3945 connectés
  Linux et OS Alternatifs
  Installation
  debian openmosix : impossible a enlever
n°343367
GUG
Posté le 23-10-2003 à 12:37:14  profilanswer
Sur ma debian(pc monopross, ce n'est pas un cluster) j ai voulu voi r l interface d'openmosixview ...
je l ai donc installer malheuresement maintenant apt n'arrive pas a le desinstaller et n arrive pas non plus a installer une version plus recente du package :((
j ai les "erreurs" suviantes qui ont l air "normale":
(Reading database ... 57510 files and directories currently installed.)
Preparing to replace openmosix 1:0.3.4-5 (using .../openmosix_1%3a0.3.4-7_i386.deb) ...
openMosix: ERROR: Cannot find the /proc/hpc directory.
openMosix: ERROR: Looks like this is not an openMosix enabled kernel.
openMosix: ERROR: Configuration ABORTED.
openMosix: HINT: need to recompile your kernel with openMosix support enabled?
openMosix: HINT: need to update your boot manager (lilo, grub, etc)?
openMosix: HINT: have you read the docs at http://openMosix.sf.net/ ?
invoke-rc.d: initscript openmosix, action "stop" failed.
dpkg: warning - old pre-removal script returned error exit status 1
dpkg - trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/openmosix_1%3a0.3.4-7_i386.deb (--unpack):
 subprocess new pre-removal script returned error exit status 1
invoke-rc.d: initscript openmosix, action "start" failed.
dpkg: error while cleaning up:
 subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
j ai essaye un
 apt-get upgrade
apt-get -f install
apt-get -f remove
dpkg -P "le package"
dpkg -i --force-all  openmosix_1%3a0.3.4-7_i386.deb
apt-get install --force-yes openmosix
Si vous avez des idee, merci d avance
n°343386
Aragorn_1e​r
Le jihad butlérian est proche
Posté le 23-10-2003 à 13:20:39  profilanswer
As tu essayer ca :
A+
n°343407
GUG
Posté le 23-10-2003 à 13:58:32  profilanswer
non mais vu que je n'ai pas de cluster ...
et peut etre y a til une solution moins "lourde" ?
n°343410
Aragorn_1e​r
Posté le 23-10-2003 à 14:01:56  profilanswer
Bah ... c'est une solution tu n'est pas obliger de reoobter ta machine quand tu compile un module ...
A+
n°343433
GUG
Posté le 23-10-2003 à 14:55:18  profilanswer
tu avais raison ... c'est bon maintenant
merci :)
  Installation
(debian) pb xfree & clavierImpossible d'accèder au mode graphique sous mandrake 9.1
[Debian] Package mega brokenDebian Sid gros problème avec apt
[Debian] - probleme avec traceroute[Debian] - petite question
[debian] toshiba 3000-514 : presque tout sur irq 10....[Debian Woody] comment virer X ?
GDM ne se lance plus suite à une upgrade de Debian SID[debian & vmware] Config carte réseau à l'installation
Plus de sujets relatifs à : debian openmosix : impossible a enlever
