5794 connectés
  Linux et OS Alternatifs
  Installation
  Problème de connexion après migration
n°1391041
nomiss
La rootine
Posté le 02-06-2016 à 11:17:27  profilanswer
salut
J'ai fait un test de migration de 12.04 vers 14.04 avant de le faire sur une machine en production. Après la migration, je me retrouve devant un écran de login qui boucle lorsque j'essaye de me connecter. Voilà ce que me dit le auth.log :
Code :
  1. Jun  2 11:14:20 rennvlxrdl4185c lightdm: pam_succeed_if(lightdm:auth): requirement "user ingroup nopasswdlogin" not met by user "userlnx"
  2. Jun  2 11:14:23 rdl4185c lightdm: pam_kwallet(lightdm:auth): pam_sm_authenticate
  3. Jun  2 11:14:24 rdl4185c lightdm: pam_unix(lightdm-greeter:session): session closed for user lightdm
  4. Jun  2 11:14:24 rdl4185c lightdm: pam_kwallet(lightdm-greeter:session): pam_sm_close_session
  5. Jun  2 11:14:24 rdl4185c lightdm: pam_kwallet(lightdm-greeter:setcred): pam_sm_setsecred
  6. Jun  2 11:14:24 rdl4185c lightdm: pam_kwallet(lightdm:setcred): pam_sm_setsecred
  7. Jun  2 11:14:24 rdl4185c lightdm: pam_unix(lightdm:session): session opened for user userlnx by (uid=0)
  8. Jun  2 11:14:24 rdl4185c lightdm: pam_ck_connector(lightdm:session): nox11 mode, ignoring PAM_TTY :0
  9. Jun  2 11:14:24 rdl4185c lightdm: pam_kwallet(lightdm:session): pam_sm_open_session
  10. Jun  2 11:14:24 rdl4185c lightdm: pam_kwallet(lightdm:session): pam-kwallet: final socket path: /tmp//userlnx.socket
  11. Jun  2 11:14:24 rdl4185c dbus[402]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.206" (uid=107 pid=18654 comm="/usr/lib/x86_64-linux-gnu/indicator-bluetooth/indi" ) interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.1" (uid=0 pid=508 comm="/usr/sbin/bluetoothd " )
  12. Jun  2 11:14:24 rdl4185c dbus[402]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.206" (uid=107 pid=18654 comm="/usr/lib/x86_64-linux-gnu/indicator-bluetooth/indi" ) interface="org.bluez.Manager" member="DefaultAdapter" error name="(unset)" requested_reply="0" destination="org.bluez" (uid=0 pid=508 comm="/usr/sbin/bluetoothd " )
  13. Jun  2 11:14:24 rdl4185c gnome-keyring-daemon[18662]: Gkm: using old keyring directory: /local/home/userlnx/.gnome2/keyrings
  14. Jun  2 11:14:24 rdl4185c gnome-keyring-daemon[18662]: Gkm: using old keyring directory: /local/home/userlnx/.gnome2/keyrings
  15. Jun  2 11:14:24 rdl4185c gnome-keyring-daemon[18662]: couldn't set environment variable in session: The name org.gnome.SessionManager was not provided by any .service files
  16. Jun  2 11:14:25 rdl4185c lightdm: pam_unix(lightdm:session): session closed for user userlnx
  17. Jun  2 11:14:25 rdl4185c lightdm: pam_kwallet(lightdm:session): pam_sm_close_session
  18. Jun  2 11:14:25 rdl4185c lightdm: pam_kwallet(lightdm:setcred): pam_sm_setsecred
  19. Jun  2 11:14:26 rdl4185c lightdm: pam_kwallet(lightdm-greeter:setcred): pam_sm_setsecred
  20. Jun  2 11:14:26 rdl4185c lightdm: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
  21. Jun  2 11:14:26 rdl4185c lightdm: pam_ck_connector(lightdm-greeter:session): nox11 mode, ignoring PAM_TTY :0
  22. Jun  2 11:14:26 rdl4185c lightdm: pam_kwallet(lightdm-greeter:session): pam_sm_open_session
  23. Jun  2 11:14:26 rdl4185c lightdm: pam_kwallet(lightdm-greeter:session): pam_kwallet: open_session called without kwallet_key
  24. Jun  2 11:14:26 rdl4185c lightdm: pam_succeed_if(lightdm:auth): requirement "user ingroup nopasswdlogin" not met by user "userlnx"
Qu'est ce que je pourrai faire ?
J'ai essayé en reinstallant lightdm mais pas de succès...
  Installation
Problème installation Docker sur OMVProbleme utilisateur Samba sous Debian
Problème installation (boot via USB)Configurer connexion wifi ?
Problème de partition sur Asusu pour linuxproblème Apache sur serveur perso
Xbuntu : problème de mot de passe et de droitsProblème : netkit-ng sur Ubuntu 32 bits
[postfix]Problème Réception, Envois OKProblème d'incompatibilité
Plus de sujets relatifs à : Problème de connexion après migration
