9839 connectés
  Linux et OS Alternatifs
  Installation
  GDM ne se lance plus suite à une upgrade de Debian SID
n°341974
roupougnou​f
Posté le 20-10-2003 à 12:01:13  profilanswer
J'ai effectué une maj de Debian SID, mais suite à cela GDM ne se lance plus:
gdm: error while loading shared libraries: libbonobo-activation.so.4: cannot open shared object file: Nosuch file or directory
Pourtant cette librairie apparaissait bien avant la confirmation, je l'ai bien vue lors de son installation.
n°341984
eL_Shaman_​__
Plop.
Posté le 20-10-2003 à 12:15:20  profilanswer
T'as installé des paquets pour Gnome2.4 non officiels ?
n°342001
roupougnou​f
Posté le 20-10-2003 à 12:28:31  profilanswer
oui en effet
n°342341
udok
La racaille des barbus ©clémen
Posté le 20-10-2003 à 22:55:32  profilanswer
Hi,
Greg Folkert <greg@gregfolkert.net> writes:
> Now that I have done it (on Saturday afternoon) I did a "dselect update
> && apt-get -u dist-upgrade"
> Now, for the fun part:
> Whence restarting gdm I get:
> duke:~# /etc/init.d/gdm start
> Starting GNOME Display Manager: gdm/usr/bin/gdm: error while loading
> file: No such file or directory already running.
> Or when starting Evolution:
> duke:~# evolution
> evolution: error while loading shared libraries:
> libbonobo-activation.so.4: cannot open shared object file: No such file
> or directory
> But looking at dpkg -l I get:
> duke:~# COLUMNS=130 dpkg -l | grep bonobo-act
> ii  bonobo-activation         2.4.0-1  Transitional package
> ii  libbonobo-activation-dev  2.4.0-1  Transitional package
> ii  libbonobo-activation4     2.4.0-1  Transitional package
> The change log for libbonobo-activation4:
> bonobo-activation (1:2.4.0-1) unstable; urgency=low
>   * Merged with bonobo upstream, dummy transitionnal package.
>   * GNOME Team Upload.
>  -- Sebastien Bacher <seb128@debian.org>  Wed, 15 Oct 2003 17:44:38
> +0200
> duke:/usr/share/doc# apt-show-versions -a bonobo
> bonobo  1.0.22-2.2      install ok installed
> bonobo  1.0.20-1        stable
> bonobo  1.0.22-2.2      testing
> bonobo  1.0.22-2.2      unstable
> bonobo/testing uptodate 1.0.22-2.2
> This currently has nearly every single GNOME app disabled for me. I have
> tried adding in older stuff... but everything core dumps (yes I know it
> should), but it was worth it.
> If anyone could clue me in on the location of the package (or name) that
> is supposed to replace it please help me out.
libbonobo2-0, version 2.4.1-2 should do the trick.
Hope this helps,
Jaume
et faut peut-être d'abord virer à la main les paquets que tu as installé provenant de mirroirs non officiels
Non au projet de loi DADVSI ! (droits d'auteurs)
n°342476
roupougnou​f
Posté le 21-10-2003 à 11:00:36  profilanswer
J'ai effectivement supprimé l'entrée non-officielle
lance un apt-get remove lignome2-0
j'ai aussi viré gdm
Ensuite lancé un apt-get update
puis apt-get install gdm gnome
mais ça ne change rien j'ai toujours exactement le même message d'erreur.
Cette librairie pose des problemes et je ne la trouve pas elle n'a pas l'air de s'installer ou alors la version officieuse reste planquée, impossible de la trouver!
J'ai aussi tenté un startx mais gnome ne se lance pas
Message édité par roupougnouf le 21-10-2003 à 11:02:15
n°342540
udok
Posté le 21-10-2003 à 13:18:39  profilanswer
j'ai eu le même pb
j'ai fais
apt-get install libbonobo2-common/unstable
apt-get install libbonobo2-0/unstable
  Installation
[debian & vmware] Config carte réseau à l'installationPb d installation du Thomson Speedtouch 330 sous linux debian
[Debian Woody] TFT Hercules ProphetView non reconnu ... HELP[Mozilla UPGRADE] des questions...
[Debian] resolution Xfree bloquée en 800*600 je vais peter un cable !Debian en Sid : badaboum
Probleme d'affichage sur portable GeForce FX 4200 Debiangtk2, debian sid : probleme de font
sid, mozilla-1.4 ne se lance pas
Plus de sujets relatifs à : GDM ne se lance plus suite à une upgrade de Debian SID
