----
il n y a aucun module a charger :/
Message édité par Tomate le 21-08-2003 à 00:33:51
n°310722
desch3
Posté le 21-08-2003 à 00:34:25  profilanswer
Bah ouais, ca me fait un peu peur. Via urpmi ya que la version 2.6.3 de dispo ya pas la 2.7.0 ou 2.8.0 :( donc ca doit pas marcher avec ma carte mere. Pourtant ya un post a ce sujet sur le forum et le mec ca a marché
n°310725
Tomate
Posté le 21-08-2003 à 00:35:28  profilanswer
essai en prenant les src du 2.8 et en les compilant (sans installer :D)
on sait jamais [:spamafote]
n°310874
desch3
Posté le 21-08-2003 à 09:49:41  profilanswer
Bon apres une bonne nuit de sommeil, je viens de lire ca :
Code :
  1. This is just a quick and dirty hack to get the hardware monitoring working
  2. on the ASUS P4B board under Linux.
  3. It works by turning on the SMBus PCI device.
  4. It is implemented as a module, p4b_smbus.o.
  5. It only works with the ICH2 (82801BA) and ICH4 (82801DB).
  6. ASUS switches off the SMBus PCI Device
  7. in the i801 ICH2/4 chip. I spoke two times
  8. with the German support and learned that: "We do not want the users to be
  9. irritated by just another PCI Device in the Win98 device manager."
  10. Really funny :-).
Ce qui pourrais expliquer mes pb. Il y a également la soluce en dessous. Je testerai ca ce soir en esperant que ca vienne de ca.
En tout cas merci de ton soutien.
n°310906
farib
Posté le 21-08-2003 à 11:15:11  profilanswer
j'en profite pour poser la question : y'a-t'il des gens qui ont des deklet qui affichent les sensors des cartes graphiques ?
n°310947
Dark_Schne​ider
Close the World, Open the Net
Posté le 21-08-2003 à 12:26:16  profilanswer
juste une remarque pkoi personne ne lui a demandé :
1°/ le contenu de son /etc/modules.conf, vue k'il doit y copier des lignes dedans pour charger les modules k'il faut
2°/ si il avait copié les lignes des insmod dans par exemple /etc/rc.local ?
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°310968
Tomate
Posté le 21-08-2003 à 13:08:41  profilanswer
parce ke sensors-detect ne nous a donne aucun module a charger ;)
n°310981
desch3
Posté le 21-08-2003 à 13:30:03  profilanswer
Dans modules.conf, j'ai mis l'alias de sensors detect. C tou ce que j'ai touché.
n°310982
Tomate
Posté le 21-08-2003 à 13:31:15  profilanswer
oue mais sans modprobe (enfin plutot nom de module a charger) ca changera rien :/
n°311066
desch3
Posté le 21-08-2003 à 15:30:09  profilanswer
bah ouais, je sais bien. Je vais retenter ce soir avec l'astuce pour les p4b, on verra bien. j'aimerais bien que ca fonctionne. Je commence a aprécier la mandrake (surtout qd je vois les nouvelles failles dans windows et les patchs a appliquer).
n°415410
mkiman
Posté le 22-02-2004 à 18:05:55  profilanswer
J'ai une debian sid avec noyau 2.6.3.
J'ai une mobo asus a7n8x Deluxe-E (nforce2), et je voulais avoir mes temperatures, ainsi que la vitesse de mes ventilo.
Je pensais que la config du noyau suffisait pour pouvoir activer les sondes, j'ai fait comme ci dessous :
 devices drivers / character devices / i2c support)
i2c support en dur
i2c device interface en dur
les 2 i2c Algorithms en dur
i2c hardware Bus support -> ISA bus support en dur
I2C Hardware Sensors Chip support -> Winbond W83781D, W83782D, W83783S, W83627HF
, Asus AS99127F en dur
Plus le support en dure du i2c nforce2.
J'ai bien compilé mais ça marchait pas  :fou:
J'ai regardé un peu les topic de HFR, et :
BLACK:~# sensors-detect
This program will help you determine which I2C/SMBus modules you need to
load to use lm_sensors most effectively. You need to have i2c and
lm_sensors installed before running this program.
Also, you need to be `root', or at least have access to the /dev/i2c-*
files, for most things.
If you have patched your kernel and have some drivers built-in, you can
safely answer NO if asked to load some modules. In this case, things may
seem a bit confusing, but they will still work.
 BIOS vendor (ACPI): Nvidia
 System vendor (DMI): ASUSTeK Computer INC.
 BIOS version (DMI): ASUS A7N8X-E Deluxe ACPI BIOS Rev 1008
 We can start with probing for (PCI) I2C or SMBus adapters.
 You do not need any special privileges for this.
 Do you want to probe now? (YES/no): yes
Probing for PCI bus adapters...
Use driver `i2c-nforce2' for device 00:01.1: nVidia Corporation nForce2 SMBus (MCP)
Probe succesfully concluded.
 We will now try to load each adapter module in turn.
Load `i2c-nforce2' (say NO if built into your kernel)? (YES/no): no
 Do you now want to be prompted for non-detectable adapters? (yes/NO): no
 To continue, we need module `i2c-dev' to be loaded.
 If it is built-in into your kernel, you can safely skip this.
 i2c-dev is not loaded. Do you want to load it now? (YES/no): no
 Well, you will know best. We will just hope you edited `/etc/modules.conf'
 for automatic loading of this module. If not,
 you won't be able to open any /dev/i2c-* file (unless youhave it built-in
 into your kernel)
 We are now going to do the adapter probings. Some adapters may hang halfway
 through; we can't really help that. Also, some chips will be double detected;
 we choose the one with the highest confidence value in that case.
 If you found that the adapter hung after probing a certain address, you can
 specify that address to remain unprobed. That often
 includes address 0x69 (clock chip).
Couldn't open /proc/bus/i2c?!? at /usr/sbin/sensors-detect line 3970, <STDIN> line 4.
Quelqu'un a t il deja configurer ces sondes avec un noyau 2.6.3 ?  :sweat:  :sweat:  :cry:  :cry:
n°473909
dastormtro​oper
Posté le 07-05-2004 à 23:49:23  profilanswer
Bin moa je viens de l'installer sur une asus A7N8X e Deluxe, sous Mandrake 10 Official....via urpmi
J'ai réussi à lancer gkrellm, qui m'affiche pas mal d'infos, mais pas ce qui m'intérresse : Les températures et la vitesse des ventilos.
Voici les modules chargés en rapport avec LM_sensors.
[root@kaneda kerozen]# lsmod | grep i2c*
i2c-algo-bit            9512  0
i2c-algo-pcf            6724  0
i2c-nforce2             6016  0
i2c-dev                10080  0
i2c-core               23044  4 i2c-algo-bit,i2c-algo-pcf,i2c-nforce2,i2c-dev
Il me manque quelque chose ?
P.S (je n'ai pas encore changé le modules.conf ni rebooté !)
n°473954
dastormtro​oper
Posté le 08-05-2004 à 02:04:25  profilanswer
bon, en fait j'ai modprobé (??) les modules qui manquaient (eeprom et asb100) et j'ai eu des résultat !
Par contre, il semble falloir iunverser les valeurs données pour la carte mère et le proco. 45°C pour la CM, ca fait beaucoup, alors que 25°C pour le proc, ca fait peu quand même !
n°490436
Zboss
Si tu doutes, reboot...
Posté le 30-05-2004 à 00:26:26  profilanswer
J'ai moi aussi des ennuis ave Ksensors :
Quand je fais "sensors-detect", à la fin j'obtiens ça :
Driver `via686a' (should be inserted):
  Detects correctly:
  * ISA bus, undetermined address (Busdriver `i2c-isa')
    Chip `VIA Technologies VT82C686 Integrated Sensors' (confidence: 9)
 I2C/SMBus (ISA/smbus)? ISA
/etc/modules.conf:
#----cut here----
#----cut here----
#----cut here----
modprobe i2c-viapro
modprobe i2c-isa
# I2C chip drivers
modprobe eeprom
modprobe via686a
# sleep 2 # optional
/usr/local/bin/sensors -s # recommended
#----cut here----
WARNING! If you have some things built into your kernel, the list above
will contain too many modules. Skip the appropriate ones! You really should
try these commands right now to make sure everything is working properly.
Monitoring programs won't work until it's done.
Do you want to generate /etc/sysconfig/lm_sensors? (YES/no): YES
J'ai donc copié :
 "# I2C module options
alias char-major-89 i2c-dev"
dans le fichier /etc/modules.conf,
 puis j'ai copié :
"# I2C adapter drivers
modprobe i2c-viapro
modprobe i2c-isa
# I2C chip drivers
modprobe eeprom
modprobe via686a
/usr/local/bin/sensors -s # recommended"
dans les fichiers rc , rc.local et rc.sysinit.
Jusque là c'est bon ?  :??:
Mais quand je fais "sensors" il me dit "no sensors!".  :cry:
Edit : tiens y'a de l'amélioration, maintenant qd je fais "sensors" j'obtiens :
sensors
eeprom-i2c-0-57
Adapter: SMBus Via Pro adapter at 5000
Memory type:            SDR SDRAM DIMM
Memory size (MB):       128
eeprom-i2c-0-56
eeprom-i2c-0-55
eeprom-i2c-0-54
eeprom-i2c-0-53
eeprom-i2c-0-52
eeprom-i2c-0-51
eeprom-i2c-0-50
Memory size (MB):       invalid (12 8 0 4)
Mais ça m'aide pas bcp....
Message édité par Zboss le 30-05-2004 à 19:12:06
Mario Kart for Ever
n°490765
Zboss
Posté le 30-05-2004 à 19:12:39  profilanswer
J'ai retenté un détection des sensors, et maintenant j'ai ça :
via686a-isa-6000
Adapter: ISA adapter
ERROR: Can't get IN0 data!
ERROR: Can't get IN1 data!
ERROR: Can't get IN2 data!
ERROR: Can't get IN3 data!
ERROR: Can't get IN4 data!
ERROR: Can't get FAN1 data!
ERROR: Can't get FAN2 data!
ERROR: Can't get TEMP data!
ERROR: Can't get TEMP2 data!
ERROR: Can't get TEMP3 data!
:cry:
Mario Kart for Ever
n°490780
void_ppc
Posté le 30-05-2004 à 19:36:26  profilanswer
Desch3 a écrit :
Salut a tous, après de nombreuses recherche et lecture de site pour installer lm_sensors, je m'en sors pas, ca fait 3 jours que je tente, mais tjs rien.
Le tout sur une mandrake 9.1 avec une carte mère Asus p4b533-e (assez ancienne, ca dfevrait fonctionner)
Y aurait-il une ame charitable pour m'expliquer la demarche pas à pas sur msn ?
mon pseudo : ddesch@wanadoo.fr
David
 [:overflow]
n°491696
Zboss
Posté le 31-05-2004 à 23:03:05  profilanswer
via686a-isa-6000
:cry:
Personne ne peut m'aider ?
Mario Kart for Ever
 Page :   1  2
Page Suivante
[debian] GnomeMeeting ne fonctionne qu'en root[DEBIAN] le site packages.debian fonctionne chez vous ?
[gkrellm & lm_sensors] J'arrive pas à configurer le bouzin :(récupérer les infos de lm_sensors
morphix game 0.4 fonctionne t il avec une Radeon 8500 ?Installation de Mandrake 9.1 ne fonctionne pas.... HELP
Option bpp de rdesktop pour les couleurs qui ne fonctionne pas.complier lm_sensors sous Mandrake 9.1 [résolu]
j'ai effacé linux comme un bourrin et y'a plus rien qui fonctionneQuestion sur les sensors
Plus de sujets relatifs à : Sensors lm_sensors ca fonctionne pas :??:
