7842 connectés
 Page :   1  2
Page Suivante
[Nvidia] nouveaux pilotes 4496
n°300399
Rasthor
Posté le 02-08-2003 à 01:34:20  profilanswer
Et hop, ça veut pas s'installer.
Je quitte le serveur X en faisant CTRL-ALT-F2, suivi de su root et init 3, je me place dans le répertoire du driver et je fais sh NVIDIA-Linux-x86-1.0-4496-pkg2.run
Et là j'ai un beau message qui s'affiche:
ERROR: An NVIDIA kernel module 'nvidia' appears to already be loaded in your kernel.  This may be because it is in use (for example, by the X server).  Please be sure you have exited X before attempting to upgrade your driver.  If you have exited X but still receive this message, then an error has occured that has confused the usage count of the kernel module; the simplest remedy is to reboot your computer.
Suivi de celui-ci:
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may findsuggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Voici le fichier /var/log/nvidia-installer.log :
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sat Aug  2 01:34:32 2003
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall               : false
  driver info             : false
  no precompiled interface: false
  no ncurses color        : false
  query latest driver ver : false
  OpenGL header files     : false
  no questions            : false
  silent                  : false
  XFree86 install prefix  : /usr/X11R6
  OpenGL install prefix   : /usr
  Installer install prefix: /usr
  kernel include path     : (not specified)
  kernel install path     : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp site                : ftp://download.nvidia.com
Using: nvidia-installer ncurses user interface
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
J'ai beau rebooter, rien n'y fait.
Que dois-je faire ou vérifier ?
n°300403
rem5
Posté le 02-08-2003 à 01:48:58  profilanswer
c pas normal tt ca, apres un init 3 ca devrait être impec
il te reste plus qu'a vérifier a la main que le module nvidia est bien déchargé et sinon le décharger :
pour voir ce qui est chargé : lsmod
pour enlever le module : rmmod "nom module"
n°300441
Rasthor
Posté le 02-08-2003 à 09:42:39  profilanswer
Merci de ta réponse.
C'était bien ça le probleme, en quittant X, le module nvidia restait activé. Donc rmmod nvidia et hop, je n'ai plus eu qu'à installer le nouveau.    :jap:
n°306539
Rasthor
Posté le 13-08-2003 à 21:37:27  profilanswer
On n'en parle pas beaucoup de ces drivers ?
Quoi de neuf ? Des bugs ?
Ou bien rien de spécial a dire, si ce n'est qu'ils font leur boulots ?
n°306560
eL_Shaman_​__
Plop.
Posté le 13-08-2003 à 22:05:16  profilanswer
Chez moi, rien à redire...  :bounce:
n°306570
lebibi
Notre torture c'est la tourtel
Posté le 13-08-2003 à 22:44:49  profilanswer
marche nickel chez moi
n°306574
farib
Posté le 13-08-2003 à 22:52:59  profilanswer
y'en a qui ont pas quand même de temps à autre un freeze complet de la machine sous X ?
ils me le fony, les nvida :-(, c'est aléatoire mais ça arrive.
le rézal répond plus, et je suis pas sur que les magic sys req keys marchent toujours avec mes freeze
Bitcoin, Magical Thinking, and Political Ideology
n°306903
Rasthor
Posté le 14-08-2003 à 17:09:58  profilanswer
Oui, c'est vrai, j'ai aussi des freezes de temps en temps => reboot en hard. (clavier bloqué)
Qui a dit que Linux était stable ? :fou:
n°306911
eL_Shaman_​__
Plop.
Posté le 14-08-2003 à 17:39:47  profilanswer
Tu plantes dans quelles conditions ?
n°306914
farib
Posté le 14-08-2003 à 17:46:49  profilanswer
totalement imprévisible.
ca peut attendre quelques jours ou quelques dizaines de minutes
n°306923
eL_Shaman_​__
Plop.
Posté le 14-08-2003 à 18:01:03  profilanswer
Ouais, bizarre  :/
J'utilise les drivers nViDIA venant des paquets Debian et j'ai un noyau 2.4.20, dernier paquet Debian pour SID. XFree4.2.1 Debian.
(je suis sur une debian SID)
n°306936
Kristoph
Posté le 14-08-2003 à 18:17:22  profilanswer
Soyez bien sur d'avoir un noyau au moins 2.4.20, surtout si vous avez un proc Athlon.
n°306948
Rasthor
Posté le 14-08-2003 à 18:52:39  profilanswer
Pour ma part:
CPU Athlon XP1700+
GeForce 4 4200Ti
Driver NVidia 4496
Linux 2.4.21-0.25mdkcustom
Message édité par Rasthor le 14-08-2003 à 18:53:01
n°306993
udok
La racaille des barbus ©clémen
Posté le 14-08-2003 à 20:43:33  profilanswer
moi je touche du bois => aucun prob avec des 2.6 pourtant :)
Non au projet de loi DADVSI ! (droits d'auteurs)
n°307071
Puissance ​Athlon XP
Posté le 14-08-2003 à 23:09:26  profilanswer
J'ai lu que pour que linux charge lé nouveau driver il fo édité un fichier. Lekel ? Kesk'il fo modifier exactement ?
Merci  :jap:
n°307082
Rasthor
Posté le 14-08-2003 à 23:45:31  profilanswer
Merci  :jap:
Tout est très bien expliqué dans la doc du driver  ;)
n°307083
eL_Shaman_​__
Plop.
Posté le 14-08-2003 à 23:53:44  profilanswer
Merci  :jap:
il fo ke tu lises la dok ke le jenti messieu nvidia fourni.
n°307097
Posté le 15-08-2003 à 00:35:54  profilanswer
Ben g lu mais je pige pa  :heink: (jsui un gro noob g mi linux hier  :whistle: )
n°307100
dark
Posté le 15-08-2003 à 00:46:32  profilanswer
il faut que tu édite ton x86config-4 (plus très sur de l'ortographe  :/) et roulaize!!
C'est à dire qu'à l'endroit qui cause de ta cg il faut que tu mette a la place de "nv" -> "nvidia" et ça roulaize ;)
Sinon je viens de les installer et c'est titop sur un 2.1.212.4.21 :jap:
Message édité par dark le 15-08-2003 à 01:00:39
n°307114
dark
Posté le 15-08-2003 à 00:59:59  profilanswer
ahhyayannnn  [:dark]
J'm a plantai [:al zheimer]
C'est bien 2.4.21
n°307120
Rasthor
Posté le 15-08-2003 à 01:05:45  profilanswer
Tenez nous au courant si vous attrapper des freeze de temps en temps.
Chez moi ça m'arrive si je laisse l'ordi seul pendant un moment et que je reviens plsu tard.
Comme si il boudait que je l'ai laissé en plan...  :D
n°307123
udok
Posté le 15-08-2003 à 01:08:32  profilanswer
ah bah c'est pour ça que j'ai pas de plantage alors ! [:joce] :sweat:  :( [:sisicaivrai]
n°307168
dark
Posté le 15-08-2003 à 05:07:18  profilanswer
bah ça fait 5 heure que ça n'a pas planté, pas de freeze ect...
Par contre j'ai pas de jeux sous nux pour essayer :cry: j'ai que QuakeIII pour win$ :sweat:
n°307248
lebibi
Posté le 15-08-2003 à 12:55:46  profilanswer
Debian unstable
kernel 2.4.21
XFree 4.3.0
Gerforce 2 DDR
les derniers drivers Nvidia et aucun problême noté.
Bon de temps en temps (1 fois par semaine peut être) crash de X et je dois refaire un startx.
Je joue réguliérement à :
Enemy Territory et Quake3 --> 0 plantage
Utilisation de Firebird (peut etre lui qui fait planter X de temps en temps avec 10-12 tabs)
Bref j'ai même remarqué que j'avais plus de ftps sous Quake qu'avant.
Moi j'en suis trés trés satisfait !
n°307254
Kristoph
Posté le 15-08-2003 à 13:07:21  profilanswer
Bah alors utilise ça : http://zerowing.idsoftware.com/linux/q3a/
Hop, Quake 3 pour Linux !
n°307284
Posté le 15-08-2003 à 14:24:54  profilanswer
G enfin compri !!!  :whistle:
Sa marche du tonnere maintenan...  :love:
Message édité par Puissance Athlon XP le 15-08-2003 à 14:25:05
n°308278
[Albator]
MDK un jour, MDK toujours !
Posté le 17-08-2003 à 14:18:51  profilanswer
Moi c'est bizarre, parfois le PC gèle alors qu'il ne fait rien (genre il est en veille avec le screensaver !) alors que je peux jouer à Q3 pdt des heures sans ennui ...
Je ne sais pas qui accuser ... (matériel ou driver ?)
Message édité par [Albator] le 17-08-2003 à 14:19:05
n°308294
farib
Posté le 17-08-2003 à 14:44:11  profilanswer
Lebibi a écrit :
Debian unstable
kernel 2.4.21
XFree 4.3.0
Gerforce 2 DDR
mozilla/firebird et les plantages, ce serait pas impossible du tout...
n°308301
parano
Time... to die...
Posté le 17-08-2003 à 14:54:57  profilanswer
kernel 2.6.xx
Debian testing
geforce2
Aucun probleme pour le moment
(1 plantage de X une fois, mais bon g plein de soft qui sont en beta, comme firebird ou XFCE, donc ca peut venir d'autre chose...)
n°308303
dark
Posté le 17-08-2003 à 14:59:40  profilanswer
bon bah j'ai fini q3 vite fait et ça a pas planté :sol:
n°308317
farib
Posté le 17-08-2003 à 15:30:59  profilanswer
yop, yop, un re-plantage
g t en train de mater un flim, sortie tv.
Freeze, et les magic sys req keys servent à rien evidemment
n°308327
dark
Posté le 17-08-2003 à 15:47:57  profilanswer
moi je sais pas comment on utilise la sortie tv donc je peux pas te dire si ça me fait pareil [:wam]
 Page :   1  2
Page Suivante
[VIA S3 ProSavage DDR] pilotes en préparation[NVIDIA] Nouveau drivers, Nouveau Problems
Drivers libres NVIDIA ???NVidia + FrameBuffer = Problème ...
Où trouver des drivers nVidia ? (Site nVidia HS)probleme fichier XF86Config-4 apres install pilotes nvidia[newb]
NVIDIA : Optimiser le twin View sous linuxNVidia et Frame Buffer
Nouveaux drivers ATI 2.9.13
Plus de sujets relatifs à : [Nvidia] nouveaux pilotes 4496
