6071 connectés
  Linux et OS Alternatifs
  Installation
  [NVIDIA] merdouille j'y arrive pas.
n°236358
kaiska
Posté le 13-03-2003 à 20:12:31  profilanswer
j'essaye d'installer les drivers nvidia sur ma mandrake 9.0 mais ça chioum. Je fait ça à partir des src.rpm
Voilà le résultat :
[root@tiberian kaiska]# rpm --build NVIDIA_kernel-1.0-4191.src.rpm
--build: unknown option
[root@tiberian kaiska]# rpm --rebuild NVIDIA_kernel-1.0-4191.src.rpm
Installing NVIDIA_kernel-1.0-4191.src.rpm
Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.19944
+ umask 022
+ cd /usr/src/RPM/BUILD
+ rm -rf NVIDIA_kernel-1.0-4191
+ /bin/gzip -dc /usr/src/RPM/SOURCES/NVIDIA_kernel-1.0-4191.tar.gz
+ tar -xf -
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd NVIDIA_kernel-1.0-4191
+ exit 0
Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.19944
+ umask 022
+ set +e
++ rpm -q --queryformat '%{VERSION}' rpm
+ RPMVERSION=4.0.4
++ echo 4.0.4
++ awk -F . '{print $1;}'
+ RPMMAJOR=4
++ echo 4.0.4
++ awk -F . '{print $2;}'
+ RPMMINOR=0
++ echo 4.0.4
++ awk -F . '{print $3;}'
+ RPMPATCH=4
+ '[' 4 -le 3 -a 0 -le 0 -a 4 -lt 4 ']'
+ make nvidia.o
echo \#define NV_COMPILER \"`cc -v 2>&1 | tail -1`\" > nv_compiler.h
cc -c -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparen
theses -Wpointer-arith -Wcast-qual -Wno-multichar  -O -MD -D__KERNEL__ -DMODULE
-D_LOOSE_KERNEL_NAMES -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -D
MODULE  -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=4191  -DNV_UNI
X   -DNV_LINUX   -DNV_INT64_OK   -DNVCPU_X86       -I. -I/usr/src/linux/include
-Wno-cast-qual nv.c
-Wno-cast-qual os-agp.c
-Wno-cast-qual os-interface.c
-Wno-cast-qual os-registry.c
ld -r -o nv-linux.o nv.o os-agp.o os-interface.o os-registry.o
ld -r -o nvidia.o nv-linux.o nv-kernel.o
size nvidia.o
   text    data     bss     dec     hex filename
1248673   92760   32940 1374373  14f8a5 nvidia.o
+ exit 0
Executing(%install): /bin/sh -e /var/tmp/rpm-tmp.11493
+ umask 022
+ rm -f /tmp/files.lst
+ '[' -z '' ']'
++ uname -r
+ export TARGET_KERNEL=2.4.19-16mdk
+ TARGET_KERNEL=2.4.19-16mdk
+ '[' -d /lib/modules/2.4.19-16mdk/kernel ']'
+ INSTALLPATH=/lib/modules/2.4.19-16mdk/kernel/drivers/video
+ mkdir -p /var/tmp/NVIDIA_kernel-1.0//lib/modules/2.4.19-16mdk/kernel/drivers/v
ideo
+ install -m 0444 nvidia.o /var/tmp/NVIDIA_kernel-1.0//lib/modules/2.4.19-16mdk/
+ echo '%attr(444 root root) ' /lib/modules/2.4.19-16mdk/kernel/drivers/video/nv
idia.o
+ unset RPM_BUILD_ROOT
+ /usr/lib/rpm/brp-mandrake
no RPM_BUILD_ROOT variable; exiting.
Processing files: NVIDIA_kernel-1.0-4191
Finding  Provides: (using /usr/lib/rpm/find-provides)...
Finding  Requires: (using /usr/lib/rpm/find-requires)...
Using BuildRoot: /var/tmp/NVIDIA_kernel-1.0 to search libs
PreReq: /bin/sh /bin/sh /bin/sh rpmlib(PayloadFilesHavePrefix) <= 4.0-1 rpmlib(C
ompressedFileNames) <= 3.0.4-1
Requires(interp): /bin/sh /bin/sh /bin/sh
Requires(rpmlib): rpmlib(PayloadFilesHavePrefix) <= 4.0-1 rpmlib(CompressedFileN
ames) <= 3.0.4-1
Requires(pre): /bin/sh
Requires(post): /bin/sh
Requires(preun): /bin/sh
Requires: kernel >= 2.2.0 rpm >= 3.0.4
Wrote: /usr/src/RPM/RPMS/i586/NVIDIA_kernel-1.0-4191.i586.rpm
Executing(%clean): /bin/sh -e /var/tmp/rpm-tmp.8991
+ umask 022
+ '[' -n /var/tmp/NVIDIA_kernel-1.0 -a /var/tmp/NVIDIA_kernel-1.0 '!=' / ']'
+ rm -rf /var/tmp/NVIDIA_kernel-1.0
+ exit 0
Executing(--clean): /bin/sh -e /var/tmp/rpm-tmp.8991
+ umask 022
+ exit 0
[root@tiberian kaiska]# rpm -Uvh /usr/src/RPM/RPMS/i586/NVIDIA_kernel-1.0-4191.i
586.rpm
Preparing...                ########################################### [100%]
   1:NVIDIA_kernel          ########################################### [100%]
depmod: *** Unresolved symbols in /lib/modules/2.4.19-16mdk/kernel/drivers/video
/nvidia.o
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol devfs
_register_R77c40f8e
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol proc_
root_driver_R6cc94f6e
_register_chrdev_R8ffccd4f
root_R6dbe9d84
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol __pol
lwait_R5f3d4455
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol creat
e_proc_entry_R12dd78d8
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol mem_m        ap_R25b77435
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol init_        mm_Rc205a47c
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol devfs        _unregister_R8dc32356
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol irq_s        tat_Rdca4da59
/lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o: unresolved symbol remov        e_proc_entry_Rd07ecc9b
Hint: You are trying to load a module without a GPL compatible license
      and it has unresolved symbols.  Contact the module supplier for
      assistance, only they can help you.
modprobe: insmod /lib/modules/2.4.19-16mdk/kernel/drivers/video/nvidia.o failed
modprobe: insmod nvidia failed
Failed to install nvidia.o
error: execution of %post scriptlet from NVIDIA_kernel-1.0-4191 failed, exit sta        tus 1
j'ai du mal à voir ce qui ne vas pas. Un peu d'aide me ferais chaud au coeur :D
n°236360
zeb_
Posté le 13-03-2003 à 20:22:12  profilanswer
Tu devrais faire l'update du kernel (vers le 24mdk) avec urpmi et installer les sources du kernel correspondantes.
Au fait, tu avais bien installe les sources ?
n°236372
kaiska
Posté le 13-03-2003 à 20:41:16  profilanswer
Yes :) merci beaucoup zeb_ ça tourne au poil en mettant ce kernel :)
n°236374
zeb_
Posté le 13-03-2003 à 20:45:50  profilanswer
\o/
Je peux dire en passant que la 9.1 est très proche et qu'elle est bien belle  :bounce:
n°236377
kaiska
Posté le 13-03-2003 à 20:56:55  profilanswer
J'aimerais bien voir ce que vaudrat la finale moi aussi :) Je viens d'aller dans la nouvelle mjc de ma ville et ils installent des belles mandrake sur tout le coin d'accées internet :) Ils ont acheté un beau pack mandrake 9.0 qui fait plaisir :D
  Installation
prob drivers nvidia avec la mandrake 9.1 rc1 et rc2 et ti4400[postfix] j'arrive pas envoyer - prob de dns ?
[MDK9] Problème avec les drivers nvidia [Résolu][Debian sid] J'arrive pas à compiler kopete
[quake]souris qui merdouille ?Je n'arrive pas à me décider sur quelle distribution je dois installer
J'arrive pas a installer les distros suivante sur cette becane !Pk j arrive po a detecter mon graveur ??
Comment installer les drivers Nvidia ?help, plus d'affichage KDE (installation de driver Nvidia)
Plus de sujets relatifs à : [NVIDIA] merdouille j'y arrive pas.
